[GRASS-SVN] r37244 - grass/trunk/imagery/i.atcorr
svn_grass at osgeo.org
Sat May 16 12:41:59 EDT 2009
Author: neteler
Date: 2009-05-16 12:41:59 -0400 (Sat, 16 May 2009)
New Revision: 37244
grass/trunk/imagery/i.atcorr/main.cpp
downsize the static cache for 32bit CPUs
Modified: grass/trunk/imagery/i.atcorr/main.cpp
--- grass/trunk/imagery/i.atcorr/main.cpp 2009-05-15 14:47:28 UTC (rev 37243)
+++ grass/trunk/imagery/i.atcorr/main.cpp 2009-05-16 16:41:59 UTC (rev 37244)
@@ -29,6 +29,7 @@
* Addition of IRS-1C LISS, Feb 2009: Markus Neteler
+TODO: use dynamic allocation for TiCache
#include <cstdlib>
@@ -131,7 +132,9 @@
enum TICacheSize
- MAX_TIs = 8192 /* this value is a guess, increase it if in general more categories are used */
+ MAX_TIs = 4096 /* this value is a guess, increase it if in general
+ * more categories are used. TODO: use dynamic allocation
+ * since 4096 is the limit on 32bit */
TransformInput tis[MAX_TIs];
float alts[MAX_TIs];
@@ -173,8 +176,9 @@
enum TIMapSize
- MAX_TICs = 8192 /* this value is a guess. It means that <size> TI's will be
- * the max combinations of vis/alt pairs */
+ MAX_TICs = 4096 /* this value is a guess. It means that <size> TI's will be
+ * the max combinations of vis/alt pairs. TODO: use dynamic allocation
TICache tic[MAX_TICs]; /* array of TICaches */
