[GRASS-SVN] r37187 - grass/branches/develbranch_6/lib/gis
    svn_grass at osgeo.org
    Tue May 12 06:05:50 EDT 2009
Author: hamish
Date: 2009-05-12 06:05:50 -0400 (Tue, 12 May 2009)
New Revision: 37187
   grass/branches/develbranch_6/lib/gis/gisinit.c
   grass/branches/develbranch_6/lib/gis/spawn.c
use _spawnvp() not _spawnv() on windows; whitespace
Modified: grass/branches/develbranch_6/lib/gis/gisinit.c
--- grass/branches/develbranch_6/lib/gis/gisinit.c	2009-05-12 10:02:13 UTC (rev 37186)
+++ grass/branches/develbranch_6/lib/gis/gisinit.c	2009-05-12 10:05:50 UTC (rev 37187)
@@ -51,7 +51,7 @@
     G_set_program_name(pgm);
     if (strcmp(version, GIS_H_VERSION) != 0)
-        G_fatal_error(_("Incompatible library version for module. "
+	G_fatal_error(_("Incompatible library version for module. "
 			"You need to rebuild GRASS or untangle multiple installations."));
     /* Make sure location and mapset are set */
@@ -87,7 +87,7 @@
 	return 0;
     gisinit();
Modified: grass/branches/develbranch_6/lib/gis/spawn.c
--- grass/branches/develbranch_6/lib/gis/spawn.c	2009-05-12 10:02:13 UTC (rev 37186)
+++ grass/branches/develbranch_6/lib/gis/spawn.c	2009-05-12 10:05:50 UTC (rev 37187)
@@ -81,7 +81,7 @@
 	return -1;
-    return _spawnv(_P_WAIT, (char *)command, args);
+    return _spawnvp(_P_WAIT, (char *)command, args);
 #else
