[GRASS-SVN] r37266 - in grass/trunk: include/vect lib/vector/diglib
Mon May 18 16:04:34 EDT 2009
Author: martinl
Date: 2009-05-18 16:04:13 -0400 (Mon, 18 May 2009)
New Revision: 37266
   grass/trunk/include/vect/dig_externs.h
   grass/trunk/lib/vector/diglib/file.c
   grass/trunk/lib/vector/diglib/portable.c
doxygen update (diglib/portable.c)
use size_t instead of int
Modified: grass/trunk/include/vect/dig_externs.h
--- grass/trunk/include/vect/dig_externs.h	2009-05-18 17:52:28 UTC (rev 37265)
+++ grass/trunk/include/vect/dig_externs.h	2009-05-18 20:04:13 UTC (rev 37266)
@@ -48,22 +48,22 @@
 int dig__write_head(struct Map_info *);
 int dig__read_head(struct Map_info *);
-int dig__fread_port_D(double *, int, GVFILE *);
-int dig__fread_port_F(float *, int, GVFILE *);
-int dig__fread_port_O(off_t *, int, GVFILE *, int);
-int dig__fread_port_L(long *, int, GVFILE *);
-int dig__fread_port_S(short *, int, GVFILE *);
-int dig__fread_port_I(int *, int, GVFILE *);
-int dig__fread_port_P(plus_t *, int, GVFILE *);
-int dig__fread_port_C(char *, int, GVFILE *);
-int dig__fwrite_port_D(const double *, int, GVFILE *);
-int dig__fwrite_port_F(const float *, int, GVFILE *);
-int dig__fwrite_port_O(const off_t *, int, GVFILE *, int);
-int dig__fwrite_port_L(const long *, int, GVFILE *);
-int dig__fwrite_port_S(const short *, int, GVFILE *);
-int dig__fwrite_port_I(const int *, int, GVFILE *);
-int dig__fwrite_port_P(const plus_t *, int, GVFILE *);
-int dig__fwrite_port_C(const char *, int, GVFILE *);
+int dig__fread_port_D(double *, size_t, GVFILE *);
+int dig__fread_port_F(float *, size_t, GVFILE *);
+int dig__fread_port_O(off_t *, size_t, GVFILE *, size_t);
+int dig__fread_port_L(long *, size_t, GVFILE *);
+int dig__fread_port_S(short *, size_t, GVFILE *);
+int dig__fread_port_I(int *, size_t, GVFILE *);
+int dig__fread_port_P(plus_t *, size_t, GVFILE *);
+int dig__fread_port_C(char *, size_t, GVFILE *);
+int dig__fwrite_port_D(const double *, size_t, GVFILE *);
+int dig__fwrite_port_F(const float *, size_t, GVFILE *);
+int dig__fwrite_port_O(const off_t *, size_t, GVFILE *, size_t);
+int dig__fwrite_port_L(const long *, size_t, GVFILE *);
+int dig__fwrite_port_S(const short *, size_t, GVFILE *);
+int dig__fwrite_port_I(const int *, size_t, GVFILE *);
+int dig__fwrite_port_P(const plus_t *, size_t, GVFILE *);
+int dig__fwrite_port_C(const char *, size_t, GVFILE *);
@@ -250,7 +250,7 @@
 void dig_rewind(GVFILE * file);
 int dig_fflush(GVFILE * file);
 size_t dig_fread(void *ptr, size_t size, size_t nmemb, GVFILE * file);
-size_t dig_fwrite(void *ptr, size_t size, size_t nmemb, GVFILE * file);
+size_t dig_fwrite(const void *ptr, size_t size, size_t nmemb, GVFILE * file);
 void dig_file_init(GVFILE * file);
 int dig_file_load(GVFILE * file);
 void dig_file_free(GVFILE * file);
Modified: grass/trunk/lib/vector/diglib/file.c
--- grass/trunk/lib/vector/diglib/file.c	2009-05-18 17:52:28 UTC (rev 37265)
+++ grass/trunk/lib/vector/diglib/file.c	2009-05-18 20:04:13 UTC (rev 37266)
@@ -14,7 +14,8 @@
    This program is free software under the GNU General Public License
    (>=v2).  Read the file COPYING that comes with GRASS for details.
