[GRASS-SVN] r37072 - grass/trunk/lib/python
svn_grass at osgeo.org
Sat May 9 12:03:47 EDT 2009
Author: glynn
Date: 2009-05-09 12:03:47 -0400 (Sat, 09 May 2009)
New Revision: 37072
grass/trunk/lib/python/grass.py
Fix raster_info to handle D:M:S output from r.info
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py 2009-05-09 15:37:07 UTC (rev 37071)
+++ grass/trunk/lib/python/grass.py 2009-05-09 16:03:47 UTC (rev 37072)
@@ -589,15 +589,20 @@
warning("Unable to write history for <%s>. Raster map <%s> not found in current mapset." % (map, map))
return False
+def float_or_dms(s):
+ return sum(float(x) / 60 ** n for (n, x) in enumerate(s.split(':')))
# run "r.info -rgstmpud ..." and parse output
def raster_info(map):
"""Return information about a raster map (interface to `r.info')."""
s = read_command('r.info', flags = 'rgstmpud', map = map)
kv = parse_key_val(s)
- for k in ['min', 'max', 'north', 'south', 'east', 'west', 'nsres', 'ewres']:
+ for k in ['min', 'max', 'north', 'south', 'east', 'west']:
kv[k] = float(kv[k])
+ for k in ['nsres', 'ewres']:
+ kv[k] = float_or_dms(kv[k])
return kv
# interface to r.mapcalc
