[GRASS-SVN] r37175 - in grass/branches/develbranch_6/gui: scripts tcltk/gis.m wxpython/xml
Tue May 12 01:25:40 EDT 2009
Author: hamish
Date: 2009-05-12 01:25:40 -0400 (Tue, 12 May 2009)
New Revision: 37175
Added:
   grass/branches/develbranch_6/gui/scripts/v.type_wrapper.py
   grass/branches/develbranch_6/gui/scripts/v.type_wrapper.sh
Removed:
   grass/branches/develbranch_6/gui/scripts/v.type.py
   grass/branches/develbranch_6/gui/scripts/v.type.sh
   grass/branches/develbranch_6/gui/scripts/Makefile
   grass/branches/develbranch_6/gui/scripts/g.change.gui.sh
   grass/branches/develbranch_6/gui/tcltk/gis.m/gmmenu.tcl
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
rename v.type.py wrapper script to avoid possible namespace collision on MS Windows (merge from trunk), rename v.type.sh as well for consistency; no .bat wrapper for .py
Modified: grass/branches/develbranch_6/gui/scripts/Makefile
--- grass/branches/develbranch_6/gui/scripts/Makefile	2009-05-12 05:22:10 UTC (rev 37174)
+++ grass/branches/develbranch_6/gui/scripts/Makefile	2009-05-12 05:25:40 UTC (rev 37175)
@@ -12,6 +12,6 @@
 	for file in d.* g.* r.* v.* ; do $(INSTALL) $$file $(ETC)/gui/scripts/ ; done
 create.bat:
-	for file in d.* g.* r.* v.* ; do \
+	for file in d.* g.*sh r.* v.*sh ; do \
 	sed -e "s#SCRIPT_NAME#$$file#" $(MODULE_TOPDIR)/gui/scripts/windows_launch.bat \
 		> $(ETC)/gui/scripts/$$file.bat ; done
Modified: grass/branches/develbranch_6/gui/scripts/g.change.gui.sh
--- grass/branches/develbranch_6/gui/scripts/g.change.gui.sh	2009-05-12 05:22:10 UTC (rev 37174)
+++ grass/branches/develbranch_6/gui/scripts/g.change.gui.sh	2009-05-12 05:25:40 UTC (rev 37175)
@@ -41,6 +41,11 @@
     exit 1
 fi
+if [ ! -x "`which $(basename "$0")`" ] ; then
+    PATH="$PATH:$GISBASE/etc/gui/scripts"
+    export PATH
+fi
 if [ "$1" != "@ARGS_PARSED@" ] ; then
     exec g.parser "$0" "$@"
 fi
Deleted: grass/branches/develbranch_6/gui/scripts/v.type.py
--- grass/branches/develbranch_6/gui/scripts/v.type.py	2009-05-12 05:22:10 UTC (rev 37174)
+++ grass/branches/develbranch_6/gui/scripts/v.type.py	2009-05-12 05:25:40 UTC (rev 37175)
@@ -1,91 +0,0 @@
-#!/usr/bin/env python
-# MODULE:       v.type.py (v.type wrapper script)
-# AUTHOR(S):    Hamish Bowman  (Otago University, New Zealand)
-#               (original contributor, v.type.sh)
-#               Pythonized by Martin Landa <landa.martin gmail.com> (2008/08)
-# PURPOSE:      Supply v.type options in a GUI compatible way
-# COPYRIGHT:    (C) 2007-2008 by Hamish Bowman, and the GRASS Development Team
-#               This program is free software under the GNU General Public
-#               License (>=v2). Read the file COPYING that comes with GRASS
-#               for details.
-#%module
-#% description: Change the type of geometry elements.
