[GRASS-SVN] r37053 - grass/trunk/scripts/r.in.wms
    svn_grass at osgeo.org
    Fri May  8 12:44:24 EDT 2009
Author: martinl
Date: 2009-05-08 12:44:24 -0400 (Fri, 08 May 2009)
New Revision: 37053
Added:
   grass/trunk/scripts/r.in.wms/gdalwarp.py
   grass/trunk/scripts/r.in.wms/wms_parse.py
   grass/trunk/scripts/r.in.wms/Makefile
   grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py
   grass/trunk/scripts/r.in.wms/r.in.wms.html
   grass/trunk/scripts/r.in.wms/r.in.wms.py
   grass/trunk/scripts/r.in.wms/wms_download.py
   grass/trunk/scripts/r.in.wms/wms_request.py
r.in.wms: various fixes, new modules (parse, gdalwarp)
Modified: grass/trunk/scripts/r.in.wms/Makefile
--- grass/trunk/scripts/r.in.wms/Makefile	2009-05-08 14:33:58 UTC (rev 37052)
+++ grass/trunk/scripts/r.in.wms/Makefile	2009-05-08 16:44:24 UTC (rev 37053)
@@ -4,7 +4,7 @@
 include $(MODULE_TOPDIR)/include/Make/Script.make
-SRCFILES = r.in.gdalwarp.py wms_request.py wms_download.py
+SRCFILES = wms_parse.py wms_request.py wms_download.py gdalwarp.py r.in.gdalwarp.py
 DSTFILES := $(patsubst %,$(ETC)/r.in.wms/%,$(SRCFILES))
 default: script
Added: grass/trunk/scripts/r.in.wms/gdalwarp.py
--- grass/trunk/scripts/r.in.wms/gdalwarp.py	                        (rev 0)
+++ grass/trunk/scripts/r.in.wms/gdalwarp.py	2009-05-08 16:44:24 UTC (rev 37053)
@@ -0,0 +1,349 @@
+# MODULE:       r.in.wms / wms_gdalwarp.py
+# AUTHOR(S):    Cedric Shock, 2006
+#               Update for GRASS 7 by Martin Landa <landa.martin gmail.com>, 2009
+# PURPOSE:      To import data from web mapping servers
+#               (based on Bash script by Cedric Shock)
+# COPYRIGHT:    (C) 2009 Martin Landa, and GRASS development team
+#               This program is free software under the GNU General
+#               Public License (>=v2). Read the file COPYING that
+#               comes with GRASS for details.
+import os
+import subprocess
+import grass
+class GDALWarp():
+    def __init__(self, flags, options):
+        self.flags   = flags
+        self.options = options
+        self.tmp = grass.tempfile()
+        self.suffixes = []
+        self.patches  = []
+        self.maplist  = []
+        self.tiler = 0
+        if not flags['p']:
+            # todo: check if gdalwarp is available
+            pass
+        # flags for r.in.gdal
+        self.gdal_flags = ''
+        if flags['e']:
+            self.gdal_flags += 'e'
+        if flags['k']:
+            self.gdal_flags += 'k'
+        # options for gdalwarp
+        method_opt = options['method']
+        if method_opt == 'nearest':
+            self.gdal_method = '-rn'
+        elif method_opt == 'bilinear':
+            self.gdal_method = '-rb'
+        elif method_opt == 'cubic':
+            self.gdal_method = '-rc'
+        elif method_opt == 'cubicspline':
+            self.gdal_method = '-rcs'
+    def run(self):
+        # import tiles
+        tiler = 0
+        for input in self.options['input'].split(','):
+            tmptilename = self.options['output'] + '_tile_' + str(tiler)
+            if not os.path.exists(input):
+                grass.warning("Missing input '%s'" % input)
+                continue
+            grass.info('Importing tile <%s>...' % os.path.basename(input))
+            if self.flags['p']:
+                self.nowarp_import(input, tmptilename, self.gdal_flags)
+            else:
+                self.warp_import(input, tmptilename, self.gdal_method)
+            maplist.append(tmptilename)
+            tiler += 1
+        if tiler < 1:
+            grass.message("Nothing imported")
+            return 0
+        # if there's more than one tile patch them together, otherwise
+        # just rename that tile.
+        if tiler == 1:
+            if len(channel_suffixes) > 0:
+                # multi-band
+                for suffix in channel_suffixes:
+                    # rename tile 0 to be the output
+                    ffile = self.options['output'] + '_tile_0' + suffix
+                    tfile = self.options['output'] + suffix
+                    if grass.run_command('g.rename',
+                                         quiet = True,
+                                         rast = ffile + ',' + tfile) != 0:
+                        grass.fatal('g.rename failed')
+            else: # single-band, single-tile
+                ffile = self.options['output'] + '_tile_0' # + sfx ?
