[GRASS-SVN] r37280 - in grass/branches/develbranch_6: . include
include/Make lib/vector/Vlib vector/v.select
svn_grass at osgeo.org
Tue May 19 09:12:36 EDT 2009
Author: martinl
Date: 2009-05-19 09:12:35 -0400 (Tue, 19 May 2009)
New Revision: 37280
Added:
grass/branches/develbranch_6/lib/vector/Vlib/geos.c
grass/branches/develbranch_6/vector/v.select/geos.c
grass/branches/develbranch_6/vector/v.select/overlap.c
grass/branches/develbranch_6/vector/v.select/proto.h
grass/branches/develbranch_6/configure
grass/branches/develbranch_6/configure.in
grass/branches/develbranch_6/include/Make/Grass.make.in
grass/branches/develbranch_6/include/Make/Platform.make.in
grass/branches/develbranch_6/include/Vect.h
grass/branches/develbranch_6/include/config.h.in
grass/branches/develbranch_6/lib/vector/Vlib/buffer2.c
grass/branches/develbranch_6/lib/vector/Vlib/dgraph.c
grass/branches/develbranch_6/lib/vector/Vlib/e_intersect.c
grass/branches/develbranch_6/vector/v.select/description.html
grass/branches/develbranch_6/vector/v.select/main.c
GEOS support backported from trunk (r36512, r36513, r36514, r36538 and r36546)
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure 2009-05-19 12:50:24 UTC (rev 37279)
+++ grass/branches/develbranch_6/configure 2009-05-19 13:12:35 UTC (rev 37280)
@@ -79,6 +79,9 @@
--with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)"
ac_help="$ac_help
+ --with-geos[=path/geos-config] enable GEOS support (geos-config with path, \
+e.g. '--with-geos=/usr/local/bin/geos-config', default: no)"
+ac_help="$ac_help
--with-includes=DIRS site include files are in DIRS"
ac_help="$ac_help
--with-libs=DIRS site library files are in DIRS"
@@ -737,7 +740,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:741: checking host system type" >&5
+echo "configure:744: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -760,7 +763,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:764: checking for $ac_word" >&5
+echo "configure:767: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -787,7 +790,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:791: checking for $ac_word" >&5
+echo "configure:794: checking for $ac_word" >&5
@@ -835,7 +838,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:839: checking for $ac_word" >&5
+echo "configure:842: checking for $ac_word" >&5
@@ -864,7 +867,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:868: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:871: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -875,12 +878,12 @@
cat > conftest.$ac_ext << EOF
-#line 879 "configure"
+#line 882 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -906,19 +909,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:910: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:913: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:915: checking whether we are using GNU C" >&5
+echo "configure:918: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:922: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:925: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -936,7 +939,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:940: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:943: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -965,10 +968,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:969: checking for Cygwin environment" >&5
+echo "configure:972: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 972 "configure"
+#line 975 "configure"
int main() {
@@ -979,7 +982,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:983: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:986: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -995,17 +998,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:999: checking for mingw32 environment" >&5
+echo "configure:1002: checking for mingw32 environment" >&5
-#line 1002 "configure"
+#line 1005 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:1009: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1012: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1023,7 +1026,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1027: checking for executable suffix" >&5
+echo "configure:1030: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1042,23 +1045,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1046: checking for full floating-point support" >&5
+echo "configure:1049: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1051: checking whether "cc -mieee" works" >&5
+echo "configure:1054: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1055 "configure"
+#line 1058 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1062: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1065: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1074,7 +1077,7 @@
else
-#line 1078 "configure"
+#line 1081 "configure"
#include <float.h>
@@ -1088,7 +1091,7 @@
EOF
-if { (eval echo configure:1092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1101,14 +1104,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1105: checking for full floating-point support with -mieee" >&5
+echo "configure:1108: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1112 "configure"
+#line 1115 "configure"
#include <float.h>
@@ -1122,7 +1125,7 @@
EOF
-if { (eval echo configure:1126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1159,7 +1162,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1163: checking for $ac_word" >&5
+echo "configure:1166: checking for $ac_word" >&5
case "$pwd" in
@@ -1197,7 +1200,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1201: checking for source directory" >&5
+echo "configure:1204: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1208,7 +1211,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1212: checking for build directory" >&5
+echo "configure:1215: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1293,7 +1296,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1297: checking for MacOSX App" >&5
+echo "configure:1300: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1316,7 +1319,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1320: checking how to build libraries" >&5
+echo "configure:1323: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1359,7 +1362,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:1363: checking for $ac_word" >&5
+echo "configure:1366: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1384,7 +1387,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1388: checking how to run the C preprocessor" >&5
+echo "configure:1391: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -1397,13 +1400,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 1401 "configure"
+#line 1404 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1407: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1410: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -1414,13 +1417,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 1418 "configure"
+#line 1421 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1424: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1431,13 +1434,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 1435 "configure"
+#line 1438 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1441: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1444: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1465,7 +1468,7 @@
# Step 0.a: Enable 64 bit support?
echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1469: checking if 64bit support is requested" >&5
+echo "configure:1472: checking if 64bit support is requested" >&5
# Check whether --enable-64bit or --disable-64bit was given.
if test "${enable_64bit+set}" = set; then
enableval="$enable_64bit"
@@ -1485,7 +1488,7 @@
# Step 0.b: Enable Solaris 64 bit VIS support?
echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1489: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1492: checking if 64bit Sparc VIS support is requested" >&5
# Check whether --enable-64bit-vis or --disable-64bit-vis was given.
if test "${enable_64bit_vis+set}" = set; then
enableval="$enable_64bit_vis"
@@ -1509,7 +1512,7 @@
# there are a few systems, like Next, where this doesn't work.
echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1513: checking system version (for dynamic loading)" >&5
+echo "configure:1516: checking system version (for dynamic loading)" >&5
if test -f /usr/lib/NextStep/software_version; then
system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
else
@@ -1535,13 +1538,13 @@
# Linux can use either -ldl or -ldld for dynamic loading.
echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1539: checking for dlopen in -ldl" >&5
+echo "configure:1542: checking for dlopen in -ldl" >&5
ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldl $LIBS"
-#line 1545 "configure"
+#line 1548 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1552,7 +1555,7 @@
dlopen()
; return 0; }
EOF
-if { (eval echo configure:1556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1599,7 +1602,7 @@
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-echo "configure:1603: checking for $ac_word" >&5
+echo "configure:1606: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1728,13 +1731,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1732: checking for gettimeofday in -lbsd" >&5
+echo "configure:1735: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 1738 "configure"
+#line 1741 "configure"
@@ -1745,7 +1748,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1752: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1786,13 +1789,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1790: checking for inet_ntoa in -lbind" >&5
+echo "configure:1793: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1796 "configure"
+#line 1799 "configure"
@@ -1803,7 +1806,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1864,13 +1867,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1868: checking for shl_load in -ldld" >&5
+echo "configure:1871: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 1874 "configure"
+#line 1877 "configure"
@@ -1881,7 +1884,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1946,13 +1949,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:1950: checking for shl_load in -ldld" >&5
+echo "configure:1953: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 1956 "configure"
+#line 1959 "configure"
@@ -1963,7 +1966,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2085,15 +2088,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2089: checking for dld.h" >&5
+echo "configure:2092: checking for dld.h" >&5
-#line 2092 "configure"
+#line 2095 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2097: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2100: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2153,15 +2156,15 @@
else
-echo "configure:2157: checking for dld.h" >&5
+echo "configure:2160: checking for dld.h" >&5
-#line 2160 "configure"
+#line 2163 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2165: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2168: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2258,9 +2261,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2262: checking for ELF" >&5
+echo "configure:2265: checking for ELF" >&5
-#line 2264 "configure"
+#line 2267 "configure"
#ifdef __ELF__
@@ -2290,15 +2293,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2294: checking for dlfcn.h" >&5
+echo "configure:2297: checking for dlfcn.h" >&5
-#line 2297 "configure"
+#line 2300 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2302: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2305: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2322,9 +2325,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2326: checking for ELF" >&5
+echo "configure:2329: checking for ELF" >&5
-#line 2328 "configure"
+#line 2331 "configure"
#ifdef __ELF__
@@ -2648,17 +2651,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2652: checking for ld accepts -Bexport flag" >&5
+echo "configure:2655: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2655 "configure"
+#line 2658 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2662: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2665: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -3044,6 +3047,15 @@
# With includes and libs options
+# Check whether --with-geos or --without-geos was given.
+if test "${with_geos+set}" = set; then
+ withval="$with_geos"
+else
+ with_geos="no"