-#% keywords: vector, geometry
-#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name of input vector map
-#% gisprompt: old,vector,vector
-#%end
-#%option
-#% key: output
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name for output vector map
-#% gisprompt: new,vector,vector
-#%end
-#%option
-#% key: type
-#% type: string
-#% required: no
-#% multiple: no
-#% options: point to centroid,point to kernel,centroid to point,centroid to kernel,kernel to point,kernel to centroid,line to boundary,line to face,boundary to line,boundary to face,face to line,face to boundary
-#% description: Conversion
-#% answer: boundary to line
-#%end
-import grass
-import sys
-def main():
-    if options['type'] == "point to centroid":
-        type_cnv = "point,centroid"
-    elif options['type'] == "point to kernel":
-        type_cnv = "point,kernel"
-    elif options['type'] == "centroid to point":
-        type_cnv = "centroid,point"
-    elif options['type'] == "centroid to kernel":
-        type_cnv = "centroid,kernel"
-    elif options['type'] == "kernel to point":
-        type_cnv = "kernel,point"
-    elif options['type'] == "kernel to centroid":
-        type_cnv = "kernel,centroid"
-    elif options['type'] == "line to boundary":
-        type_cnv = "line,boundary"
-    elif options['type'] == "line to face":
-        type_cnv = "line,face"
-    elif options['type'] == "boundary to line":
-        type_cnv = "boundary,line"
-    elif options['type'] == "boundary to face":
-        type_cnv = "boundary,face"
-    elif options['type'] == "face to line":
-        type_cnv = "face,line"
-    elif options['type'] == "face to boundary":
-        type_cnv = "face,boundary"
-    options.pop('type')
-    grass.exec_command("v.type", type = type_cnv, **options)
-    return 0
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    sys.exit(main())
Deleted: grass/branches/develbranch_6/gui/scripts/v.type.sh
--- grass/branches/develbranch_6/gui/scripts/v.type.sh	2009-05-12 05:22:10 UTC (rev 37174)
+++ grass/branches/develbranch_6/gui/scripts/v.type.sh	2009-05-12 05:25:40 UTC (rev 37175)
@@ -1,88 +0,0 @@
-#!/bin/sh
-# MODULE:       v.type.sh (v.type wrapper script)
-# COPYRIGHT:    (c) 2007 by Hamish Bowman, and the GRASS Development Team
-#               for details.
-# Notes:
-#   Created with "v.type --script" from GRASS 6.3-CVS 23 May 2007
-#%Module
-#%End
-#%Option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#%End
-#%Option
-#% key: output
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#%End
-#%Option
-#% key: type
-#% type: string
-#% required: no
-#% multiple: no
-#%End
-if [ -z "$GISBASE" ] ; then
-    echo "You must be in GRASS GIS to run this program." 1>&2
-    exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
-    exec g.parser "$0" "$@"
-fi
-unset TYPE_CNV
-case "$GIS_OPT_TYPE" in
-  "point to centroid")
-    TYPE_CNV="point,centroid" ;;
-  "centroid to point")
-    TYPE_CNV="centroid,point" ;;
-  "line to boundary")
-    TYPE_CNV="line,boundary" ;;
-  "boundary to line")
-    TYPE_CNV="boundary,line" ;;
-  "kernel to centroid")
-    TYPE_CNV="kernel,centroid" ;;
-  "centroid to kernel")
-    TYPE_CNV="centroid,kernel" ;;
-  "face to boundary")
-    TYPE_CNV="face,boundary" ;;
-  "boundary to face")
-    TYPE_CNV="boundary,face" ;;
-  "point to kernel")
-    TYPE_CNV="point,kernel" ;;
-  "kernel to point")
-    TYPE_CNV="kernel,point" ;;
-  "line to face")
-    TYPE_CNV="line,face" ;;
-  "face to line")
-    TYPE_CNV="face,line" ;;
-esac
-exec v.type input="$GIS_OPT_INPUT" output="$GIS_OPT_OUTPUT" type="$TYPE_CNV"
Copied: grass/branches/develbranch_6/gui/scripts/v.type_wrapper.py (from rev 37173, grass/trunk/gui/scripts/v.type_wrapper.py)
--- grass/branches/develbranch_6/gui/scripts/v.type_wrapper.py	                        (rev 0)
+++ grass/branches/develbranch_6/gui/scripts/v.type_wrapper.py	2009-05-12 05:25:40 UTC (rev 37175)
@@ -0,0 +1,91 @@
+#!/usr/bin/env python
+# MODULE:       v.type_wrapper.py (v.type wrapper script)
+# AUTHOR(S):    Hamish Bowman  (Otago University, New Zealand)
+#               (original contributor, v.type.sh)
+#               Pythonized by Martin Landa <landa.martin gmail.com> (2008/08)
+# PURPOSE:      Supply v.type options in a GUI compatible way
+# COPYRIGHT:    (C) 2007-2008 by Hamish Bowman, and the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%module
+#% description: Change the type of geometry elements.