+                tfile = self.options['output'] # + sfx ?
+                                     quiet = True,
+        else:
+            # patch together each channel
+            grass.debug('suffixes: %s' % ','.join(suffixes))
+            if len(suffixes) > 0:
+                # multi-band data
+                for suffix in suffixes:
+                    suffix = suffix.replace('.', '_')
+                    # patch these together (using nulls only)
+                    grass.message("Patching '%s' channel..." % suffix)
+                    if grass.run_command('r.patch',
+                                         quiet = True,
+                                         input = patches, # ???
+                                         output = self.options['output'] + suffix) != 0:
+                        grass.fatal('r.patch failed')
+                    # remove the temporary patches we made
+                    if grass.run_command('g.remove',
+                                         quiet = True,
+                                         rast = patches) != 0:
+                        grass.fatal('g.remove failed')
+            else:
+                # single-band data
+                grass.info("Patching tiles (this may take some time)...")
+                grass.debug("patch list = %s" % ','.join(maplist))
+                # HACK: for 8bit PNG, GIF all the different tiles can have
+                #   different color tables so patches output end up all freaky.
+                #	r.mapcalc r#,g#,b# manual patching + r.composite?
+                #	or d.out.file + r.in.png + r.region?
+                # *** there is a GDAL utility to do this: gdal_merge.py
+                #       http://www.gdal.org/gdal_merge.html
+                for color in ('r', 'g', 'b'):
+                    maplist_color = []
+                    for map in maplist:
+                        outmap = map + '_' + color
+                        maplist_color.append(outmap)
+                        if grass.run_command('r.mapcalc',
+                                             quiet = True,
+                                             expression = '%s = %s#%s' % (outmap, color, map)) != 0:
+                            grass.fatal('r.mapcalc failed')
+                        if grass.run_command('r.colors',
+                                             quiet = True,
+                                             map = outmap,
+                                             color = 'grey255') != 0:
+                            grass.fatal('r.colors failed')
+                        if grass.run_command('r.null',
+                                             quiet = True,
+                                             map = outmap,
+                                             setnull = 255) != 0:
+                            grass.fatal('r.null failed')
+                                             input = ','.join(maplist_color),
+                                             output = outmap + '_all') != 0:
+                if grass.run_command('r.composite',
+                                     quiet = True,
+                                     red = map + '_r_all',
+                                     green = map + '_g_all',
+                                     blue = map + '_b_all',
+                                     output = self.options['output']) != 0:
+                    grass.fatal('r.composite failed')
+                if grass.run_command('g.mremove',
+                                     quiet = True,
+                                     flags = 'f',
+                                     rast = map + '*') != 0:
+        # there's already a no suffix, can't make colors
+        # can only go up from here ;)
+        colors = 4 # ???
+            if suffix in ('.red', '.green', '.blue'):
+                colors += 1
+        # make a composite image if asked for and colors exist
+        if colors == 3 or self.flags['c']:
+            grass.message("Building color image <%s>..." % self.options['output'])
+                                 quiet = True,
+                                 red = self.options['output'] + '.red',
+                                 green = self.options['output'] + '.green',
+                                 blue = self.options['output'] + '.blue',
+                                 output = option['output']) != 0:
+        return 0
+    def warp_import(self, file, map, method):
+        """Wrap raster file using gdalwarp and import wrapped file
+        into GRASS"""
+        warpfile = self.tmp + 'warped.geotiff'
+        tmpmapname = map + '_tmp'
+        t_srs = grass.read_command('g.proj',
+                                   quiet = True,
+                                   flags = 'wf')
+        if not t_srs:
+            grass.fatal('g.proj failed')
+        grass.debug('gdalwarp -s_srs "%s" -t_srs "%s" "%s" "%s" %s %s' % \
+                        (self.options['srs'], t_srs, file,
+                         warpfile, self.options['warpoptions'], method))
+        grass.verbose("Warping input file '%s'..." % file)
+        ps = subprocess.Popen(['gdalwarp',
+                               '-s_srs', self.options['srs'],
+                               '-t_srs', t_srs,
+                               file, warpfile,
+                               self.options['warpoptions'],
+                               method])
+        if ps.wait() != 0:
+            grass.fatal('gdalwarp failed')
+        # import it into a temporary map
+        grass.info('Importing temporary raster map...')