+fi
# Check whether --with-includes or --without-includes was given.
if test "${with_includes+set}" = set; then
withval="$with_includes"
@@ -3457,7 +3469,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3461: checking for additional include dirs" >&5
+echo "configure:3473: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3480,7 +3492,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3484: checking for additional library dirs" >&5
+echo "configure:3496: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3514,7 +3526,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3518: checking for a BSD compatible install" >&5
+echo "configure:3530: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3567,7 +3579,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:3571: checking for $ac_word" >&5
+echo "configure:3583: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3598,13 +3610,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3602: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3614: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3608 "configure"
+#line 3620 "configure"
@@ -3615,7 +3627,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3640,7 +3652,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3644: checking for $ac_word" >&5
+echo "configure:3656: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3680,7 +3692,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3684: checking for $ac_word" >&5
+echo "configure:3696: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3711,7 +3723,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3715: checking for $ac_word" >&5
+echo "configure:3727: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3749,7 +3761,7 @@
-echo "configure:3753: checking for $ac_word" >&5
+echo "configure:3765: checking for $ac_word" >&5
@@ -3778,7 +3790,7 @@
-echo "configure:3782: checking for $ac_word" >&5
+echo "configure:3794: checking for $ac_word" >&5
@@ -3809,7 +3821,7 @@
-echo "configure:3813: checking for $ac_word" >&5
+echo "configure:3825: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3838,7 +3850,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3842: checking for $ac_word" >&5
+echo "configure:3854: checking for $ac_word" >&5
case "$PERL" in
@@ -3869,10 +3881,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3873: checking for ANSI C header files" >&5
+echo "configure:3885: checking for ANSI C header files" >&5
-#line 3876 "configure"
+#line 3888 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -3880,7 +3892,7 @@
#include <float.h>
EOF
-{ (eval echo configure:3884: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3896: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3897,7 +3909,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3901 "configure"
+#line 3913 "configure"
#include <string.h>
EOF
@@ -3915,7 +3927,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3919 "configure"
+#line 3931 "configure"
#include <stdlib.h>
EOF
@@ -3936,7 +3948,7 @@
else
-#line 3940 "configure"
+#line 3952 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3947,7 +3959,7 @@
exit (0); }
EOF
-if { (eval echo configure:3951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -3974,15 +3986,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3978: checking for $ac_hdr" >&5
+echo "configure:3990: checking for $ac_hdr" >&5
-#line 3981 "configure"
+#line 3993 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3986: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3998: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4011,15 +4023,15 @@
do
-echo "configure:4015: checking for $ac_hdr" >&5
+echo "configure:4027: checking for $ac_hdr" >&5
-#line 4018 "configure"
+#line 4030 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4023: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4035: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4048,15 +4060,15 @@
do
-echo "configure:4052: checking for $ac_hdr" >&5
+echo "configure:4064: checking for $ac_hdr" >&5
-#line 4055 "configure"
+#line 4067 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4060: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4072: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4085,15 +4097,15 @@
do
-echo "configure:4089: checking for $ac_hdr" >&5
+echo "configure:4101: checking for $ac_hdr" >&5
-#line 4092 "configure"
+#line 4104 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4097: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4109: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4122,15 +4134,15 @@
do
-echo "configure:4126: checking for $ac_hdr" >&5
+echo "configure:4138: checking for $ac_hdr" >&5
-#line 4129 "configure"
+#line 4141 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4134: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4146: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4156,10 +4168,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4160: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4172: checking whether time.h and sys/time.h may both be included" >&5
-#line 4163 "configure"
+#line 4175 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4168,7 +4180,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4172: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4184: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4188,10 +4200,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4192: checking for off_t" >&5
+echo "configure:4204: checking for off_t" >&5
-#line 4195 "configure"
+#line 4207 "configure"
#if STDC_HEADERS
@@ -4218,10 +4230,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4222: checking for uid_t in sys/types.h" >&5
+echo "configure:4234: checking for uid_t in sys/types.h" >&5
-#line 4225 "configure"
+#line 4237 "configure"
EOF
@@ -4249,10 +4261,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4253: checking return type of signal handlers" >&5
+echo "configure:4265: checking return type of signal handlers" >&5
-#line 4256 "configure"
+#line 4268 "configure"
#include <signal.h>
@@ -4269,7 +4281,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4273: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4285: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4287,10 +4299,10 @@
-echo "configure:4291: checking for Cygwin environment" >&5
+echo "configure:4303: checking for Cygwin environment" >&5
-#line 4294 "configure"
+#line 4306 "configure"
int main() {
@@ -4301,7 +4313,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4305: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4317: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4319,10 +4331,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4323: checking for $ac_func" >&5
+echo "configure:4335: checking for $ac_func" >&5
-#line 4326 "configure"
+#line 4338 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4345,7 +4357,7 @@
; return 0; }
EOF
-if { (eval echo configure:4349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4371,10 +4383,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4375: checking for $ac_func" >&5
+echo "configure:4387: checking for $ac_func" >&5
-#line 4378 "configure"
+#line 4390 "configure"
@@ -4397,7 +4409,7 @@
; return 0; }
EOF
-if { (eval echo configure:4401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4423,10 +4435,10 @@
for ac_func in drand48
do
-echo "configure:4427: checking for $ac_func" >&5
+echo "configure:4439: checking for $ac_func" >&5
-#line 4430 "configure"
+#line 4442 "configure"
@@ -4449,7 +4461,7 @@
; return 0; }
EOF
-if { (eval echo configure:4453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4475,10 +4487,10 @@
for ac_func in putenv setenv
do
-echo "configure:4479: checking for $ac_func" >&5
+echo "configure:4491: checking for $ac_func" >&5
-#line 4482 "configure"
+#line 4494 "configure"
@@ -4501,7 +4513,7 @@
; return 0; }
EOF
-if { (eval echo configure:4505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4527,10 +4539,10 @@
for ac_func in nanosleep
do
-echo "configure:4531: checking for $ac_func" >&5
+echo "configure:4543: checking for $ac_func" >&5
-#line 4534 "configure"
+#line 4546 "configure"
@@ -4553,7 +4565,7 @@
; return 0; }
EOF
-if { (eval echo configure:4557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4578,13 +4590,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4582: checking whether setpgrp takes no argument" >&5
+echo "configure:4594: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4588 "configure"
+#line 4600 "configure"
#ifdef HAVE_UNISTD_H
@@ -4604,7 +4616,7 @@
EOF
-if { (eval echo configure:4608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4632,16 +4644,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4636: checking for long long int" >&5
+echo "configure:4648: checking for long long int" >&5
-#line 4638 "configure"
+#line 4650 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4645: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4657: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -4661,7 +4673,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4665: checking for W11" >&5
+echo "configure:4677: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4689,7 +4701,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4693: checking for X" >&5
+echo "configure:4705: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4749,12 +4761,12 @@
# First, try using that file with no special directory specified.
-#line 4753 "configure"
+#line 4765 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4758: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4770: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4823,14 +4835,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4827 "configure"
+#line 4839 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -4935,17 +4947,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4939: checking whether -R must be followed by a space" >&5
+echo "configure:4951: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4942 "configure"
+#line 4954 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -4961,14 +4973,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4965 "configure"
+#line 4977 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -5000,13 +5012,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5004: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5016: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 5010 "configure"
+#line 5022 "configure"
@@ -5017,7 +5029,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5038,13 +5050,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5042: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5054: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 5048 "configure"
+#line 5060 "configure"
@@ -5055,7 +5067,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5083,10 +5095,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5087: checking for gethostbyname" >&5
+echo "configure:5099: checking for gethostbyname" >&5
-#line 5090 "configure"
+#line 5102 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5109,7 +5121,7 @@
; return 0; }
EOF
-if { (eval echo configure:5113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5129,13 +5141,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5133: checking for gethostbyname in -lnsl" >&5
+echo "configure:5145: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5139 "configure"
+#line 5151 "configure"
@@ -5146,7 +5158,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5175,10 +5187,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5179: checking for connect" >&5
+echo "configure:5191: checking for connect" >&5
-#line 5182 "configure"
+#line 5194 "configure"
which can conflict with char connect(); below. */
@@ -5201,7 +5213,7 @@
; return 0; }
EOF
-if { (eval echo configure:5205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5221,13 +5233,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5225: checking for connect in -lsocket" >&5
+echo "configure:5237: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5231 "configure"
+#line 5243 "configure"
@@ -5238,7 +5250,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5261,10 +5273,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5265: checking for remove" >&5
+echo "configure:5277: checking for remove" >&5
-#line 5268 "configure"
+#line 5280 "configure"
which can conflict with char remove(); below. */
@@ -5287,7 +5299,7 @@
; return 0; }
EOF
-if { (eval echo configure:5291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5307,13 +5319,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5311: checking for remove in -lposix" >&5
+echo "configure:5323: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5317 "configure"
+#line 5329 "configure"
@@ -5324,7 +5336,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5347,10 +5359,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5351: checking for shmat" >&5
+echo "configure:5363: checking for shmat" >&5
-#line 5354 "configure"
+#line 5366 "configure"
which can conflict with char shmat(); below. */
@@ -5373,7 +5385,7 @@
; return 0; }
EOF
-if { (eval echo configure:5377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5393,13 +5405,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5397: checking for shmat in -lipc" >&5
+echo "configure:5409: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5403 "configure"
+#line 5415 "configure"
@@ -5410,7 +5422,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5442,13 +5454,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5446: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5458: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5452 "configure"
+#line 5464 "configure"
@@ -5459,7 +5471,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5497,7 +5509,7 @@
echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5501: checking whether to use Curses" >&5
+echo "configure:5513: checking whether to use Curses" >&5
echo "$ac_t"""$with_curses"" 1>&6
case "$with_curses" in
"no") USE_CURSES= ;;
@@ -5516,15 +5528,15 @@
do
-echo "configure:5520: checking for $ac_hdr" >&5
+echo "configure:5532: checking for $ac_hdr" >&5
-#line 5523 "configure"
+#line 5535 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5528: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5540: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5555,10 +5567,10 @@
echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5559: checking curses.h WINDOW structure component" >&5
+echo "configure:5571: checking curses.h WINDOW structure component" >&5
CURSES_MAXY=NONE
-#line 5562 "configure"
+#line 5574 "configure"
#include <curses.h>
@@ -5567,7 +5579,7 @@
WINDOW w; w.maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5571: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5583: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=maxy
else
@@ -5576,7 +5588,7 @@
fi
rm -f conftest*
-#line 5580 "configure"
+#line 5592 "configure"
#include <curses.h>
@@ -5585,7 +5597,7 @@
WINDOW w; w._maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5589: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5601: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=_maxy
else
@@ -5601,13 +5613,13 @@
echo "$ac_t""$CURSES_MAXY" 1>&6
echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5605: checking for initscr in -lncurses" >&5
+echo "configure:5617: checking for initscr in -lncurses" >&5
ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lncurses $LIBS"
-#line 5611 "configure"
+#line 5623 "configure"
@@ -5618,7 +5630,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5637,13 +5649,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5641: checking for initscr in -lcurses" >&5
+echo "configure:5653: checking for initscr in -lcurses" >&5
ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lcurses $LIBS"
-#line 5647 "configure"
+#line 5659 "configure"
@@ -5654,7 +5666,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5670: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5683,13 +5695,13 @@
echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5687: checking for keypad in -lncurses" >&5
+echo "configure:5699: checking for keypad in -lncurses" >&5
ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5693 "configure"
+#line 5705 "configure"
@@ -5700,7 +5712,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5704: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5722,13 +5734,13 @@
echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5726: checking for keypad in -lcurses" >&5
+echo "configure:5738: checking for keypad in -lcurses" >&5
ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5732 "configure"
+#line 5744 "configure"
@@ -5739,7 +5751,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5769,13 +5781,13 @@
fi # $USE_CURSES
echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5773: checking for gtty in -lcompat" >&5
+echo "configure:5785: checking for gtty in -lcompat" >&5
ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lcompat $LIBS"
-#line 5779 "configure"
+#line 5791 "configure"
@@ -5786,7 +5798,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5805,13 +5817,13 @@
echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5809: checking for gtty in -lbsd-compat" >&5
