[GRASS-SVN] r37117 - grass/trunk/lib/python
svn_grass at osgeo.org
Sun May 10 14:47:33 EDT 2009
Author: glynn
Date: 2009-05-10 14:47:33 -0400 (Sun, 10 May 2009)
New Revision: 37117
grass/trunk/lib/python/grass.py
Remove parsing functionality from read_command; moved to parse_command
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py 2009-05-10 18:46:56 UTC (rev 37116)
+++ grass/trunk/lib/python/grass.py 2009-05-10 18:47:33 UTC (rev 37117)
@@ -109,7 +109,14 @@
def read_command(*args, **kwargs):
"""Passes all arguments to pipe_command, then waits for the process to
complete, returning its stdout (i.e. similar to shell `backticks`).
+ ps = pipe_command(*args, **kwargs)
+ return ps.communicate()[0]
+def parse_command(*args, **kwargs):
+ """Passes all arguments to read_command, then optionally parses
+ the output.
Output can be automatically parsed if <b>parse</b> parameter is
given. Use True for default parse function -- parse_key_val().
@@ -122,13 +129,14 @@
parse = parse_key_val # use default fn
parse_args = {}
del kwargs['parse']
- ps = pipe_command(*args, **kwargs)
+ res = read_command(*args, **kwargs)
if parse:
- return parse(ps.communicate()[0], **parse_args)
- return ps.communicate()[0]
+ res parse(res, **parse_args)
+ return res
def write_command(*args, **kwargs):
"""Passes all arguments to feed_command, with the string specified
by the 'stdin' argument fed to the process' stdin.
@@ -241,7 +249,7 @@
by newlines and the key and value are separated by `sep' (default: `=')
result = {}
if not s:
return result
