[GRASS-SVN] r37185 - in grass/branches/releasebranch_6_4: lib/gis
visualization/nviz/scripts
svn_grass at osgeo.org
Tue May 12 06:01:46 EDT 2009
Author: hamish
Date: 2009-05-12 06:01:46 -0400 (Tue, 12 May 2009)
New Revision: 37185
grass/branches/releasebranch_6_4/lib/gis/gisinit.c
grass/branches/releasebranch_6_4/lib/gis/spawn.c
grass/branches/releasebranch_6_4/visualization/nviz/scripts/nviz
grass/branches/releasebranch_6_4/visualization/nviz/scripts/nviz2.2_script
update wrapper script to latest descr changes (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/lib/gis/gisinit.c
--- grass/branches/releasebranch_6_4/lib/gis/gisinit.c 2009-05-12 09:59:11 UTC (rev 37184)
+++ grass/branches/releasebranch_6_4/lib/gis/gisinit.c 2009-05-12 10:01:46 UTC (rev 37185)
@@ -51,7 +51,7 @@
G_set_program_name(pgm);
if (strcmp(version, GIS_H_VERSION) != 0)
- G_fatal_error(_("Incompatible library version for module. "
+ G_fatal_error(_("Incompatible library version for module. "
"You need to rebuild GRASS or untangle multiple installations."));
/* Make sure location and mapset are set */
@@ -87,7 +87,7 @@
return 0;
gisinit();
Modified: grass/branches/releasebranch_6_4/lib/gis/spawn.c
--- grass/branches/releasebranch_6_4/lib/gis/spawn.c 2009-05-12 09:59:11 UTC (rev 37184)
+++ grass/branches/releasebranch_6_4/lib/gis/spawn.c 2009-05-12 10:01:46 UTC (rev 37185)
@@ -81,7 +81,7 @@
return -1;
- return _spawnv(_P_WAIT, (char *)command, args);
+ return _spawnvp(_P_WAIT, (char *)command, args);
#else
Modified: grass/branches/releasebranch_6_4/visualization/nviz/scripts/nviz
--- grass/branches/releasebranch_6_4/visualization/nviz/scripts/nviz 2009-05-12 09:59:11 UTC (rev 37184)
+++ grass/branches/releasebranch_6_4/visualization/nviz/scripts/nviz 2009-05-12 10:01:46 UTC (rev 37185)
@@ -11,74 +11,93 @@
# for details.
-#% Module
-#% description: nviz - Visualization and animation tool for GRASS data
-#% keywords: raster, vector, visualization
-#% End
-#%flag
-#% key: q
-#% description: Quickstart - Do not load any data
-#% End
-#% key: k
-#% description: Script kill option
-#% End
-#% key: x
-#% description: Start in Demo mode
-#% End
-#% key: v
-#% description: Output more comments (default=quiet)
-#% End
-#%option
+## template generated 'with nviz --script'
+#%Module
+#% description: nviz - Visualization and animation tool for GRASS data.
+#% keywords: raster, vector, visualization
+#%End
+#%Flag
+#% key: q
+#% description: Quickstart - Do not load any data
+#%End
+#%Flag
+#% key: k
+#% description: Exit after completing script launched from the command line
+#%End
+#%Flag
+#% key: x
+#% description: Start in Demo mode (skip the "please wait" message)
+#%End
+#%Flag
+#% key: v
+#% description: Verbose module output (default=quiet)
+#%End
+#%Option
#% key: elevation
#% type: string
+#% required: no
+#% multiple: yes
+#% key_desc: name
+#% description: Name of raster map(s) for Elevation
#% gisprompt: old,cell,raster
-#% description: Raster file(s) for elevation
-#% required : no
+#% guisection: Raster
#%End
-#%option
+#%Option
#% key: color
#% type: string
+#% required: no
+#% multiple: yes
+#% description: Name of raster map(s) for Color
-#% description: Raster file(s) for color
-#% required : no
#%End
-#%option
+#%Option
#% key: vector
#% type: string
+#% required: no
+#% multiple: yes
+#% description: Name of vector lines/areas overlay map(s)
#% gisprompt: old,vector,vector
-#% description: Vector lines/areas overlay file(s)
-#% required : no
+#% guisection: Vector
#%End
-#%option
+#%Option
#% key: points
#% type: string
+#% required: no
+#% multiple: yes
+#% description: Name of vector points overlay file(s)
-#% description: Vector points overlay file(s)
-#% required : no
#%End
-#%option
+#%Option
#% key: volume
#% type: string
+#% required: no
+#% multiple: yes
#% description: Name of existing 3d raster map
-#% required : no
+#% gisprompt: old,grid3,3d-raster
#%End
-#%option
+#%Option
#% key: path
#% type: string
+#% required: no
+#% multiple: no
#% description: Set alternative panel path
-#% required : no
#%End
-#%option
+#%Option
#% key: script
#% type: string
+#% required: no
+#% multiple: no
#% description: Execute script file at startup
-#% required : no
#%End
-#%option
+#%Option
#% key: state
#% type: string
-#% description: Load previosly saved state file
-#% required : no
+#% required: no
+#% multiple: no
+#% description: Load previously saved state file
#%End
Modified: grass/branches/releasebranch_6_4/visualization/nviz/scripts/nviz2.2_script
--- grass/branches/releasebranch_6_4/visualization/nviz/scripts/nviz2.2_script 2009-05-12 09:59:11 UTC (rev 37184)
+++ grass/branches/releasebranch_6_4/visualization/nviz/scripts/nviz2.2_script 2009-05-12 10:01:46 UTC (rev 37185)
@@ -1117,10 +1117,3 @@
after 5000 CheckScriptDone