+#% keywords: vector, geometry
+#%end
+#%option
+#% key: input
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input vector map
+#% gisprompt: old,vector,vector
+#%end
+#%option
+#% key: output
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name for output vector map
+#% gisprompt: new,vector,vector
+#%end
+#%option
+#% key: type
+#% type: string
+#% required: no
+#% multiple: no
+#% options: point to centroid,point to kernel,centroid to point,centroid to kernel,kernel to point,kernel to centroid,line to boundary,line to face,boundary to line,boundary to face,face to line,face to boundary
+#% description: Conversion
+#% answer: boundary to line
+#%end
+import grass
+import sys
+def main():
+    if options['type'] == "point to centroid":
+        type_cnv = "point,centroid"
+    elif options['type'] == "point to kernel":
+        type_cnv = "point,kernel"
+    elif options['type'] == "centroid to point":
+        type_cnv = "centroid,point"
+    elif options['type'] == "centroid to kernel":
+        type_cnv = "centroid,kernel"
+    elif options['type'] == "kernel to point":
+        type_cnv = "kernel,point"
+    elif options['type'] == "kernel to centroid":
+        type_cnv = "kernel,centroid"
+    elif options['type'] == "line to boundary":
+        type_cnv = "line,boundary"
+    elif options['type'] == "line to face":
+        type_cnv = "line,face"
+    elif options['type'] == "boundary to line":
+        type_cnv = "boundary,line"
+    elif options['type'] == "boundary to face":
+        type_cnv = "boundary,face"
+    elif options['type'] == "face to line":
+        type_cnv = "face,line"
+    elif options['type'] == "face to boundary":
+        type_cnv = "face,boundary"
+    options.pop('type')
+    grass.exec_command("v.type", type = type_cnv, **options)
+    return 0
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
Copied: grass/branches/develbranch_6/gui/scripts/v.type_wrapper.sh (from rev 37174, grass/branches/releasebranch_6_4/gui/scripts/v.type_wrapper.sh)
--- grass/branches/develbranch_6/gui/scripts/v.type_wrapper.sh	                        (rev 0)
+++ grass/branches/develbranch_6/gui/scripts/v.type_wrapper.sh	2009-05-12 05:25:40 UTC (rev 37175)
@@ -0,0 +1,88 @@
+#!/bin/sh
+# MODULE:       v.type_wrapper.sh (v.type wrapper script)
+# COPYRIGHT:    (c) 2007 by Hamish Bowman, and the GRASS Development Team
+#               for details.
+# Notes:
+#   Created with "v.type --script" from GRASS 6.3-CVS 23 May 2007
+#%Module
+#%End
+#%Option
+#% key: input
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#%End
+#%Option
+#% key: output
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#%End
+#%Option
+#% key: type
+#% type: string
+#% required: no
+#% multiple: no
+#%End
+if [ -z "$GISBASE" ] ; then
+    echo "You must be in GRASS GIS to run this program." 1>&2
+    exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+    exec g.parser "$0" "$@"
+fi
+unset TYPE_CNV
+case "$GIS_OPT_TYPE" in
+  "point to centroid")
+    TYPE_CNV="point,centroid" ;;
+  "centroid to point")
+    TYPE_CNV="centroid,point" ;;
+  "line to boundary")
+    TYPE_CNV="line,boundary" ;;
+  "boundary to line")
+    TYPE_CNV="boundary,line" ;;
+  "kernel to centroid")
+    TYPE_CNV="kernel,centroid" ;;
+  "centroid to kernel")
+    TYPE_CNV="centroid,kernel" ;;
+  "face to boundary")
+    TYPE_CNV="face,boundary" ;;
+  "boundary to face")
+    TYPE_CNV="boundary,face" ;;
+  "point to kernel")
+    TYPE_CNV="point,kernel" ;;
+  "kernel to point")
+    TYPE_CNV="kernel,point" ;;
+  "line to face")
+    TYPE_CNV="line,face" ;;
+  "face to line")
+    TYPE_CNV="face,line" ;;
+esac
+exec v.type input="$GIS_OPT_INPUT" output="$GIS_OPT_OUTPUT" type="$TYPE_CNV"
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/gmmenu.tcl
--- grass/branches/develbranch_6/gui/tcltk/gis.m/gmmenu.tcl	2009-05-12 05:22:10 UTC (rev 37174)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/gmmenu.tcl	2009-05-12 05:25:40 UTC (rev 37175)
@@ -435,7 +435,7 @@
 		{command {[G_msg "Clean vector"]} {} "v.clean: Clean vector objects" {} -command {execute v.clean }}
 		{command {[G_msg "Smooth or simplify"]} {} "v.generalize: Smooth or simplify lines and boundaries (reduce vertices)" {} -command {execute v.generalize }}
 		{separator}
-		{command {[G_msg "Convert object types"]} {} "v.type: Convert vector objects from one feature type to another" {} -command {execute $env(GISBASE)/etc/gui/scripts/v.type.sh }}
+		{command {[G_msg "Convert object types"]} {} "v.type: Convert vector objects from one feature type to another" {} -command {execute $env(GISBASE)/etc/gui/scripts/v.type_wrapper.sh }}
 		{separator}
 		{command {[G_msg "Add centroids"]} {} "v.centroids: Add centroids to closed boundaries to create areas" {} -command {execute v.centroids }}
 		{separator}
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2009-05-12 05:22:10 UTC (rev 37174)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2009-05-12 05:25:40 UTC (rev 37175)
@@ -1533,7 +1533,7 @@
 	      <label>Convert object types</label>
 	      <help>Change the type of geometry elements.</help>
 	      <handler>self.OnMenuCmd</handler>
-	      <command>v.type.py</command>
+	      <command>v.type_wrapper.py</command>
 	    </menuitem>
 	    <separator/>
 	    <menuitem>