+echo "configure:5821: checking for gtty in -lbsd-compat" >&5
ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd-compat $LIBS"
-#line 5815 "configure"
+#line 5827 "configure"
@@ -5822,7 +5834,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5841,13 +5853,13 @@
echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5845: checking for gtty in -lbsd" >&5
+echo "configure:5857: checking for gtty in -lbsd" >&5
ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 5851 "configure"
+#line 5863 "configure"
@@ -5858,7 +5870,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5892,12 +5904,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5896: checking for library containing cuserid" >&5
+echo "configure:5908: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 5901 "configure"
+#line 5913 "configure"
@@ -5908,7 +5920,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -5919,7 +5931,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 5923 "configure"
+#line 5935 "configure"
@@ -5930,7 +5942,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -5956,10 +5968,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5960: checking for xdrmem_create" >&5
+echo "configure:5972: checking for xdrmem_create" >&5
-#line 5963 "configure"
+#line 5975 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -5982,7 +5994,7 @@
; return 0; }
EOF
-if { (eval echo configure:5986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -6000,13 +6012,13 @@
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:6004: checking for xdrmem_create in -lsun" >&5
+echo "configure:6016: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 6010 "configure"
+#line 6022 "configure"
@@ -6017,7 +6029,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6036,13 +6048,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6040: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6052: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 6046 "configure"
+#line 6058 "configure"
@@ -6053,7 +6065,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6072,13 +6084,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6076: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6088: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 6082 "configure"
+#line 6094 "configure"
@@ -6089,7 +6101,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6108,13 +6120,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6112: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6124: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 6118 "configure"
+#line 6130 "configure"
@@ -6125,7 +6137,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6159,10 +6171,10 @@
for ac_func in asprintf
do
-echo "configure:6163: checking for $ac_func" >&5
+echo "configure:6175: checking for $ac_func" >&5
-#line 6166 "configure"
+#line 6178 "configure"
@@ -6185,7 +6197,7 @@
; return 0; }
EOF
-if { (eval echo configure:6189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6201: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6212,10 +6224,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6216: checking for atan" >&5
+echo "configure:6228: checking for atan" >&5
-#line 6219 "configure"
+#line 6231 "configure"
which can conflict with char atan(); below. */
@@ -6238,7 +6250,7 @@
; return 0; }
EOF
-if { (eval echo configure:6242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -6256,13 +6268,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6260: checking for atan in -lm" >&5
+echo "configure:6272: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 6266 "configure"
+#line 6278 "configure"
@@ -6273,7 +6285,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:6277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6300,10 +6312,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6304: checking for dlsym" >&5
+echo "configure:6316: checking for dlsym" >&5
-#line 6307 "configure"
+#line 6319 "configure"
which can conflict with char dlsym(); below. */
@@ -6326,7 +6338,7 @@
; return 0; }
EOF
-if { (eval echo configure:6330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -6344,13 +6356,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6348: checking for dlsym in -ldl" >&5
+echo "configure:6360: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 6354 "configure"
+#line 6366 "configure"
@@ -6361,7 +6373,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:6365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6388,10 +6400,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6392: checking for iconv" >&5
+echo "configure:6404: checking for iconv" >&5
-#line 6395 "configure"
+#line 6407 "configure"
which can conflict with char iconv(); below. */
@@ -6414,7 +6426,7 @@
; return 0; }
EOF
-if { (eval echo configure:6418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -6432,13 +6444,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6436: checking for iconv in -liconv" >&5
+echo "configure:6448: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 6442 "configure"
+#line 6454 "configure"
@@ -6449,7 +6461,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6468,13 +6480,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6472: checking for iconv in -lgiconv" >&5
+echo "configure:6484: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6478 "configure"
+#line 6490 "configure"
@@ -6485,7 +6497,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6504,10 +6516,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6508: checking for libiconv" >&5
+echo "configure:6520: checking for libiconv" >&5
-#line 6511 "configure"
+#line 6523 "configure"
which can conflict with char libiconv(); below. */
@@ -6530,7 +6542,7 @@
; return 0; }
EOF
-if { (eval echo configure:6534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6548,13 +6560,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6552: checking for libiconv in -liconv" >&5
+echo "configure:6564: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6558 "configure"
+#line 6570 "configure"
@@ -6565,7 +6577,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6584,13 +6596,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6588: checking for libiconv in -lgiconv" >&5
+echo "configure:6600: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6594 "configure"
+#line 6606 "configure"
@@ -6601,7 +6613,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6638,10 +6650,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6642: checking for socket" >&5
+echo "configure:6654: checking for socket" >&5
-#line 6645 "configure"
+#line 6657 "configure"
which can conflict with char socket(); below. */
@@ -6664,7 +6676,7 @@
; return 0; }
EOF
-if { (eval echo configure:6668: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6682,13 +6694,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6686: checking for socket in -lsocket" >&5
+echo "configure:6698: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6692 "configure"
+#line 6704 "configure"
@@ -6699,7 +6711,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6747,7 +6759,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6751: checking for location of zlib includes" >&5
+echo "configure:6763: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6773,15 +6785,15 @@
do
-echo "configure:6777: checking for $ac_hdr" >&5
+echo "configure:6789: checking for $ac_hdr" >&5
-#line 6780 "configure"
+#line 6792 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6785: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6797: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6815,7 +6827,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6819: checking for location of zlib library" >&5
+echo "configure:6831: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6840,13 +6852,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6844: checking for deflate in -lz" >&5
+echo "configure:6856: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6850 "configure"
+#line 6862 "configure"
@@ -6857,7 +6869,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6905,7 +6917,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6909: checking for location of External PROJ.4 includes" >&5
+echo "configure:6921: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6931,15 +6943,15 @@
do
-echo "configure:6935: checking for $ac_hdr" >&5
+echo "configure:6947: checking for $ac_hdr" >&5
-#line 6938 "configure"
+#line 6950 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6943: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6955: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6976,7 +6988,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6980: checking External PROJ.4 version" >&5
+echo "configure:6992: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6984,7 +6996,7 @@
else
-#line 6988 "configure"
+#line 7000 "configure"
#include <stdio.h>
@@ -6996,7 +7008,7 @@
EOF
-if { (eval echo configure:7000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:7012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -7021,7 +7033,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:7025: checking for location of External PROJ.4 library" >&5
+echo "configure:7037: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7046,13 +7058,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7050: checking for pj_get_def in -lproj" >&5
+echo "configure:7062: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 7056 "configure"
+#line 7068 "configure"
@@ -7063,7 +7075,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:7067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7097,7 +7109,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7101: checking for location of External PROJ.4 data files" >&5
+echo "configure:7113: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7121,14 +7133,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7125: checking for epsg" >&5
+echo "configure:7137: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7132: checking for $PROJSHARE/epsg" >&5
+echo "configure:7144: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7160,7 +7172,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7164: checking for $ac_word" >&5
+echo "configure:7176: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -7200,7 +7212,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7204: checking whether to use regex" >&5
+echo "configure:7216: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -7220,7 +7232,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7224: checking for location of regex includes" >&5
+echo "configure:7236: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7246,15 +7258,15 @@
do
-echo "configure:7250: checking for $ac_hdr" >&5
+echo "configure:7262: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 7253 "configure"
+#line 7265 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7270: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7288,7 +7300,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7292: checking for location of regex library" >&5
+echo "configure:7304: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7313,10 +7325,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7317: checking for regcomp" >&5
+echo "configure:7329: checking for regcomp" >&5
-#line 7320 "configure"
+#line 7332 "configure"
which can conflict with char regcomp(); below. */
@@ -7339,7 +7351,7 @@
; return 0; }
EOF
-if { (eval echo configure:7343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -7366,13 +7378,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7370: checking for regcomp in -lregex" >&5
+echo "configure:7382: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 7376 "configure"
+#line 7388 "configure"
@@ -7383,7 +7395,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:7387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7433,7 +7445,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7437: checking whether to use Readline" >&5
+echo "configure:7449: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -7454,7 +7466,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7458: checking for location of Readline includes" >&5
+echo "configure:7470: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7480,15 +7492,15 @@
do
-echo "configure:7484: checking for $ac_hdr" >&5
+echo "configure:7496: checking for $ac_hdr" >&5
-#line 7487 "configure"
+#line 7499 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7504: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7524,15 +7536,15 @@
do
-echo "configure:7528: checking for $ac_hdr" >&5
+echo "configure:7540: checking for $ac_hdr" >&5
-#line 7531 "configure"
+#line 7543 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7548: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7566,7 +7578,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7570: checking for location of Readline library" >&5
+echo "configure:7582: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7591,13 +7603,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7595: checking for readline in -lreadline" >&5
+echo "configure:7607: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 7601 "configure"
+#line 7613 "configure"
@@ -7608,7 +7620,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:7612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7624: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7643,13 +7655,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7647: checking for add_history in -lhistory" >&5
+echo "configure:7659: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 7653 "configure"
+#line 7665 "configure"
@@ -7660,7 +7672,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:7664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7676: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7703,7 +7715,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7707: checking whether to use JPEG" >&5
+echo "configure:7719: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -7723,7 +7735,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7727: checking for location of JPEG includes" >&5
+echo "configure:7739: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7749,15 +7761,15 @@
do
-echo "configure:7753: checking for $ac_hdr" >&5
+echo "configure:7765: checking for $ac_hdr" >&5
-#line 7756 "configure"
+#line 7768 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7761: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7773: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7791,7 +7803,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7795: checking for location of JPEG library" >&5
+echo "configure:7807: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7818,13 +7830,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7822: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7834: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ljpeg $LIBS"
-#line 7828 "configure"
+#line 7840 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7835,7 +7847,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:7839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7854,13 +7866,13 @@
-echo "configure:7858: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7870: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 7864 "configure"
+#line 7876 "configure"
@@ -7871,7 +7883,7 @@
; return 0; }
EOF
-if { (eval echo configure:7875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7920,7 +7932,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7924: checking whether to use GDAL" >&5
+echo "configure:7936: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -7938,7 +7950,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:7942: checking for $ac_word" >&5
+echo "configure:7954: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -7993,14 +8005,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7997 "configure"
+#line 8009 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:8004: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8016: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -8009,14 +8021,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 8013 "configure"
+#line 8025 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:8020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -8045,11 +8057,127 @@
+# GEOS option
+echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
+echo "configure:8064: checking whether to use GEOS" >&5
+GEOS_LIBS=
+GGEOS_CFLAGS=
+USE_GEOS=
+if test "`basename xx/$with_geos`" = "geos-config" ; then
+ GEOS_CONFIG="$with_geos"
+fi
+if test "$with_geos" = "no" ; then
+ echo "$ac_t""no" 1>&6
+else
+ echo "$ac_t""yes" 1>&6
+ # Extract the first word of "geos-config", so it can be a program name with args.
+set dummy geos-config; ac_word=$2
+echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
+echo "configure:8081: checking for $ac_word" >&5
+case "$GEOS_CONFIG" in
+ ac_cv_path_GEOS_CONFIG="$GEOS_CONFIG" # Let the user override the test with a path.
+ ac_cv_path_GEOS_CONFIG="$GEOS_CONFIG" # Let the user override the test with a dos path.
+ IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
+ ac_dummy="$PATH"
+ for ac_dir in $ac_dummy; do
+ test -z "$ac_dir" && ac_dir=.