+        if grass.run_command('r.in.gdal',
+                             quiet = True,
+                             flags = gdal_flags,
+                             input = warpfile,
+                             output = tmpmapname) != 0:
+            grass.fatal('r.in.gdal failed')
+        os.remove(warpfile)
+        # get list of channels
+        pattern = tmpmapfile + '*'
+        grass.debug('Pattern: %s' % pattern)
+        mapset = grass.gisenv()['MAPSET']
+        channel_list = grass.mlist_grouped(type = 'rast', pattern = pattern, mapset = mapset)
+        grass.debug('Channel list: %s' % ','.join(channel_list))
+        if len(channel_list) < 2: # test for single band data
+            channel_suffixes = []
+        else:
+            channel_suffixes = channel_list # ???
+        grass.debug('Channel suffixes: %s', ','.join(channel_suffixes))
+        # add to the list of all suffixes
+        self.suffixes = self.suffixes + channel_suffixes
+        self.suffixes.sort()
+        # get last suffix
+            last_suffix = channel_suffixes[-1]
+        else:
+            last_suffix = ''
+        # find the alpha layer
+        if self.flags['k']:
+            alphalayer = tmpmapname + last_suffix
+        else:
+            alphalayer = tmpmapname + '.alpha'
+        # test to see if the alpha map exists
+        if not grass.find_file(element = 'cell', file = alphalayer)['name']:
+            alphalayer = ''
+        # calculate the new maps:
+            grass.debug("alpha=%s MAPsfx=%s% tmpname=%s%s" % \
+                            (alphalayer, map, suffix, tmpmapname, suffix))
+            if alphalayer:
+                # Use alpha channel for nulls: problem: I've seen a map
+                # where alpha was 1-255; 1 being transparent. what to do?
+                # (Geosci Australia Gold layer, format=tiff)
+                                     quiet = True,
+                                     expression = "%s%s = if(%s, %s%s, null())" % \
+                                         (map, sfx, alphalayer, tmpmapname, sfx)) != 0:
+            else:
+                if grass.run_command('g.copy',
+                                     quiet = True,
+                                     rast = "%s%s,%s%s" % \
+                                         (tmpmapname, suffix, map, suffix)) != 0:
+                    grass.fatal('g.copy failed')
+            # copy the color tables
+                                 quiet = True,
+                                 map = map + suffix,
+                                 rast = tmpmapname + suffix) != 0:
+            # make patch lists
+            # this is a hack to make the patch lists empty:
+            if self.tiler == 0:
+                self.patches = []
+            self.patches = self.patches.append(map + suffix)
+        # if no suffix, processing is simple (e.g. elevation has only 1
+        # band)
+        if len(channel_list) < 1:
+            # run r.mapcalc to crop to region
+                                 quiet = True,
+                                 expression = "%s = %s" % \
+                                     (map, tmpmapname)) != 0:
+                                 quiet = True,
+                                 map = map,
+                                 rast = tmpmapname) != 0:
+        # remove the old channels
+                             quiet = True,
+                             rast = ','.channel_list) != 0:
+    def nowarp_import(self, file, map, gdal_flags):
+        """Import raster file into GRASS"""
+                             quiet = True,
+                             flags = 'o' + gdal_flags,
+                             input = file,
+                             output = map) != 0:
+        # get a list of channels:
+        pattern = map + '*'
+        grass.debug("pattern: %s" % ','.join(pattern))
+        grass.debug("channel list: %s" % ','.join(channel_list))
+            # test for single band data
+        else:
+        # add to the list of all suffixes:
+        self.suffixes = self.suffixes + channel.suffixes
+                self.patches = []
Property changes on: grass/trunk/scripts/r.in.wms/gdalwarp.py
___________________________________________________________________
   + text/x-python
   + Author Date Id
   + native
Modified: grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py
--- grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py	2009-05-08 14:33:58 UTC (rev 37052)
+++ grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py	2009-05-08 16:44:24 UTC (rev 37053)
@@ -79,337 +79,20 @@
 import grass
+path = os.path.join(os.getenv('GISBASE'), 'etc', 'r.in.wms')
+sys.path.append(path)
+import gdalwarp
 def cleanup():
     if tmp:
 	grass.run_command('g.remove', rast = tmp, quiet = True)
-def warp_import(file, map, method,
-                suffixes, tiler, patches):
-    """Wrap raster file using gdalwarp before importing into GRASS"""
-    global tmp
-    warpfile = tmp + 'warped.geotiff'
-    tmpmapname = map + '_tmp'
-    t_srs = grass.read_command('g.proj',
-                               quiet = True,
-                               flags = 'wf')
-    if not t_srs:
-        grass.fatal('g.proj failed')
-    grass.debug('gdalwarp -s_srs "%s" -t_srs "%s" "%s" "%s" %s %s' % \
-                    (options['s_srs'], t_srs, file,
-                     warpfile, options['warpoptions'], method))
-    grass.info("Warping input file '%s'..." % file)
-    ps = subprocess.Popen('gdalwarp',
-                          '-s_srs', options['s_srs'],
-                          '-t_srs', t_srs,
-                          file, warpfile, options['warpoptions'], method)
-    if ps.wait() != 0:
-        grass.fatal('gdalwarp failed')
-    # import it into a temporary map
-    grass.info('Importing temporary raster map...')
