[GRASS-SVN] r37146 - grass/trunk/mswindows
    svn_grass at osgeo.org
    Mon May 11 01:27:39 EDT 2009
Author: hamish
Date: 2009-05-11 01:27:39 -0400 (Mon, 11 May 2009)
New Revision: 37146
   grass/trunk/mswindows/GRASS-Installer.nsi
   grass/trunk/mswindows/GRASS-Packager.bat
   grass/trunk/mswindows/README.html
svn:eol-style + native (merge from relbr6)
Modified: grass/trunk/mswindows/GRASS-Installer.nsi
--- grass/trunk/mswindows/GRASS-Installer.nsi	2009-05-11 05:22:21 UTC (rev 37145)
+++ grass/trunk/mswindows/GRASS-Installer.nsi	2009-05-11 05:27:39 UTC (rev 37146)
@@ -1,861 +1,861 @@
-;GRASS Installer for Windows
-;Written by Marco Pasetti
-;Updated for OSGeo4W by Colin Nielsen
-;Last Update: 30 March 2009
-;Mail to: grass-dev at lists.osgeo.org
-;Define the source path of the demolocation files
-!define DEMOLOCATION_PATH "c:\osgeo4w\usr\src\grass-7.0.svn\demolocation"
-;Select if you are building a "Development Version" or a "Release Version" of the GRASS Installer
-;Change the INSTALLER_TYPE variable to Release, Dev6 or Dev7
-!define INSTALLER_TYPE "Dev7"
-;Version variables
-!define RELEASE_VERSION_NUMBER "6.4.0RC4"
-!define RELEASE_SVN_REVISION "36599"
-!define RELEASE_BINARY_REVISION "1"
-!define RELEASE_GRASS_COMMAND "grass64"
-!define RELEASE_GRASS_BASE "GRASS"
-!define DEV6_VERSION_NUMBER "6-SVN"
-!define DEV6_SVN_REVISION "36599"
-!define DEV6_BINARY_REVISION "1"
-!define DEV6_GRASS_COMMAND "grass65"
-!define DEV6_GRASS_BASE "GRASS-6-SVN"
-!define DEV7_VERSION_NUMBER "7-SVN"
-!define DEV7_SVN_REVISION ""
-!define DEV7_BINARY_REVISION "1"
-!define DEV7_GRASS_COMMAND "grass7"
-!define DEV7_GRASS_BASE"GRASS-7-SVN"
-;Don't modify the following lines
-;NSIS Includes
-!include "MUI2.nsh"
-!include "LogicLib.nsh"
-;Set the installer variables, depending on the selected version to build
-!if ${INSTALLER_TYPE} == "Release"
-	!define VERSION_NUMBER "${RELEASE_VERSION_NUMBER}"
-	!define SVN_REVISION "${RELEASE_SVN_REVISION}"
-	!define BINARY_REVISION "${RELEASE_BINARY_REVISION}"
-	!define GRASS_COMMAND "${RELEASE_GRASS_COMMAND}"
-	!define GRASS_BASE "${RELEASE_GRASS_BASE}"
-	!define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-${BINARY_REVISION}-Setup.exe"
-	!define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-${BINARY_REVISION}"
-	!define CHECK_INSTALL_NAME "GRASS"
-	!define PACKAGE_FOLDER ".\GRASS-Release-Package"
-!else if ${INSTALLER_TYPE} == "Dev6"
-	!define VERSION_NUMBER "${DEV6_VERSION_NUMBER}"
-	!define SVN_REVISION "${DEV6_SVN_REVISION}"
-	!define BINARY_REVISION "${DEV6_BINARY_REVISION}"
-	!define GRASS_COMMAND "${DEV6_GRASS_COMMAND}"
-	!define GRASS_BASE "${DEV6_GRASS_BASE}"
-	!define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}-Setup.exe"
-	!define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
-	!define CHECK_INSTALL_NAME "GRASS 6 SVN"
-	!define PACKAGE_FOLDER ".\GRASS-6-Dev-Package"
-!else if ${INSTALLER_TYPE} == "Dev7"
-	!define VERSION_NUMBER "${DV7_VERSION_NUMBER}"
-	!define SVN_REVISION "${DV7_SVN_REVISION}"
-	!define BINARY_REVISION "${DV7_BINARY_REVISION}"
-	!define GRASS_COMMAND "${DEV7_GRASS_COMMAND}"
-	!define GRASS_BASE "${DEV7_GRASS_BASE}"
-	!define CHECK_INSTALL_NAME "GRASS 7 SVN"
-	!define PACKAGE_FOLDER ".\GRASS-7-Dev-Package"
-!endif
-;Publisher variables
-!define PUBLISHER "GRASS Development Team"
-!define WEB_SITE "http://grass.osgeo.org/"
-!define WIKI_PAGE "http://grass.osgeo.org/wiki/Main_Page"
-;General Definitions
-;Name of the application shown during install
-Name "${DISPLAYED_NAME}"
-;Name of the output file (installer executable)
-OutFile "${INSTALLER_NAME}"
-;Define installation folder
-InstallDir "C:\${GRASS_BASE}"
-;Request application privileges for Windows Vista
-RequestExecutionLevel user
-;Tell the installer to show Install and Uninstall details as default
-ShowInstDetails show
-ShowUnInstDetails show
-;StrReplace Function
-;Replaces all ocurrences of a given needle within a haystack with another string
-;Written by dandaman32
-Var STR_REPLACE_VAR_0
-Var STR_REPLACE_VAR_1
-Var STR_REPLACE_VAR_2
-Var STR_REPLACE_VAR_3
-Var STR_REPLACE_VAR_4
-Var STR_REPLACE_VAR_5
-Var STR_REPLACE_VAR_6
-Var STR_REPLACE_VAR_7
-Var STR_REPLACE_VAR_8
-Function StrReplace
-	Exch $STR_REPLACE_VAR_2
-	Exch 1
-	Exch $STR_REPLACE_VAR_1
-	Exch 2
-	Exch $STR_REPLACE_VAR_0
-		StrCpy $STR_REPLACE_VAR_3 -1
-		StrLen $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_1
-		StrLen $STR_REPLACE_VAR_6 $STR_REPLACE_VAR_0
-		loop:
-			IntOp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_3 + 1
-			StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_3
-			StrCmp $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_1 found
-			StrCmp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_6 done
-			Goto loop
-		found:
-			StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_3
-			IntOp $STR_REPLACE_VAR_8 $STR_REPLACE_VAR_3 + $STR_REPLACE_VAR_4
-			StrCpy $STR_REPLACE_VAR_7 $STR_REPLACE_VAR_0 "" $STR_REPLACE_VAR_8
-			StrCpy $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_5$STR_REPLACE_VAR_2$STR_REPLACE_VAR_7
-			Goto loop
-		done:
-	Pop $STR_REPLACE_VAR_1 ; Prevent "invalid opcode" errors and keep the
-	Pop $STR_REPLACE_VAR_1 ; stack as it was before the function was called
-FunctionEnd
-!macro _strReplaceConstructor OUT NEEDLE NEEDLE2 HAYSTACK
-	Push "${HAYSTACK}"
-	Push "${NEEDLE}"
-	Push "${NEEDLE2}"
-	Call StrReplace
-	Pop "${OUT}"
-!macroend
-!define StrReplace '!insertmacro "_strReplaceConstructor"'
-;.onInit Function (called when the installer is nearly finished initializing)
-;Check if GRASS is already installed on the system and, if yes, what version and binary release;
-;depending on that, select the install procedure:
-;1. first installation = if GRASS is not already installed
-;install GRASS asking for the install PATH
-;2. upgrade installation = if an older release of GRASS is already installed
-;call the uninstaller of the currently installed GRASS release
-;if the uninstall procedure succeeded, call the current installer without asking for the install PATH
-;GRASS will be installed in the same PATH of the previous installation
-;3. downgrade installation = if a newer release of GRASS is already installed
-;4. repair installation = if the same release of GRASS is already installed
-;if the uninstall procedure succeeded, call the current installer asking for the install PATH
-;the currently installed release of GRASS is defined by the variable $INSTALLED_VERSION = $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
-Function .onInit
-	Var /GLOBAL ASK_FOR_PATH
-	StrCpy $ASK_FOR_PATH "YES"
-	Var /GLOBAL UNINSTALL_STRING
-	Var /GLOBAL INSTALL_PATH
-	Var /GLOBAL INSTALLED_VERSION_NUMBER
-	Var /GLOBAL INSTALLED_SVN_REVISION
-	Var /GLOBAL INSTALLED_BINARY_REVISION
-	Var /GLOBAL DISPLAYED_INSTALLED_VERSION
-	Var /GLOBAL MESSAGE_0_
-	Var /GLOBAL MESSAGE_1_
-	Var /GLOBAL MESSAGE_2_
-	Var /GLOBAL MESSAGE_3_
-	ReadRegStr $UNINSTALL_STRING HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString"
-	ReadRegStr $INSTALL_PATH HKLM "Software\${GRASS_BASE}" "InstallPath"
-	ReadRegStr $INSTALLED_VERSION_NUMBER HKLM "Software\${GRASS_BASE}" "VersionNumber"
-	ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "SvnRevision"
-	${If} $INSTALLED_SVN_REVISION == ""
-		ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "Revision"
-	${EndIf}
-	ReadRegStr $INSTALLED_BINARY_REVISION HKLM "Software\${GRASS_BASE}" "BinaryRevision"
-	StrCpy $MESSAGE_0_ "${CHECK_INSTALL_NAME} is already installed on your system.$\r$\n"
-	StrCpy $MESSAGE_0_ "$MESSAGE_0_$\r$\n"
-	!if ${INSTALLER_TYPE} == "Release"
-		${If} $INSTALLED_BINARY_REVISION == ""
-			StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER"
-		${Else}
-			StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_BINARY_REVISION"
-		${EndIf}
-	!else
-		StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_SVN_REVISION-$INSTALLED_BINARY_REVISION"
-	!endif
-	StrCpy $MESSAGE_0_ "$MESSAGE_0_The installed release is $DISPLAYED_INSTALLED_VERSION$\r$\n"
-	StrCpy $MESSAGE_1_ "$MESSAGE_0_$\r$\n"
-	StrCpy $MESSAGE_1_ "$MESSAGE_1_You are going to install a newer release of ${CHECK_INSTALL_NAME}$\r$\n"
-	StrCpy $MESSAGE_1_ "$MESSAGE_1_$\r$\n"
-	StrCpy $MESSAGE_1_ "$MESSAGE_1_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
-	StrCpy $MESSAGE_1_ "$MESSAGE_1_ and install ${DISPLAYED_NAME} or Cancel to quit."
-	StrCpy $MESSAGE_2_ "$MESSAGE_0_$\r$\n"
-	StrCpy $MESSAGE_2_ "$MESSAGE_2_You are going to install an older release of ${CHECK_INSTALL_NAME}$\r$\n"
-	StrCpy $MESSAGE_2_ "$MESSAGE_2_$\r$\n"
-	StrCpy $MESSAGE_2_ "$MESSAGE_2_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
-	StrCpy $MESSAGE_2_ "$MESSAGE_2_ and install ${DISPLAYED_NAME} or Cancel to quit."
-	StrCpy $MESSAGE_3_ "$MESSAGE_0_$\r$\n"
-	StrCpy $MESSAGE_3_ "$MESSAGE_3_This is the latest release available.$\r$\n"
-	StrCpy $MESSAGE_3_ "$MESSAGE_3_$\r$\n"
-	StrCpy $MESSAGE_3_ "$MESSAGE_3_Press OK to reinstall ${DISPLAYED_NAME} or Cancel to quit."