+ if test -f $ac_dir/$ac_word; then
+ ac_cv_path_GEOS_CONFIG="$ac_dir/$ac_word"
+ break
+ fi
+ done
+ IFS="$ac_save_ifs"
+ test -z "$ac_cv_path_GEOS_CONFIG" && ac_cv_path_GEOS_CONFIG="no"
+esac
+GEOS_CONFIG="$ac_cv_path_GEOS_CONFIG"
+if test -n "$GEOS_CONFIG"; then
+ echo "$ac_t""$GEOS_CONFIG" 1>&6
+else
+fi
+ if test "$GEOS_CONFIG" = "no" ; then
+ { echo "configure: error: *** couldn't find geos-config" 1>&2; exit 1; }
+ fi
+ if test "$GEOS_CONFIG" != "" ; then
+ GEOS_LIBS=`"$GEOS_CONFIG" --libs`
+ GEOS_CFLAGS=`"$GEOS_CONFIG" --cflags`
+ USE_GEOS=1
+ fi
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$GEOS_CFLAGS $CPPFLAGS"
+for ac_hdr in geos_c.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:8129: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 8132 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:8137: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=yes"
+else
+ echo "$ac_err" >&5
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+ ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+ cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+{ echo "configure: error: *** Unable to locate GEOS includes." 1>&2; exit 1; }
+fi
+done
+CPPFLAGS=$ac_save_cppflags
+ cat >> confdefs.h <<\EOF
+#define HAVE_GEOS 1
+EOF
+fi
# Enable TIFF option
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8053: checking whether to use TIFF" >&5
+echo "configure:8181: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -8069,7 +8197,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8073: checking for location of TIFF includes" >&5
+echo "configure:8201: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8095,15 +8223,15 @@
do
-echo "configure:8099: checking for $ac_hdr" >&5
+echo "configure:8227: checking for $ac_hdr" >&5
-#line 8102 "configure"
+#line 8230 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8107: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8235: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8137,7 +8265,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8141: checking for location of TIFF library" >&5
+echo "configure:8269: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8168,13 +8296,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8172: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8300: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 8178 "configure"
+#line 8306 "configure"
@@ -8185,7 +8313,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8204,13 +8332,13 @@
-echo "configure:8208: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8336: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 8214 "configure"
+#line 8342 "configure"
@@ -8221,7 +8349,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8240,13 +8368,13 @@
-echo "configure:8244: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8372: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 8250 "configure"
+#line 8378 "configure"
@@ -8257,7 +8385,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8276,13 +8404,13 @@
-echo "configure:8280: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8408: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8286 "configure"
+#line 8414 "configure"
@@ -8293,7 +8421,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8312,13 +8440,13 @@
-echo "configure:8316: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8444: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8322 "configure"
+#line 8450 "configure"
@@ -8329,7 +8457,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8348,13 +8476,13 @@
-echo "configure:8352: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8480: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8358 "configure"
+#line 8486 "configure"
@@ -8365,7 +8493,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8384,13 +8512,13 @@
-echo "configure:8388: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8516: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8394 "configure"
+#line 8522 "configure"
@@ -8401,7 +8529,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8420,13 +8548,13 @@
-echo "configure:8424: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8552: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8430 "configure"
+#line 8558 "configure"
@@ -8437,7 +8565,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8535,7 +8663,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8539: checking whether to use PNG" >&5
+echo "configure:8667: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8554,7 +8682,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8558: checking for location of PNG includes" >&5
+echo "configure:8686: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8580,15 +8708,15 @@
do
-echo "configure:8584: checking for $ac_hdr" >&5
+echo "configure:8712: checking for $ac_hdr" >&5
-#line 8587 "configure"
+#line 8715 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8592: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8720: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8622,7 +8750,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8626: checking for location of PNG library" >&5
+echo "configure:8754: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8647,13 +8775,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8651: checking for png_read_image in -lpng" >&5
+echo "configure:8779: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8657 "configure"
+#line 8785 "configure"
@@ -8664,7 +8792,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8668: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8706,7 +8834,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8710: checking whether to use Tcl/Tk" >&5
+echo "configure:8838: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -8726,7 +8854,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8730: checking for location of Tcl/Tk includes" >&5
+echo "configure:8858: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8752,15 +8880,15 @@
do
-echo "configure:8756: checking for $ac_hdr" >&5
+echo "configure:8884: checking for $ac_hdr" >&5
-#line 8759 "configure"
+#line 8887 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8764: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8892: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8797,15 +8925,15 @@
do
-echo "configure:8801: checking for $ac_hdr" >&5
+echo "configure:8929: checking for $ac_hdr" >&5
-#line 8804 "configure"
+#line 8932 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8809: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8838,7 +8966,7 @@
# Tcl/Tk version checks
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8842: checking Tcl version" >&5
+echo "configure:8970: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -8846,7 +8974,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 8850 "configure"
+#line 8978 "configure"
#include <stdio.h>
@@ -8858,7 +8986,7 @@
EOF
-if { (eval echo configure:8862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -8876,7 +9004,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8880: checking Tk version" >&5
+echo "configure:9008: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8884,7 +9012,7 @@
else
-#line 8888 "configure"
+#line 9016 "configure"
#include <stdio.h>
@@ -8896,7 +9024,7 @@
EOF
-if { (eval echo configure:8900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:9028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -8927,7 +9055,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8931: checking for location of Tcl/Tk library" >&5
+echo "configure:9059: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8957,13 +9085,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8961: checking for Tcl_Init in -ltcl" >&5
+echo "configure:9089: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 8967 "configure"
+#line 9095 "configure"
@@ -8974,7 +9102,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8993,13 +9121,13 @@
-echo "configure:8997: checking for Tcl_Init in -ltcl" >&5
+echo "configure:9125: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 9003 "configure"
+#line 9131 "configure"
@@ -9010,7 +9138,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:9014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9037,13 +9165,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9041: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:9169: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 9047 "configure"
+#line 9175 "configure"
@@ -9054,7 +9182,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:9058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9073,13 +9201,13 @@
-echo "configure:9077: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:9205: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 9083 "configure"
+#line 9211 "configure"
@@ -9090,7 +9218,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:9094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9117,13 +9245,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9121: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:9249: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 9127 "configure"
+#line 9255 "configure"
@@ -9134,7 +9262,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:9138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9153,13 +9281,13 @@
-echo "configure:9157: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:9285: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 9163 "configure"
+#line 9291 "configure"
@@ -9170,7 +9298,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:9174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9248,13 +9376,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:9252: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9380: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 9258 "configure"
+#line 9386 "configure"
@@ -9265,7 +9393,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9284,13 +9412,13 @@
-echo "configure:9288: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9416: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9294 "configure"
+#line 9422 "configure"
@@ -9301,7 +9429,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9328,13 +9456,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9332: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9460: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9338 "configure"
+#line 9466 "configure"
@@ -9345,7 +9473,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9364,13 +9492,13 @@
-echo "configure:9368: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9496: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9374 "configure"
+#line 9502 "configure"
@@ -9381,7 +9509,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9513: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9408,13 +9536,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9412: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9540: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9418 "configure"
+#line 9546 "configure"
@@ -9425,7 +9553,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9444,13 +9572,13 @@
-echo "configure:9448: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9576: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9454 "configure"
+#line 9582 "configure"
@@ -9461,7 +9589,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9553,7 +9681,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9557: checking whether to use PostgreSQL" >&5
+echo "configure:9685: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9580,7 +9708,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9584: checking for location of PostgreSQL includes" >&5
+echo "configure:9712: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9606,15 +9734,15 @@
do
-echo "configure:9610: checking for $ac_hdr" >&5
+echo "configure:9738: checking for $ac_hdr" >&5
-#line 9613 "configure"
+#line 9741 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9746: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9652,7 +9780,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9656: checking for location of PostgreSQL library" >&5
+echo "configure:9784: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9681,13 +9809,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9685: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9813: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9691 "configure"
+#line 9819 "configure"
@@ -9698,7 +9826,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9717,13 +9845,13 @@
-echo "configure:9721: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9849: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9727 "configure"
+#line 9855 "configure"
@@ -9734,7 +9862,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9753,13 +9881,13 @@
-echo "configure:9757: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9885: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9763 "configure"
+#line 9891 "configure"
@@ -9770,7 +9898,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9789,13 +9917,13 @@
-echo "configure:9793: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9921: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9799 "configure"
+#line 9927 "configure"
@@ -9806,7 +9934,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9863,13 +9991,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9867: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9995: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9873 "configure"
+#line 10001 "configure"
@@ -9880,7 +10008,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9902,13 +10030,13 @@
-echo "configure:9906: checking for PQcmdTuples in -lpq" >&5
+echo "configure:10034: checking for PQcmdTuples in -lpq" >&5
-#line 9912 "configure"
+#line 10040 "configure"
@@ -9919,7 +10047,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9962,7 +10090,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9966: checking whether to use MySQL" >&5
+echo "configure:10094: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9982,7 +10110,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9986: checking for location of MySQL includes" >&5
+echo "configure:10114: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -10008,15 +10136,15 @@
do
-echo "configure:10012: checking for $ac_hdr" >&5
+echo "configure:10140: checking for $ac_hdr" >&5
-#line 10015 "configure"
+#line 10143 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10020: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10148: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10053,7 +10181,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:10057: checking for location of MySQL library" >&5
+echo "configure:10185: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -10084,13 +10212,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:10088: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10216: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 10094 "configure"
+#line 10222 "configure"
@@ -10101,7 +10229,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10120,13 +10248,13 @@
-echo "configure:10124: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10252: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 10130 "configure"
+#line 10258 "configure"
@@ -10137,7 +10265,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10156,13 +10284,13 @@
-echo "configure:10160: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10288: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 10166 "configure"
+#line 10294 "configure"
@@ -10173,7 +10301,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10192,13 +10320,13 @@
-echo "configure:10196: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10324: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 10202 "configure"
+#line 10330 "configure"
@@ -10209,7 +10337,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10228,13 +10356,13 @@
-echo "configure:10232: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10360: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 10238 "configure"
+#line 10366 "configure"
@@ -10245,7 +10373,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10264,13 +10392,13 @@
-echo "configure:10268: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10396: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 10274 "configure"
+#line 10402 "configure"
@@ -10281,7 +10409,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10300,13 +10428,13 @@
-echo "configure:10304: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10432: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10310 "configure"
+#line 10438 "configure"
@@ -10317,7 +10445,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10336,13 +10464,13 @@
-echo "configure:10340: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10468: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10346 "configure"
