[GRASS-SVN] r37232 -
grass/branches/releasebranch_6_4/imagery/i.atcorr
svn_grass at osgeo.org
Thu May 14 04:57:21 EDT 2009
Author: neteler
Date: 2009-05-14 04:57:21 -0400 (Thu, 14 May 2009)
New Revision: 37232
grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html
final docs boost: sun position calculation added
Modified: grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html 2009-05-14 08:57:11 UTC (rev 37231)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html 2009-05-14 08:57:21 UTC (rev 37232)
@@ -493,9 +493,15 @@
# find mean elevation (target above sea level, used as initialization value in control file)
r.univar elev_int
-# create control file 'icnd.txt' for channel 4 (NIR), based on <a href="ftp://ftp.glcf.umiacs.umd.edu/glcf/Landsat/WRS2/p016/r035/p016r035_7x20020524.ETM-EarthSat-Orthorectified/p016r035_7x20020524.met">metadata</a>
+# check satellite overpass time with sun position reported in <a href="ftp://ftp.glcf.umiacs.umd.edu/glcf/Landsat/WRS2/p016/r035/p016r035_7x20020524.ETM-EarthSat-Orthorectified/p016r035_7x20020524.met">metadata</a>
+# here: SUN_AZIMUTH = 120.8810347, SUN_ELEVATION = 64.7730999
+r.sunmask -s elev=elevation out=dummy year=2002 month=5 day=24 hour=11 min=40 sec=0 timezone=-4
+# .. reports: sun azimuth: 120.555206, sun angle above horz.(refraction corrected): 65.028458
+# create control file 'icnd.txt' for channel 4 (NIR), based on metadata
+# 11:40 local time is 15.66 decimal hour GMT(decimal minutes: 40 * 100 / 60):
echo "8 - geometrical conditions=Landsat ETM+
-5 24 15.70 -78.691 35.749 - month day hh.ddd longitude latitude ("hh.ddd" is a decimal hour GMT)
+5 24 15.66 -78.691 35.749 - month day hh.ddd longitude latitude ("hh.ddd" is a decimal hour GMT)
2 - atmospheric mode=midlatitude summer
1 - aerosols model=continental
50 - visibility [km] (aerosol model concentration)
@@ -513,7 +519,8 @@
the the mean value of the elevation model. For the atmospheric correction then
the raster elevation values are used from the map.
<p>
-Note that the process is computationally intensive.
+Note that the process is computationally intensive.<br>
+Note also, that <em>i.atcorr</em> reports solar elevation angle above horizon rather than solar zenith angle.
<H2>AUTHORS</H2>