-	IntOp $INSTALLED_SVN_REVISION $INSTALLED_SVN_REVISION * 1
-	IntOp $INSTALLED_BINARY_REVISION $INSTALLED_BINARY_REVISION * 1
-	IntOp $INSTALLED_VERSION $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
-	!define /math VERSION ${SVN_REVISION} + ${BINARY_REVISION}
-	${If} $INSTALLED_VERSION_NUMBER == ""
-	${Else}
-		${If} $INSTALLED_VERSION < ${VERSION}
-			MessageBox MB_OKCANCEL "$MESSAGE_1_" IDOK upgrade IDCANCEL quit_upgrade
-			upgrade:
-				StrCpy $ASK_FOR_PATH "NO"
-				ExecWait '"$UNINSTALL_STRING" _?=$INSTALL_PATH' $0
-				Goto continue_upgrade
-			quit_upgrade:
-				Abort
-			continue_upgrade:
-		${ElseIf} $INSTALLED_VERSION > ${VERSION}
-			MessageBox MB_OKCANCEL "$MESSAGE_2_" IDOK downgrade IDCANCEL quit_downgrade
-			downgrade:
-				Goto continue_downgrade
-			quit_downgrade:
-				Abort
-			continue_downgrade:
-		${ElseIf} $INSTALLED_VERSION = ${VERSION}
-			MessageBox MB_OKCANCEL "$MESSAGE_3_" IDOK reinstall IDCANCEL quit_reinstall
-			reinstall:
-				Goto continue_reinstall
-			quit_reinstall:
-				Abort
-			continue_reinstall:
-		${EndIf}
-	${EndIf}
-	${Else}
-		${If} $0 = 0
-		${Else}
-			Abort
-		${EndIf}
-	${EndIf}
-FunctionEnd
-;CheckUpdate Function
-;Check if to show the MUI_PAGE_DIRECTORY during the installation (to ask for the install PATH)
-Function CheckUpdate
-	${If} $ASK_FOR_PATH == "NO"
-		Abort
-	${EndIf}
-FunctionEnd
-;CheckInstDir Function
-;Check if GRASS is going to be installed in a directory containing spaces
-;if yes, show a warning message
-Function CheckInstDir
-	Var /GLOBAL INSTDIR_TEST
-	Var /GLOBAL INSTDIR_LENGHT
-	Var /GLOBAL INSTDIR_TEST_LENGHT
-	Var /GLOBAL MESSAGE_CHKINST_
-	StrCpy $MESSAGE_CHKINST_ "WARNING: you are about to install GRASS into a directory that has spaces$\r$\n"
-	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_in either its name or the path of directories leading up to it.$\r$\n"
-	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_Some functionalities of GRASS might be hampered by this. We would highly$\r$\n"
-	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_appreciate if you tried and reported any problems, so that we can fix them.$\r$\n"
-	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_However, if you want to avoid any such issues, we recommend that you$\r$\n"
-	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_choose a simple installation path without spaces, such as: C:\${GRASS_BASE}.$\r$\n"
-	${StrReplace} "$INSTDIR_TEST" " " "" "$INSTDIR"
-	StrLen $INSTDIR_LENGHT "$INSTDIR"
-	StrLen $INSTDIR_TEST_LENGHT "$INSTDIR_TEST"
-	${If} $INSTDIR_TEST_LENGHT < $INSTDIR_LENGHT
-		MessageBox MB_OK|MB_ICONEXCLAMATION "$MESSAGE_CHKINST_"
-	${EndIf}
-FunctionEnd
-;Interface Settings
-!define MUI_ABORTWARNING
-!define MUI_ICON ".\Installer-Files\Install_GRASS.ico"
-!define MUI_UNICON ".\Installer-Files\Uninstall_GRASS.ico"
-!define MUI_HEADERIMAGE_BITMAP_NOSTETCH ".\Installer-Files\InstallHeaderImage.bmp"
-!define MUI_HEADERIMAGE_UNBITMAP_NOSTRETCH ".\Installer-Files\UnInstallHeaderImage.bmp"
-!define MUI_WELCOMEFINISHPAGE_BITMAP ".\Installer-Files\WelcomeFinishPage.bmp"
-!define MUI_UNWELCOMEFINISHPAGE_BITMAP ".\Installer-Files\UnWelcomeFinishPage.bmp"
-;Installer Pages
-!insertmacro MUI_PAGE_WELCOME
-!insertmacro MUI_PAGE_LICENSE "${PACKAGE_FOLDER}\GPL.TXT"
-!define MUI_PAGE_CUSTOMFUNCTION_PRE CheckUpdate
-!insertmacro MUI_PAGE_DIRECTORY
-Page custom CheckInstDir
-!insertmacro MUI_PAGE_COMPONENTS
-!insertmacro MUI_PAGE_INSTFILES
-!insertmacro MUI_PAGE_FINISH
-!insertmacro MUI_UNPAGE_WELCOME
-!insertmacro MUI_UNPAGE_CONFIRM
-!insertmacro MUI_UNPAGE_INSTFILES
-!insertmacro MUI_UNPAGE_FINISH
-;Language files
-!insertmacro MUI_LANGUAGE "English"
-;Installer Sections
-;Declares the variables for optional Sample Data Sections
-Var /GLOBAL HTTP_PATH
-Var /GLOBAL ARCHIVE_NAME
-Var /GLOBAL EXTENDED_ARCHIVE_NAME
-Var /GLOBAL ORIGINAL_UNTAR_FOLDER
-Var /GLOBAL CUSTOM_UNTAR_FOLDER
-Var /GLOBAL ARCHIVE_SIZE_KB
-Var /GLOBAL ARCHIVE_SIZE_MB
-Var /GLOBAL DOWNLOAD_MESSAGE_
-Section "GRASS" SecGRASS
-	SectionIn RO
-	;Set the INSTALL_DIR variable
-	Var /GLOBAL INSTALL_DIR
-		StrCpy $INSTALL_DIR "$INSTALL_PATH"
-	${Else}
-		StrCpy $INSTALL_DIR "$INSTDIR"
-	${EndIf}
-	;Set to try to overwrite existing files
-	SetOverwrite try
-	;Set the GIS_DATABASE directory
-	SetShellVarContext current
-	Var /GLOBAL GIS_DATABASE
-	StrCpy $GIS_DATABASE "$DOCUMENTS\GIS DataBase"
-	;Create the GIS_DATABASE directory
-	CreateDirectory "$GIS_DATABASE"
-	;add Installer files
-	SetOutPath "$INSTALL_DIR\icons"
-	File .\Installer-Files\GRASS.ico
-	File .\Installer-Files\GRASS_Web.ico
-	File .\Installer-Files\GRASS_CMD.ico
-	File .\Installer-Files\MSYS_Custom_Icon.ico
-	File .\Installer-Files\WinGRASS.ico
-	SetOutPath "$INSTALL_DIR"
-	File .\Installer-Files\GRASS-WebSite.url
-	File .\Installer-Files\WinGRASS-README.url
-	;add GRASS files
-	File /r ${PACKAGE_FOLDER}\*.*
-	;Install demolocation into the GIS_DATABASE directory
-	SetOutPath "$GIS_DATABASE\demolocation"
-	File /r ${DEMOLOCATION_PATH}\*.*
-	;Create the Uninstaller
-	WriteUninstaller "$INSTALL_DIR\Uninstall-GRASS.exe"
-	;Registry Key Entries
-	;HKEY_LOCAL_MACHINE Install entries
-	;Set the Name, Version and Revision of GRASS + PublisherInfo + InstallPath
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "Name" "GRASS"
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "VersionNumber" "${VERSION_NUMBER}"
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "SvnRevision" "${SVN_REVISION}"
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "BinaryRevision" "${BINARY_REVISION}"
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "WebSite" "${WEB_SITE}"
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "InstallPath" "$INSTALL_DIR"
-	;HKEY_LOCAL_MACHINE Uninstall entries
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayName" "GRASS"
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString" "$INSTALL_DIR\Uninstall-GRASS.exe"
-		WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"\
-		"DisplayVersion" "${VERSION_NUMBER}-${BINARY_REVISION}"
-	!else
-		"DisplayVersion" "${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
-	!endif
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayIcon" "$INSTALL_DIR\icons\GRASS.ico"
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "EstimatedSize" 1
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "HelpLink" "${WIKI_PAGE}"
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "URLInfoAbout" "${WEB_SITE}"
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
-	;Create the Desktop Shortcut
-	CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wxpython"\
-	"$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER}"
-	CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER} msys.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
-	"$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with msys Terminal"
-	;Create the Windows Start Menu Shortcuts
-	SetShellVarContext all
-	CreateDirectory "$SMPROGRAMS\${GRASS_BASE}"
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Old GUI.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-tcltk"\
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wxpython"\
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Command Line.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-text"\
-	"$INSTALL_DIR\icons\GRASS_CMD.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS in Text Mode on the Command Line"
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS MSYS Console.lnk" "$INSTALL_DIR\msys\msys.bat" ""\
-	"$INSTALL_DIR\icons\MSYS_Custom_Icon.ico" "" SW_SHOWNORMAL "" "Open the GRASS MSYS Console"
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Web Site.lnk" "$INSTALL_DIR\GRASS-WebSite.url" ""\
-	"$INSTALL_DIR\icons\GRASS_Web.ico" "" SW_SHOWNORMAL "" "Visit the GRASS Web Site"
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} msys.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
-		CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Release Notes.lnk" "$INSTALL_DIR\WinGRASS-README.url" ""\
-		"$INSTALL_DIR\icons\WinGRASS.ico" "" SW_SHOWNORMAL "" "Visit the WinGRASS Project Web Page"
-	!endif
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Uninstall GRASS.lnk" "$INSTALL_DIR\Uninstall-GRASS.exe" ""\
-	"$INSTALL_DIR\Uninstall-GRASS.exe" "" SW_SHOWNORMAL "" "Uninstall GRASS ${VERSION_NUMBER}"
-	;Create the grass_command.bat
-	ClearErrors
-	FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}.bat w
-	IfErrors done_create_grass_command.bat
-	FileWrite $0 '@echo off$\r$\n'
-	FileWrite $0 'rem #########################################################################$\r$\n'
-	FileWrite $0 'rem #$\r$\n'
-	FileWrite $0 'rem # File dynamically created by NSIS installer script;$\r$\n'
-	FileWrite $0 'rem # Written by Marco Pasetti;$\r$\n'
-	FileWrite $0 'rem # GRASS Initialization$\r$\n'
-	FileWrite $0 '$\r$\n'
-	FileWrite $0 'rem *******Environment variables***********$\r$\n'
-	FileWrite $0 'rem Set GRASS Installation Directory Variable$\r$\n'
-	FileWrite $0 'set GRASSDIR=$INSTALL_DIR$\r$\n'
-	FileWrite $0 'rem Directory where your .grassrc6 file will be stored$\r$\n'
-	FileWrite $0 'set HOME=%USERPROFILE%$\r$\n'
-	FileWrite $0 'rem Name of the wish (Tk) executable$\r$\n'
-	FileWrite $0 'set GRASS_WISH=wish.exe$\r$\n'
-	FileWrite $0 'rem Path to the shell command$\r$\n'
-	FileWrite $0 'set GRASS_SH=%GRASSDIR%\msys\bin\sh.exe$\r$\n'
-	FileWrite $0 'rem Set Path to utilities (libraries and bynaries) used by GRASS$\r$\n'
-	FileWrite $0 'set PATH=%GRASSDIR%\msys\bin;%PATH%$\r$\n'
-	FileWrite $0 'set PATH=%GRASSDIR%\extrabin;%GRASSDIR%\extralib;%PATH%$\r$\n'
-	FileWrite $0 'set PATH=%GRASSDIR%\tcl-tk\bin;%GRASSDIR%\sqlite\bin;%GRASSDIR%\gpsbabel;%PATH%$\r$\n'
-	FileWrite $0 'rem Set Path to MSIE web browser$\r$\n'
-	FileWrite $0 'set GRASS_HTML_BROWSER=%PROGRAMFILES%/Internet Explorer/iexplore.exe$\r$\n'
-	FileWrite $0 'rem Path to the proj files (notably the epsg projection list)$\r$\n'
-	FileWrite $0 'set GRASS_PROJSHARE=%GRASSDIR%\proj$\r$\n'
-	FileWrite $0 'rem Path to the python directory$\r$\n'
-	FileWrite $0 'set PYTHONHOME=%GRASSDIR%\Python25$\r$\n'
-	FileWrite $0 'set WINGISBASE=%GRASSDIR%$\r$\n'
-	FileWrite $0 '"%WINGISBASE%\etc\init.bat" %*'
-	FileClose $0
-	done_create_grass_command.bat:
-	;Set the UNIX_LIKE GRASS Path
-	Var /GLOBAL UNIX_LIKE_DRIVE
-	Var /GLOBAL UNIX_LIKE_GRASS_PATH