+#line 10474 "configure"
@@ -10353,7 +10481,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10443,7 +10571,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:10447: checking for $ac_word" >&5
+echo "configure:10575: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -10484,10 +10612,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10488: checking for mysql_server_init" >&5
+echo "configure:10616: checking for mysql_server_init" >&5
-#line 10491 "configure"
+#line 10619 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -10510,7 +10638,7 @@
; return 0; }
EOF
-if { (eval echo configure:10514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -10548,7 +10676,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10552: checking whether to use SQLite" >&5
+echo "configure:10680: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10568,7 +10696,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10572: checking for location of SQLite includes" >&5
+echo "configure:10700: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10594,15 +10722,15 @@
do
-echo "configure:10598: checking for $ac_hdr" >&5
+echo "configure:10726: checking for $ac_hdr" >&5
-#line 10601 "configure"
+#line 10729 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10606: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10645,7 +10773,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10649: checking for location of SQLite library" >&5
+echo "configure:10777: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10672,13 +10800,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10676: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10804: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10682 "configure"
+#line 10810 "configure"
@@ -10689,7 +10817,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10708,13 +10836,13 @@
-echo "configure:10712: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10840: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10718 "configure"
+#line 10846 "configure"
@@ -10725,7 +10853,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10778,7 +10906,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10782: checking whether to use FFMPEG" >&5
+echo "configure:10910: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10798,7 +10926,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10802: checking for location of FFMPEG includes" >&5
+echo "configure:10930: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10824,15 +10952,15 @@
do
-echo "configure:10828: checking for $ac_hdr" >&5
+echo "configure:10956: checking for $ac_hdr" >&5
-#line 10831 "configure"
+#line 10959 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10836: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10868,15 +10996,15 @@
do
-echo "configure:10872: checking for $ac_hdr" >&5
+echo "configure:11000: checking for $ac_hdr" >&5
-#line 10875 "configure"
+#line 11003 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10880: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10912,15 +11040,15 @@
do
-echo "configure:10916: checking for $ac_hdr" >&5
+echo "configure:11044: checking for $ac_hdr" >&5
-#line 10919 "configure"
+#line 11047 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10924: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11052: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10963,7 +11091,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10967: checking for location of FFMPEG library" >&5
+echo "configure:11095: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10990,13 +11118,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10994: checking for av_free in -lavutil" >&5
+echo "configure:11122: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 11000 "configure"
+#line 11128 "configure"
@@ -11007,7 +11135,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:11011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11026,13 +11154,13 @@
-echo "configure:11030: checking for av_free in -lavutil" >&5
+echo "configure:11158: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 11036 "configure"
+#line 11164 "configure"
@@ -11043,7 +11171,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:11047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11088,13 +11216,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:11092: checking for avcodec_init in -lavcodec" >&5
+echo "configure:11220: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 11098 "configure"
+#line 11226 "configure"
@@ -11105,7 +11233,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:11109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11124,13 +11252,13 @@
-echo "configure:11128: checking for avcodec_init in -lavcodec" >&5
+echo "configure:11256: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 11134 "configure"
+#line 11262 "configure"
@@ -11141,7 +11269,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:11145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11186,13 +11314,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:11190: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11318: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 11196 "configure"
+#line 11324 "configure"
@@ -11203,7 +11331,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:11207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11222,13 +11350,13 @@
-echo "configure:11226: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11354: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 11232 "configure"
+#line 11360 "configure"
@@ -11239,7 +11367,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:11243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11299,7 +11427,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:11303: checking whether to use OpenGL" >&5
+echo "configure:11431: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -11333,7 +11461,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11337: checking for location of OpenGL includes" >&5
+echo "configure:11465: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11359,15 +11487,15 @@
do
-echo "configure:11363: checking for $ac_hdr" >&5
+echo "configure:11491: checking for $ac_hdr" >&5
-#line 11366 "configure"
+#line 11494 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11371: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11499: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11401,7 +11529,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11405: checking for location of OpenGL library" >&5
+echo "configure:11533: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11430,13 +11558,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11434: checking for glBegin in -lGL" >&5
+echo "configure:11562: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11440 "configure"
+#line 11568 "configure"
@@ -11447,7 +11575,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11466,13 +11594,13 @@
-echo "configure:11470: checking for glBegin in -lGL" >&5
+echo "configure:11598: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11476 "configure"
+#line 11604 "configure"
@@ -11483,7 +11611,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11502,13 +11630,13 @@
-echo "configure:11506: checking for glBegin in -lGL" >&5
+echo "configure:11634: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11512 "configure"
+#line 11640 "configure"
@@ -11519,7 +11647,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11651: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11538,13 +11666,13 @@
-echo "configure:11542: checking for glBegin in -lGL" >&5
+echo "configure:11670: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11548 "configure"
+#line 11676 "configure"
@@ -11555,7 +11683,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11617,13 +11745,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11621: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11749: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11627 "configure"
+#line 11755 "configure"
@@ -11634,7 +11762,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11653,13 +11781,13 @@
-echo "configure:11657: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11785: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11663 "configure"
+#line 11791 "configure"
@@ -11670,7 +11798,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11674: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11714,10 +11842,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11718: checking for glXCreatePbuffer" >&5
+echo "configure:11846: checking for glXCreatePbuffer" >&5
-#line 11721 "configure"
+#line 11849 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11740,7 +11868,7 @@
; return 0; }
EOF
-if { (eval echo configure:11744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11762,10 +11890,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11766: checking for glXCreateGLXPixmap" >&5
+echo "configure:11894: checking for glXCreateGLXPixmap" >&5
-#line 11769 "configure"
+#line 11897 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11788,7 +11916,7 @@
; return 0; }
EOF
-if { (eval echo configure:11792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11827,7 +11955,7 @@
-echo "configure:11831: checking for location of OpenGL includes" >&5
+echo "configure:11959: checking for location of OpenGL includes" >&5
@@ -11853,15 +11981,15 @@
do
-echo "configure:11857: checking for $ac_hdr" >&5
+echo "configure:11985: checking for $ac_hdr" >&5
-#line 11860 "configure"
+#line 11988 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11865: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11993: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11896,10 +12024,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11900: checking for glBegin" >&5
+echo "configure:12028: checking for glBegin" >&5
-#line 11903 "configure"
+#line 12031 "configure"
which can conflict with char glBegin(); below. */
@@ -11922,7 +12050,7 @@
; return 0; }
EOF
-if { (eval echo configure:11926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11937,10 +12065,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11941: checking for gluBeginCurve" >&5
+echo "configure:12069: checking for gluBeginCurve" >&5
-#line 11944 "configure"
+#line 12072 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11963,7 +12091,7 @@
; return 0; }
EOF
-if { (eval echo configure:11967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -12007,7 +12135,7 @@
-echo "configure:12011: checking for location of OpenGL includes" >&5
+echo "configure:12139: checking for location of OpenGL includes" >&5
@@ -12033,15 +12161,15 @@
do
-echo "configure:12037: checking for $ac_hdr" >&5
+echo "configure:12165: checking for $ac_hdr" >&5
-#line 12040 "configure"
+#line 12168 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12045: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12173: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12075,7 +12203,7 @@
-echo "configure:12079: checking for location of OpenGL library" >&5
+echo "configure:12207: checking for location of OpenGL library" >&5
@@ -12100,18 +12228,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:12104: checking for OpenGL library" >&5
+echo "configure:12232: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 12108 "configure"
+#line 12236 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:12115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -12135,18 +12263,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:12139: checking for GLU library" >&5
+echo "configure:12267: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 12143 "configure"
+#line 12271 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:12150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12195,7 +12323,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12199: checking whether to use ODBC" >&5
+echo "configure:12327: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12214,7 +12342,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12218: checking for location of ODBC includes" >&5
+echo "configure:12346: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12240,15 +12368,15 @@
do
-echo "configure:12244: checking for $ac_hdr" >&5
+echo "configure:12372: checking for $ac_hdr" >&5
-#line 12247 "configure"
+#line 12375 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12380: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12282,7 +12410,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12286: checking for location of ODBC library" >&5
+echo "configure:12414: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12307,13 +12435,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12311: checking for SQLConnect in -lodbc" >&5
+echo "configure:12439: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12317 "configure"
+#line 12445 "configure"
@@ -12324,7 +12452,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12349,13 +12477,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12353: checking for SQLConnect in -liodbc" >&5
+echo "configure:12481: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12359 "configure"
+#line 12487 "configure"
@@ -12366,7 +12494,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12391,11 +12519,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12395: checking for ODBC library" >&5
+echo "configure:12523: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12399 "configure"
+#line 12527 "configure"
#include <windows.h>
#include <sql.h>
@@ -12403,7 +12531,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12452,7 +12580,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12456: checking whether to use FFTW" >&5
+echo "configure:12584: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12471,7 +12599,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12475: checking for location of FFTW includes" >&5
+echo "configure:12603: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12497,15 +12625,15 @@
do
-echo "configure:12501: checking for $ac_hdr" >&5
+echo "configure:12629: checking for $ac_hdr" >&5
-#line 12504 "configure"
+#line 12632 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12509: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12637: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12533,15 +12661,15 @@
do
-echo "configure:12537: checking for $ac_hdr" >&5
+echo "configure:12665: checking for $ac_hdr" >&5
-#line 12540 "configure"
+#line 12668 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12545: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12673: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12569,15 +12697,15 @@
do
-echo "configure:12573: checking for $ac_hdr" >&5
+echo "configure:12701: checking for $ac_hdr" >&5
-#line 12576 "configure"
+#line 12704 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12581: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12709: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12623,7 +12751,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12627: checking for location of FFTW library" >&5
+echo "configure:12755: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12648,13 +12776,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12652: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12780: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12658 "configure"
+#line 12786 "configure"
@@ -12665,7 +12793,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12690,13 +12818,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12694: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12822: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12700 "configure"
+#line 12828 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12707,7 +12835,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12732,13 +12860,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12736: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12864: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12742 "configure"
+#line 12870 "configure"
@@ -12749,7 +12877,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12806,7 +12934,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12810: checking whether to use BLAS" >&5
+echo "configure:12938: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12827,7 +12955,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12831: checking for location of BLAS includes" >&5
+echo "configure:12959: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12847,7 +12975,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12851: checking for location of BLAS library" >&5
+echo "configure:12979: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12873,15 +13001,15 @@
do
-echo "configure:12877: checking for $ac_hdr" >&5
+echo "configure:13005: checking for $ac_hdr" >&5