-    if grass.run_command('r.in.gdal',
-                         quiet = True,
-                         flags = gdal_flags,
-                         input = warpfile,
-                         output = tmpmapname) != 0:
-        grass.fatal('r.in.gdal failed')
-    os.remove(warpfile)
-    # get list of channels
-    pattern = tmpmapfile + '*'
-    grass.debug('Pattern: %s' % pattern)
-    mapset = grass.gisenv()['MAPSET']
-    channel_list = grass.mlist_grouped(type = 'rast', pattern = pattern, mapset = mapset)
-    grass.debug('Channel list: %s' % ','.join(channel_list))
-    if len(channel_list) < 2: # test for single band data
-        channel_suffixes = []
-    else:
-        channel_suffixes = channel_list # ???
-    grass.debug('Channel suffixes: %s', ','.join(channel_suffixes))
-    # add to the list of all suffixes
-    suffixes = suffixes + channel_suffixes
-    suffixes.sort()
-    # get last suffix
-    if len(channel_suffixes) > 0:
-        last_suffix = channel_suffixes[-1]
-    else:
-        last_suffix = ''
-    # find the alpha layer
-    if flags['k']:
-        alphalayer = tmpmapname + last_suffix
-    else:
-        alphalayer = tmpmapname + '.alpha'
-    # test to see if the alpha map exists
-    if not grass.find_file(element = 'cell', file = alphalayer)['name']:
-        alphalayer = ''
-    # calculate the new maps:
-    for suffix in channel_suffixes:
-        grass.debug("alpha=%s MAPsfx=%s% tmpname=%s%s" % \
-                        (alphalayer, map, suffix, tmpmapname, suffix))
-        if alphalayer:
-            # Use alpha channel for nulls: problem: I've seen a map
-            # where alpha was 1-255; 1 being transparent. what to do?
-            # (Geosci Australia Gold layer, format=tiff)
-            if grass.run_command('r.mapcalc',
-                                 quiet = True,
-                                 expression = "%s%s = if(%s, %s%s, null())" % \
-                                     (map, sfx, alphalayer, tmpmapname, sfx)) != 0:
-                grass.fatal('r.mapcalc failed')
-        else:
-            if grass.run_command('g.copy',
-                                 quiet = True,
-                                 rast = "%s%s,%s%s" % \
-                                     (tmpmapname, suffix, map, suffix)) != 0:
-                grass.fatal('g.copy failed')
-        # copy the color tables
-        if grass.run_command('r.colors',
-                             quiet = True,
-                             map = map + suffix,
-                             rast = tmpmapname + suffix) != 0:
-        # make patch lists
-        suffix = suffix.replace('.', '_')
-        # this is a hack to make the patch lists empty:
-        if tiler == 0:
-            patches = []
-        patches = patches.append(map + suffix)
-    # if no suffix, processing is simple (e.g. elevation has only 1
-    # band)
-    if len(channel_list) < 1:
-        # run r.mapcalc to crop to region
-                             quiet = True,
-                             expression = "%s = %s" % \
-                                 (map, tmpmapname)) != 0:
-                             quiet = True,
-                             map = map,
-                             rast = tmpmapname) != 0:
-            grass.fatal('r.colors failed')
-    # remove the old channels
-    if grass.run_command('g.remove',
-                         quiet = True,
-                         rast = ','.channel_list) != 0:
-        grass.fatal('g.remove failed')
-def nowarp_import(file, map, gdal_flags,
-                         quiet = True,
-                         flags = 'o' + gdal_flags,
-                         input = file,
-                         output = map) != 0:
-    # get a list of channels:
-    pattern = map + '*'
-    grass.debug("pattern: %s" % ','.join(pattern))
-    grass.debug("channel list: %s" % ','.join(channel_list))
-        # test for single band data
-    else:
-    # add to the list of all suffixes:
-    suffixes.sort()
-        if tiler == 0:
-            patches = []
 def main():
-    if not flags['p']:
-        # todo: check if gdalwarp is available
-        pass
-    # flags for r.in.gdal
-    gdal_flags = ''
-    if flags['e']:
-        gdal_flags += 'e'
-    if flags['k']:
-        gdal_flags += 'k'
-    # options for gdalwarp
-    method_opt = options['method']
-    if method_opt == 'nearest':
-        gdal_method = '-rn'
-    elif method_opt == 'bilinear':
-        gdal_method = '-rb'
-    elif method_opt == 'cubic':
-        gdal_method = '-rc'
-    elif method_opt == 'cubicspline':
-        gdal_method = '-rcs'
-    global tmp
-    tmp = grass.tempfile()
-    # list of all suffixes
-    suffixes = []
-    # we need a way to make sure patches are intialized correctly
-    tiler = 0
-    # list of maps
-    maplist = []
-    # list of maps to be patched
-    patches = []
     # show progress infromation and grass.info() by default
     os.environ['GRASS_VERBOSE'] = '1'
-    # import tiles
-    for input in options['input'].split(','):
-        tmptilename = options['output'] + '_tile_' + str(tiler)