-	StrCpy $UNIX_LIKE_DRIVE "$INSTALL_DIR" 3
-	StrCpy $UNIX_LIKE_GRASS_PATH "$INSTALL_DIR" "" 3
-	;replace "\" with "/" in $UNIX_LIKE_DRIVE
-	${StrReplace} "$UNIX_LIKE_DRIVE" "\" "/" "$UNIX_LIKE_DRIVE"
-	;replace ":" with "" in $UNIX_LIKE_DRIVE
-	${StrReplace} "$UNIX_LIKE_DRIVE" ":" "" "$UNIX_LIKE_DRIVE"
-	;replace "\" with "/" in $UNIX_LIKE_GRASS_PATH
-	${StrReplace} "$UNIX_LIKE_GRASS_PATH" "\" "/" "$UNIX_LIKE_GRASS_PATH"
-	;Set the USERNAME variable
-	Var /GLOBAL USERNAME
-	Var /GLOBAL PROFILE_DRIVE
-	Var /GLOBAL PROFILE_ROOT
-	;It first searches for the Key Regestry value "Logon User Name" in HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer"
-	ReadRegStr $USERNAME HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer" "Logon User Name"
-	;If the Key Registry value is empty, it uses a work around, retrieving the Username string from the System User Profile variable ($PROFILE)
-	;It first read the $PROFILE variable, to scan the OS version:
-	;If equal to "drive:\Users\UserName", the OS is Vista, and the $USERNAME variable set to $PROFILE -  "drive:\Users\"
-	;If not, the OS is XP or previous, and the $USERNAME variable set to $PROFILE -  "drive:\Documents and Settings\"
-	${If} $USERNAME = ""
-		StrCpy $PROFILE_DRIVE "$PROFILE" 2
-		StrCpy $PROFILE_ROOT "$PROFILE" 5 -3
-		${If} $USERNAME = "Users"
-			${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Users\" "" "$PROFILE"
-		${Else}
-			${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Documents and Settings\" "" "$PROFILE"
-		${EndIf}
-	${EndIf}
-	;Create the $INSTALL_DIR\msys\home and the $INSTALL_DIR\msys\home\$USERNAME directories
-	CreateDirectory $INSTALL_DIR\msys\home
-	CreateDirectory $INSTALL_DIR\msys\home\$USERNAME
-	;create the $INSTALL_DIR\bin grass_command
-	ClearErrors
-	FileOpen $0 $INSTALL_DIR\bin\${GRASS_COMMAND} w
-	FileWrite $0 '#! /bin/sh$\r$\n'
-	FileWrite $0 '#########################################################################$\r$\n'
-	FileWrite $0 '#$\r$\n'
-	FileWrite $0 '# File dynamically created by NSIS installer script;$\r$\n'
-	FileWrite $0 '# Written by Marco Pasetti;$\r$\n'
-	FileWrite $0 '# MODULE:   	GRASS Initialization$\r$\n'
-	FileWrite $0 '# AUTHOR(S):	Justin Hickey - Thailand - jhickey at hpcc.nectec.or.th$\r$\n'
-	FileWrite $0 '# PURPOSE:  	The source file for this shell script is in$\r$\n'
-	FileWrite $0 '#   	    	lib/init/grass.src and is the grass startup script. It$\r$\n'
-	FileWrite $0 '#   	    	requires a source file because the definition of GISBASE$\r$\n'
-	FileWrite $0 '#   	    	is not known until compile time and is substituted from the$\r$\n'
-	FileWrite $0 '#   	    	Makefile. Any command line options are passed to Init.sh.$\r$\n'
-	FileWrite $0 '# COPYRIGHT:    (C) 2000-2005 by the GRASS Development Team$\r$\n'
-	FileWrite $0 '#               This program is free software under the GNU General Public$\r$\n'
-	FileWrite $0 '#   	    	License (>=v2). Read the file COPYING that comes with GRASS$\r$\n'
-	FileWrite $0 '#   	    	for details.$\r$\n'
-	FileWrite $0 '# Modified by Marco Pasetti$\r$\n'
-	FileWrite $0 '# added the export PATH instruction to let GRASS work from$\r$\n'
-	FileWrite $0 '# the MSYS environment in the dynamic NSIS installation$\r$\n'
-	FileWrite $0 'trap "echo '
-	FileWrite $0 "'User break!' ; "
-	FileWrite $0 'exit" 2 3 9 15$\r$\n'
-	FileWrite $0 '# Set the GISBASE variable$\r$\n'
-	FileWrite $0 'GISBASE=/$UNIX_LIKE_DRIVE$UNIX_LIKE_GRASS_PATH$\r$\n'
-	FileWrite $0 'export GISBASE$\r$\n'
-	FileWrite $0 '# Set the PATH variable$\r$\n'
-	FileWrite $0 'PATH="$$GISBASE/extrabin:$$GISBASE/extralib:$$PATH"$\r$\n'
-	FileWrite $0 'PATH="$$GISBASE/tcl-tk/bin:$$GISBASE/sqlite/bin:$$GISBASE/gpsbabel:$$PATH"$\r$\n'
-	FileWrite $0 'export PATH$\r$\n'
-	FileWrite $0 '# Set the PYTHONPATH variable$\r$\n'
-	FileWrite $0 'PYTHONPATH="$$GISBASE/etc/python:$$GISBASE/Python25:$$PYTHONPATH"$\r$\n'
-	FileWrite $0 'export PYTHONPATH$\r$\n'
-	FileWrite $0 'PYTHONHOME="$INSTALL_DIR\Python25"$\r$\n'
-	FileWrite $0 'export PYTHONHOME$\r$\n'
-	FileWrite $0 '# Set the GRASS_PROJSHARE variable$\r$\n'
-	FileWrite $0 'GRASS_PROJSHARE="$INSTALL_DIR\proj"$\r$\n'
-	FileWrite $0 'export GRASS_PROJSHARE$\r$\n'
-	FileWrite $0 'exec "$$GISBASE/etc/Init.sh" "$$@"'
-	FileClose $0
-	done_create_grass_command:
-	;Create the $INSTALL_DIR\msys\grass link directory
-	CreateDirectory $INSTALL_DIR\msys\grass
-	;create the $INSTALL_DIR\msys\etc\fstab with the main grass dir mount info
-	ClearErrors
-	FileOpen $0 $INSTALL_DIR\msys\etc\fstab w
-	IfErrors done_create_fstab
-	FileWrite $0 '$INSTALL_DIR   /grass$\r$\n'
-	FileClose $0
-	done_create_fstab:
-	;Set the Unix-Like GIS_DATABASE Path
-	Var /GLOBAL UNIX_LIKE_GIS_DATABASE_PATH
-	;replace \ with / in $GIS_DATABASE
-	${StrReplace} "$UNIX_LIKE_GIS_DATABASE_PATH" "\" "/" "$GIS_DATABASE"
-	;create $PROFILE\.grassrc6
-	ClearErrors
-	FileOpen $0 $PROFILE\.grassrc6 w
-	IfErrors done_create_.grassrc6
-	FileWrite $0 'GISDBASE: $UNIX_LIKE_GIS_DATABASE_PATH$\r$\n'
-	FileWrite $0 'LOCATION_NAME: demolocation$\r$\n'
-	FileWrite $0 'MAPSET: PERMANENT$\r$\n'
-	FileClose $0
-	done_create_.grassrc6:
-	CopyFiles $PROFILE\.grassrc6 $INSTALL_DIR\msys\home\$USERNAME
-SectionEnd
-Function DownloadDataSet
-	IntOp $ARCHIVE_SIZE_MB $ARCHIVE_SIZE_KB / 1024
-	StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME sample data set.$\r$\n"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The archive is about $ARCHIVE_SIZE_MB MB and may take"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ several minutes to be downloaded.$\r$\n"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The $EXTENDED_ARCHIVE_NAME will be copyed to:$\r$\n"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER.$\r$\n"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue or Cancel to skip the download and complete the GRASS"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME data set.$\r$\n"
-	MessageBox MB_OKCANCEL "$DOWNLOAD_MESSAGE_" IDOK download IDCANCEL cancel_download
-	download:
-	InitPluginsDir
-	NSISdl::download "$HTTP_PATH/$ARCHIVE_NAME" "$TEMP\$ARCHIVE_NAME"
-	Pop $0
-	StrCmp $0 "success" download_ok download_failed
-	download_ok:
-	InitPluginsDir
-	untgz::extract "-d" "$GIS_DATABASE" "$TEMP\$ARCHIVE_NAME"
-	Pop $0
-	StrCmp $0 "success" untar_ok untar_failed
-	untar_ok:
-	Rename "$GIS_DATABASE\$ORIGINAL_UNTAR_FOLDER" "$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER"
-	Delete "$TEMP\$ARCHIVE_NAME"
-	Goto end
-	download_failed:
-	DetailPrint "$0" ;print error message to log
-	MessageBox MB_OK "Download Failed.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
-	Goto end
-	cancel_download:
-	MessageBox MB_OK "Download Cancelled.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
-	Goto end
-	untar_failed:
-	end:
-FunctionEnd
-Section /O "North Carolina Data Set" SecNorthCarolinaSDB
-	;Set the size (in KB)  of the archive file
-	StrCpy $ARCHIVE_SIZE_KB 138629
-	;Set the size (in KB) of the unpacked archive file
-	AddSize 293314
-  	StrCpy $HTTP_PATH "http://grass.osgeo.org/sampledata"
-	StrCpy $ARCHIVE_NAME "nc_spm_latest.tar.gz"
-	StrCpy $EXTENDED_ARCHIVE_NAME "North Carolina"
-	StrCpy $ORIGINAL_UNTAR_FOLDER "nc_spm_08"
-	StrCpy $CUSTOM_UNTAR_FOLDER "North-Carolina"
-	Call DownloadDataSet
-SectionEnd
-Section /O "South Dakota (Spearfish) Data Set" SecSpearfishSDB
-	StrCpy $ARCHIVE_SIZE_KB 20803
-	AddSize 42171
-	StrCpy $ARCHIVE_NAME "spearfish_grass60data-0.3.tar.gz"
-	StrCpy $EXTENDED_ARCHIVE_NAME "South Dakota (Spearfish)"
-	StrCpy $ORIGINAL_UNTAR_FOLDER "spearfish60"
-	StrCpy $CUSTOM_UNTAR_FOLDER "Spearfish60"
-SectionEnd
-;Uninstaller Section
-Section "Uninstall"
-	;remove files
-	Delete "$INSTDIR\Uninstall-GRASS.exe"
-	Delete "$INSTDIR\GPL.TXT"
-	Delete "$INSTDIR\AUTHORS"
-	Delete "$INSTDIR\CHANGES"
-	Delete "$INSTDIR\COPYING"
-	Delete "$INSTDIR\${GRASS_COMMAND}.bat"
-	Delete "$INSTDIR\GRASS-WebSite.url"
-	Delete "$INSTDIR\WinGRASS-README.url"
-	Delete "$INSTDIR\REQUIREMENTS.html"
-	;remove folders
-	RMDir /r "$INSTDIR\bin"
-	RMDir /r "$INSTDIR\bwidget"
-	RMDir /r "$INSTDIR\docs"
-	RMDir /r "$INSTDIR\driver"
-	RMDir /r "$INSTDIR\etc"
-	RMDir /r "$INSTDIR\extrabin"
-	RMDir /r "$INSTDIR\extralib"
-	RMDir /r "$INSTDIR\fonts"
-	RMDir /r "$INSTDIR\gpsbabel"
-	RMDir /r "$INSTDIR\icons"
-	RMDir /r "$INSTDIR\include"
-	RMDir /r "$INSTDIR\lib"
-	RMDir /r "$INSTDIR\locale"
-	RMDir /r "$INSTDIR\msys"
-	RMDir /r "$INSTDIR\proj"
-	RMDir /r "$INSTDIR\Python25"
-	RMDir /r "$INSTDIR\scripts"
-	RMDir /r "$INSTDIR\sqlite"
-	RMDir /r "$INSTDIR\tcl-tk"
-	;if empty, remove the install folder
-	RMDir "$INSTDIR"
-	;remove the Desktop ShortCut
-	Delete "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk"
-	Delete "$DESKTOP\GRASS ${VERSION_NUMBER} msys.lnk"
-	;remove the Programs Start ShortCuts
-	RMDir /r "$SMPROGRAMS\${GRASS_BASE}"
-	;remove the .grassrc6 file
-	Delete "$PROFILE\.grassrc6"
-	;remove the Registry Entries
-	DeleteRegKey HKLM "Software\${GRASS_BASE}"
-	DeleteRegKey HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"
-SectionEnd
-;Installer Section Descriptions
-!insertmacro MUI_FUNCTION_DESCRIPTION_BEGIN
-	!insertmacro MUI_DESCRIPTION_TEXT ${SecGRASS} "Install GRASS ${VERSION_NUMBER}"
-	!insertmacro MUI_DESCRIPTION_TEXT ${SecNorthCarolinaSDB} "Download and install the North Carolina sample data set"
-	!insertmacro MUI_DESCRIPTION_TEXT ${SecSpearfishSDB} "Download and install the South Dakota (Spearfish) sample data set"
-!insertmacro MUI_FUNCTION_DESCRIPTION_END
+;GRASS Installer for Windows
+;Written by Marco Pasetti
+;Updated for OSGeo4W by Colin Nielsen
+;Last Update: 30 March 2009
+;Mail to: grass-dev at lists.osgeo.org
+;Define the source path of the demolocation files
+!define DEMOLOCATION_PATH "c:\osgeo4w\usr\src\grass-7.0.svn\demolocation"
+;Select if you are building a "Development Version" or a "Release Version" of the GRASS Installer
+;Change the INSTALLER_TYPE variable to Release, Dev6 or Dev7
+!define INSTALLER_TYPE "Dev7"
+;Version variables
+!define RELEASE_VERSION_NUMBER "6.4.0RC4"
+!define RELEASE_SVN_REVISION "36599"
+!define RELEASE_BINARY_REVISION "1"
+!define RELEASE_GRASS_COMMAND "grass64"
+!define RELEASE_GRASS_BASE "GRASS"
+!define DEV6_VERSION_NUMBER "6-SVN"
+!define DEV6_SVN_REVISION "36599"
+!define DEV6_BINARY_REVISION "1"
+!define DEV6_GRASS_COMMAND "grass65"
+!define DEV6_GRASS_BASE "GRASS-6-SVN"
+!define DEV7_VERSION_NUMBER "7-SVN"
