[GRASS-SVN] r37159 - grass/trunk/scripts/m.proj
svn_grass at osgeo.org
Mon May 11 05:07:42 EDT 2009
Author: martinl
Date: 2009-05-11 05:07:42 -0400 (Mon, 11 May 2009)
New Revision: 37159
grass/trunk/scripts/m.proj/m.proj.py
m.proj: input required
field separator for output
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py 2009-05-11 08:50:34 UTC (rev 37158)
+++ grass/trunk/scripts/m.proj/m.proj.py 2009-05-11 09:07:42 UTC (rev 37159)
@@ -20,15 +20,15 @@
# - if you send cs2cs a third data column, beware it might be treated as "z"
#%Module
-#% description: Convert coordinates from one projection to another (cs2cs frontend).
+#% description: Converts coordinates from one projection to another (cs2cs frontend).
#% keywords: miscellaneous, projection
#%End
#%option
#% key: input
#% type: string
#% gisprompt: old_file,file,file
-#% description: Input coordinate file (omit to read from stdin)
-#% required : no
+#% description: Input coordinate file ('-' to read from stdin)
+#% required : yes
#% key_desc : filename
#%end
#%option
@@ -42,10 +42,10 @@
#%option
#% key: fs
#% type: string
-#% description: Field separator
+#% description: Field separator (format: input,output)
#% required : no
-#% key_desc : character
-#% answer : |
+#% key_desc : character,character
+#% answer : |,|
#%end
#%option
#% key: proj_in
@@ -92,34 +92,41 @@
#### check for overenthusiasm
if proj_in and ll_in:
- grass.fatal("Chose only one input parameter method")
+ grass.fatal("Choose only one input parameter method")
if proj_out and ll_out:
- grass.fatal("Chose only one output parameter method")
+ grass.fatal("Choose only one output parameter method")
if ll_in and ll_out:
- grass.fatal("Chose only one auto-projection parameter method")
+ grass.fatal("Choise only one auto-projection parameter method")
if output and not grass.overwrite() and os.path.exists(output):
grass.fatal("Output file already exists")
#### parse field separator
- if fs.lower() in ["space", "tab"]:
- fs = ' '
+ ifs, ofs = fs.split(',')
+ if ifs.lower() in ["space", "tab"]:
+ ifs = ' '
else:
- fs = fs[0]
+ ifs = ifs[0]
+ if ofs.lower() == "space":
+ ofs = ' '
+ elif ofs.lower() == "tab":
+ ofs = '\t'
+ else:
+ ofs = ofs[0]
#### set up projection params
s = grass.read_command("g.proj", flags='j')
kv = grass.parse_key_val(s)
if "XY location" in kv['+proj'] and (ll_in or ll_out):
- grass.fatal("Cannot project to or from a XY location.")
+ grass.fatal("Unable to project to or from a XY location")
in_proj = None
if ll_in:
in_proj = "+proj=longlat +datum=WGS84"
- grass.verbose("Assuming LL WGS84 as input, current projection as output.")
+ grass.verbose("Assuming LL WGS84 as input, current projection as output ")
if ll_out:
in_proj = grass.read_command('g.proj', flags = 'jf')
@@ -128,14 +135,15 @@
in_proj = proj_in
if not in_proj:
- grass.fatal("Missing input projection parameters.")
+ grass.fatal("Missing input projection parameters ")
in_proj = in_proj.strip()
+ grass.verbose("Input parameters: '%s'" % in_proj)
out_proj = None
if ll_out:
out_proj = "+proj=longlat +datum=WGS84"
- grass.verbose("Assuming current projection as input, LL WGS84 as output.")
+ grass.verbose("Assuming current projection as input, LL WGS84 as output ")
if ll_in:
out_proj = grass.read_command('g.proj', flags = 'jf')
@@ -144,20 +152,20 @@
out_proj = proj_out
if not out_proj:
- grass.fatal("Missing output projection parameters.")
+ grass.fatal("Missing output projection parameters ")
out_proj = out_proj.strip()
- grass.verbose("output parameters=[%s]" % out_proj)
+ grass.verbose("Output parameters: '%s'" % out_proj)
#### set up input file
- if input in ['', '-']:
+ if input == '-':
infile = None
inf = sys.stdin
else:
infile = input
if not os.path.exists(infile):
- grass.fatal("Unable to read input data.")
+ grass.fatal("Unable to read input data")
inf = file(infile)
- grass.verbose("input file=[%s]" % infile)
+ grass.debug("input file=[%s]" % infile)
#### set up output file
if not output:
@@ -165,8 +173,8 @@
outf = sys.stdout
else:
outfile = output
- outf = file(outfile)
- grass.message("output file=[%s]" % outfile)
+ outf = open(outfile, 'w')
+ grass.debug("output file=[%s]" % outfile)
#### set up output style
if not decimal:
@@ -179,23 +187,30 @@
# cs2cs | sed -e 's/d/:/g' -e "s/'/:/g" -e 's/"//g'
cmd = ['cs2cs'] + outfmt + in_proj.split() + ['+to'] + out_proj.split()
- p = grass.Popen(cmd, stdin = grass.PIPE, stdout = outf)
+ p = grass.Popen(cmd, stdin = grass.PIPE, stdout = grass.PIPE)
while True:
line = inf.readline()
if not line:
break
- line = line.replace(fs, ' ')
+ line = line.replace(ifs, ' ')
p.stdin.write(line)
p.stdin.flush()
p.stdin.close()
+ p.stdin = None
exitcode = p.wait()
if exitcode != 0:
- grass.warning("Projection transform probably failed, please investigate.")
+ grass.warning("Projection transform probably failed, please investigate")
+ for line in p.communicate()[0].splitlines():
+ x, yz = line.split('\t')
+ y, z = yz.split(' ')
+ outf.write('%s%s%s%s%s\n' % \
+ (x.strip(), ofs, y.strip(), ofs, z.strip()))
if __name__ == "__main__":
options, flags = grass.parser()
main()
