[GRASS-SVN] r37128 - grass/branches/develbranch_6/imagery/i.atcorr
Sun May 10 15:48:52 EDT 2009
Author: neteler
Date: 2009-05-10 15:48:52 -0400 (Sun, 10 May 2009)
New Revision: 37128
   grass/branches/develbranch_6/imagery/i.atcorr/description.html
fix example; suggest integer DEM for circa 1:80 faster computations
Modified: grass/branches/develbranch_6/imagery/i.atcorr/description.html
--- grass/branches/develbranch_6/imagery/i.atcorr/description.html	2009-05-10 19:48:31 UTC (rev 37127)
+++ grass/branches/develbranch_6/imagery/i.atcorr/description.html	2009-05-10 19:48:52 UTC (rev 37128)
@@ -500,24 +500,30 @@
 <h2>EXAMPLES</h2>
-North Carolina sample dataset: Atmospheric correction of LANDSAT-7 channels:
+North Carolina sample dataset: Atmospheric correction of a LANDSAT-7 channel:
 <div class="code"><pre>
 g.region rast=lsat7_2002_40 -p
 r.info lsat7_2002_40
-# create control file for channel 1 (blue)
+# using an integer DEM greatly accelerates the i.atcorr computations
+r.mapcalc "elev_int = round(elevation)"
+# find mean elevation (target above sea level)
+r.univar elev_int
+# create control file for channel 4 (NIR)
 echo "8                            - geometrical conditions=Landsat ETM+
 5 24 14.30 -78.691 35.749    - month day hh.ddd longitude latitude ("hh.ddd" is a decimal hour GMT)
 2                            - atmospheric mode=midlatitude summer
 1                            - aerosols model=continental
 50                           - visibility [km] (aerosol model concentration)
--.600                        - target at 600m above sea level
+-.110                        - target at 110m above sea level
 -1000                        - sensor on board a satellite
-61                           - 1th band of ETM+ Landsat 7" > icnd.txt
+64                           - 1th band of ETM+ Landsat 7" > icnd.txt
 # run atmospheric correction
-i.atcorr lsat7_2002_40 ialt=elevation icnd=icnd.txt oimg=lsat7_2002_40_atcorr
+i.atcorr lsat7_2002_40 ialt=elev_int icnd=icnd.txt oimg=lsat7_2002_40_atcorr
 </pre></div>
 Note that the process is computationally intensive.