+!define DEV7_SVN_REVISION ""
+!define DEV7_BINARY_REVISION "1"
+!define DEV7_GRASS_COMMAND "grass7"
+!define DEV7_GRASS_BASE"GRASS-7-SVN"
+;Don't modify the following lines
+;NSIS Includes
+!include "MUI2.nsh"
+!include "LogicLib.nsh"
+;Set the installer variables, depending on the selected version to build
+!if ${INSTALLER_TYPE} == "Release"
+	!define VERSION_NUMBER "${RELEASE_VERSION_NUMBER}"
+	!define SVN_REVISION "${RELEASE_SVN_REVISION}"
+	!define BINARY_REVISION "${RELEASE_BINARY_REVISION}"
+	!define GRASS_COMMAND "${RELEASE_GRASS_COMMAND}"
+	!define GRASS_BASE "${RELEASE_GRASS_BASE}"
+	!define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-${BINARY_REVISION}-Setup.exe"
+	!define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-${BINARY_REVISION}"
+	!define CHECK_INSTALL_NAME "GRASS"
+	!define PACKAGE_FOLDER ".\GRASS-Release-Package"
+!else if ${INSTALLER_TYPE} == "Dev6"
+	!define VERSION_NUMBER "${DEV6_VERSION_NUMBER}"
+	!define SVN_REVISION "${DEV6_SVN_REVISION}"
+	!define BINARY_REVISION "${DEV6_BINARY_REVISION}"
+	!define GRASS_COMMAND "${DEV6_GRASS_COMMAND}"
+	!define GRASS_BASE "${DEV6_GRASS_BASE}"
+	!define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}-Setup.exe"
+	!define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
+	!define CHECK_INSTALL_NAME "GRASS 6 SVN"
+	!define PACKAGE_FOLDER ".\GRASS-6-Dev-Package"
+!else if ${INSTALLER_TYPE} == "Dev7"
+	!define VERSION_NUMBER "${DV7_VERSION_NUMBER}"
+	!define SVN_REVISION "${DV7_SVN_REVISION}"
+	!define BINARY_REVISION "${DV7_BINARY_REVISION}"
+	!define GRASS_COMMAND "${DEV7_GRASS_COMMAND}"
+	!define GRASS_BASE "${DEV7_GRASS_BASE}"
+	!define CHECK_INSTALL_NAME "GRASS 7 SVN"
+	!define PACKAGE_FOLDER ".\GRASS-7-Dev-Package"
+!endif
+;Publisher variables
+!define PUBLISHER "GRASS Development Team"
+!define WEB_SITE "http://grass.osgeo.org/"
+!define WIKI_PAGE "http://grass.osgeo.org/wiki/Main_Page"
+;General Definitions
+;Name of the application shown during install
+Name "${DISPLAYED_NAME}"
+;Name of the output file (installer executable)
+OutFile "${INSTALLER_NAME}"
+;Define installation folder
+InstallDir "C:\${GRASS_BASE}"
+;Request application privileges for Windows Vista
+RequestExecutionLevel user
+;Tell the installer to show Install and Uninstall details as default
+ShowInstDetails show
+ShowUnInstDetails show
+;StrReplace Function
+;Replaces all ocurrences of a given needle within a haystack with another string
+;Written by dandaman32
+Var STR_REPLACE_VAR_0
+Var STR_REPLACE_VAR_1
+Var STR_REPLACE_VAR_2
+Var STR_REPLACE_VAR_3
+Var STR_REPLACE_VAR_4
+Var STR_REPLACE_VAR_5
+Var STR_REPLACE_VAR_6
+Var STR_REPLACE_VAR_7
+Var STR_REPLACE_VAR_8
+Function StrReplace
+	Exch $STR_REPLACE_VAR_2
+	Exch 1
+	Exch $STR_REPLACE_VAR_1
+	Exch 2
+	Exch $STR_REPLACE_VAR_0
+		StrCpy $STR_REPLACE_VAR_3 -1
+		StrLen $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_1
+		StrLen $STR_REPLACE_VAR_6 $STR_REPLACE_VAR_0
+		loop:
+			IntOp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_3 + 1
+			StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_3
+			StrCmp $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_1 found
+			StrCmp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_6 done
+			Goto loop
+		found:
+			StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_3
+			IntOp $STR_REPLACE_VAR_8 $STR_REPLACE_VAR_3 + $STR_REPLACE_VAR_4
+			StrCpy $STR_REPLACE_VAR_7 $STR_REPLACE_VAR_0 "" $STR_REPLACE_VAR_8
+			StrCpy $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_5$STR_REPLACE_VAR_2$STR_REPLACE_VAR_7
+			Goto loop
+		done:
+	Pop $STR_REPLACE_VAR_1 ; Prevent "invalid opcode" errors and keep the
+	Pop $STR_REPLACE_VAR_1 ; stack as it was before the function was called
+FunctionEnd
+!macro _strReplaceConstructor OUT NEEDLE NEEDLE2 HAYSTACK
+	Push "${HAYSTACK}"
+	Push "${NEEDLE}"
+	Push "${NEEDLE2}"
+	Call StrReplace
+	Pop "${OUT}"
+!macroend
+!define StrReplace '!insertmacro "_strReplaceConstructor"'
+;.onInit Function (called when the installer is nearly finished initializing)
+;Check if GRASS is already installed on the system and, if yes, what version and binary release;
+;depending on that, select the install procedure:
+;1. first installation = if GRASS is not already installed
+;install GRASS asking for the install PATH
+;2. upgrade installation = if an older release of GRASS is already installed
+;call the uninstaller of the currently installed GRASS release
+;if the uninstall procedure succeeded, call the current installer without asking for the install PATH
+;GRASS will be installed in the same PATH of the previous installation
+;3. downgrade installation = if a newer release of GRASS is already installed
+;4. repair installation = if the same release of GRASS is already installed
+;if the uninstall procedure succeeded, call the current installer asking for the install PATH
+;the currently installed release of GRASS is defined by the variable $INSTALLED_VERSION = $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
+Function .onInit
+	Var /GLOBAL ASK_FOR_PATH
+	StrCpy $ASK_FOR_PATH "YES"
+	Var /GLOBAL UNINSTALL_STRING
+	Var /GLOBAL INSTALL_PATH
+	Var /GLOBAL INSTALLED_VERSION_NUMBER
+	Var /GLOBAL INSTALLED_SVN_REVISION
+	Var /GLOBAL INSTALLED_BINARY_REVISION
+	Var /GLOBAL DISPLAYED_INSTALLED_VERSION
+	Var /GLOBAL MESSAGE_0_
+	Var /GLOBAL MESSAGE_1_
+	Var /GLOBAL MESSAGE_2_
+	Var /GLOBAL MESSAGE_3_
+	ReadRegStr $UNINSTALL_STRING HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString"
+	ReadRegStr $INSTALL_PATH HKLM "Software\${GRASS_BASE}" "InstallPath"
+	ReadRegStr $INSTALLED_VERSION_NUMBER HKLM "Software\${GRASS_BASE}" "VersionNumber"
+	ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "SvnRevision"
+	${If} $INSTALLED_SVN_REVISION == ""
+		ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "Revision"
+	${EndIf}
+	ReadRegStr $INSTALLED_BINARY_REVISION HKLM "Software\${GRASS_BASE}" "BinaryRevision"
+	StrCpy $MESSAGE_0_ "${CHECK_INSTALL_NAME} is already installed on your system.$\r$\n"
+	StrCpy $MESSAGE_0_ "$MESSAGE_0_$\r$\n"
+	!if ${INSTALLER_TYPE} == "Release"
+		${If} $INSTALLED_BINARY_REVISION == ""
+			StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER"
+		${Else}
+			StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_BINARY_REVISION"
+		${EndIf}
+	!else
+		StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_SVN_REVISION-$INSTALLED_BINARY_REVISION"
+	!endif
+	StrCpy $MESSAGE_0_ "$MESSAGE_0_The installed release is $DISPLAYED_INSTALLED_VERSION$\r$\n"
+	StrCpy $MESSAGE_1_ "$MESSAGE_0_$\r$\n"
+	StrCpy $MESSAGE_1_ "$MESSAGE_1_You are going to install a newer release of ${CHECK_INSTALL_NAME}$\r$\n"
+	StrCpy $MESSAGE_1_ "$MESSAGE_1_$\r$\n"
+	StrCpy $MESSAGE_1_ "$MESSAGE_1_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
+	StrCpy $MESSAGE_1_ "$MESSAGE_1_ and install ${DISPLAYED_NAME} or Cancel to quit."
+	StrCpy $MESSAGE_2_ "$MESSAGE_0_$\r$\n"
+	StrCpy $MESSAGE_2_ "$MESSAGE_2_You are going to install an older release of ${CHECK_INSTALL_NAME}$\r$\n"
+	StrCpy $MESSAGE_2_ "$MESSAGE_2_$\r$\n"
+	StrCpy $MESSAGE_2_ "$MESSAGE_2_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
+	StrCpy $MESSAGE_2_ "$MESSAGE_2_ and install ${DISPLAYED_NAME} or Cancel to quit."
+	StrCpy $MESSAGE_3_ "$MESSAGE_0_$\r$\n"
+	StrCpy $MESSAGE_3_ "$MESSAGE_3_This is the latest release available.$\r$\n"
+	StrCpy $MESSAGE_3_ "$MESSAGE_3_$\r$\n"
+	StrCpy $MESSAGE_3_ "$MESSAGE_3_Press OK to reinstall ${DISPLAYED_NAME} or Cancel to quit."
+	IntOp $INSTALLED_SVN_REVISION $INSTALLED_SVN_REVISION * 1
+	IntOp $INSTALLED_BINARY_REVISION $INSTALLED_BINARY_REVISION * 1
+	IntOp $INSTALLED_VERSION $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
+	!define /math VERSION ${SVN_REVISION} + ${BINARY_REVISION}
+	${If} $INSTALLED_VERSION_NUMBER == ""
+	${Else}
+		${If} $INSTALLED_VERSION < ${VERSION}
+			MessageBox MB_OKCANCEL "$MESSAGE_1_" IDOK upgrade IDCANCEL quit_upgrade
+			upgrade:
+				StrCpy $ASK_FOR_PATH "NO"
+				ExecWait '"$UNINSTALL_STRING" _?=$INSTALL_PATH' $0
+				Goto continue_upgrade
+			quit_upgrade:
+				Abort
+			continue_upgrade:
+		${ElseIf} $INSTALLED_VERSION > ${VERSION}
+			MessageBox MB_OKCANCEL "$MESSAGE_2_" IDOK downgrade IDCANCEL quit_downgrade
+			downgrade:
+				Goto continue_downgrade
+			quit_downgrade:
+				Abort
+			continue_downgrade:
+		${ElseIf} $INSTALLED_VERSION = ${VERSION}
+			MessageBox MB_OKCANCEL "$MESSAGE_3_" IDOK reinstall IDCANCEL quit_reinstall
+			reinstall:
+				Goto continue_reinstall
+			quit_reinstall:
+				Abort
+			continue_reinstall:
+		${EndIf}
+	${EndIf}
+	${Else}
+		${If} $0 = 0
+		${Else}
+			Abort
+		${EndIf}
+	${EndIf}
+FunctionEnd
+;CheckUpdate Function
+;Check if to show the MUI_PAGE_DIRECTORY during the installation (to ask for the install PATH)
+Function CheckUpdate
+	${If} $ASK_FOR_PATH == "NO"
+		Abort
+	${EndIf}
+FunctionEnd
+;CheckInstDir Function
+;Check if GRASS is going to be installed in a directory containing spaces
+;if yes, show a warning message
+Function CheckInstDir
+	Var /GLOBAL INSTDIR_TEST
+	Var /GLOBAL INSTDIR_LENGHT
+	Var /GLOBAL INSTDIR_TEST_LENGHT
+	Var /GLOBAL MESSAGE_CHKINST_
+	StrCpy $MESSAGE_CHKINST_ "WARNING: you are about to install GRASS into a directory that has spaces$\r$\n"
+	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_in either its name or the path of directories leading up to it.$\r$\n"
+	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_Some functionalities of GRASS might be hampered by this. We would highly$\r$\n"
+	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_appreciate if you tried and reported any problems, so that we can fix them.$\r$\n"
+	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_However, if you want to avoid any such issues, we recommend that you$\r$\n"
+	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_choose a simple installation path without spaces, such as: C:\${GRASS_BASE}.$\r$\n"
+	${StrReplace} "$INSTDIR_TEST" " " "" "$INSTDIR"
+	StrLen $INSTDIR_LENGHT "$INSTDIR"
+	StrLen $INSTDIR_TEST_LENGHT "$INSTDIR_TEST"
+	${If} $INSTDIR_TEST_LENGHT < $INSTDIR_LENGHT
+		MessageBox MB_OK|MB_ICONEXCLAMATION "$MESSAGE_CHKINST_"
+	${EndIf}
+FunctionEnd
+;Interface Settings
+!define MUI_ABORTWARNING
+!define MUI_ICON ".\Installer-Files\Install_GRASS.ico"
+!define MUI_UNICON ".\Installer-Files\Uninstall_GRASS.ico"
+!define MUI_HEADERIMAGE_BITMAP_NOSTETCH ".\Installer-Files\InstallHeaderImage.bmp"