-        if not os.path.exists(input):
-            grass.warning("Missing input '%s'" % input)
-            continue
-        grass.info('Importing tile <%s>...' % input)
-        if flags['p']:
-            channel_suffixes = nowarp_import(input, tmptilename, gdal_flags,
-        else:
-            warp_import(input, tmptilename, gdal_method,
-        maplist.append(tmptilename)
-        tiler += 1
-    if tiler < 1:
-        grass.message("Nothing imported")
-        return 0
+    return gdalwarp.GDALWarp(flags, options).run()
-    # if there's more than one tile patch them together, otherwise
-    # just rename that tile.
-    if tiler == 1:
-            # multi-band
-                # rename tile 0 to be the output
-                ffile = options['output'] + '_tile_0' + suffix
-                tfile = options['output'] + suffix
-                if grass.run_command('g.rename',
-                                     quiet = True,
-                                     rast = ffile + ',' + tfile) != 0:
-                    grass.fatal('g.rename failed')
-        else: # single-band, single-tile
-            ffile = options['output'] + '_tile_0' # + sfx ?
-            tfile = options['output'] # + sfx ?
-                                 quiet = True,
-    else:
-        # patch together each channel
-        grass.debug('suffixes: %s' % ','.join(suffixes))
-        if len(suffixes) > 0:
-            # multi-band data
-            for suffix in suffixes:
-                # patch these together (using nulls only)
-		grass.message("Patching '%s' channel..." % suffix)
-		if grass.run_command('r.patch',
-                                     quiet = True,
-                                     input = patches, # ???
-                                     output = options['output'] + suffix) != 0:
-                    grass.fatal('r.patch failed')
-		# remove the temporary patches we made
-                                     quiet = True,
-                                     rast = patches) != 0:
-        else:
-            # single-band data
-	    grass.info("Patching tiles (this may take some time)...")
-	    grass.debug("patch list = %s" % ','.join(maplist))
-            # HACK: for 8bit PNG, GIF all the different tiles can have
-	    #   different color tables so patches output end up all freaky.
-	    #	r.mapcalc r#,g#,b# manual patching + r.composite?
-	    #	or d.out.file + r.in.png + r.region?
-	    # *** there is a GDAL utility to do this: gdal_merge.py
-	    #       http://www.gdal.org/gdal_merge.html
-            for color in ('r', 'g', 'b'):
-                maplist_color = []
-                for map in maplist:
-                    outmap = map + '_' + color
-                    maplist_color.append(outmap)
-                                         quiet = True,
-                                         expression = '%s = %s#%s' % (outmap, color, map)) != 0:
-                                         quiet = True,
-                                         map = outmap,
-                                         color = 'grey255') != 0:
-                    if grass.run_command('r.null',
-                                         quiet = True,
-                                         map = outmap,
-                                         setnull = 255) != 0:
-                        grass.fatal('r.null failed')
-                                     input = ','.join(maplist_color),
-                                     output = outmap + '_all') != 0:
-            if grass.run_command('r.composite',
-                                 quiet = True,
-                                 red = map + '_r_all',
-                                 green = map + '_g_all',
-                                 blue = map + '_b_all',
-                                 output = options['output']) != 0:
-                grass.fatal('r.composite failed')
-            if grass.run_command('g.mremove',
-                                 quiet = True,
-                                 flags = 'f',
-                                 rast = map + '*') != 0:
-    # there's already a no suffix, can't make colors
-    # can only go up from here ;)
-    colors = 4
-        if suffix in ('.red', '.green', '.blue'):
-            colors += 1
-    # make a composite image if asked for and colors exist
-    if colors == 3 or flags['c']:
-        grass.message("Building color image <%s>..." % options['output'])
-                             quiet = True,
-                             red = options['output'] + '.red',
-                             green = options['output'] + '.green',
-                             blue = options['output'] + '.blue',
-                             output = option['output']) != 0:
 if __name__ == "__main__":
     options, flags = grass.parser()
     tmp = None
Modified: grass/trunk/scripts/r.in.wms/r.in.wms.html
--- grass/trunk/scripts/r.in.wms/r.in.wms.html	2009-05-08 14:33:58 UTC (rev 37052)
+++ grass/trunk/scripts/r.in.wms/r.in.wms.html	2009-05-08 16:44:24 UTC (rev 37053)
@@ -20,9 +20,11 @@
 capabilities request to NASA's OnEarth server</a>.
 <p>
 Some brain-dead servers will only talk to certain web browsers. You can
 fool these by adding <tt>--user-agent=MSIE5.5</tt> to <b>wgetoptions</b>
 or for curl adding <tt>-A "MSIE5.5"</tt> to <b>curloptions</b>.
 Other brain-dead servers will not accept queries in the form of POST data.
 If you get an error try using the <b>-g</b> flag to force <em>r.in.wms</em>
 to send an atomic GET request instead.
Modified: grass/trunk/scripts/r.in.wms/r.in.wms.py
--- grass/trunk/scripts/r.in.wms/r.in.wms.py	2009-05-08 14:33:58 UTC (rev 37052)
+++ grass/trunk/scripts/r.in.wms/r.in.wms.py	2009-05-08 16:44:24 UTC (rev 37053)
@@ -170,79 +170,21 @@
 import sys
 import tempfile
 import urllib
 import xml.sax
-import xml.sax.handler
-HandlerBase=xml.sax.handler.ContentHandler
-from xml.sax import make_parser
 import grass
 wmsPath = os.path.join(os.getenv('GISBASE'), 'etc', 'r.in.wms')
 sys.path.append(wmsPath)
-import wms_request
-import wms_download
+try:
+    import wms_parse
+    import wms_request
+    import wms_download
+    import gdalwarp
+except ImportError:
+    pass
-class ProcessCapFile(HandlerBase):
-    A SAX handler for the capabilities file
-    def __init__(self):
-        self.inTag = {}
-        for tag in ('layer', 'name', 'style',
-                    'title', 'srs'):
-            self.inTag[tag] = False
-        self.value = ''
-        self.layers = []
-    def startElement(self, name, attrs):
-        if self.inTag.has_key(name.lower()):
-            self.inTag[name.lower()] = True
-        if name.lower() == 'layer':
-            self.layers.append({})
-    def endElement(self, name):
-            self.inTag[name.lower()] = False
-        for tag in ('name', 'title', 'srs'):
-            if name.lower() != tag:
-                continue
-            if self.inTag['style']:
-                if not self.layers[-1].has_key('style'):
-                    self.layers[-1]['style'] = {}
-                if not self.layers[-1]['style'].has_key(tag):
-                    self.layers[-1]['style'][tag] = []
-                self.layers[-1]['style'][tag].append(self.value)
-            elif self.inTag['layer']:
-                self.layers[-1][tag] = self.value
-        if name.lower() in ('name', 'title', 'srs'):
-            self.value = ''
-    def characters(self, ch):
-        if self.inTag['name'] or \
-                self.inTag['title'] or \
-                self.inTag['srs']:
-            self.value += ch
-    def getLayers(self):
-        """Print list of layers"""
-        for ly in self.layers:
-            if ly.has_key('name'):
-                print "LAYER: " + ly['name']
-            else:
-                print "LAYER: ???"
