[GRASS-SVN] r37122 - grass/branches/releasebranch_6_4/lib/python
svn_grass at osgeo.org
Sun May 10 15:15:43 EDT 2009
Author: martinl
Date: 2009-05-10 15:15:43 -0400 (Sun, 10 May 2009)
New Revision: 37122
grass/branches/releasebranch_6_4/lib/python/grass.py
grass.parse_command() - parse output by default
(merge from trunk, r37121)
Modified: grass/branches/releasebranch_6_4/lib/python/grass.py
--- grass/branches/releasebranch_6_4/lib/python/grass.py 2009-05-10 19:11:23 UTC (rev 37121)
+++ grass/branches/releasebranch_6_4/lib/python/grass.py 2009-05-10 19:15:43 UTC (rev 37122)
@@ -113,29 +113,31 @@
return ps.communicate()[0]
def parse_command(*args, **kwargs):
- """Passes all arguments to read_command, then optionally parses
- the output.
+ """Passes all arguments to read_command, then parses the output by
+ parse_key_val().
- Output can be automatically parsed if <b>parse</b> parameter is
- given. Use True for default parse function -- parse_key_val().
+ Parsing function can be optionally given by <b>parse</b> parameter
+ including its arguments, e.g.
+ @code
+ parse_command(..., parse = (grass.parse_key_val, { 'sep' : ':' }))
+ @endcode
- parse = None # do not parse output
+ parse = None
if kwargs.has_key('parse'):
if type(kwargs['parse']) is types.TupleType:
parse = kwargs['parse'][0]
parse_args = kwargs['parse'][1]
- else:
- parse = parse_key_val # use default fn
- parse_args = {}
del kwargs['parse']
+ if not parse:
+ parse = parse_key_val # use default fn
+ parse_args = {}
res = read_command(*args, **kwargs)
- if parse:
- return parse(res, **parse_args)
+ return parse(res, **parse_args)
- return res
def write_command(*args, **kwargs):
"""Passes all arguments to feed_command, with the string specified
by the 'stdin' argument fed to the process' stdin.