-#line 12880 "configure"
+#line 13008 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12885: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13013: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12916,13 +13044,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12920: checking for dnrm2_ in -lblas" >&5
+echo "configure:13048: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12926 "configure"
+#line 13054 "configure"
@@ -12933,7 +13061,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12952,13 +13080,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:12956: checking for dnrm2_ in -lblas" >&5
+echo "configure:13084: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12962 "configure"
+#line 13090 "configure"
@@ -12969,7 +13097,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13013,13 +13141,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13017: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13145: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 13023 "configure"
+#line 13151 "configure"
#include "confdefs.h"
@@ -13030,7 +13158,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:13034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13045,13 +13173,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13049: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13177: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 13055 "configure"
+#line 13183 "configure"
@@ -13062,7 +13190,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13077,13 +13205,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13081: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13209: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13087 "configure"
+#line 13215 "configure"
@@ -13094,7 +13222,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:13098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13139,16 +13267,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13143: checking for sgemm in $vlib_flags" >&5
+echo "configure:13271: checking for sgemm in $vlib_flags" >&5
-#line 13145 "configure"
+#line 13273 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:13152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13280: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -13166,13 +13294,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13170: checking for sgemm_ in -lblas" >&5
+echo "configure:13298: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 13176 "configure"
+#line 13304 "configure"
@@ -13183,7 +13311,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13198,13 +13326,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13202: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13330: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 13208 "configure"
+#line 13336 "configure"
@@ -13215,7 +13343,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13230,13 +13358,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13234: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13362: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13240 "configure"
+#line 13368 "configure"
@@ -13247,7 +13375,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13281,13 +13409,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13285: checking for acosp in -lsunmath" >&5
+echo "configure:13413: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13291 "configure"
+#line 13419 "configure"
@@ -13298,7 +13426,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13313,13 +13441,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13317: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13445: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13323 "configure"
+#line 13451 "configure"
@@ -13330,7 +13458,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13360,13 +13488,13 @@
# Generic BLAS library
-echo "configure:13364: checking for sgemm_ in -lblas" >&5
+echo "configure:13492: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13370 "configure"
+#line 13498 "configure"
@@ -13377,7 +13505,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13381: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13416,7 +13544,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13420: checking whether to use LAPACK" >&5
+echo "configure:13548: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13441,7 +13569,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13445: checking for location of LAPACK includes" >&5
+echo "configure:13573: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13461,7 +13589,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13465: checking for location of LAPACK library" >&5
+echo "configure:13593: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13487,15 +13615,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13491: checking for $ac_hdr" >&5
+echo "configure:13619: checking for $ac_hdr" >&5
-#line 13494 "configure"
+#line 13622 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13499: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13527,10 +13655,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13531: checking for dsegv_" >&5
+echo "configure:13659: checking for dsegv_" >&5
-#line 13534 "configure"
+#line 13662 "configure"
which can conflict with char dsegv_(); below. */
@@ -13553,7 +13681,7 @@
; return 0; }
EOF
-if { (eval echo configure:13557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13580,13 +13708,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13584: checking for desgv_ in -llapack" >&5
+echo "configure:13712: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13590 "configure"
+#line 13718 "configure"
@@ -13597,7 +13725,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13629,13 +13757,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13633: checking for dgesv_ in -llapack" >&5
+echo "configure:13761: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13639 "configure"
+#line 13767 "configure"
@@ -13646,7 +13774,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13665,13 +13793,13 @@
-echo "configure:13669: checking for dgesv_ in -llapack" >&5
+echo "configure:13797: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13675 "configure"
+#line 13803 "configure"
@@ -13682,7 +13810,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13814: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13738,7 +13866,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13742: checking whether to use Motif" >&5
+echo "configure:13870: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -13757,7 +13885,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13761: checking for location of Motif includes" >&5
+echo "configure:13889: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13783,15 +13911,15 @@
do
-echo "configure:13787: checking for $ac_hdr" >&5
+echo "configure:13915: checking for $ac_hdr" >&5
-#line 13790 "configure"
+#line 13918 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13795: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13923: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13825,7 +13953,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13829: checking for location of Motif library" >&5
+echo "configure:13957: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13850,13 +13978,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13854: checking for XmStringCreate in -lXm" >&5
+echo "configure:13982: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 13860 "configure"
+#line 13988 "configure"
@@ -13867,7 +13995,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:13871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13908,7 +14036,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13912: checking whether to use Cairo" >&5
+echo "configure:14040: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13934,7 +14062,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13938: checking for location of cairo includes" >&5
+echo "configure:14066: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13960,15 +14088,15 @@
do
-echo "configure:13964: checking for $ac_hdr" >&5
+echo "configure:14092: checking for $ac_hdr" >&5
-#line 13967 "configure"
+#line 14095 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13972: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14100: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14004,7 +14132,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14008: checking for location of cairo library" >&5
+echo "configure:14136: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14024,7 +14152,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14028: checking for cairo linking flags" >&5
+echo "configure:14156: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14040,10 +14168,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14044: checking for cairo_create" >&5
+echo "configure:14172: checking for cairo_create" >&5
-#line 14047 "configure"
+#line 14175 "configure"
which can conflict with char cairo_create(); below. */
@@ -14066,7 +14194,7 @@
; return 0; }
EOF
-if { (eval echo configure:14070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -14100,10 +14228,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14104: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14232: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14107 "configure"
+#line 14235 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -14126,7 +14254,7 @@
; return 0; }
EOF
-if { (eval echo configure:14130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -14168,7 +14296,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14172: checking whether to use GLw" >&5
+echo "configure:14300: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -14187,7 +14315,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14191: checking for location of GLw includes" >&5
+echo "configure:14319: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14213,15 +14341,15 @@
do
-echo "configure:14217: checking for $ac_hdr" >&5
+echo "configure:14345: checking for $ac_hdr" >&5
-#line 14220 "configure"
+#line 14348 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14225: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14353: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14249,15 +14377,15 @@
do
-echo "configure:14253: checking for $ac_hdr" >&5
+echo "configure:14381: checking for $ac_hdr" >&5
-#line 14256 "configure"
+#line 14384 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14261: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14389: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14297,7 +14425,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14301: checking for location of GLw library" >&5
+echo "configure:14429: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14322,13 +14450,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14326: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14454: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14332 "configure"
+#line 14460 "configure"
@@ -14339,7 +14467,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14364,13 +14492,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14368: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14496: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14374 "configure"
+#line 14502 "configure"
@@ -14381,7 +14509,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14513: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14406,13 +14534,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14410: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14538: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14416 "configure"
+#line 14544 "configure"
@@ -14423,7 +14551,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14448,13 +14576,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14452: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14580: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14458 "configure"
+#line 14586 "configure"
@@ -14465,7 +14593,7 @@
; return 0; }
EOF
-if { (eval echo configure:14469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14490,13 +14618,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14494: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14622: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14500 "configure"
+#line 14628 "configure"
@@ -14507,7 +14635,7 @@
; return 0; }
EOF
-if { (eval echo configure:14511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14532,13 +14660,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14536: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14664: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14542 "configure"
+#line 14670 "configure"
@@ -14549,7 +14677,7 @@
; return 0; }
EOF
-if { (eval echo configure:14553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14576,13 +14704,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14580: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14708: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14586 "configure"
+#line 14714 "configure"
@@ -14593,7 +14721,7 @@
; return 0; }
EOF
-if { (eval echo configure:14597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14612,13 +14740,13 @@
-echo "configure:14616: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14744: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14622 "configure"
+#line 14750 "configure"
@@ -14629,7 +14757,7 @@
; return 0; }
EOF
-if { (eval echo configure:14633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14656,13 +14784,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14660: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14788: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14666 "configure"
+#line 14794 "configure"
@@ -14673,7 +14801,7 @@
; return 0; }
EOF
-if { (eval echo configure:14677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14692,13 +14820,13 @@
-echo "configure:14696: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14824: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14702 "configure"
+#line 14830 "configure"
@@ -14709,7 +14837,7 @@
; return 0; }
EOF
-if { (eval echo configure:14713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14822,7 +14950,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14826: checking whether to use FreeType" >&5
+echo "configure:14954: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -14841,7 +14969,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14845: checking for location of FreeType includes" >&5
+echo "configure:14973: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14867,15 +14995,15 @@
do
-echo "configure:14871: checking for $ac_hdr" >&5
+echo "configure:14999: checking for $ac_hdr" >&5
-#line 14874 "configure"
+#line 15002 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14879: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15007: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14909,7 +15037,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14913: checking for location of FreeType library" >&5
+echo "configure:15041: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14934,13 +15062,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14938: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15066: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 14944 "configure"
+#line 15072 "configure"
@@ -14951,7 +15079,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:14955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14992,7 +15120,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14996: checking whether to use NLS" >&5
+echo "configure:15124: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -15012,10 +15140,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15016: checking for gettext" >&5
+echo "configure:15144: checking for gettext" >&5
-#line 15019 "configure"
+#line 15147 "configure"
which can conflict with char gettext(); below. */
@@ -15038,7 +15166,7 @@
; return 0; }
EOF
-if { (eval echo configure:15042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15170: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -15056,13 +15184,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15060: checking for gettext in -lintl" >&5
+echo "configure:15188: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 15066 "configure"
+#line 15194 "configure"
@@ -15073,7 +15201,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:15077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15108,7 +15236,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15112: checking whether to use C++" >&5
+echo "configure:15240: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -15124,7 +15252,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15128: checking for $ac_word" >&5
