[GRASS-SVN] r37247 - grass/branches/develbranch_6/vector/v.label.sa
svn_grass at osgeo.org
Sat May 16 12:57:18 EDT 2009
Author: wolf
Date: 2009-05-16 12:57:17 -0400 (Sat, 16 May 2009)
New Revision: 37247
grass/branches/develbranch_6/vector/v.label.sa/font.c
grass/branches/develbranch_6/vector/v.label.sa/labels.c
grass/branches/develbranch_6/vector/v.label.sa/labels.h
Fixed includes so that G_malloc and friends work. Also changed all allocs to use G_malloc and friends
Modified: grass/branches/develbranch_6/vector/v.label.sa/font.c
--- grass/branches/develbranch_6/vector/v.label.sa/font.c 2009-05-16 16:42:34 UTC (rev 37246)
+++ grass/branches/develbranch_6/vector/v.label.sa/font.c 2009-05-16 16:57:17 UTC (rev 37247)
@@ -9,6 +9,7 @@
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
+#include <grass/gisdefs.h>
#include <grass/glocale.h>
#include <grass/freetypecap.h>
#include "labels.h"
Modified: grass/branches/develbranch_6/vector/v.label.sa/labels.c
--- grass/branches/develbranch_6/vector/v.label.sa/labels.c 2009-05-16 16:42:34 UTC (rev 37246)
+++ grass/branches/develbranch_6/vector/v.label.sa/labels.c 2009-05-16 16:57:17 UTC (rev 37247)
@@ -66,7 +66,7 @@
G_debug(1, "Need to allocate %d bytes of memory",
sizeof(label_t) * label_sz);
- labels = malloc(sizeof(label_t) * label_sz);
+ labels = (label_t *) G_malloc(sizeof(label_t) * label_sz);
G_debug(1, "labels=%p", labels);
if (labels == NULL)
@@ -128,7 +128,7 @@
label_sz += 100;
G_debug(1, "Need to resize %p to %d bytes of memory",
(void *)labels, sizeof(label_t) * label_sz);
- labels = realloc(labels, sizeof(label_t) * label_sz);
+ labels = G_realloc(labels, sizeof(label_t) * label_sz);
if (labels == NULL) {
G_fatal_error(_("Cannot allocate more memory"));
@@ -153,7 +153,7 @@
if (cat < 0)
continue; /* no cat for this field */
- sql = G_malloc(sql_len);
+ sql = (char *) G_malloc(sql_len);
/* Read label from database */
if (p->overlap->answer[0] != '\0') {
sprintf(sql, "select %s,%s from %s where %s = %d",
@@ -167,7 +167,7 @@
G_debug(3, "SQL: %s", sql);
db_init_string(&query);
db_set_string(&query, sql);
- free(sql);
+ G_free(sql);
if (db_open_select_cursor(driver, &query, &cursor, DB_SEQUENTIAL) !=
DB_OK)
@@ -407,7 +407,7 @@
int i;
label_candidate_t *candidates;
- candidates = calloc(19, sizeof(label_candidate_t));
+ candidates = G_calloc(19, sizeof(label_candidate_t));
if (candidates == NULL) {
G_fatal_error("Cannot allocate memory.");
@@ -550,8 +550,8 @@
return;
- above_candidates = calloc(n, sizeof(label_candidate_t));
- below_candidates = calloc(n, sizeof(label_candidate_t));
+ above_candidates = G_calloc(n, sizeof(label_candidate_t));
+ below_candidates = G_calloc(n, sizeof(label_candidate_t));
if ((above_candidates == NULL) || (below_candidates == NULL)) {
@@ -761,15 +761,15 @@
return;
- candidates = calloc(n * 2, sizeof(label_candidate_t));
+ candidates = G_calloc(n * 2, sizeof(label_candidate_t));
for (i = 0; i < n; i++) {
memcpy(&candidates[i * 2], &above_candidates[i],
memcpy(&candidates[i * 2 + 1], &below_candidates[i],
- free(above_candidates);
- free(below_candidates);
+ G_free(above_candidates);
+ G_free(below_candidates);
n_c = n * 2;
/* pick the 32 best candidates */
@@ -783,7 +783,7 @@
Vect_destroy_line_struct(candidates[i].swathline);
- tmp = realloc(candidates, sizeof(label_candidate_t) * 32);
+ tmp = G_realloc(candidates, sizeof(label_candidate_t) * 32);
if (tmp != NULL) {
candidates = tmp;
@@ -1234,7 +1234,7 @@
label_intersection_t *li;
n = ++(labels[i].candidates[j].n_intersections);
- li = realloc(labels[i].candidates[j].intersections,
+ li = G_realloc(labels[i].candidates[j].intersections,
n * sizeof(label_intersection_t));
if (li == NULL)
G_fatal_error("\nUnable to allocate memory\n");
@@ -1247,7 +1247,7 @@
labels[i].candidates[j].intersections = li;
n = ++(labels[k].candidates[l].n_intersections);
- li = realloc(labels[k].candidates[l].intersections,
+ li = G_realloc(labels[k].candidates[l].intersections,
if (li == NULL)
Modified: grass/branches/develbranch_6/vector/v.label.sa/labels.h
--- grass/branches/develbranch_6/vector/v.label.sa/labels.h 2009-05-16 16:42:34 UTC (rev 37246)
+++ grass/branches/develbranch_6/vector/v.label.sa/labels.h 2009-05-16 16:57:17 UTC (rev 37247)
@@ -10,6 +10,7 @@
#include <string.h>
#include <math.h>
#include <grass/display.h>
#include <grass/raster.h>
#include <grass/Vect.h>