+!define MUI_HEADERIMAGE_UNBITMAP_NOSTRETCH ".\Installer-Files\UnInstallHeaderImage.bmp"
+!define MUI_WELCOMEFINISHPAGE_BITMAP ".\Installer-Files\WelcomeFinishPage.bmp"
+!define MUI_UNWELCOMEFINISHPAGE_BITMAP ".\Installer-Files\UnWelcomeFinishPage.bmp"
+;Installer Pages
+!insertmacro MUI_PAGE_WELCOME
+!insertmacro MUI_PAGE_LICENSE "${PACKAGE_FOLDER}\GPL.TXT"
+!define MUI_PAGE_CUSTOMFUNCTION_PRE CheckUpdate
+!insertmacro MUI_PAGE_DIRECTORY
+Page custom CheckInstDir
+!insertmacro MUI_PAGE_COMPONENTS
+!insertmacro MUI_PAGE_INSTFILES
+!insertmacro MUI_PAGE_FINISH
+!insertmacro MUI_UNPAGE_WELCOME
+!insertmacro MUI_UNPAGE_CONFIRM
+!insertmacro MUI_UNPAGE_INSTFILES
+!insertmacro MUI_UNPAGE_FINISH
+;Language files
+!insertmacro MUI_LANGUAGE "English"
+;Installer Sections
+;Declares the variables for optional Sample Data Sections
+Var /GLOBAL HTTP_PATH
+Var /GLOBAL ARCHIVE_NAME
+Var /GLOBAL EXTENDED_ARCHIVE_NAME
+Var /GLOBAL ORIGINAL_UNTAR_FOLDER
+Var /GLOBAL CUSTOM_UNTAR_FOLDER
+Var /GLOBAL ARCHIVE_SIZE_KB
+Var /GLOBAL ARCHIVE_SIZE_MB
+Var /GLOBAL DOWNLOAD_MESSAGE_
+Section "GRASS" SecGRASS
+	SectionIn RO
+	;Set the INSTALL_DIR variable
+	Var /GLOBAL INSTALL_DIR
+		StrCpy $INSTALL_DIR "$INSTALL_PATH"
+	${Else}
+		StrCpy $INSTALL_DIR "$INSTDIR"
+	${EndIf}
+	;Set to try to overwrite existing files
+	SetOverwrite try
+	;Set the GIS_DATABASE directory
+	SetShellVarContext current
+	Var /GLOBAL GIS_DATABASE
+	StrCpy $GIS_DATABASE "$DOCUMENTS\GIS DataBase"
+	;Create the GIS_DATABASE directory
+	CreateDirectory "$GIS_DATABASE"
+	;add Installer files
+	SetOutPath "$INSTALL_DIR\icons"
+	File .\Installer-Files\GRASS.ico
+	File .\Installer-Files\GRASS_Web.ico
+	File .\Installer-Files\GRASS_CMD.ico
+	File .\Installer-Files\MSYS_Custom_Icon.ico
+	File .\Installer-Files\WinGRASS.ico
+	SetOutPath "$INSTALL_DIR"
+	File .\Installer-Files\GRASS-WebSite.url
+	File .\Installer-Files\WinGRASS-README.url
+	;add GRASS files
+	File /r ${PACKAGE_FOLDER}\*.*
+	;Install demolocation into the GIS_DATABASE directory
+	SetOutPath "$GIS_DATABASE\demolocation"
+	File /r ${DEMOLOCATION_PATH}\*.*
+	;Create the Uninstaller
+	WriteUninstaller "$INSTALL_DIR\Uninstall-GRASS.exe"
+	;Registry Key Entries
+	;HKEY_LOCAL_MACHINE Install entries
+	;Set the Name, Version and Revision of GRASS + PublisherInfo + InstallPath
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "Name" "GRASS"
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "VersionNumber" "${VERSION_NUMBER}"
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "SvnRevision" "${SVN_REVISION}"
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "BinaryRevision" "${BINARY_REVISION}"
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "WebSite" "${WEB_SITE}"
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "InstallPath" "$INSTALL_DIR"
+	;HKEY_LOCAL_MACHINE Uninstall entries
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayName" "GRASS"
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString" "$INSTALL_DIR\Uninstall-GRASS.exe"
+		WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"\
+		"DisplayVersion" "${VERSION_NUMBER}-${BINARY_REVISION}"
+	!else
+		"DisplayVersion" "${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
+	!endif
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayIcon" "$INSTALL_DIR\icons\GRASS.ico"
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "EstimatedSize" 1
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "HelpLink" "${WIKI_PAGE}"
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "URLInfoAbout" "${WEB_SITE}"
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
+	;Create the Desktop Shortcut
+	CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wxpython"\
+	"$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER}"
+	CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER} msys.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
+	"$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with msys Terminal"
+	;Create the Windows Start Menu Shortcuts
+	SetShellVarContext all
+	CreateDirectory "$SMPROGRAMS\${GRASS_BASE}"
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Old GUI.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-tcltk"\
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wxpython"\
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Command Line.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-text"\
+	"$INSTALL_DIR\icons\GRASS_CMD.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS in Text Mode on the Command Line"
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS MSYS Console.lnk" "$INSTALL_DIR\msys\msys.bat" ""\
+	"$INSTALL_DIR\icons\MSYS_Custom_Icon.ico" "" SW_SHOWNORMAL "" "Open the GRASS MSYS Console"
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Web Site.lnk" "$INSTALL_DIR\GRASS-WebSite.url" ""\
+	"$INSTALL_DIR\icons\GRASS_Web.ico" "" SW_SHOWNORMAL "" "Visit the GRASS Web Site"
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} msys.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
+		CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Release Notes.lnk" "$INSTALL_DIR\WinGRASS-README.url" ""\
+		"$INSTALL_DIR\icons\WinGRASS.ico" "" SW_SHOWNORMAL "" "Visit the WinGRASS Project Web Page"
+	!endif
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Uninstall GRASS.lnk" "$INSTALL_DIR\Uninstall-GRASS.exe" ""\
+	"$INSTALL_DIR\Uninstall-GRASS.exe" "" SW_SHOWNORMAL "" "Uninstall GRASS ${VERSION_NUMBER}"
+	;Create the grass_command.bat
+	ClearErrors
+	FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}.bat w
+	IfErrors done_create_grass_command.bat
+	FileWrite $0 '@echo off$\r$\n'
+	FileWrite $0 'rem #########################################################################$\r$\n'
+	FileWrite $0 'rem #$\r$\n'
+	FileWrite $0 'rem # File dynamically created by NSIS installer script;$\r$\n'
+	FileWrite $0 'rem # Written by Marco Pasetti;$\r$\n'
+	FileWrite $0 'rem # GRASS Initialization$\r$\n'
+	FileWrite $0 '$\r$\n'
+	FileWrite $0 'rem *******Environment variables***********$\r$\n'
+	FileWrite $0 'rem Set GRASS Installation Directory Variable$\r$\n'
+	FileWrite $0 'set GRASSDIR=$INSTALL_DIR$\r$\n'
+	FileWrite $0 'rem Directory where your .grassrc6 file will be stored$\r$\n'
+	FileWrite $0 'set HOME=%USERPROFILE%$\r$\n'
+	FileWrite $0 'rem Name of the wish (Tk) executable$\r$\n'
+	FileWrite $0 'set GRASS_WISH=wish.exe$\r$\n'
+	FileWrite $0 'rem Path to the shell command$\r$\n'
+	FileWrite $0 'set GRASS_SH=%GRASSDIR%\msys\bin\sh.exe$\r$\n'
+	FileWrite $0 'rem Set Path to utilities (libraries and bynaries) used by GRASS$\r$\n'
+	FileWrite $0 'set PATH=%GRASSDIR%\msys\bin;%PATH%$\r$\n'
+	FileWrite $0 'set PATH=%GRASSDIR%\extrabin;%GRASSDIR%\extralib;%PATH%$\r$\n'
+	FileWrite $0 'set PATH=%GRASSDIR%\tcl-tk\bin;%GRASSDIR%\sqlite\bin;%GRASSDIR%\gpsbabel;%PATH%$\r$\n'
+	FileWrite $0 'rem Set Path to MSIE web browser$\r$\n'
+	FileWrite $0 'set GRASS_HTML_BROWSER=%PROGRAMFILES%/Internet Explorer/iexplore.exe$\r$\n'
+	FileWrite $0 'rem Path to the proj files (notably the epsg projection list)$\r$\n'
+	FileWrite $0 'set GRASS_PROJSHARE=%GRASSDIR%\proj$\r$\n'
+	FileWrite $0 'rem Path to the python directory$\r$\n'
+	FileWrite $0 'set PYTHONHOME=%GRASSDIR%\Python25$\r$\n'
+	FileWrite $0 'set WINGISBASE=%GRASSDIR%$\r$\n'
+	FileWrite $0 '"%WINGISBASE%\etc\init.bat" %*'
+	FileClose $0
+	done_create_grass_command.bat:
+	;Set the UNIX_LIKE GRASS Path
+	Var /GLOBAL UNIX_LIKE_DRIVE
+	Var /GLOBAL UNIX_LIKE_GRASS_PATH
+	StrCpy $UNIX_LIKE_DRIVE "$INSTALL_DIR" 3
+	StrCpy $UNIX_LIKE_GRASS_PATH "$INSTALL_DIR" "" 3
+	;replace "\" with "/" in $UNIX_LIKE_DRIVE
+	${StrReplace} "$UNIX_LIKE_DRIVE" "\" "/" "$UNIX_LIKE_DRIVE"
+	;replace ":" with "" in $UNIX_LIKE_DRIVE
+	${StrReplace} "$UNIX_LIKE_DRIVE" ":" "" "$UNIX_LIKE_DRIVE"
+	;replace "\" with "/" in $UNIX_LIKE_GRASS_PATH
+	${StrReplace} "$UNIX_LIKE_GRASS_PATH" "\" "/" "$UNIX_LIKE_GRASS_PATH"
+	;Set the USERNAME variable
+	Var /GLOBAL USERNAME
+	Var /GLOBAL PROFILE_DRIVE
+	Var /GLOBAL PROFILE_ROOT
+	;It first searches for the Key Regestry value "Logon User Name" in HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer"
+	ReadRegStr $USERNAME HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer" "Logon User Name"
+	;If the Key Registry value is empty, it uses a work around, retrieving the Username string from the System User Profile variable ($PROFILE)
+	;It first read the $PROFILE variable, to scan the OS version:
+	;If equal to "drive:\Users\UserName", the OS is Vista, and the $USERNAME variable set to $PROFILE -  "drive:\Users\"
+	;If not, the OS is XP or previous, and the $USERNAME variable set to $PROFILE -  "drive:\Documents and Settings\"
+	${If} $USERNAME = ""
+		StrCpy $PROFILE_DRIVE "$PROFILE" 2
+		StrCpy $PROFILE_ROOT "$PROFILE" 5 -3
+		${If} $USERNAME = "Users"
+			${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Users\" "" "$PROFILE"
+		${Else}
+			${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Documents and Settings\" "" "$PROFILE"
+		${EndIf}
+	${EndIf}
+	;Create the $INSTALL_DIR\msys\home and the $INSTALL_DIR\msys\home\$USERNAME directories
+	CreateDirectory $INSTALL_DIR\msys\home
+	CreateDirectory $INSTALL_DIR\msys\home\$USERNAME
+	;create the $INSTALL_DIR\bin grass_command
+	ClearErrors
+	FileOpen $0 $INSTALL_DIR\bin\${GRASS_COMMAND} w
+	FileWrite $0 '#! /bin/sh$\r$\n'
+	FileWrite $0 '#########################################################################$\r$\n'
+	FileWrite $0 '#$\r$\n'
+	FileWrite $0 '# File dynamically created by NSIS installer script;$\r$\n'
+	FileWrite $0 '# Written by Marco Pasetti;$\r$\n'
+	FileWrite $0 '# MODULE:   	GRASS Initialization$\r$\n'
+	FileWrite $0 '# AUTHOR(S):	Justin Hickey - Thailand - jhickey at hpcc.nectec.or.th$\r$\n'
+	FileWrite $0 '# PURPOSE:  	The source file for this shell script is in$\r$\n'
+	FileWrite $0 '#   	    	lib/init/grass.src and is the grass startup script. It$\r$\n'
+	FileWrite $0 '#   	    	requires a source file because the definition of GISBASE$\r$\n'
+	FileWrite $0 '#   	    	is not known until compile time and is substituted from the$\r$\n'
+	FileWrite $0 '#   	    	Makefile. Any command line options are passed to Init.sh.$\r$\n'
+	FileWrite $0 '# COPYRIGHT:    (C) 2000-2005 by the GRASS Development Team$\r$\n'
+	FileWrite $0 '#               This program is free software under the GNU General Public$\r$\n'
