[GRASS-SVN] r37070 - grass/trunk/lib/init
svn_grass at osgeo.org
Sat May 9 11:11:45 EDT 2009
Author: glynn
Date: 2009-05-09 11:11:45 -0400 (Sat, 09 May 2009)
New Revision: 37070
grass/trunk/lib/init/functions.sh
grass/trunk/lib/init/init.sh
Fix bugs in Init.sh on Windows
Modified: grass/trunk/lib/init/functions.sh
--- grass/trunk/lib/init/functions.sh 2009-05-09 14:51:57 UTC (rev 37069)
+++ grass/trunk/lib/init/functions.sh 2009-05-09 15:11:45 UTC (rev 37070)
@@ -124,20 +124,13 @@
fi
export PATH
- # Set LD_LIBRARY_PATH to find GRASS shared libraries
- if [ ! "GRASS_LD_LIBRARY_PATH" ] ; then
- GRASS_LD_LIBRARY_PATH="$GISBASE/lib"
+ # Set PYTHONPATH to find GRASS Python modules
+ if [ ! "$PYTHONPATH" ] ; then
+ PYTHONPATH="$GISBASE/etc/python"
else
- GRASS_LD_LIBRARY_PATH="$GISBASE/lib:$GRASS_LD_LIBRARY_PATH"
+ PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
fi
-# Set PYTHONPATH to find GRASS Python modules
-if [ ! "$PYTHONPATH" ] ; then
- PYTHONPATH="$GISBASE/etc/python"
-else
- PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
-fi
-export PYTHONPATH
+ export PYTHONPATH
set_defaults()
Modified: grass/trunk/lib/init/init.sh
--- grass/trunk/lib/init/init.sh 2009-05-09 14:51:57 UTC (rev 37069)
+++ grass/trunk/lib/init/init.sh 2009-05-09 15:11:45 UTC (rev 37070)
@@ -144,10 +144,15 @@
# Get Locale name
get_locale
-# Set PATH, @LD_LIBRARY_PATH_VAR@, PYTHONPATH
-GRASS_LD_LIBRARY_PATH="$@LD_LIBRARY_PATH_VAR@"
+# Set PATH, PYTHONPATH
set_paths
- at LD_LIBRARY_PATH_VAR@="$GRASS_LD_LIBRARY_PATH"
+# Set LD_LIBRARY_PATH (etc) to find GRASS shared libraries
+if [ ! "$@LD_LIBRARY_PATH_VAR@" ] ; then
+ @LD_LIBRARY_PATH_VAR@="$GISBASE/lib"
+else
+ @LD_LIBRARY_PATH_VAR@="$GISBASE/lib:$@LD_LIBRARY_PATH_VAR@"
+fi
export @LD_LIBRARY_PATH_VAR@
# Set GRASS_PAGER, GRASS_WISH, GRASS_PYTHON, GRASS_GNUPLOT