-            if ly.has_key('title'):
-                print "  Title: " + ly['title']
-            if ly.has_key('srs'):
-                print "  SRS: " + ly['srs']
-            if ly.has_key('style'):
-                for idx in range(len(ly['style']['name'])):
-                    print "  STYLE: " + ly['style']['name'][idx]
-                    print "    Style title: " + ly['style']['title'][idx]
 def list_layers():
     """Get list of available layers from WMS server"""
     qstring = "service=WMS&request=GetCapabilities&" + options['wmsquery']
@@ -253,9 +195,9 @@
     cap_file = urllib.urlopen(options['mapserver'] + '?' + qstring)
     if not cap_file:
         grass.fatal("Unable to get capabilities of '%s'" % options['mapserver'])
     # parse file with sax
-    cap_xml = ProcessCapFile()
+    cap_xml = wms_parse.ProcessCapFile()
     try:
         xml.sax.parse(cap_file, cap_xml)
     except xml.sax.SAXParseException, err:
@@ -271,7 +213,7 @@
         return 0
     elif not options['output']:
         grass.fatal("No output map specified")
     # set directory for download
     if not options['folder']:
         options['folder'] = os.path.join(grass.gisenv()['GISDBASE'], 'wms_download')
@@ -297,10 +239,14 @@
     for item in request.GetRequests():
         files.append(item['output'])
     files = ','.join(files)
+    # add flags for r.in.gdalwarp
+    options['input'] = files
+    flags['e'] = False
+    flags['c'] = True
+    options['warpoptions'] = ''
-    gdalwarp.GDALWarp(flags, options)
-    return 0
Modified: grass/trunk/scripts/r.in.wms/wms_download.py
--- grass/trunk/scripts/r.in.wms/wms_download.py	2009-05-08 14:33:58 UTC (rev 37052)
+++ grass/trunk/scripts/r.in.wms/wms_download.py	2009-05-08 16:44:24 UTC (rev 37053)
@@ -1,11 +1,9 @@
-#!/usr/bin/env python
-# MODULE:       r.in.wms
+# MODULE:       r.in.wms / wms_download.py
-#               Pythonized by Martin Landa <landa.martin gmail.com>, 2009
+#               Updated for GRASS 7 by Martin Landa <landa.martin gmail.com>, 2009
@@ -35,9 +33,9 @@
         for item in requests:
             if os.path.exists(item['output']) and \
                     os.path.getsize(item['output']) > 0:
-                grass.message("Tile already downloaded")
+                grass.verbose("Tile already downloaded")
             else:
-                self.GetData(i, item['server'] + item['string'], item['output'])
+                self.GetData(i, item['server'] + '?' + item['string'], item['output'])
             i += 1
     def GetData(self, idx, url, output):
@@ -45,8 +43,9 @@
         grass.message("Downloading data (tile %d)..." % idx)
         grass.verbose("Requesting data: %s" % self.options['mapserver'])
         grass.verbose(url)
         if not self.flags['g']: # -> post
+            print url
             try:
                 urllib.urlretrieve(url, output, data="POST")
             except IOError:
@@ -54,13 +53,13 @@
             if not os.path.exists(output):
                 grass.fatal("Failed while downloading the data")
             # work-around for brain-dead ArcIMS servers which want POST-data as part of the GET URL
             #   (this is technically allowed by OGC WMS def v1.3.0 Sec6.3.4)
             if os.path.getsize(output) == 0:
                 grass.warning("Downloaded image file is empty -- trying another method")
                 self.flags['g'] = True
         if self.flags['g']: # -> get
             try:
                 urllib.urlretrieve(url, output, data="GET")
@@ -69,4 +68,4 @@
             if not os.path.exists(output) or os.path.getsize(output) == 0:
Added: grass/trunk/scripts/r.in.wms/wms_parse.py
--- grass/trunk/scripts/r.in.wms/wms_parse.py	                        (rev 0)
+++ grass/trunk/scripts/r.in.wms/wms_parse.py	2009-05-08 16:44:24 UTC (rev 37053)
@@ -0,0 +1,83 @@
+# MODULE:       r.in.wms / wms_parse
+#               Upgraded for GRASS 7 by Martin Landa <landa.martin gmail.com>, 2009
+import xml.sax
+import xml.sax.handler
+HandlerBase=xml.sax.handler.ContentHandler
+from xml.sax import make_parser
+class ProcessCapFile(HandlerBase):
+    A SAX handler for the capabilities file
+    def __init__(self):
+        self.inTag = {}
+        for tag in ('layer', 'name', 'style',
+                    'title', 'srs'):
+            self.inTag[tag] = False
+        self.value = ''
+        self.layers = []
+    def startElement(self, name, attrs):
+        if self.inTag.has_key(name.lower()):
+            self.inTag[name.lower()] = True
+        if name.lower() == 'layer':
+            self.layers.append({})
+    def endElement(self, name):
+            self.inTag[name.lower()] = False
+        for tag in ('name', 'title', 'srs'):
+            if name.lower() != tag:
+                continue
+            if self.inTag['style']:
+                if not self.layers[-1].has_key('style'):
+                    self.layers[-1]['style'] = {}
+                if not self.layers[-1]['style'].has_key(tag):
+                    self.layers[-1]['style'][tag] = []
+                self.layers[-1]['style'][tag].append(self.value)
+            elif self.inTag['layer']:
+                self.layers[-1][tag] = self.value
+        if name.lower() in ('name', 'title', 'srs'):
+            self.value = ''
+    def characters(self, ch):
+        if self.inTag['name'] or \
+                self.inTag['title'] or \
+                self.inTag['srs']:
+            self.value += ch
+    def getLayers(self):
+        """Print list of layers"""
+        for ly in self.layers:
+            if ly.has_key('name'):
+                print "LAYER: " + ly['name']
+            else:
+                print "LAYER: ???"