+	FileWrite $0 '#   	    	License (>=v2). Read the file COPYING that comes with GRASS$\r$\n'
+	FileWrite $0 '#   	    	for details.$\r$\n'
+	FileWrite $0 '# Modified by Marco Pasetti$\r$\n'
+	FileWrite $0 '# added the export PATH instruction to let GRASS work from$\r$\n'
+	FileWrite $0 '# the MSYS environment in the dynamic NSIS installation$\r$\n'
+	FileWrite $0 'trap "echo '
+	FileWrite $0 "'User break!' ; "
+	FileWrite $0 'exit" 2 3 9 15$\r$\n'
+	FileWrite $0 '# Set the GISBASE variable$\r$\n'
+	FileWrite $0 'GISBASE=/$UNIX_LIKE_DRIVE$UNIX_LIKE_GRASS_PATH$\r$\n'
+	FileWrite $0 'export GISBASE$\r$\n'
+	FileWrite $0 '# Set the PATH variable$\r$\n'
+	FileWrite $0 'PATH="$$GISBASE/extrabin:$$GISBASE/extralib:$$PATH"$\r$\n'
+	FileWrite $0 'PATH="$$GISBASE/tcl-tk/bin:$$GISBASE/sqlite/bin:$$GISBASE/gpsbabel:$$PATH"$\r$\n'
+	FileWrite $0 'export PATH$\r$\n'
+	FileWrite $0 '# Set the PYTHONPATH variable$\r$\n'
+	FileWrite $0 'PYTHONPATH="$$GISBASE/etc/python:$$GISBASE/Python25:$$PYTHONPATH"$\r$\n'
+	FileWrite $0 'export PYTHONPATH$\r$\n'
+	FileWrite $0 'PYTHONHOME="$INSTALL_DIR\Python25"$\r$\n'
+	FileWrite $0 'export PYTHONHOME$\r$\n'
+	FileWrite $0 '# Set the GRASS_PROJSHARE variable$\r$\n'
+	FileWrite $0 'GRASS_PROJSHARE="$INSTALL_DIR\proj"$\r$\n'
+	FileWrite $0 'export GRASS_PROJSHARE$\r$\n'
+	FileWrite $0 'exec "$$GISBASE/etc/Init.sh" "$$@"'
+	FileClose $0
+	done_create_grass_command:
+	;Create the $INSTALL_DIR\msys\grass link directory
+	CreateDirectory $INSTALL_DIR\msys\grass
+	;create the $INSTALL_DIR\msys\etc\fstab with the main grass dir mount info
+	ClearErrors
+	FileOpen $0 $INSTALL_DIR\msys\etc\fstab w
+	IfErrors done_create_fstab
+	FileWrite $0 '$INSTALL_DIR   /grass$\r$\n'
+	FileClose $0
+	done_create_fstab:
+	;Set the Unix-Like GIS_DATABASE Path
+	Var /GLOBAL UNIX_LIKE_GIS_DATABASE_PATH
+	;replace \ with / in $GIS_DATABASE
+	${StrReplace} "$UNIX_LIKE_GIS_DATABASE_PATH" "\" "/" "$GIS_DATABASE"
+	;create $PROFILE\.grassrc6
+	ClearErrors
+	FileOpen $0 $PROFILE\.grassrc6 w
+	IfErrors done_create_.grassrc6
+	FileWrite $0 'GISDBASE: $UNIX_LIKE_GIS_DATABASE_PATH$\r$\n'
+	FileWrite $0 'LOCATION_NAME: demolocation$\r$\n'
+	FileWrite $0 'MAPSET: PERMANENT$\r$\n'
+	FileClose $0
+	done_create_.grassrc6:
+	CopyFiles $PROFILE\.grassrc6 $INSTALL_DIR\msys\home\$USERNAME
+SectionEnd
+Function DownloadDataSet
+	IntOp $ARCHIVE_SIZE_MB $ARCHIVE_SIZE_KB / 1024
+	StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME sample data set.$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The archive is about $ARCHIVE_SIZE_MB MB and may take"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ several minutes to be downloaded.$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The $EXTENDED_ARCHIVE_NAME will be copyed to:$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER.$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue or Cancel to skip the download and complete the GRASS"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME data set.$\r$\n"
+	MessageBox MB_OKCANCEL "$DOWNLOAD_MESSAGE_" IDOK download IDCANCEL cancel_download
+	download:
+	InitPluginsDir
+	NSISdl::download "$HTTP_PATH/$ARCHIVE_NAME" "$TEMP\$ARCHIVE_NAME"
+	Pop $0
+	StrCmp $0 "success" download_ok download_failed
+	download_ok:
+	InitPluginsDir
+	untgz::extract "-d" "$GIS_DATABASE" "$TEMP\$ARCHIVE_NAME"
+	Pop $0
+	StrCmp $0 "success" untar_ok untar_failed
+	untar_ok:
+	Rename "$GIS_DATABASE\$ORIGINAL_UNTAR_FOLDER" "$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER"
+	Delete "$TEMP\$ARCHIVE_NAME"
+	Goto end
+	download_failed:
+	DetailPrint "$0" ;print error message to log
+	MessageBox MB_OK "Download Failed.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
+	Goto end
+	cancel_download:
+	MessageBox MB_OK "Download Cancelled.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
+	Goto end
+	untar_failed:
+	end:
+FunctionEnd
+Section /O "North Carolina Data Set" SecNorthCarolinaSDB
+	;Set the size (in KB)  of the archive file
+	StrCpy $ARCHIVE_SIZE_KB 138629
+	;Set the size (in KB) of the unpacked archive file
+	AddSize 293314
+  	StrCpy $HTTP_PATH "http://grass.osgeo.org/sampledata"
+	StrCpy $ARCHIVE_NAME "nc_spm_latest.tar.gz"
+	StrCpy $EXTENDED_ARCHIVE_NAME "North Carolina"
+	StrCpy $ORIGINAL_UNTAR_FOLDER "nc_spm_08"
+	StrCpy $CUSTOM_UNTAR_FOLDER "North-Carolina"
+	Call DownloadDataSet
+SectionEnd
+Section /O "South Dakota (Spearfish) Data Set" SecSpearfishSDB
+	StrCpy $ARCHIVE_SIZE_KB 20803
+	AddSize 42171
+	StrCpy $ARCHIVE_NAME "spearfish_grass60data-0.3.tar.gz"
+	StrCpy $EXTENDED_ARCHIVE_NAME "South Dakota (Spearfish)"
+	StrCpy $ORIGINAL_UNTAR_FOLDER "spearfish60"
+	StrCpy $CUSTOM_UNTAR_FOLDER "Spearfish60"
+SectionEnd
+;Uninstaller Section
+Section "Uninstall"
+	;remove files
+	Delete "$INSTDIR\Uninstall-GRASS.exe"
+	Delete "$INSTDIR\GPL.TXT"
+	Delete "$INSTDIR\AUTHORS"
+	Delete "$INSTDIR\CHANGES"
+	Delete "$INSTDIR\COPYING"
+	Delete "$INSTDIR\${GRASS_COMMAND}.bat"
+	Delete "$INSTDIR\GRASS-WebSite.url"
+	Delete "$INSTDIR\WinGRASS-README.url"
+	Delete "$INSTDIR\REQUIREMENTS.html"
+	;remove folders
+	RMDir /r "$INSTDIR\bin"
+	RMDir /r "$INSTDIR\bwidget"
+	RMDir /r "$INSTDIR\docs"
+	RMDir /r "$INSTDIR\driver"
+	RMDir /r "$INSTDIR\etc"
+	RMDir /r "$INSTDIR\extrabin"
+	RMDir /r "$INSTDIR\extralib"
+	RMDir /r "$INSTDIR\fonts"
+	RMDir /r "$INSTDIR\gpsbabel"
+	RMDir /r "$INSTDIR\icons"
+	RMDir /r "$INSTDIR\include"
+	RMDir /r "$INSTDIR\lib"
+	RMDir /r "$INSTDIR\locale"
+	RMDir /r "$INSTDIR\msys"
+	RMDir /r "$INSTDIR\proj"
+	RMDir /r "$INSTDIR\Python25"
+	RMDir /r "$INSTDIR\scripts"
+	RMDir /r "$INSTDIR\sqlite"
+	RMDir /r "$INSTDIR\tcl-tk"
+	;if empty, remove the install folder
+	RMDir "$INSTDIR"
+	;remove the Desktop ShortCut
+	Delete "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk"
+	Delete "$DESKTOP\GRASS ${VERSION_NUMBER} msys.lnk"
+	;remove the Programs Start ShortCuts
+	RMDir /r "$SMPROGRAMS\${GRASS_BASE}"
+	;remove the .grassrc6 file
+	Delete "$PROFILE\.grassrc6"
+	;remove the Registry Entries
+	DeleteRegKey HKLM "Software\${GRASS_BASE}"
+	DeleteRegKey HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"
+SectionEnd
+;Installer Section Descriptions
+!insertmacro MUI_FUNCTION_DESCRIPTION_BEGIN
+	!insertmacro MUI_DESCRIPTION_TEXT ${SecGRASS} "Install GRASS ${VERSION_NUMBER}"
+	!insertmacro MUI_DESCRIPTION_TEXT ${SecNorthCarolinaSDB} "Download and install the North Carolina sample data set"
+	!insertmacro MUI_DESCRIPTION_TEXT ${SecSpearfishSDB} "Download and install the South Dakota (Spearfish) sample data set"
+!insertmacro MUI_FUNCTION_DESCRIPTION_END
Property changes on: grass/trunk/mswindows/GRASS-Installer.nsi
___________________________________________________________________
   + native
Modified: grass/trunk/mswindows/GRASS-Packager.bat
--- grass/trunk/mswindows/GRASS-Packager.bat	2009-05-11 05:22:21 UTC (rev 37145)
+++ grass/trunk/mswindows/GRASS-Packager.bat	2009-05-11 05:27:39 UTC (rev 37146)
@@ -1,211 +1,211 @@
- at echo off
-rem --------------------------------------------------------------------------------------------------------------------------
-rem Set the script variables
-set GRASS_RELEASE_PACKAGE_DIR=.\GRASS-Release-Package
-set GRASS_6_DEV_PACKAGE_DIR=.\GRASS-6-Dev-Package
-set GRASS_7_DEV_PACKAGE_DIR=.\GRASS-7-Dev-Package
-set OSGEO4W_DIR=c:\osgeo4w
-set GRASS_RELEASE_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-6.4.0RC4
-set GRASS_6_DEV_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-6.5.svn
-set GRASS_7_DEV_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-7.0.svn
- at echo -----------------------------------------------------------------------------------------------------------------------
- at echo Self Contained GRASS Automated Packager
- at echo Edited by: Marco Pasetti
- at echo Revised for OSGeo4W by: Colin Nielsen
- at echo Last Update: 30 March 2009
- at echo Select the GRASS version to pack:
- at echo.
- at echo 1. Current GRASS Release Version
- at echo.
- at echo 2. Current GRASS-6 Development Version
- at echo.
- at echo 3. Current GRASS-7 Development Version
- at echo.
-set /p SELECTION=Enter your selection (1/2/3):
-if %SELECTION%==1 (
-set PACKAGE_DIR=%GRASS_RELEASE_PACKAGE_DIR%
-set GRASS_PREFIX=%GRASS_RELEASE_INSTALL_FOLDER%
-if %SELECTION%==2 (
-set PACKAGE_DIR=%GRASS_6_DEV_PACKAGE_DIR%
-set GRASS_PREFIX=%GRASS_6_DEV_INSTALL_FOLDER%
-if %SELECTION%==3 (
-set PACKAGE_DIR=%GRASS_7_DEV_PACKAGE_DIR%
-set GRASS_PREFIX=%GRASS_7_DEV_INSTALL_FOLDER%
- at echo.
- at echo Remove the previous Selected Package and create a new PACKAGE_DIR
- at echo.
-pause
-if exist %PACKAGE_DIR% rmdir /S/Q %PACKAGE_DIR%
-mkdir %PACKAGE_DIR%
- at echo.
- at echo Copy %GRASS_PREFIX% content to PACKAGE_DIR
- at echo.
-xcopy %GRASS_PREFIX% %PACKAGE_DIR% /S/V/F
- at echo.
- at echo Copy Extralibs to PACKAGE_DIR\extralib
- at echo.
-mkdir %PACKAGE_DIR%\extralib
-copy %OSGEO4W_DIR%\bin\*.dll %PACKAGE_DIR%\extralib
-rem copy %OSGEO4W_DIR%\pgsql\lib\libpq.dll %PACKAGE_DIR%\extralib
- at echo.
- at echo Copy Extrabins to PACKAGE_DIR\extrabin
- at echo.
-mkdir %PACKAGE_DIR%\extrabin
-copy %OSGEO4W_DIR%\bin\*.exe %PACKAGE_DIR%\extrabin
- at echo.
- at echo Copy SQLite content to PACKAGE_DIR\sqlite
- at echo.
-mkdir %PACKAGE_DIR%\sqlite
-mkdir %PACKAGE_DIR%\sqlite\bin
-mkdir %PACKAGE_DIR%\sqlite\include
-mkdir %PACKAGE_DIR%\sqlite\lib
-xcopy %OSGEO4W_DIR%\bin\sqlite3.dll %PACKAGE_DIR%\sqlite\bin /S/V/F/I
-copy %OSGEO4W_DIR%\include\btree.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\fts1*.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\hash.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\keywordhash.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\opcodes.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\os.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\os_common.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\pager.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\parse.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\sqlite*.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\vdbe.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\vdbeInt.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\lib\sqlite3_i.lib %PACKAGE_DIR%\sqlite\lib
- at echo.
- at echo Copy GPSBABEL executable and dll to PACKAGE_DIR\gpsbabel
- at echo.
-mkdir %PACKAGE_DIR%\gpsbabel
-copy %OSGEO4W_DIR%\gpsbabel.exe %PACKAGE_DIR%\gpsbabel
-rem copy %OSGEO4W_DIR%\libexpat.dll %PACKAGE_DIR%\gpsbabel
- at echo.