+echo "configure:15256: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15153,7 +15281,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15157: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15285: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15164,12 +15292,12 @@
cat > conftest.$ac_ext << EOF
-#line 15168 "configure"
+#line 15296 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:15173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -15195,19 +15323,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15199: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15327: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15204: checking whether we are using GNU C++" >&5
+echo "configure:15332: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15211: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15339: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -15225,7 +15353,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15229: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15357: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15266,7 +15394,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15270: checking whether to use openDWG" >&5
+echo "configure:15398: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15286,7 +15414,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15290: checking for location of openDGW includes" >&5
+echo "configure:15418: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15312,15 +15440,15 @@
do
-echo "configure:15316: checking for $ac_hdr" >&5
+echo "configure:15444: checking for $ac_hdr" >&5
-#line 15319 "configure"
+#line 15447 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15324: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15452: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15354,7 +15482,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15358: checking for location of openDWG library" >&5
+echo "configure:15486: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15401,7 +15529,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15405: checking for special C compiler options needed for large files" >&5
+echo "configure:15533: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15409,7 +15537,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15413 "configure"
+#line 15541 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15425,7 +15553,7 @@
; return 0; }
EOF
-if { (eval echo configure:15429: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15557: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -15434,7 +15562,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15438 "configure"
+#line 15566 "configure"
@@ -15450,7 +15578,7 @@
; return 0; }
EOF
-if { (eval echo configure:15454: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15582: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15470,11 +15598,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15474: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15602: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15478 "configure"
+#line 15606 "configure"
@@ -15490,14 +15618,14 @@
; return 0; }
EOF
-if { (eval echo configure:15494: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15622: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 15501 "configure"
+#line 15629 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15515,7 +15643,7 @@
; return 0; }
EOF
-if { (eval echo configure:15519: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15647: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15534,11 +15662,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15538: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15666: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15542 "configure"
+#line 15670 "configure"
@@ -15554,14 +15682,14 @@
; return 0; }
EOF
-if { (eval echo configure:15558: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15686: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15565 "configure"
+#line 15693 "configure"
#define _LARGE_FILES 1
@@ -15579,7 +15707,7 @@
; return 0; }
EOF
-if { (eval echo configure:15583: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15711: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15598,25 +15726,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15602: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15730: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15606 "configure"
+#line 15734 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15613: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15741: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15620 "configure"
+#line 15748 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15625,7 +15753,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15629: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15757: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -15646,10 +15774,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15650: checking if system supports Large Files at all" >&5
+echo "configure:15778: checking if system supports Large Files at all" >&5
-#line 15653 "configure"
+#line 15781 "configure"
#include <stdio.h>
@@ -15681,7 +15809,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:15685: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15813: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -15710,7 +15838,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15714: checking whether to use Python" >&5
+echo "configure:15842: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -15730,7 +15858,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:15734: checking for $ac_word" >&5
+echo "configure:15862: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -15772,15 +15900,15 @@
do
-echo "configure:15776: checking for $ac_hdr" >&5
+echo "configure:15904: checking for $ac_hdr" >&5
-#line 15779 "configure"
+#line 15907 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15784: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15912: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15821,7 +15949,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:15825: checking for $ac_word" >&5
+echo "configure:15953: checking for $ac_word" >&5
case "$SWIG" in
@@ -15867,7 +15995,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15871: checking whether to use wxWidgets" >&5
+echo "configure:15999: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -15887,7 +16015,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:15891: checking for $ac_word" >&5
+echo "configure:16019: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -15935,7 +16063,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15939: checking wxWidgets version" >&5
+echo "configure:16067: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -15958,15 +16086,15 @@
do
-echo "configure:15962: checking for $ac_hdr" >&5
+echo "configure:16090: checking for $ac_hdr" >&5
-#line 15965 "configure"
+#line 16093 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15970: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16098: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16212,6 +16340,10 @@
s%@GDAL_CFLAGS@%$GDAL_CFLAGS%g
s%@USE_GDAL@%$USE_GDAL%g
s%@USE_OGR@%$USE_OGR%g
+s%@GEOS_CONFIG@%$GEOS_CONFIG%g
+s%@GEOS_LIBS@%$GEOS_LIBS%g
+s%@GEOS_CFLAGS@%$GEOS_CFLAGS%g
+s%@USE_GEOS@%$USE_GEOS%g
s%@TIFF_INCLUDE_DIRS@%$TIFF_INCLUDE_DIRS%g
s%@TIFF_LIBRARY_DIRS@%$TIFF_LIBRARY_DIRS%g
s%@TIFFLIB@%$TIFFLIB%g
@@ -16559,6 +16691,9 @@
echo " OpenGL platform: ${OPENGL_TYPE}"
+echo ""
echo " MacOSX application: `if test -n "${MACOSX_APP}" ; then echo yes ; else echo no ; fi`"
echo ""
@@ -16585,6 +16720,8 @@
echo " GDAL support: `if test -n "${USE_GDAL}" ; then echo yes ; else echo no ; fi`"
+echo " GEOS support: `if test -n "${USE_GEOS}" ; then echo yes ; else echo no ; fi`"
echo " GLw support: `if test -n "${USE_GLW}" ; then echo yes ; else echo no ; fi`"
echo " JPEG support: `if test -n "${USE_JPEG}" ; then echo yes ; else echo no ; fi`"
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in 2009-05-19 12:50:24 UTC (rev 37279)
+++ grass/branches/develbranch_6/configure.in 2009-05-19 13:12:35 UTC (rev 37280)
@@ -214,6 +214,10 @@
# With includes and libs options
+AC_ARG_WITH(geos,
+[ --with-geos[=path/geos-config] enable GEOS support (geos-config with path, \
+e.g. '--with-geos=/usr/local/bin/geos-config', default: no)],, with_geos="no")
AC_ARG_WITH(includes,
[ --with-includes=DIRS site include files are in DIRS])
@@ -775,6 +779,43 @@
AC_SUBST(USE_GDAL)
AC_SUBST(USE_OGR)
+# GEOS option
+AC_MSG_CHECKING(whether to use GEOS)
+GEOS_LIBS=
+GGEOS_CFLAGS=
+USE_GEOS=
+if test "`basename xx/$with_geos`" = "geos-config" ; then
+ GEOS_CONFIG="$with_geos"
+fi
+if test "$with_geos" = "no" ; then
+ AC_MSG_RESULT(no)
+else
+ AC_MSG_RESULT(yes)
+ AC_PATH_PROG(GEOS_CONFIG, geos-config, no)
+ if test "$GEOS_CONFIG" = "no" ; then
+ AC_MSG_ERROR([*** couldn't find geos-config])
+ fi
+ if test "$GEOS_CONFIG" != "" ; then
+ GEOS_LIBS=`"$GEOS_CONFIG" --libs`
+ GEOS_CFLAGS=`"$GEOS_CONFIG" --cflags`
+ USE_GEOS=1
+ fi
+ LOC_CHECK_INCLUDES(geos_c.h,GEOS,$GEOS_CFLAGS)
+ AC_DEFINE(HAVE_GEOS)
+fi
+AC_SUBST(GEOS_LIBS)
+AC_SUBST(GEOS_CFLAGS)
+AC_SUBST(USE_GEOS)
# Enable TIFF option
LOC_CHECK_USE(tiff,TIFF,USE_TIFF)
@@ -1834,6 +1875,7 @@
LOC_MSG([ Building shared libraries: ${shared_ok}])
LOC_MSG([ 64bit support: ${do64bit}])
LOC_MSG([ OpenGL platform: ${OPENGL_TYPE}])
+LOC_MSG()
LOC_MSG_USE(MacOSX application,MACOSX_APP)
LOC_MSG()
LOC_MSG_USE(NVIZ,USE_TOGL)
@@ -1846,6 +1888,7 @@
LOC_MSG_USE(FFTW support,USE_FFTW)
LOC_MSG_USE(FreeType support,USE_FREETYPE)
LOC_MSG_USE(GDAL support,USE_GDAL)
+LOC_MSG_USE(GEOS support,USE_GEOS)
LOC_MSG_USE(GLw support,USE_GLW)
LOC_MSG_USE(JPEG support,USE_JPEG)
LOC_MSG_USE(LAPACK support,USE_LAPACK)
Modified: grass/branches/develbranch_6/include/Make/Grass.make.in
--- grass/branches/develbranch_6/include/Make/Grass.make.in 2009-05-19 12:50:24 UTC (rev 37279)
+++ grass/branches/develbranch_6/include/Make/Grass.make.in 2009-05-19 13:12:35 UTC (rev 37280)
@@ -82,7 +82,7 @@
CFLAGS = $(INC) $(COMPILE_FLAGS) $(USE_TERMIO)
CXXFLAGS = $(INC) $(COMPILE_FLAGS_CXX) $(USE_TERMIO)
LDFLAGS = $(LIBPATH) $(LINK_FLAGS) $(LD_SEARCH_FLAGS) $(PQLIBPATH) $(USE_TERMIO)
-VECT_CFLAGS = $(GDALCFLAGS)
+VECT_CFLAGS = $(GDALCFLAGS) $(GEOSCFLAGS)
# Object with _fmode which must be linked to each executable on Windows
ifdef MINGW
@@ -244,7 +244,7 @@
GRAPHLIB = -l$(GRAPH_LIBNAME)
RTREELIB = -l$(RTREE_LIBNAME)
VEDITLIB = -l$(VEDIT_LIBNAME) $(GISLIB) $(VECTRLIB)
-VECTLIB = $(VECTRLIB) $(DIG2LIB) $(GRAPHLIB) $(RTREELIB) $(LINKMLIB) $(DBMILIB) $(GDALLIBS)
+VECTLIB = $(VECTRLIB) $(DIG2LIB) $(GRAPHLIB) $(RTREELIB) $(LINKMLIB) $(DBMILIB) $(GDALLIBS) $(GEOSLIBS)
# Interpolation
INTERPDATALIB = -l$(INTERPDATA_LIBNAME)
Modified: grass/branches/develbranch_6/include/Make/Platform.make.in
--- grass/branches/develbranch_6/include/Make/Platform.make.in 2009-05-19 12:50:24 UTC (rev 37279)
+++ grass/branches/develbranch_6/include/Make/Platform.make.in 2009-05-19 13:12:35 UTC (rev 37280)
@@ -188,6 +188,11 @@
USE_GDAL = @USE_GDAL@
USE_OGR = @USE_OGR@
+#GEOS
+GEOSLIBS = @GEOS_LIBS@
+GEOSCFLAGS = @GEOS_CFLAGS@
+USE_GEOS = @USE_GEOS@
#FreeType:
FTINC = @FTINC@
FTLIB = @FTLIB@
Modified: grass/branches/develbranch_6/include/Vect.h
--- grass/branches/develbranch_6/include/Vect.h 2009-05-19 12:50:24 UTC (rev 37279)
+++ grass/branches/develbranch_6/include/Vect.h 2009-05-19 13:12:35 UTC (rev 37280)
@@ -3,6 +3,10 @@
#include <grass/gis.h>
#include <grass/vect/digit.h>
+#ifdef HAVE_GEOS
+#include <geos_c.h>
+#endif
/* --- ANSI prototypes for the lib/vector/Vlib functions --- */
@@ -465,4 +469,11 @@
int Vect_attach_isles(struct Map_info *, BOUND_BOX *);
int Vect_attach_centroids(struct Map_info *, BOUND_BOX *);
+ /* GEOS support */
+#ifdef HAVE_GEOS
+GEOSGeometry *Vect_read_line_geos(const struct Map_info *, int);
+GEOSGeometry *Vect_read_area_geos(const struct Map_info *, int);
+GEOSGeometry *Vect_line_to_geos(const struct Map_info *, const struct line_pnts*, int);
+#endif
#endif /* GRASS_VECT_H */
Modified: grass/branches/develbranch_6/include/config.h.in
--- grass/branches/develbranch_6/include/config.h.in 2009-05-19 12:50:24 UTC (rev 37279)
+++ grass/branches/develbranch_6/include/config.h.in 2009-05-19 13:12:35 UTC (rev 37280)
@@ -152,6 +152,9 @@
/* define if OGR is to be used */
#undef HAVE_OGR
+/* define if GEOS is to be used */
+#undef HAVE_GEOS
/* define if postgres client header exists */
#undef HAVE_LIBPQ_FE_H
Property changes on: grass/branches/develbranch_6/lib/vector/Vlib/buffer2.c
___________________________________________________________________
+ text/x-csrc
+ Author Date Id
+ native
Property changes on: grass/branches/develbranch_6/lib/vector/Vlib/dgraph.c
+ text/x-csrc
+ Author Date Id
Property changes on: grass/branches/develbranch_6/lib/vector/Vlib/e_intersect.c
+ text/x-csrc
+ Author Date Id
Copied: grass/branches/develbranch_6/lib/vector/Vlib/geos.c (from rev 36512, grass/trunk/lib/vector/Vlib/geos.c)
--- grass/branches/develbranch_6/lib/vector/Vlib/geos.c (rev 0)
+++ grass/branches/develbranch_6/lib/vector/Vlib/geos.c 2009-05-19 13:12:35 UTC (rev 37280)
@@ -0,0 +1,178 @@
+ * \file geos.c
+ * \brief Vector library - GEOS support
+ * Higher level functions for reading/writing/manipulating vectors.
+ * (C) 2009 by the GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
+ * \author Martin Landa <landa.martin gmail.com>
+#include <grass/config.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/glocale.h>
+#ifdef HAVE_GEOS
+static struct line_pnts *Points;
+ \brief Read vector feature and stores it as GEOSGeometry instance
+ Note: Free allocated memory by GEOSGeom_destroy().
+ \param Map pointer to Map_info structure
+ \param line feature id
+ \return pointer to GEOSGeometry instance
+ \return NULL on error
+GEOSGeometry *Vect_read_line_geos(const struct Map_info *Map, int line)
+ int type, dim;
+ GEOSGeometry *geom;
+ GEOSCoordSequence *pseq;
+ if (!Points)
+ Points = Vect_new_line_struct();
+ G_debug(3, "Vect_read_line_geos(line=%d)", line);
+ if (Vect_is_3d(Map))
+ dim = 3;
+ else
+ dim = 2;
+ type = Vect_read_line(Map, Points, NULL, line);
+ if (type < 0)
+ return NULL;
+ return Vect_line_to_geos(Map, Points, type);
+ \brief Read vector area and stores it as GEOSGeometry instance
+ \param area area id
+GEOSGeometry *Vect_read_area_geos(const struct Map_info * Map, int area)
+ int i, type, dim, nholes, isle;
+ GEOSGeometry *boundary, **holes;
+ if (!Points)
+ G_debug(3, "Vect_read_area_geos(area=%d)", area);
+ dim = 3;
+ else
+ dim = 2;
+ if (Vect_get_area_points(Map, area, Points) == -1) {
+ G_fatal_error(_("Vect_read_area_geos(): unable to read area id %d"),
+ area);
+ boundary = Vect_line_to_geos(Map, Points, GV_BOUNDARY);
+ if (!boundary) {
+ area);
+ nholes = Vect_get_area_num_isles(Map, area);
+ holes = (GEOSGeometry **) G_malloc(nholes * sizeof(GEOSGeometry *));
+ for (i = 0; i < nholes; i++) {
+ isle = Vect_get_area_isle(Map, area, i);
+ if (isle < 1)
+ continue;
+ if (Vect_get_isle_points(Map, isle, Points) < 0)
+ G_fatal_error(_("Vect_read_area_geos(): unable to read isle id %d of area id %d"),
+ isle, area);
+ holes[i] = Vect_line_to_geos(Map, Points, GV_BOUNDARY);
+ return GEOSGeom_createPolygon(boundary, holes, nholes);
+ \brief Create GEOSGeometry of given type from feature points.
+ Supported types:
+ - GV_POINT -> POINT
+ - GV_LINE -> LINESTRING
+ - GV_BOUNDARY -> LINERING
+ \param type feature type (see supported types)
+GEOSGeometry *Vect_line_to_geos(const struct Map_info * Map,
+ const struct line_pnts * points, int type)
+ int i, dim;
+ G_debug(3, "Vect_line_to_geos(type=%d)", type);
+ dim = 3;
+ else
+ dim = 2;
+ if (type == GV_POINT) {
+ if (points->n_points != 1)
+ return NULL;
+ else { /* GV_LINES */
+ if (points->n_points < 2)
+ return NULL;
+ if (!(type & (GV_POINT | GV_LINES)))
+ return NULL;
+ pseq = GEOSCoordSeq_create(points->n_points, dim);
+ for (i = 0; i < points->n_points; i++) {
+ GEOSCoordSeq_setX(pseq, i, points->x[i]);
+ GEOSCoordSeq_setY(pseq, i, points->y[i]);
+ if (dim == 3)
+ GEOSCoordSeq_setZ(pseq, i, points->z[i]);
+ geom = GEOSGeom_createPoint(pseq);
+ else if (type == GV_LINE)
+ geom = GEOSGeom_createLineString(pseq);
+ else { /* GV_BOUNDARY */
+ if (GEOSisRing(geom)) {
+ /* GEOSGeom_destroy(geom); */
+ geom = GEOSGeom_createLinearRing(pseq);
+ /* GEOSCoordSeq_destroy(pseq); */
+ return geom;
+#endif /* HAVE_GEOS */
Modified: grass/branches/develbranch_6/vector/v.select/description.html
--- grass/branches/develbranch_6/vector/v.select/description.html 2009-05-19 12:50:24 UTC (rev 37279)
+++ grass/branches/develbranch_6/vector/v.select/description.html 2009-05-19 13:12:35 UTC (rev 37280)
@@ -1,17 +1,37 @@
<h2>DESCRIPTION</h2>
<em>v.select</em> allows the user to select features from a vector
-by features from another one.
