[GRASS-SVN] r37205 - grass/branches/develbranch_6/scripts/m.proj
svn_grass at osgeo.org
Wed May 13 06:31:00 EDT 2009
Author: hamish
Date: 2009-05-13 06:31:00 -0400 (Wed, 13 May 2009)
New Revision: 37205
grass/branches/develbranch_6/scripts/m.proj/m.proj
obey GRASS_VERBOSE
Modified: grass/branches/develbranch_6/scripts/m.proj/m.proj
--- grass/branches/develbranch_6/scripts/m.proj/m.proj 2009-05-13 10:28:36 UTC (rev 37204)
+++ grass/branches/develbranch_6/scripts/m.proj/m.proj 2009-05-13 10:31:00 UTC (rev 37205)
@@ -99,6 +99,13 @@
LC_NUMERIC=C
export LC_NUMERIC
+# turn verbose mode on if requested either way
+if [ "$GIS_FLAG_V" -eq 1 ] ; then
+ g.message -w "The verbosity option is superseded. Use --verbose instead"
+ GRASS_VERBOSE=3
+ export GRASS_VERBOSE
+fi
#### check for cs2cs
if [ ! -x "`which cs2cs`" ] ; then
g.message -e "cs2cs program not found, install PROJ.4 first"
@@ -143,9 +150,7 @@
unset IN_PROJ
if [ $GIS_FLAG_I -eq 1 ] ; then
IN_PROJ="+proj=longlat +datum=WGS84"
- if [ $GIS_FLAG_V -eq 1 ] ; then
- g.message "Assuming LL WGS84 as input, current projection as output."
- fi
+ g.message -v "Assuming LL WGS84 as input, current projection as output."
fi
if [ $GIS_FLAG_O -eq 1 ] ; then
IN_PROJ="`g.proj -jf`"
@@ -162,9 +167,7 @@
unset OUT_PROJ
OUT_PROJ="+proj=longlat +datum=WGS84"
- g.message "Assuming current projection as input, LL WGS84 as output."
- fi
+ g.message -v "Assuming current projection as input, LL WGS84 as output."
fi
OUT_PROJ="`g.proj -jf`"
@@ -219,10 +222,10 @@
outfile="$GIS_OPT_OUTPUT"
if [ -n "$infile" ] ; then
- g.message message="input file=[$infile]"
+ g.message -v message="input file=[$infile]"
fi
if [ -n "$outfile" ] ; then
- g.message message="output file=[$outfile]"
+ g.message -v message="output file=[$outfile]"
fi
#### setup output style