+            if ly.has_key('title'):
+                print "  Title: " + ly['title']
+            if ly.has_key('srs'):
+                print "  SRS: " + ly['srs']
+            if ly.has_key('style'):
+                for idx in range(len(ly['style']['name'])):
+                    print "  STYLE: " + ly['style']['name'][idx]
+                    print "    Style title: " + ly['style']['title'][idx]
Property changes on: grass/trunk/scripts/r.in.wms/wms_parse.py
   + text/x-python
   + Author Date Id
   + native
Modified: grass/trunk/scripts/r.in.wms/wms_request.py
--- grass/trunk/scripts/r.in.wms/wms_request.py	2009-05-08 14:33:58 UTC (rev 37052)
+++ grass/trunk/scripts/r.in.wms/wms_request.py	2009-05-08 16:44:24 UTC (rev 37053)
@@ -1,11 +1,9 @@
-# MODULE:       r.in.wms
+# MODULE:       r.in.wms / wms_request.py
@@ -26,20 +24,22 @@
         self.flags   = flags
         self.__set_options()
     def __set_options(self):
-        # If the user asserts that this projection is the same as the
+        # if the user asserts that this projection is the same as the
         # source use this projection as the source to get a trivial
         # tiling from r.tileset
         if self.flags['p']:
             self.proj_srs = grass.read_command('g.proj', flags='j')
+            if not self.proj_srs:
             self.srs_scale = int(grass.parse_key_val(proj_srs['+to_meter']))
         else:
             self.proj_srs = '+init=%s' % self.options['srs'].lower()
             self.srs_scale = 1
         # options for r.tileset
         self.tileset_options = grass.parse_key_val(self.options['tileoptions'])
         if self.options['region']:
@@ -50,7 +50,7 @@
             self.transparency = "transparent=FALSE"
         else:
         # image format
         format_opt = self.options['format']
         if format_opt == "geotiff":
@@ -75,17 +75,20 @@
             self.file_extent = ".gif"
         else:
             grass.fatal("Uknown image format '%s'" % format_opt)
         # create download directory
         if not os.path.exists(self.options['folder']):
             os.mkdir(self.options['folder'])
+        odir = os.path.join(self.options['folder'], self.options['output'])
+        if not os.path.exists(odir):
+            os.mkdir(odir)
+        self._tdir = os.path.join(self.options['folder'], self.options['output'],
+                                  self.options['region'])
+        if not os.path.exists(self._tdir):
+            os.mkdir(self._tdir)
-        # clean files
-        self._tdir = os.path.join(self.options['folder'], self.options['output'],
-                            self.options['region'])
         self.request_file = os.path.join(self._tdir, 'request')
     def GetRequestFile(self):
         return self.request_file
@@ -97,9 +100,9 @@
                 ret.append(grass.parse_key_val(line, vsep = ';'))
         finally:
             rf.close()
         return ret
     def GetTiles(self):
         grass.message("Calculating tiles...")
         tiles = grass.read_command('r.tileset',
@@ -114,7 +117,6 @@
         if not tiles:
             grass.fatal("r.tileset failed")
         tiles = tiles.splitlines()
-        grass.message("Requesting %d tiles" % len(tiles))
         if self.flags['c']:
             rmfiles = os.path.join(self._tdir, '*')
@@ -124,7 +126,7 @@
                     os.rmdir(file)
                 else:
                     os.remove(file)
         rf = open(self.request_file, 'w')
         i = 0
         for tile in tiles:
@@ -137,7 +139,7 @@
             w = float(dtile['w'])
             nr = int(dtile['rows'])
             nc = int(dtile['cols'])
             size = "bbox=%f,%f,%f,%f&width=%d&height=%d" % \
                 (w, s, e, n, nr, nc)
             xres = (e - w) / nc
@@ -145,7 +147,7 @@
             # center of top left cell
             top_left_cell_center_x = w + xres / 2
             top_left_cell_center_y = n + yres / 2
             # write the world file
             wf = open(worldfile, 'w')
             try:
@@ -153,7 +155,7 @@
                              (xres, yres, top_left_cell_center_x, top_left_cell_center_y))
             finally:
                 wf.close()
             # request for data
             string = "request=GetMap&layers=%s&srs=%s&%s&format=%s&%s&%s" % \
                 (self.options['layers'], self.options['srs'],
@@ -163,5 +165,6 @@
             rf.write('output=%s;server=%s;string=%s\n' % \
                          (outputfile, self.options['mapserver'], string))
             i += 1
         rf.close()
+        grass.message("Done: requesting %d tiles" % len(tiles))