-   \author Dave Gerdes, Radim Blazek
+   \author Original author CERL, probably Dave Gerdes
+   \author Update to GRASS 5.7 Radim Blazek
 #include <grass/config.h>
@@ -154,7 +155,7 @@
   \return number of items written
-size_t dig_fwrite(void *ptr, size_t size, size_t nmemb, GVFILE *file)
+size_t dig_fwrite(const void *ptr, size_t size, size_t nmemb, GVFILE *file)
     if (file->loaded) {	/* using memory */
 	G_fatal_error(_("Writing to file loaded to memory not supported"));
Modified: grass/trunk/lib/vector/diglib/portable.c
--- grass/trunk/lib/vector/diglib/portable.c	2009-05-18 17:52:28 UTC (rev 37265)
+++ grass/trunk/lib/vector/diglib/portable.c	2009-05-18 20:04:13 UTC (rev 37266)
@@ -1,32 +1,32 @@
- * MODULE:       Vector library
- * AUTHOR(S):    Original author CERL, probably Dave Gerdes.
- *               Update to GRASS 5.7 Radim Blazek.
- * PURPOSE:      Lower level functions for reading/writing/manipulating vectors.
- * COPYRIGHT:    (C) 2001 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *              License (>=v2). Read the file COPYING that comes with GRASS
- *              for details.
+   \file diglib/file.c
+   \brief Vector library (diglib) - portability
+   Lower level functions for reading/writing/manipulating vectors.
+   (C) 2001-2009 by the GRASS Development Team
+   This program is free software under the GNU General Public License
+   (>=v2).  Read the file COPYING that comes with GRASS for details.
 #include <sys/types.h>
 #include <string.h>
 #include <grass/gis.h>
 #include <grass/Vect.h>
+#include <grass/glocale.h>
 extern void port_init(void);
 extern int nat_dbl;
 extern int nat_flt;
 extern int nat_lng;
-extern int nat_off_t;
+extern size_t nat_off_t;
 extern int nat_int;
 extern int nat_shrt;
@@ -65,33 +65,35 @@
     return (0);
-/***************************** READ ************************************/
-/*  These are the routines to read from the Portable Vector Format.
+  \brief Read doubles from the Portable Vector Format
    These routines must handle any type size conversions between the
    portable format and the native machine.
-   Return:  0 error
-   1 OK
+   \param[out] buf data buffer
+   \param cnt number of members
+   \param fp pointer to GVFILE
-/* read doubles from the PVF file */
-int dig__fread_port_D(double *buf, int cnt, GVFILE * fp)
+   \return 0 error
+   \return 1 OK
+int dig__fread_port_D(double *buf, size_t cnt, GVFILE * fp)
-    int i, j, ret;
+    unsigned int i, j;
+    int ret;
     unsigned char *c1, *c2;
     if (Cur_Head->dbl_quick) {
 	ret = dig_fread(buf, PORT_DOUBLE, cnt, fp);
-	if (ret != cnt)
+	if (ret != (int) cnt)
 	    return 0;
     else {
 	/* read into buffer */
 	buf_alloc(cnt * PORT_DOUBLE);
 	ret = dig_fread(buffer, PORT_DOUBLE, cnt, fp);
-	if (ret != cnt)
 	    return 0;
 	/* read from buffer in changed order */
 	c1 = (unsigned char *)buffer;
@@ -107,22 +109,35 @@
     return 1;
-/* read floats from the PVF file */
-int dig__fread_port_F(float *buf, int cnt, GVFILE * fp)
+  \brief Read floats from the Portable Vector Format
+   These routines must handle any type size conversions between the
+   portable format and the native machine.
+   \return 0 error
+   \return 1 OK
+int dig__fread_port_F(float *buf, size_t cnt, GVFILE * fp)
-    int i, j, ret;
+    int ret;
     if (Cur_Head->flt_quick) {
 	ret = dig_fread(buf, PORT_FLOAT, cnt, fp);
-	if (ret != cnt)
 	    return 0;
     else {
 	buf_alloc(cnt * PORT_FLOAT);
 	ret = dig_fread(buffer, PORT_FLOAT, cnt, fp);
-	if (ret != cnt)
 	    return 0;
@@ -138,23 +153,36 @@
     return 1;
-/* read off_ts from the PVF file */
-int dig__fread_port_O(off_t *buf, int cnt, GVFILE * fp, int port_off_t_size)
+  \brief Read off_ts from the Portable Vector Format
+   \param port_off_t_size offset
+   \return 0 error
+   \return 1 OK
+int dig__fread_port_O(off_t *buf, size_t cnt, GVFILE * fp, size_t port_off_t_size)
-    int i, j, ret;
+    int ret;
     if (Cur_Head->off_t_quick) {
 	if (nat_off_t == port_off_t_size) {
 	    ret = dig_fread(buf, port_off_t_size, cnt, fp);
-	    if (ret != cnt)
 		return 0;
 	else if (nat_off_t > port_off_t_size) {
 	    buf_alloc(cnt * port_off_t_size);
 	    ret = dig_fread(buffer, port_off_t_size, cnt, fp);
-	    if (ret != cnt)
 		return 0;
 	    /* set buffer to zero (positive numbers) */
 	    memset(buf, 0, cnt * sizeof(off_t));
@@ -181,7 +209,7 @@
 	else if (nat_off_t < port_off_t_size) {
 	    /* should never happen */
-	    G_fatal_error("Vector exceeds supported file size limit");
+	    G_fatal_error(_("Vector exceeds supported file size limit"));
     else {
@@ -189,7 +217,7 @@
-	    if (ret != cnt)
 		return 0;
@@ -214,29 +242,42 @@
     return 1;
-/* read longs from the PVF file */
-int dig__fread_port_L(long *buf, int cnt, GVFILE * fp)
+  \brief Read longs from the Portable Vector Format
+   \return 0 error
+   \return 1 OK
+int dig__fread_port_L(long *buf, size_t cnt, GVFILE * fp)
-    int i, j, ret;
+    int ret;
     if (Cur_Head->lng_quick) {
 	if (nat_lng == PORT_LONG) {
 	    ret = dig_fread(buf, PORT_LONG, cnt, fp);
-	    if (ret != cnt)
 		return 0;
 	else {
 	    buf_alloc(cnt * PORT_LONG);
 	    ret = dig_fread(buffer, PORT_LONG, cnt, fp);
-	    if (ret != cnt)
 		return 0;
 	    memset(buf, 0, cnt * sizeof(long));
@@ -266,7 +307,7 @@
-	if (ret != cnt)
 	    return 0;
@@ -292,23 +333,36 @@
     return 1;
-/* read ints from the PVF file */
-int dig__fread_port_I(int *buf, int cnt, GVFILE * fp)
+  \brief Read integers from the Portable Vector Format
+   \return 0 error
+   \return 1 OK
+int dig__fread_port_I(int *buf, size_t cnt, GVFILE * fp)
-    int i, j, ret;
+    int ret;
     if (Cur_Head->int_quick) {
 	if (nat_int == PORT_INT) {
 	    ret = dig_fread(buf, PORT_INT, cnt, fp);
-	    if (ret != cnt)
 		return 0;
 	else {
 	    buf_alloc(cnt * PORT_INT);
 	    ret = dig_fread(buffer, PORT_INT, cnt, fp);
-	    if (ret != cnt)
 		return 0;
 	    memset(buf, 0, cnt * sizeof(int));
@@ -338,7 +392,7 @@
-	if (ret != cnt)
 	    return 0;
@@ -364,23 +418,36 @@
     return 1;
-/* read shorts from the PVF file */
-int dig__fread_port_S(short *buf, int cnt, GVFILE * fp)
+  \brief Read shorts from the Portable Vector Format
+   \return 0 error
+   \return 1 OK
+int dig__fread_port_S(short *buf, size_t cnt, GVFILE * fp)
-    int i, j, ret;
+    int ret;
     if (Cur_Head->shrt_quick) {
 	if (nat_shrt == PORT_SHORT) {
 	    ret = dig_fread(buf, PORT_SHORT, cnt, fp);
-	    if (ret != cnt)
 		return 0;
 	else {
 	    buf_alloc(cnt * PORT_SHORT);
 	    if (0 >= (ret = dig_fread(buffer, PORT_SHORT, cnt, fp)))
-		if (ret != cnt)
 		    return 0;
 	    memset(buf, 0, cnt * sizeof(short));
@@ -410,7 +477,7 @@
 	ret = dig_fread(buffer, PORT_SHORT, cnt, fp);
-	if (ret != cnt)
 	    return 0;
@@ -436,20 +503,46 @@
     return 1;
-/* read chars from the PVF file */
-int dig__fread_port_C(char *buf, int cnt, GVFILE * fp)
+  \brief Read chars from the Portable Vector Format
+   \return 0 error
+   \return 1 OK
+int dig__fread_port_C(char *buf, size_t cnt, GVFILE * fp)
     int ret;
     ret = dig_fread(buf, PORT_CHAR, cnt, fp);
-    if (ret != cnt)
 	return 0;
     return 1;
-/* read plus_t from the PVF file */
-/* plus_t is defined as int so we only retype pointer and use int function */
-int dig__fread_port_P(plus_t * buf, int cnt, GVFILE * fp)
+  \brief Read plus_t from the Portable Vector Format
+   plus_t is defined as int so we only retype pointer and use int
+   function.
+   \return 0 error
+   \return 1 OK
+int dig__fread_port_P(plus_t * buf, size_t cnt, GVFILE * fp)
     int *ibuf;
@@ -458,12 +551,23 @@
     return (dig__fread_port_I(ibuf, cnt, fp));
-/***************************** WRITE ************************************/
+  \brief Write doubles to the Portable Vector Format
-int dig__fwrite_port_D(const double *buf,	/* DOUBLE */
-		       int cnt, GVFILE * fp)
+   \param buf data buffer
+   \param[in,out] fp pointer to GVFILE
+   \return 0 error
+   \return 1 OK
+int dig__fwrite_port_D(const double *buf,
+		       size_t cnt, GVFILE * fp)
-    int i, j;
@@ -486,10 +590,23 @@
     return 0;
-int dig__fwrite_port_F(const float *buf,	/* FLOAT */
+  \brief Write floats to the Portable Vector Format
+   \return 0 error
+   \return 1 OK
+int dig__fwrite_port_F(const float *buf,
-    int i, j;
@@ -512,10 +629,23 @@
     return 0;
-int dig__fwrite_port_O(const off_t *buf,	/* OFF_T */
-		       int cnt, GVFILE * fp, int port_off_t_size)
+  \brief Write off_ts to the Portable Vector Format
+   \return 0 error
+   \return 1 OK
+int dig__fwrite_port_O(const off_t *buf,
+		       size_t cnt, GVFILE * fp, size_t port_off_t_size)
-    int i, j;
@@ -559,16 +689,29 @@
     return 0;
-int dig__fwrite_port_L(const long *buf,	/* LONG */
+  \brief Write longs to the Portable Vector Format
+   \return 0 error
+   \return 1 OK
+int dig__fwrite_port_L(const long *buf,
-    int i, j;
@@ -608,10 +751,23 @@
     return 0;
-int dig__fwrite_port_I(const int *buf,	/* INT */
+  \brief Write integers to the Portable Vector Format
+   \return 0 error
+   \return 1 OK
+int dig__fwrite_port_I(const int *buf,
-    int i, j;
@@ -651,10 +807,23 @@
     return 0;
-int dig__fwrite_port_S(const short *buf,	/* SHORT */
+  \brief Write shorts to the Portable Vector Format
+   \return 0 error
+   \return 1 OK
+int dig__fwrite_port_S(const short *buf,
-    int i, j;
@@ -694,15 +863,41 @@
     return 0;
-int dig__fwrite_port_P(const plus_t * buf,	/* PLUS_T->INT */
+  \brief Write plus_t to the Portable Vector Format
+   \return 0 error
+   \return 1 OK
+int dig__fwrite_port_P(const plus_t * buf,
     return (dig__fwrite_port_I((int *)buf, cnt, fp));
-int dig__fwrite_port_C(const char *buf,	/* CHAR */
+  \brief Write chars to the Portable Vector Format
+   \return 0 error
+   \return 1 OK
+int dig__fwrite_port_C(const char *buf,
     if (dig_fwrite(buf, PORT_CHAR, cnt, fp) == cnt)
 	return 1;
@@ -710,10 +905,15 @@
     return 0;
-/* set portable info structure to byte order of file */
+  \brief Set portable info structure to byte order of file
+  \param port pointer to Port_info
+  \param byte_order ENDIAN_BIG or ENDIAN_LITTLE
 void dig_init_portable(struct Port_info *port, int byte_order)
-    int i;
+    unsigned int i;
     port_init();
@@ -800,13 +1000,25 @@
     return;
-/* set current portable info */
+  \brief set current portable info
+  \return 0
 int dig_set_cur_port(struct Port_info *port)
     Cur_Head = port;
     return 0;
+  \brief Get byte order
+  \return ENDIAN_LITTLE
+  \return ENDIAN_BIG
 int dig__byte_order_out()
     if (dbl_order == ENDIAN_LITTLE)
