[GRASS-SVN] r37105 - grass/trunk/imagery/i.atcorr/test_suite
svn_grass at osgeo.org
Sun May 10 12:12:17 EDT 2009
Author: neteler
Date: 2009-05-10 12:12:17 -0400 (Sun, 10 May 2009)
New Revision: 37105
Added:
grass/trunk/imagery/i.atcorr/test_suite/README.txt
explain how to test
Added: grass/trunk/imagery/i.atcorr/test_suite/README.txt
--- grass/trunk/imagery/i.atcorr/test_suite/README.txt (rev 0)
+++ grass/trunk/imagery/i.atcorr/test_suite/README.txt 2009-05-10 16:12:17 UTC (rev 37105)
@@ -0,0 +1,30 @@
+Test suite i.atcorr
+ETM4_atmospheric_input.txt = File with the atmospheric and sensor conditions
+ETM4.res = Output file showing the atmospheric and sensor conditions
+ETM4_400x400.raw = Image input file
+ETM4_400x400_atms_corr.raw = Image output file (expected output)
+# try in Spearfish location or other:
+# import raw Landsat channel 4:
+r.in.gdal ETM4_400x400.raw out=ETM4_400x400.raw -o
+# set region to this map
+g.region rast=ETM4_400x400.raw
+# run atmospheric correction on imported channel 4:
+i.atcorr -r --o iimg=ETM4_400x400.raw \
+ icnd=./ETM4_atmospheric_input_GRASS.txt \
+ ialt=dem \
+ oimg=ETM4_400x400.corrected
+# import already corrected test data set for comparison:
+r.in.gdal ETM4_400x400_atms_corr.raw out=ETM4_400x400_atms_corr -o
+# compare:
+r.mapcalc "diff = ETM4_400x400_atms_corr - ETM4_400x400.corrected"
+r.colors diff color=differences
+r.univar diff
Property changes on: grass/trunk/imagery/i.atcorr/test_suite/README.txt
___________________________________________________________________
+ native
