[GRASS-SVN] r37173 - in grass/trunk/gui: scripts wxpython/xml
svn_grass at osgeo.org
Tue May 12 01:00:55 EDT 2009
Author: hamish
Date: 2009-05-12 01:00:55 -0400 (Tue, 12 May 2009)
New Revision: 37173
Added:
grass/trunk/gui/scripts/v.type_wrapper.py
Removed:
grass/trunk/gui/scripts/v.type.py
grass/trunk/gui/wxpython/xml/menudata.xml
rename v.type wrapper script to avoid possible namespace collision on MS Windows
Deleted: grass/trunk/gui/scripts/v.type.py
--- grass/trunk/gui/scripts/v.type.py 2009-05-11 21:56:48 UTC (rev 37172)
+++ grass/trunk/gui/scripts/v.type.py 2009-05-12 05:00:55 UTC (rev 37173)
@@ -1,91 +0,0 @@
-#!/usr/bin/env python
-# MODULE: v.type.py (v.type wrapper script)
-# AUTHOR(S): Hamish Bowman (Otago University, New Zealand)
-# (original contributor, v.type.sh)
-# Pythonized by Martin Landa <landa.martin gmail.com> (2008/08)
-# PURPOSE: Supply v.type options in a GUI compatible way
-# COPYRIGHT: (C) 2007-2008 by Hamish Bowman, and the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%module
-#% description: Change the type of geometry elements.
-#% keywords: vector, geometry
-#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name of input vector map
-#% gisprompt: old,vector,vector
-#%end
-#%option
-#% key: output
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name for output vector map
-#% gisprompt: new,vector,vector
-#%end
-#%option
-#% key: type
-#% type: string
-#% required: no
-#% multiple: no
-#% options: point to centroid,point to kernel,centroid to point,centroid to kernel,kernel to point,kernel to centroid,line to boundary,line to face,boundary to line,boundary to face,face to line,face to boundary
-#% description: Conversion
-#% answer: boundary to line
-#%end
-import grass
-import sys
-def main():
- if options['type'] == "point to centroid":
- type_cnv = "point,centroid"
- elif options['type'] == "point to kernel":
- type_cnv = "point,kernel"
- elif options['type'] == "centroid to point":
- type_cnv = "centroid,point"
- elif options['type'] == "centroid to kernel":
- type_cnv = "centroid,kernel"
- elif options['type'] == "kernel to point":
- type_cnv = "kernel,point"
- elif options['type'] == "kernel to centroid":
- type_cnv = "kernel,centroid"
- elif options['type'] == "line to boundary":
- type_cnv = "line,boundary"
- elif options['type'] == "line to face":
- type_cnv = "line,face"
- elif options['type'] == "boundary to line":
- type_cnv = "boundary,line"
- elif options['type'] == "boundary to face":
- type_cnv = "boundary,face"
- elif options['type'] == "face to line":
- type_cnv = "face,line"
- elif options['type'] == "face to boundary":
- type_cnv = "face,boundary"
- options.pop('type')
- grass.exec_command("v.type", type = type_cnv, **options)
- return 0
-if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
Copied: grass/trunk/gui/scripts/v.type_wrapper.py (from rev 37165, grass/trunk/gui/scripts/v.type.py)
--- grass/trunk/gui/scripts/v.type_wrapper.py (rev 0)
+++ grass/trunk/gui/scripts/v.type_wrapper.py 2009-05-12 05:00:55 UTC (rev 37173)
@@ -0,0 +1,91 @@
+#!/usr/bin/env python
+# MODULE: v.type_wrapper.py (v.type wrapper script)
+# AUTHOR(S): Hamish Bowman (Otago University, New Zealand)
+# (original contributor, v.type.sh)
+# Pythonized by Martin Landa <landa.martin gmail.com> (2008/08)
+# PURPOSE: Supply v.type options in a GUI compatible way
+# COPYRIGHT: (C) 2007-2008 by Hamish Bowman, and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Change the type of geometry elements.
+#% keywords: vector, geometry
+#%end
+#%option
+#% key: input
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input vector map
+#% gisprompt: old,vector,vector
+#%end
+#%option
+#% key: output
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name for output vector map
+#% gisprompt: new,vector,vector
+#%end
+#%option
+#% key: type
+#% type: string
+#% required: no
+#% multiple: no
+#% options: point to centroid,point to kernel,centroid to point,centroid to kernel,kernel to point,kernel to centroid,line to boundary,line to face,boundary to line,boundary to face,face to line,face to boundary
+#% description: Conversion
+#% answer: boundary to line
+#%end
+import grass
+import sys
+def main():
+ if options['type'] == "point to centroid":
+ type_cnv = "point,centroid"
+ elif options['type'] == "point to kernel":
+ type_cnv = "point,kernel"
+ elif options['type'] == "centroid to point":
+ type_cnv = "centroid,point"
+ elif options['type'] == "centroid to kernel":
+ type_cnv = "centroid,kernel"
+ elif options['type'] == "kernel to point":
+ type_cnv = "kernel,point"
+ elif options['type'] == "kernel to centroid":
+ type_cnv = "kernel,centroid"
+ elif options['type'] == "line to boundary":
+ type_cnv = "line,boundary"
+ elif options['type'] == "line to face":
+ type_cnv = "line,face"
+ elif options['type'] == "boundary to line":
+ type_cnv = "boundary,line"
+ elif options['type'] == "boundary to face":
+ type_cnv = "boundary,face"
+ elif options['type'] == "face to line":
+ type_cnv = "face,line"
+ elif options['type'] == "face to boundary":
+ type_cnv = "face,boundary"
+ options.pop('type')
+ grass.exec_command("v.type", type = type_cnv, **options)
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2009-05-11 21:56:48 UTC (rev 37172)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2009-05-12 05:00:55 UTC (rev 37173)
@@ -1552,7 +1552,7 @@
<label>Convert object types</label>
<help>Change the type of geometry elements.</help>
<handler>self.OnMenuCmd</handler>
- <command>v.type.py</command>
+ <command>v.type_wrapper.py</command>
</menuitem>
<separator/>
<menuitem>