- at echo Copy shared PROJ.4 files to PACKAGE_DIR\proj
- at echo.
-xcopy %OSGEO4W_DIR%\share\proj %PACKAGE_DIR%\proj /S/V/F/I
- at echo.
- at echo Copy Tcl/Tk content to PACKAGE_DIR\tcl-tk
- at echo.
-mkdir %PACKAGE_DIR%\tcl-tk
-mkdir %PACKAGE_DIR%\tcl-tk\bin
-mkdir %PACKAGE_DIR%\tcl-tk\include
-mkdir %PACKAGE_DIR%\tcl-tk\lib
-mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
-mkdir %PACKAGE_DIR%\tcl-tk\lib\tk8.5
-xcopy %OSGEO4W_DIR%\bin\tclpip85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tcl85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tclsh.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tclsh85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tk85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\wish.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\wish85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-copy %OSGEO4W_DIR%\include\tcl*.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\tk*.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\tommath_class.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\tommath_superclass.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\ttkDecls.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\lib\tcl8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
-copy %OSGEO4W_DIR%\lib\tcl8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
-copy %OSGEO4W_DIR%\lib\tk8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tk8.5
-copy %OSGEO4W_DIR%\lib\tk8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tk8.5
-xcopy %OSGEO4W_DIR%\lib\tk8.5\ttk %PACKAGE_DIR%\tcl-tk\lib\tk8.5\ttk /S/V/F/I
- at echo.
- at echo Copy MSYS files to PACKAGE_DIR\msys
- at echo.
-mkdir %PACKAGE_DIR%\msys
-copy %OSGEO4W_DIR%\apps\msys\* %PACKAGE_DIR%\msys
-xcopy %OSGEO4W_DIR%\apps\msys\bin %PACKAGE_DIR%\msys\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\doc %PACKAGE_DIR%\msys\doc /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\etc %PACKAGE_DIR%\msys\etc /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\info %PACKAGE_DIR%\msys\info /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\lib %PACKAGE_DIR%\msys\lib /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\man %PACKAGE_DIR%\msys\man /S/V/F/I
-del %OSGEO4W_DIR%\apps\msys\etc\fstab
- at echo.
- at echo Copy Python content to PACKAGE_DIR\Python25
- at echo.
-mkdir %PACKAGE_DIR%\Python25
-copy %OSGEO4W_DIR%\apps\Python25\* %PACKAGE_DIR%\Python25
-xcopy %OSGEO4W_DIR%\apps\Python25\DLLs %PACKAGE_DIR%\Python25\DLLs /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python25\include %PACKAGE_DIR%\Python25\include /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python25\Lib %PACKAGE_DIR%\Python25\Lib /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python25\libs %PACKAGE_DIR%\Python25\libs /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python25\Scripts %PACKAGE_DIR%\Python25\Scripts /S/V/F/I
- at echo.
- at echo Packaging Completed
- at echo Remove lines 11-16 from %PACKAGE_DIR%\msys\msys.bat
- at echo.
-pause
+ at echo off
+rem --------------------------------------------------------------------------------------------------------------------------
+rem Set the script variables
+set GRASS_RELEASE_PACKAGE_DIR=.\GRASS-Release-Package
+set GRASS_6_DEV_PACKAGE_DIR=.\GRASS-6-Dev-Package
+set GRASS_7_DEV_PACKAGE_DIR=.\GRASS-7-Dev-Package
+set OSGEO4W_DIR=c:\osgeo4w
+set GRASS_RELEASE_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-6.4.0RC4
+set GRASS_6_DEV_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-6.5.svn
+set GRASS_7_DEV_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-7.0.svn
+ at echo -----------------------------------------------------------------------------------------------------------------------
+ at echo Self Contained GRASS Automated Packager
+ at echo Edited by: Marco Pasetti
+ at echo Revised for OSGeo4W by: Colin Nielsen
+ at echo Last Update: 30 March 2009
+ at echo Select the GRASS version to pack:
+ at echo.
+ at echo 1. Current GRASS Release Version
+ at echo.
+ at echo 2. Current GRASS-6 Development Version
+ at echo.
+ at echo 3. Current GRASS-7 Development Version
+ at echo.
+set /p SELECTION=Enter your selection (1/2/3):
+if %SELECTION%==1 (
+set PACKAGE_DIR=%GRASS_RELEASE_PACKAGE_DIR%
+set GRASS_PREFIX=%GRASS_RELEASE_INSTALL_FOLDER%
+if %SELECTION%==2 (
+set PACKAGE_DIR=%GRASS_6_DEV_PACKAGE_DIR%
+set GRASS_PREFIX=%GRASS_6_DEV_INSTALL_FOLDER%
+if %SELECTION%==3 (
+set PACKAGE_DIR=%GRASS_7_DEV_PACKAGE_DIR%
+set GRASS_PREFIX=%GRASS_7_DEV_INSTALL_FOLDER%
+ at echo.
+ at echo Remove the previous Selected Package and create a new PACKAGE_DIR
+ at echo.
+pause
+if exist %PACKAGE_DIR% rmdir /S/Q %PACKAGE_DIR%
+mkdir %PACKAGE_DIR%
+ at echo.
+ at echo Copy %GRASS_PREFIX% content to PACKAGE_DIR
+ at echo.
+xcopy %GRASS_PREFIX% %PACKAGE_DIR% /S/V/F
+ at echo.
+ at echo Copy Extralibs to PACKAGE_DIR\extralib
+ at echo.
+mkdir %PACKAGE_DIR%\extralib
+copy %OSGEO4W_DIR%\bin\*.dll %PACKAGE_DIR%\extralib
+rem copy %OSGEO4W_DIR%\pgsql\lib\libpq.dll %PACKAGE_DIR%\extralib
+ at echo.
+ at echo Copy Extrabins to PACKAGE_DIR\extrabin
+ at echo.
+mkdir %PACKAGE_DIR%\extrabin
+copy %OSGEO4W_DIR%\bin\*.exe %PACKAGE_DIR%\extrabin
+ at echo.
+ at echo Copy SQLite content to PACKAGE_DIR\sqlite
+ at echo.
+mkdir %PACKAGE_DIR%\sqlite
+mkdir %PACKAGE_DIR%\sqlite\bin
+mkdir %PACKAGE_DIR%\sqlite\include
+mkdir %PACKAGE_DIR%\sqlite\lib
+xcopy %OSGEO4W_DIR%\bin\sqlite3.dll %PACKAGE_DIR%\sqlite\bin /S/V/F/I
+copy %OSGEO4W_DIR%\include\btree.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\fts1*.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\hash.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\keywordhash.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\opcodes.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\os.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\os_common.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\pager.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\parse.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\sqlite*.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\vdbe.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\vdbeInt.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\lib\sqlite3_i.lib %PACKAGE_DIR%\sqlite\lib
+ at echo.
+ at echo Copy GPSBABEL executable and dll to PACKAGE_DIR\gpsbabel
+ at echo.
+mkdir %PACKAGE_DIR%\gpsbabel
+copy %OSGEO4W_DIR%\gpsbabel.exe %PACKAGE_DIR%\gpsbabel
+rem copy %OSGEO4W_DIR%\libexpat.dll %PACKAGE_DIR%\gpsbabel
+ at echo.
+ at echo Copy shared PROJ.4 files to PACKAGE_DIR\proj
+ at echo.
+xcopy %OSGEO4W_DIR%\share\proj %PACKAGE_DIR%\proj /S/V/F/I
+ at echo.
+ at echo Copy Tcl/Tk content to PACKAGE_DIR\tcl-tk
+ at echo.
+mkdir %PACKAGE_DIR%\tcl-tk
+mkdir %PACKAGE_DIR%\tcl-tk\bin
+mkdir %PACKAGE_DIR%\tcl-tk\include
+mkdir %PACKAGE_DIR%\tcl-tk\lib
+mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
+mkdir %PACKAGE_DIR%\tcl-tk\lib\tk8.5
+xcopy %OSGEO4W_DIR%\bin\tclpip85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tcl85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tclsh.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tclsh85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tk85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\wish.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\wish85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+copy %OSGEO4W_DIR%\include\tcl*.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\tk*.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\tommath_class.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\tommath_superclass.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\ttkDecls.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\lib\tcl8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
+copy %OSGEO4W_DIR%\lib\tcl8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
+copy %OSGEO4W_DIR%\lib\tk8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tk8.5
+copy %OSGEO4W_DIR%\lib\tk8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tk8.5
+xcopy %OSGEO4W_DIR%\lib\tk8.5\ttk %PACKAGE_DIR%\tcl-tk\lib\tk8.5\ttk /S/V/F/I
+ at echo.
+ at echo Copy MSYS files to PACKAGE_DIR\msys
+ at echo.
+mkdir %PACKAGE_DIR%\msys
+copy %OSGEO4W_DIR%\apps\msys\* %PACKAGE_DIR%\msys
+xcopy %OSGEO4W_DIR%\apps\msys\bin %PACKAGE_DIR%\msys\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\doc %PACKAGE_DIR%\msys\doc /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\etc %PACKAGE_DIR%\msys\etc /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\info %PACKAGE_DIR%\msys\info /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\lib %PACKAGE_DIR%\msys\lib /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\man %PACKAGE_DIR%\msys\man /S/V/F/I
+del %OSGEO4W_DIR%\apps\msys\etc\fstab
+ at echo.
+ at echo Copy Python content to PACKAGE_DIR\Python25
+ at echo.
+mkdir %PACKAGE_DIR%\Python25
+copy %OSGEO4W_DIR%\apps\Python25\* %PACKAGE_DIR%\Python25
+xcopy %OSGEO4W_DIR%\apps\Python25\DLLs %PACKAGE_DIR%\Python25\DLLs /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python25\include %PACKAGE_DIR%\Python25\include /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python25\Lib %PACKAGE_DIR%\Python25\Lib /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python25\libs %PACKAGE_DIR%\Python25\libs /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python25\Scripts %PACKAGE_DIR%\Python25\Scripts /S/V/F/I
+ at echo.
+ at echo Packaging Completed
+ at echo Remove lines 11-16 from %PACKAGE_DIR%\msys\msys.bat
+ at echo.
