[GRASS-SVN] r37112 - grass/trunk/lib/python
Sun May 10 14:30:56 EDT 2009
Author: martinl
Date: 2009-05-10 14:30:56 -0400 (Sun, 10 May 2009)
New Revision: 37112
   grass/trunk/lib/python/grass.py
grass.py: allow parse arguments in read_command()
	  add 'vsep' to parse_key_val()
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py	2009-05-10 17:18:55 UTC (rev 37111)
+++ grass/trunk/lib/python/grass.py	2009-05-10 18:30:56 UTC (rev 37112)
@@ -115,15 +115,17 @@
     parse = None # do not parse output
     if kwargs.has_key('parse'):
-        if type(parse) is types.FunctionType:
-            parse = kwargs['parse']
+        if type(kwargs['parse']) is types.TupleType:
+            parse = kwargs['parse'][0]
+            parse_args = kwargs['parse'][1]
         else:
             parse = parse_key_val # use default fn
+            parse_args = {}
         del kwargs['parse']
     ps = pipe_command(*args, **kwargs)
     if parse:
-        return parse(ps.communicate()[0])
+        return parse(ps.communicate()[0], **parse_args)
     return ps.communicate()[0]
@@ -234,15 +236,25 @@
 # key-value parsers
-def parse_key_val(s, sep = '=', dflt = None, val_type = None):
+def parse_key_val(s, sep = '=', dflt = None, val_type = None, vsep = None):
     """Parse a string into a dictionary, where entries are separated
     by newlines and the key and value are separated by `sep' (default: `=')
     result = {}
     if not s:
         return result
-    for line in s.splitlines():
+    if vsep:
+        lines = s.split(vsep)
+        try:
+            lines.remove('\n')
+        except ValueError:
+            pass
+    else:
+        lines = s.splitlines()
+    for line in lines:
 	kv = line.split(sep, 1)
 	k = kv[0].strip()
 	if len(kv) > 1:
