[GRASS-SVN] r37270 - in grass/trunk: include/vect lib/vector/Vlib
lib/vector/diglib
svn_grass at osgeo.org
Mon May 18 17:05:06 EDT 2009
Author: martinl
Date: 2009-05-18 17:05:06 -0400 (Mon, 18 May 2009)
New Revision: 37270
grass/trunk/include/vect/dig_externs.h
grass/trunk/lib/vector/Vlib/cindex.c
grass/trunk/lib/vector/Vlib/sindex.c
grass/trunk/lib/vector/diglib/file.c
grass/trunk/lib/vector/diglib/port_init.c
grass/trunk/lib/vector/diglib/portable.c
grass/trunk/lib/vector/diglib/spindex.c
grass/trunk/lib/vector/diglib/spindex_rw.c
vlib/diglib: doxygen update
use const / size_t
Modified: grass/trunk/include/vect/dig_externs.h
--- grass/trunk/include/vect/dig_externs.h 2009-05-18 21:02:34 UTC (rev 37269)
+++ grass/trunk/include/vect/dig_externs.h 2009-05-18 21:05:06 UTC (rev 37270)
@@ -177,7 +177,7 @@
void dig_spidx_free_isles(struct Plus_head *);
void dig_spidx_free(struct Plus_head *);
int dig_write_spidx(GVFILE *, struct Plus_head *);
-int dig_dump_spidx(FILE *, struct Plus_head *);
+int dig_dump_spidx(FILE *, const struct Plus_head *);
int dig_read_spidx(GVFILE *, struct Plus_head *);
/* category index */
Modified: grass/trunk/lib/vector/Vlib/cindex.c
--- grass/trunk/lib/vector/Vlib/cindex.c 2009-05-18 21:02:34 UTC (rev 37269)
+++ grass/trunk/lib/vector/Vlib/cindex.c 2009-05-18 21:05:06 UTC (rev 37270)
@@ -1,7 +1,7 @@
* \file Vlib/cindex.c
- * \brief Vector library - Category index.
+ * \brief Vector library - category index.
* Higher level functions for reading/writing/manipulating vectors.
@@ -432,7 +432,7 @@
- \brief Save category index
+ \brief Save category index to file (cidx)
\param Map vector map
Modified: grass/trunk/lib/vector/Vlib/sindex.c
--- grass/trunk/lib/vector/Vlib/sindex.c 2009-05-18 21:02:34 UTC (rev 37269)
+++ grass/trunk/lib/vector/Vlib/sindex.c 2009-05-18 21:05:06 UTC (rev 37270)
@@ -1,5 +1,5 @@
- \file sindex.c
+ \file Vlib/sindex.c
\brief Vector library - spatial index
@@ -11,6 +11,7 @@
(>=v2). Read the file COPYING that comes with GRASS for details.
\author Radim Blazek
+ \author Martin Landa <landa.martin gmail.com> (storing sidx to file)
#include <stdlib.h>
@@ -21,7 +22,7 @@
#include <grass/glocale.h>
- \brief Init spatial index
+ \brief Initialize spatial index structure
\param si pointer to spatial index structure
@@ -51,7 +52,7 @@
- \brief Add a new item to spatial index
+ \brief Add a new item to spatial index structure
\param[in,out] si pointer to spatial index structure
\param id item identifier
@@ -75,7 +76,7 @@
- \brief Delete item from spatial index
+ \brief Delete item from spatial index structure
@@ -112,8 +113,7 @@
Map must be opened on level 2.
\param[in,out] Map pointer to vector map
- \param out print progress here
\return 0 OK
\return 1 error
@@ -121,7 +121,7 @@
if (Map->level < 2) {
G_fatal_error(_("Unable to build spatial index from topology, "
- "vector map is not opened at topo level 2"));
+ "vector map is not opened at topology level 2"));
if (!(Map->plus.Spidx_built)) {
return (Vect_build_sidx_from_topo(Map));
@@ -130,7 +130,7 @@
- \brief Create spatial index from topo if necessary
+ \brief Create spatial index from topology if necessary
\param Map pointer to vector map
@@ -243,7 +243,7 @@
\param box bounding box
- \param list pointer to list where selected items are stored
+ \param[out] list pointer to list where selected items are stored
\return number of selected items
@@ -255,7 +255,7 @@
G_debug(3, "Vect_spatial_index_select()");
- list->n_values = 0;
+ Vect_reset_list(list);
rect.boundary[0] = box->W;
rect.boundary[1] = box->S;
@@ -266,5 +266,7 @@
RTreeSearch(si->root, &rect, (void *)_add_item, list);
G_debug(3, " %d items selected", list->n_values);
return (list->n_values);
Modified: grass/trunk/lib/vector/diglib/file.c
--- grass/trunk/lib/vector/diglib/file.c 2009-05-18 21:02:34 UTC (rev 37269)
+++ grass/trunk/lib/vector/diglib/file.c 2009-05-18 21:05:06 UTC (rev 37270)
@@ -1,7 +1,7 @@
\file diglib/file.c
- \brief Vector library (diglib) - file management
+ \brief Vector library - file management (lower level functions)
Lower level functions for reading/writing/manipulating vectors.
Modified: grass/trunk/lib/vector/diglib/port_init.c
--- grass/trunk/lib/vector/diglib/port_init.c 2009-05-18 21:02:34 UTC (rev 37269)
+++ grass/trunk/lib/vector/diglib/port_init.c 2009-05-18 21:05:06 UTC (rev 37270)
@@ -1,62 +1,87 @@
- * MODULE: Vector library
- * AUTHOR(S): Original author CERL, probably Dave Gerdes.
- * Update to GRASS 5.7 Radim Blazek.
- * PURPOSE: Lower level functions for reading/writing/manipulating vectors.
- * COPYRIGHT: (C) 2001 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
-#include <grass/config.h>
-#include <stdio.h>
-#include <sys/types.h>
-#include <grass/Vect.h>
+ \file diglib/port_init.c
- ** Written by Dave Gerdes 9/1988
- ** US Army Construction Engineering Research Lab
+ \brief Vector library - portability (lower level functions)
+ Lower level functions for reading/writing/manipulating vectors.
- ** This code is a quick hack to allow the writing of portable
- ** binary data files.
- ** The approach is to take known values and compare them against
- ** the current machine's internal representation. A cross reference
- ** table is then built, and then all file reads and writes must go
- ** through these routines to correct the numbers if need be.
- ** As long as the byte switching is symetrical, the conversion routines
- ** will work both directions.
+ This code is a quick hack to allow the writing of portable
+ binary data files.
+ The approach is to take known values and compare them against
+ the current machine's internal representation. A cross reference
+ table is then built, and then all file reads and writes must go
+ through these routines to correct the numbers if need be.
- ** The integer test patterns are quite simple, and their choice was
- ** arbitrary, but the float and double valued were more critical.
+ As long as the byte switching is symetrical, the conversion routines
+ will work both directions.
+ The integer test patterns are quite simple, and their choice was
+ arbitrary, but the float and double valued were more critical.
- ** I did not have a specification for IEEE to go by, so it is possible
- ** that I have missed something. My criteria were:
- ** First, true IEEE numbers had to be chosen to avoid getting an FPE.
- ** Second, every byte in the test pattern had to be unique. And
- ** finally, the number had to not be sensitive to rounding by the
- ** specific hardware implementation.
- ** By experimentation it was found that the number 1.3333 met
- ** all these criteria for both floats and doubles
+ I did not have a specification for IEEE to go by, so it is possible
+ that I have missed something. My criteria were:
- ** See the discourse at the end of this file for more information
+ First, true IEEE numbers had to be chosen to avoid getting an FPE.
+ Second, every byte in the test pattern had to be unique. And
+ finally, the number had to not be sensitive to rounding by the
+ specific hardware implementation.
+ By experimentation it was found that the number 1.3333 met
+ all these criteria for both floats and doubles
+ See the discourse at the end of this file for more information
+ The 3.0 dig, and dig_plus files are inherently non-portable. This
+ can be seen in moving files between a SUN 386i and other SUN machines.
+ The recommended way to transport files was always to convert to ASCII
+ (b.a.vect) and copy the ASCII files: dig_ascii and dig_att to the
+ destination machine.
+ The problem lies in the way that different architectures internally
+ represent data. If a number is internally store as 0x01020304 on
+ a 680x0 family machine, the same number will be stored as
+ 0x04030201 on an 80386 class machine.
+ The CERL port of GRASS to the Compaq 386 already has code to deal
+ with this incompatibility. This code converts all files that are written
+ out to conform to the 680x0 standard. These binary files can then be
+ shared between machines without conversion.
+ This code is designed to work with the majority of computers in use
+ today that fit the following requirements:
+ byte == 8 bits
+ int == 4 bytes
+ long == 4 bytes
+ double == IEEE standard 64 bit
+ float == IEEE standard 32 bit
+ bytes can be swapped around in any reasonable way, but bits within each
+ byte must be maintained in normal high to low ordering: 76543210
+ is this a problem?
+ If this ability is desired on a SUN 386i, for example, you simply
+ define the compiler flag CERL_PORTABLE in the src/CMD/makehead file
+ and recompile all of the mapdev programs.
+ needs update, makehead/mapdev no longer exist
+ Binary DLG files are NOT supported by this code, and will continue to
+ be non-portable between different architectures.
+ applies to the files coor/topo/cidx, needs testing
+ (C) 2001-2009 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Original author CERL, probably Dave Gerdes
+ \author Update to GRASS 5.7 Radim Blazek
+#include <grass/config.h>
+#include <stdio.h>
+#include <sys/types.h>
+#include <grass/Vect.h>
+#include <grass/glocale.h>
#define TEST_PATTERN 1.3333
#define OFF_T_TEST 0x0102030405060708
#define LONG_TEST 0x01020304
@@ -106,7 +131,6 @@
* match search_value against each char in basis.
* return offset or -1 if not found
static int find_offset(const unsigned char *basis, unsigned char search_value,
int size)
@@ -130,7 +154,7 @@
int off = find_offset(pattern, cmpr[i], nat_size);
if (off < 0)
- G_fatal_error("could not find '%x' in %s", cmpr[i], typename);
+ G_fatal_error(_("Unable to find '%x' in %s"), cmpr[i], typename);
cnvrt[i] = off;
@@ -153,6 +177,9 @@
return ENDIAN_OTHER;
+ \brief Initialize structures
void port_init(void)
static int done;
@@ -202,46 +229,3 @@
find_offsets(&u_s, shrt_cnvrt, shrt_cmpr, PORT_SHORT, nat_shrt,
"short");
- comment copied from port_test.c
- MM Feb 2009
- The 3.0 dig, and dig_plus files are inherently non-portable. This
- can be seen in moving files between a SUN 386i and other SUN machines.
- The recommended way to transport files was always to convert to ASCII
- (b.a.vect) and copy the ASCII files: dig_ascii and dig_att to the
- destination machine.
- The problem lies in the way that different architectures internally
- represent data. If a number is internally store as 0x01020304 on
- a 680x0 family machine, the same number will be stored as
- 0x04030201 on an 80386 class machine.
- The CERL port of GRASS to the Compaq 386 already has code to deal
- with this incompatibility. This code converts all files that are written
- out to conform to the 680x0 standard. These binary files can then be
- shared between machines without conversion.
- This code is designed to work with the majority of computers in use
- today that fit the following requirements:
- byte == 8 bits
- int == 4 bytes
- long == 4 bytes
- double == IEEE standard 64 bit
- float == IEEE standard 32 bit
- bytes can be swapped around in any reasonable way, but bits within each
- byte must be maintained in normal high to low ordering: 76543210
- is this a problem?
- If this ability is desired on a SUN 386i, for example, you simply
- define the compiler flag CERL_PORTABLE in the src/CMD/makehead file
- and recompile all of the mapdev programs.
- needs update, makehead/mapdev no longer exist
- Binary DLG files are NOT supported by this code, and will continue to
- be non-portable between different architectures.
- applies to the files coor/topo/cidx, needs testing
- -dave gerdes
Modified: grass/trunk/lib/vector/diglib/portable.c
--- grass/trunk/lib/vector/diglib/portable.c 2009-05-18 21:02:34 UTC (rev 37269)
+++ grass/trunk/lib/vector/diglib/portable.c 2009-05-18 21:05:06 UTC (rev 37270)
@@ -1,7 +1,7 @@
\file diglib/file.c
- \brief Vector library (diglib) - portability
Modified: grass/trunk/lib/vector/diglib/spindex.c
--- grass/trunk/lib/vector/diglib/spindex.c 2009-05-18 21:02:34 UTC (rev 37269)
+++ grass/trunk/lib/vector/diglib/spindex.c 2009-05-18 21:05:06 UTC (rev 37270)
@@ -1,19 +1,19 @@
+ \file diglib/spindex.c
+ \brief Vector library - spatial index (lower level functions)
- * \file spindex.c
- * \brief Vector library - spatial index (lower level functions)
- * Lower level functions for reading/writing/manipulating vectors.
- * (C) 2001 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author CERL (probably Dave Gerdes), Radim Blazek
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c 2009-05-18 21:02:34 UTC (rev 37269)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c 2009-05-18 21:05:06 UTC (rev 37270)
@@ -1,28 +1,37 @@
- * AUTHOR(S): Radim Blazek.
- * for details.
+ \brief Vector library - spatial index - read/write (lower level functions)
#include <stdlib.h>
#include <string.h>
+ \brief Write spatial index to the file
+ \param[in,out] fp pointer to GVFILE
+ \param ptr pointer to Plus_head structure
-int dig_Wr_spindx_head(GVFILE * fp, struct Plus_head *ptr)
+ \return 0 on success
+ \return -1 on error
+static int dig_Wr_spindx_head(GVFILE * fp, struct Plus_head *ptr)
unsigned char buf[5];
long length = 42;
@@ -36,7 +45,7 @@
buf[2] = GV_SIDX_EARLIEST_MAJOR;
buf[3] = GV_SIDX_EARLIEST_MINOR;
buf[4] = ptr->spidx_port.byte_order;
- if (0 >= dig__fwrite_port_C(buf, 5, fp))
+ if (0 >= dig__fwrite_port_C((const char *)buf, 5, fp))
return (-1);
/* get required offset size */
@@ -60,7 +69,7 @@
/* byte 10 : dimension 2D or 3D */
buf[0] = ptr->spidx_with_z;
- if (0 >= dig__fwrite_port_C(buf, 1, fp))
+ if (0 >= dig__fwrite_port_C((const char*) buf, 1, fp))
return (-1);
/* bytes 11 - 38 (large files 11 - 66) : Offsets */
@@ -79,30 +88,38 @@
if (0 >= dig__fwrite_port_O(&(ptr->Hole_spidx_offset), 1, fp, ptr->off_t_size))
return (-1);
- G_debug(3, "spidx offset node = %ld line = %ld, area = %ld isle = %ld",
- ptr->Node_spidx_offset, ptr->Line_spidx_offset,
- ptr->Area_spidx_offset, ptr->Isle_spidx_offset);
+ G_debug(3, "spidx offset node = %lu line = %lu, area = %lu isle = %lu",
+ (long unsigned) ptr->Node_spidx_offset, (long unsigned) ptr->Line_spidx_offset,
+ (long unsigned) ptr->Area_spidx_offset, (long unsigned) ptr->Isle_spidx_offset);
/* bytes 39 - 42 (large files 67 - 74) : Offsets */
if (0 >= dig__fwrite_port_O(&(ptr->coor_size), 1, fp, ptr->off_t_size))
return (-1);
- G_debug(2, "spidx body offset %ld", dig_ftell(fp));
+ G_debug(2, "spidx body offset %lu", (long unsigned) dig_ftell(fp));
return (0);
+ \brief Read spatial index to the file
+ \param fp pointer to GVFILE
+ \param[in,out] ptr pointer to Plus_head structure
-int dig_Rd_spindx_head(GVFILE * fp, struct Plus_head *ptr)
+static int dig_Rd_spindx_head(GVFILE * fp, struct Plus_head *ptr)
int byte_order;
- long coor_size;
+ off_t coor_size;
dig_rewind(fp);
/* bytes 1 - 5 */
- if (0 >= dig__fread_port_C(buf, 5, fp))
+ if (0 >= dig__fread_port_C((char*) buf, 5, fp))
return (-1);
ptr->spidx_Version_Major = buf[0];
ptr->spidx_Version_Minor = buf[1];
@@ -110,8 +127,7 @@
ptr->spidx_Back_Minor = buf[3];
byte_order = buf[4];
- G_debug(2,
- "Sidx header: file version %d.%d , supported from GRASS version %d.%d",
+ G_debug(2, "Sidx header: file version %d.%d , supported from GRASS version %d.%d",
ptr->spidx_Version_Major, ptr->spidx_Version_Minor,
ptr->spidx_Back_Major, ptr->spidx_Back_Minor);
@@ -125,17 +141,17 @@
if (ptr->spidx_Back_Major > GV_SIDX_VER_MAJOR ||
ptr->spidx_Back_Minor > GV_SIDX_VER_MINOR) {
/* This version of GRASS lib is lower than the oldest which can read this format */
- G_fatal_error
- ("Spatial index format version %d.%d is not supported by this release."
- " Try to rebuild topology or upgrade GRASS.",
- ptr->spidx_Version_Major, ptr->spidx_Version_Minor);
+ G_fatal_error(_("Spatial index format version %d.%d is not "
+ "supported by this release."
+ " Try to rebuild topology or upgrade GRASS."),
+ ptr->spidx_Version_Major, ptr->spidx_Version_Minor);
return (-1);
- G_warning
- ("Your GRASS version does not fully support spatial index format %d.%d of the vector."
- " Consider to rebuild topology or upgrade GRASS.",
+ G_warning(_("Your GRASS version does not fully support "
+ "spatial index format %d.%d of the vector."
+ " Consider to rebuild topology or upgrade GRASS."),
dig_init_portable(&(ptr->spidx_port), byte_order);
@@ -147,7 +163,7 @@
G_debug(2, " header size %ld", ptr->spidx_head_size);
- if (0 >= dig__fread_port_C(buf, 1, fp))
+ if (0 >= dig__fread_port_C((char *)buf, 1, fp))
return (-1);
ptr->spidx_with_z = buf[0];
G_debug(2, " with_z %d", ptr->spidx_with_z);
@@ -181,19 +197,28 @@
if (0 >= dig__fread_port_O(&coor_size, 1, fp, ptr->off_t_size))
return (-1);
- G_debug(2, " coor size %ld", coor_size);
+ G_debug(2, " coor size %lu", (long unsigned) coor_size);
dig_fseek(fp, ptr->spidx_head_size, SEEK_SET);
return (0);
-int rtree_dump_node(FILE * fp, struct Node *n, int with_z);
+static int rtree_dump_node(FILE *, const struct Node *, int);
-/* Dump RTree branch to file */
-int rtree_dump_branch(FILE * fp, struct Branch *b, int with_z, int level)
+ \brief Dump R-tree branch to the file
+ \param fp pointer to FILE
+ \param b pointer to Branch structure
+ \param with_z non-zero value for 3D vector data
+ \param level level value
+ \return 0
+static int rtree_dump_branch(FILE * fp, const struct Branch *b, int with_z, int level)
- struct Rect *r;
+ const struct Rect *r;
r = &(b->rect);
@@ -209,8 +234,16 @@
return 0;
-/* Dump RTree node to file */
+ \brief Dump R-tree node to the file
+ \param n pointer to Node structure
+ \return 0
+int rtree_dump_node(FILE * fp, const struct Node *n, int with_z)
int i, nn;
@@ -231,12 +264,22 @@
return 0;
-int rtree_write_node(GVFILE * fp, struct Node *n, int with_z);
+static int rtree_write_node(GVFILE *, const struct Node *, int);
-/* Write RTree branch to file */
-int rtree_write_branch(GVFILE * fp, struct Branch *b, int with_z, int level)
+ \brief Write R-tree node to the file
+static int rtree_write_branch(GVFILE * fp, const struct Branch *b, int with_z, int level)
- struct Rect *r;
int i;
r = &(b->rect);
@@ -263,8 +306,17 @@
return 0;
-/* Write RTree node to file */
+int rtree_write_node(GVFILE * fp, const struct Node *n, int with_z)
int i, nn;
@@ -289,10 +341,20 @@
return 0;
-int rtree_read_node(GVFILE * fp, struct Node *n, int with_z);
+static int rtree_read_node(GVFILE * fp, struct Node *n, int with_z);
-/* Read RTree branch from file */
-int rtree_read_branch(GVFILE * fp, struct Branch *b, int with_z, int level)
+ \brief Read R-tree branch from the file
+static int rtree_read_branch(GVFILE * fp, struct Branch *b, int with_z, int level)
struct Rect *r;
int i;
@@ -328,7 +390,17 @@
return 0;
-/* Read RTree node from file */
+ \brief Read R-tree node from the file
int level, count, i;
@@ -353,7 +425,14 @@
return 0;
-/* Write spatial index */
+ \param[out] fp pointer to GVFILE
+ \param Plus pointer to Plus_head structure
+ \return 0
int dig_write_spidx(GVFILE * fp, struct Plus_head *Plus)
dig_set_cur_port(&(Plus->spidx_port));
@@ -379,7 +458,14 @@
return 0;
-/* Read spatial index file */
+ \brief Read spatial index from the file
+ \param[in,out] Plus pointer to Plus_head structure
+ \return 0
int dig_read_spidx(GVFILE * fp, struct Plus_head *Plus)
G_debug(1, "dig_read_spindx()");
@@ -406,8 +492,15 @@
return 0;
-/* Dump spatial index */
-int dig_dump_spidx(FILE * fp, struct Plus_head *Plus)
+ \brief Dump spatial index
+ \param[out] fp pointe to FILE
+ \return 0
+int dig_dump_spidx(FILE * fp, const struct Plus_head *Plus)
fprintf(fp, "Nodes\n");