+pause
Property changes on: grass/trunk/mswindows/GRASS-Packager.bat
   + native
Modified: grass/trunk/mswindows/README.html
--- grass/trunk/mswindows/README.html	2009-05-11 05:22:21 UTC (rev 37145)
+++ grass/trunk/mswindows/README.html	2009-05-11 05:27:39 UTC (rev 37146)
@@ -1,292 +1,292 @@
-<html>
-<head>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
-<meta http-equiv="Content-Language" content="en" />
-<meta name="Author" content="Marco Pasetti" />
-<meta name="Description" content="SVN mswindows README" />
-<title>SVN mswindows README</title>
-<style type="text/css" />
-/* Wiki Pages Styles */
-/* TableOfContents */
-.table-of-contents	{
-					border: 1px solid #bbbbbb;
-					color: black; background-color: #eeeeee;
-					font-size: small;
-					text-align:left;
-					margin: 0.5em; padding-left: 1em;
-					width: 360;
-/* Contents */
-html	{
-		background-color: white;
-		color: black;
-		font-family: Arial, Lucida Grande, sans-serif;
-		font-size: 10pt;
-body	{
-		margin: 30;
-ol	{
-	font-size: 10pt;
-	margin-top: 0;
-	margin-bottom: 0;
-	margin-left: 0;
-h1	{
-	font-size: 18pt;
-	margin-top: 0;
-	margin-bottom: 50;
-h2	{
-	font-size: 16pt;
-	margin-top: 60;
-	margin-bottom: 20;
-h3	{
-	font-size: 14pt;
-	margin-top: 60;
-h4	{
-	font-size: 11pt;
-	margin-top: 0;
-	margin-bottom: 0;
-p	{
-	font-size: 10pt;
-	margin-top: 10;
-	margin-bottom: 10;
-code	{
-		font-family: Courier-new, monospace;
-		font-size: 10pt;
-		margin-top: 10;
-pre	{
-	padding: 1em;
-	border: 1px dashed #2f6fab;
-	color: black;
-	background-color: #f9f9f9;
-	line-height: 1.1em;
-/* Tables */
-table
-	margin: 0.5em 0 0 0.5em;
-	border-collapse: collapse;
-td
-	padding: 0.25em 0.5em 0.25em 0.5em;
-	border: 0pt solid #ADB9CC;
-	font-size: 10pt;
-/* Links */
-a	{
-	text-decoration: none;
-	color: #002bb8;
-	background: none;
-a:hover {
-		text-decoration: underline;
-		color: green;
-a:visited:hover	{
-				color: red;
-</style>
-</head>
-<body>
-<h1>How to prepare a WinGRASS Release</h1>
-<div class="table-of-contents">
-<p><strong>Table of Contents</strong></p>
-<p><a href="#Introduction">Introduction</a></p>
-<p><ol>
-<li><a href="#Install OSGeo4w Tree and Compile Grass">Install OSGeo4w Tree and Compile Grass</a></li>
-<li><a href="#Create a GRASS self-contained Package">Create a GRASS self-contained Package</a></li>
-<li><a href="#Remove OSGeo4W Traces from Package">Remove OSGeo4W Traces from Package</a></li>
-<li><a href="#Install NSIS">Install NSIS</a></li>
-<li><a href="#Install NSIS: Untgz Plugin">Install NSIS: Untgz Plugin</a></li>
-<li><a href="#Create the WinGRASS Installer">Create the WinGRASS Installer</a></li>
-</ol></p>
-<p><a href="#Credits and Contacts">Credits and Contacts</a></p>
-<br>
-</div>
-<div id="Introduction">
-<p><h3>Introduction</h3></p>
-<p>This document explains how to prepare a WinGRASS release (as a self-contained package installer) using the scripts contained
-in the mswindows folder. In order to avoid mistakes or misunderstandings, we highly recommend to follow each step and command
-exactly as they are written in this document.</p>
-</div>
-<div id="Install OSGeo4w Tree and Compile Grass">
-<p><h3>1. Install OSGeo4w Tree and Compile Grass</h3></p>
-<p>Follow the instructions <a target="_blank" href="http://trac.osgeo.org/grass/wiki/CompileOnWindows">here</a> to download the OSGeo4W installer, install the required dependencies, and build Grass from source.</p>
-<p>Do not move on to step two until you have successfully <a target="_blank" href="http://trac.osgeo.org/grass/wiki/HowToTestGrass6">tested</a> your new version of Grass.</p>
-</div>
-<div id="Create a GRASS self-contained Package">
-<p><h3>2. Create a GRASS self-contained Package</h3></p>
-<p>Copy all the content of the mswindows folder to a temporary directory, for example <code>c:\temp</code>.</p>
-<p>Edit lines 11-15 in the file <code>c:\temp\GRASS-Packager.bat</code> to reflect the paths to your OSGeo4W tree (eg. <code>c:\OSGeo4W</code>) and the GRASS version being packaged (eg. <code>grass-7.0.svn</code>).</p>
-<p>Launch the file <code>c:\temp\GRASS-Packager.bat</code> and select the option number 1.</p>
-<p>When finished, you should have a GRASS self-contained release package in <code>c:\temp\GRASS-Release-Package</code>.</p>
-</div>
-<div id="Remove OSGeo4W Traces from Package">
-<p><h3>3. Remove OSGeo4W Traces from Package</h3></p>
-<p>Open <code>c:\temp\GRASS-Release-Package\msys\msys.bat</code> and remove lines 11-16.</p>
-<p>At the end of line 88 (also in msys.bat) change:
-<pre><code>start %WD%rxvt -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"</code></pre>
-To:
-<pre><code>if "x%*" == "x" start %WD%rxvt -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -i
-if NOT "x%*" == "x" start %WD%rxvt -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"</code></pre>
-<p>Delete <code>c:\temp\GRASS-Release-Package\msys\etc\fstab</code></p>
-</div>
-<div id="Install NSIS">
-<p><h3>4. Install NSIS (2.38)</h3></p>
-<p>Download the <a target="_blank" href="http://prdownloads.sourceforge.net/nsis/nsis-2.38-setup.exe">NSIS installer</a></p>
-<p>Install to <code>c:\DevTools</code></p>
-</div>
-<div id="Install NSIS: Untgz Plugin">
-<p><h3>5. Install NSIS: Untgz Plugin (1.0.15)</h3></p>
-<p>Download the <a target="_blank" href="http://nsis.sourceforge.net/mediawiki/images/9/9d/Untgz.zip">NSIS Untgz Plugin</a></p>
-<p>Unzip to <code>c:\DevTools\Plugins\</code></p>
-<p>Copy <code>c:\DevTools\Plugins\untgz\untgz.dll</code> to <code>c:\DevTools\Plugins\</code></p>
-</div>
-<div id="Create the WinGRASS Installer">
-<p><h3>6. Create the WinGRASS Installer</h3></p>
-<p>Open the the file <code>c:\temp\GRASS-Installer.nsi</code>.</p>
-<p>At line 13 set the <code>DEMOLOCATION_PATH</code> varibale to the demolocation folder in the source tree.
-For example, <code>c:\msys\local\src\grass-7.0.svn\demolocation</code>
-<p>At line 18 set the <code>INSTALLER_TYPE</code> variable to <code>"Release"</code>, then, at lines 24-26, set the
-<code>RELEASE_VERSION_NUMBER</code>, the <code>RELEASE_SVN_REVISION</code> and the <code>RELEASE_BINARY_REVISION</code> variables.</p>
-<p>Finally, right click on the file <code>c:\temp\GRASS-Installer.nsi</code> and select <code>Compile NSIS Script</code>.</p>
-<p>When finished, you should have the WinGRASS release installer in <code>c:\temp</code>.</p>
-</div>
-<div id="Credits and Contacts">
-<p><h3>Credits and Contacts</h3></p>
-<p>The GRASS MSYS Environment and the GRASS Packager and Installer scripts were created by Marco Pasetti, and updated for use on the
-osgeo4w tree by Colin Nielsen</p>
-<p>To contact them, e-mail to: GRASS Development Mailing List
-(<a target="_blank" href="http://lists.osgeo.org/mailman/listinfo/grass-dev">http://lists.osgeo.org/mailman/listinfo/grass-dev</a>).</p>
-<p>Last edited by Colin Nielsen on 29 April 2009.</p>
-</div>
-</body>
-</html>
+<html>
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
+<meta http-equiv="Content-Language" content="en" />
+<meta name="Author" content="Marco Pasetti" />
+<meta name="Description" content="SVN mswindows README" />
+<title>SVN mswindows README</title>
+<style type="text/css" />
+/* Wiki Pages Styles */
+/* TableOfContents */
+.table-of-contents	{
+					border: 1px solid #bbbbbb;
+					color: black; background-color: #eeeeee;
+					font-size: small;
+					text-align:left;
+					margin: 0.5em; padding-left: 1em;
+					width: 360;
+/* Contents */
+html	{
+		background-color: white;
+		color: black;
+		font-family: Arial, Lucida Grande, sans-serif;
+		font-size: 10pt;
+body	{
+		margin: 30;
+ol	{
+	font-size: 10pt;
+	margin-top: 0;
+	margin-bottom: 0;
+	margin-left: 0;
+h1	{
+	font-size: 18pt;
+	margin-top: 0;
+	margin-bottom: 50;
+h2	{
+	font-size: 16pt;
+	margin-top: 60;
+	margin-bottom: 20;
+h3	{
+	font-size: 14pt;
+	margin-top: 60;
+h4	{
+	font-size: 11pt;
+	margin-top: 0;
+	margin-bottom: 0;
+p	{
+	font-size: 10pt;
+	margin-top: 10;
+	margin-bottom: 10;
+code	{
+		font-family: Courier-new, monospace;
+		font-size: 10pt;
+		margin-top: 10;
+pre	{
+	padding: 1em;
+	border: 1px dashed #2f6fab;
+	color: black;
+	background-color: #f9f9f9;
+	line-height: 1.1em;
+/* Tables */
+table
+	margin: 0.5em 0 0 0.5em;
+	border-collapse: collapse;
+td
+	padding: 0.25em 0.5em 0.25em 0.5em;
+	border: 0pt solid #ADB9CC;
+	font-size: 10pt;
+/* Links */
+a	{
+	text-decoration: none;
+	color: #002bb8;
+	background: none;
+a:hover {
+		text-decoration: underline;
+		color: green;
+a:visited:hover	{
+				color: red;
+</style>
+</head>
+<body>
+<h1>How to prepare a WinGRASS Release</h1>
+<div class="table-of-contents">
+<p><strong>Table of Contents</strong></p>
+<p><a href="#Introduction">Introduction</a></p>
+<p><ol>
+<li><a href="#Install OSGeo4w Tree and Compile Grass">Install OSGeo4w Tree and Compile Grass</a></li>
+<li><a href="#Create a GRASS self-contained Package">Create a GRASS self-contained Package</a></li>
+<li><a href="#Remove OSGeo4W Traces from Package">Remove OSGeo4W Traces from Package</a></li>
+<li><a href="#Install NSIS">Install NSIS</a></li>
+<li><a href="#Install NSIS: Untgz Plugin">Install NSIS: Untgz Plugin</a></li>
+<li><a href="#Create the WinGRASS Installer">Create the WinGRASS Installer</a></li>
+</ol></p>
+<p><a href="#Credits and Contacts">Credits and Contacts</a></p>
+<br>
+</div>
+<div id="Introduction">
+<p><h3>Introduction</h3></p>
+<p>This document explains how to prepare a WinGRASS release (as a self-contained package installer) using the scripts contained
+in the mswindows folder. In order to avoid mistakes or misunderstandings, we highly recommend to follow each step and command
+exactly as they are written in this document.</p>
+</div>
+<div id="Install OSGeo4w Tree and Compile Grass">
+<p><h3>1. Install OSGeo4w Tree and Compile Grass</h3></p>
+<p>Follow the instructions <a target="_blank" href="http://trac.osgeo.org/grass/wiki/CompileOnWindows">here</a> to download the OSGeo4W installer, install the required dependencies, and build Grass from source.</p>
+<p>Do not move on to step two until you have successfully <a target="_blank" href="http://trac.osgeo.org/grass/wiki/HowToTestGrass6">tested</a> your new version of Grass.</p>
+</div>
+<div id="Create a GRASS self-contained Package">
+<p><h3>2. Create a GRASS self-contained Package</h3></p>
+<p>Copy all the content of the mswindows folder to a temporary directory, for example <code>c:\temp</code>.</p>
+<p>Edit lines 11-15 in the file <code>c:\temp\GRASS-Packager.bat</code> to reflect the paths to your OSGeo4W tree (eg. <code>c:\OSGeo4W</code>) and the GRASS version being packaged (eg. <code>grass-7.0.svn</code>).</p>
+<p>Launch the file <code>c:\temp\GRASS-Packager.bat</code> and select the option number 1.</p>
+<p>When finished, you should have a GRASS self-contained release package in <code>c:\temp\GRASS-Release-Package</code>.</p>
+</div>
+<div id="Remove OSGeo4W Traces from Package">
+<p><h3>3. Remove OSGeo4W Traces from Package</h3></p>
+<p>Open <code>c:\temp\GRASS-Release-Package\msys\msys.bat</code> and remove lines 11-16.</p>
+<p>At the end of line 88 (also in msys.bat) change:
+<pre><code>start %WD%rxvt -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"</code></pre>
+To:
+<pre><code>if "x%*" == "x" start %WD%rxvt -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -i
+if NOT "x%*" == "x" start %WD%rxvt -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"</code></pre>
+<p>Delete <code>c:\temp\GRASS-Release-Package\msys\etc\fstab</code></p>
+</div>
+<div id="Install NSIS">
+<p><h3>4. Install NSIS (2.38)</h3></p>
+<p>Download the <a target="_blank" href="http://prdownloads.sourceforge.net/nsis/nsis-2.38-setup.exe">NSIS installer</a></p>
+<p>Install to <code>c:\DevTools</code></p>
+</div>
+<div id="Install NSIS: Untgz Plugin">
+<p><h3>5. Install NSIS: Untgz Plugin (1.0.15)</h3></p>
+<p>Download the <a target="_blank" href="http://nsis.sourceforge.net/mediawiki/images/9/9d/Untgz.zip">NSIS Untgz Plugin</a></p>
+<p>Unzip to <code>c:\DevTools\Plugins\</code></p>
+<p>Copy <code>c:\DevTools\Plugins\untgz\untgz.dll</code> to <code>c:\DevTools\Plugins\</code></p>
+</div>
+<div id="Create the WinGRASS Installer">
+<p><h3>6. Create the WinGRASS Installer</h3></p>
+<p>Open the the file <code>c:\temp\GRASS-Installer.nsi</code>.</p>
+<p>At line 13 set the <code>DEMOLOCATION_PATH</code> varibale to the demolocation folder in the source tree.
+For example, <code>c:\msys\local\src\grass-7.0.svn\demolocation</code>
+<p>At line 18 set the <code>INSTALLER_TYPE</code> variable to <code>"Release"</code>, then, at lines 24-26, set the
+<code>RELEASE_VERSION_NUMBER</code>, the <code>RELEASE_SVN_REVISION</code> and the <code>RELEASE_BINARY_REVISION</code> variables.</p>
+<p>Finally, right click on the file <code>c:\temp\GRASS-Installer.nsi</code> and select <code>Compile NSIS Script</code>.</p>
+<p>When finished, you should have the WinGRASS release installer in <code>c:\temp</code>.</p>
+</div>
+<div id="Credits and Contacts">
+<p><h3>Credits and Contacts</h3></p>
+<p>The GRASS MSYS Environment and the GRASS Packager and Installer scripts were created by Marco Pasetti, and updated for use on the
+osgeo4w tree by Colin Nielsen</p>
+<p>To contact them, e-mail to: GRASS Development Mailing List
+(<a target="_blank" href="http://lists.osgeo.org/mailman/listinfo/grass-dev">http://lists.osgeo.org/mailman/listinfo/grass-dev</a>).</p>
+<p>Last edited by Colin Nielsen on 29 April 2009.</p>
+</div>
+</body>
+</html>
Property changes on: grass/trunk/mswindows/README.html
   + text/html
   + native