+map by features from another one.
+<p>
+Supported operators (without GEOS):
+<ul>
+ <li><tt>overlap</tt> - features partially or completely overlap
+</ul>
+Supported operators (with GEOS):
+<ul>
+ <li><tt>equals</tt> - features are spatially equals</li>
+ <li><tt>disjoint</tt> - features do not spatially intersect</li>
+ <li><tt>intersects</tt> - features spatially intersect</li>
+ <li><tt>touches</tt> - features spatially touches</li>
+ <li><tt>crosses</tt> - features spatially crosses</li>
+ <li><tt>within</tt> - feature A is completely inside feature B</li>
+ <li><tt>contains</tt> - feature B is completely inside feature A</li>
+ <li><tt>overlap</tt> - features spatilly overlap</li>
+ <li><tt>relate</tt> - feature A is spatially related to feature B</li>
+</ul>
<h2>NOTES</h2>
Only features with category numbers will be considered. If required
-the <em>v.category</em> module can be used to add them. Typically
-boundaries do not need to be given a category number, as an area's
-attributes are inherited from the centroid. Typically points, lines, and
-centroids will always want to have a cat number.
+the <a href="v.category.html">v.category</a> module can be used to add
+them. Typically boundaries do not need to be given a category number,
+as an area's attributes are inherited from the centroid. Typically
+points, lines, and centroids will always want to have a cat number.
<p>
-e.g. take a road which separates two farms. It is ambiguous as to which
+E.g. take a road which separates two farms. It is ambiguous as to which
farm an attribute that is attached to the road belongs to. The boundary
only needs a cat number if it will hold its own attributes, such as road
name or pavement form. A centroid in each paddock holds the information
@@ -20,12 +40,11 @@
<h2>EXAMPLES</h2>
-Extract forest fire points from larger fire map:
+Extract forest fire points from larger fire vector map:
<div class="code"><pre>
-v.select ainput=fire binput=forest output=forest_fire
+v.select ainput=fire binput=forest output=forest_fire operator=overlap
</pre></div>
-<P>
Extract Italian rivers from VMAP0 watercourses map:
@@ -39,13 +58,20 @@
<em>
<a HREF="v.category.html">v.category</a>,
-<a HREF="v.overlay.html">v.overlay</a>,
-<a HREF="sql.html">GRASS SQL interface</a></em>
+<a HREF="v.overlay.html">v.overlay</a>
+</em>
+<p>
+<em>
+<a HREF="sql.html">GRASS SQL interface</a>
+</em>
<h2>AUTHORS</h2>
-Radim Blazek
+Radim Blazek<br>
+Updated by Martin Landa, CTU in Prague, Czech Republic (GEOS support)
<p>
<i>Last changed: $Date$</i>
Copied: grass/branches/develbranch_6/vector/v.select/geos.c (from rev 36512, grass/trunk/vector/v.select/geos.c)
--- grass/branches/develbranch_6/vector/v.select/geos.c (rev 0)
+++ grass/branches/develbranch_6/vector/v.select/geos.c 2009-05-19 13:12:35 UTC (rev 37280)
@@ -0,0 +1,123 @@
+#include <grass/dbmi.h>
+#include "proto.h"
+#ifdef HAVE_GEOS
+static int relate_geos(const struct Map_info *, const GEOSGeometry *,
+ int, int, const char *, int);
+int line_relate_geos(const struct Map_info *BIn, const GEOSGeometry * AGeom,
+ int bline, int operator, const char *relate)
+ return relate_geos(BIn, AGeom, bline, operator, relate, 0);
+int area_relate_geos(const struct Map_info *BIn, const GEOSGeometry * AGeom,
+ int barea, int operator, const char *relate)
+ return relate_geos(BIn, AGeom, barea, operator, relate, 1);
+int relate_geos(const struct Map_info *BIn, const GEOSGeometry * AGeom,
+ int bfid, int operator, const char *relate, int area)
+ GEOSGeometry *BGeom = NULL;
+ int found;
+ found = 0;
+ if (area)
+ BGeom = Vect_read_area_geos(BIn, bfid);
+ else
+ BGeom = Vect_read_line_geos(BIn, bfid);
+ if (!BGeom)
+ return 0;
+ if (!BGeom) {
+ if (area)
+ G_fatal_error(_("Unable to read area id %d from vector map <%s>"),
+ bfid, Vect_get_full_name(BIn));
+ else
+ G_fatal_error(_("Unable to read line id %d from vector map <%s>"),
+ switch (operator) {
+ case OP_EQUALS:{
+ if (GEOSEquals(AGeom, BGeom)) {
+ found = 1;
+ break;
+ break;
+ case OP_DISJOINT:{
+ if (GEOSDisjoint(AGeom, BGeom)) {
+ found = 1;
+ break;
+ break;
+ case OP_INTERSECTS:{
+ if (GEOSIntersects(AGeom, BGeom)) {
+ found = 1;
+ break;
+ break;
+ case OP_TOUCHES:{
+ if (GEOSTouches(AGeom, BGeom)) {
+ found = 1;
+ break;
+ break;
+ case OP_CROSSES:{
+ if (GEOSCrosses(AGeom, BGeom)) {
+ found = 1;
+ break;
+ break;
+ case OP_WITHIN:{
+ if (GEOSWithin(AGeom, BGeom)) {
+ found = 1;
+ break;
+ break;
+ case OP_CONTAINS:{
+ if (GEOSContains(AGeom, BGeom)) {
+ found = 1;
+ break;
+ break;
+ case OP_OVERLAPS:{
+ if (GEOSOverlaps(AGeom, BGeom)) {
+ found = 1;
+ break;
+ break;
+ case OP_RELATE:{
+ if (GEOSRelatePattern(AGeom, BGeom, relate)) {
+ found = 1;
+ break;
+ break;
+ default:
+ break;
+ if (BGeom)
+ GEOSGeom_destroy(BGeom);
+ return found;
Modified: grass/branches/develbranch_6/vector/v.select/main.c
--- grass/branches/develbranch_6/vector/v.select/main.c 2009-05-19 12:50:24 UTC (rev 37279)
+++ grass/branches/develbranch_6/vector/v.select/main.c 2009-05-19 13:12:35 UTC (rev 37280)
@@ -4,8 +4,9 @@
* MODULE: v.select - select features from one map by features in another map.
* AUTHOR(S): Radim Blazek <radim.blazek gmail.com> (original contributor)
* Glynn Clements <glynn gclements.plus.com>, Markus Neteler <neteler itc.it>
+ * Martin Landa <landa.martin gmail.com> (GEOS support)
* PURPOSE:
- * COPYRIGHT: (C) 2003-2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2009 by the GRASS Development Team
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -16,110 +17,30 @@
#include <stdlib.h>
#include <string.h>
#include <stdio.h>
-#define OP_OVERLAP 0
+#include "proto.h"
-/* Add all elements of area A to the list */
-void add_aarea(struct Map_info *In, int aarea, int *ALines)
- int i, j, aline, naisles, aisle, acentroid;
- static struct ilist *BoundList = NULL;
- if (!BoundList)
- BoundList = Vect_new_list();
- acentroid = Vect_get_area_centroid(In, aarea);
- ALines[acentroid] = 1;
- Vect_get_area_boundaries(In, aarea, BoundList);
- for (i = 0; i < BoundList->n_values; i++) {
- aline = abs(BoundList->value[i]);
- ALines[aline] = 1;
- naisles = Vect_get_area_num_isles(In, aarea);
- for (j = 0; j < naisles; j++) {
- aisle = Vect_get_area_isle(In, aarea, j);
- Vect_get_isle_boundaries(In, aisle, BoundList);
-/* Returns 1 if line1 from Map1 overlaps area2 from Map2,
- * 0 otherwise */
-int line_overlap_area(struct Map_info *LMap, int line, struct Map_info *AMap,
- int area)
- int i, nisles, isle;
- static struct line_pnts *LPoints = NULL;
- static struct line_pnts *APoints = NULL;
- G_debug(4, "line_overlap_area line = %d area = %d", line, area);
- if (!LPoints) {
- LPoints = Vect_new_line_struct();
- APoints = Vect_new_line_struct();
- /* Read line coordinates */
- Vect_read_line(LMap, LPoints, NULL, line);
- /* Try if any of line vertices is within area */
- for (i = 0; i < LPoints->n_points; i++) {
- if (Vect_point_in_area(AMap, area, LPoints->x[i], LPoints->y[i])) {
- G_debug(4, " -> line vertex inside area");
- return 1;
- /* Skip points */
- if (LPoints->n_points < 2)
- return 0;
- /* Try intersections of line with area/isles boundary */
- /* Outer boundary */
- Vect_get_area_points(AMap, area, APoints);
- if (Vect_line_check_intersection(LPoints, APoints, 0)) {
- G_debug(4, " -> line intersects outer area boundary");
- return 1;
- nisles = Vect_get_area_num_isles(AMap, area);
- for (i = 0; i < nisles; i++) {
- isle = Vect_get_area_isle(AMap, area, i);
- Vect_get_isle_points(AMap, isle, APoints);
- G_debug(4, " -> line intersects area island boundary");
- return 1;
- return 0;
int main(int argc, char *argv[])
- int i;
- int input, operator;
- int aline, nalines;
- int type[2], field[2];
+ int i, iopt;
+ int operator;
+ int aline, nalines, nskipped;
+ int ltype, itype[2], ifield[2];
int **cats, *ncats, nfields, *fields;
char *mapset[2], *pre[2];
struct GModule *module;
- struct Option *in_opt[2], *out_opt, *type_opt[2], *field_opt[2],
- *operator_opt;
- struct Flag *table_flag, *r_flag;
+ struct {
+ struct Option *input[2], *output, *type[2], *field[2],
+ *operator, *relate;
+ } parm;
+ struct {
+ struct Flag *table, *reverse, *geos;
+ } flag;
struct Map_info In[2], Out;
struct field_info *IFi, *OFi;
struct line_pnts *APoints, *BPoints;
@@ -133,88 +54,144 @@
pre[1] = "b";
module = G_define_module();
- module->keywords = _("vector, query");
+ module->keywords = _("vector, spatial query");
module->description =
_("Selects features from vector map (A) by features from other vector map (B).");
- in_opt[0] = G_define_standard_option(G_OPT_V_INPUT);
- in_opt[0]->description = _("Name of input vector map (A)");
- in_opt[0]->key = "ainput";
+ parm.input[0] = G_define_standard_option(G_OPT_V_INPUT);
+ parm.input[0]->description = _("Name of input vector map (A)");
+ parm.input[0]->key = "ainput";
- type_opt[0] = G_define_standard_option(G_OPT_V_TYPE);
- type_opt[0]->label = _("Feature type (vector map A)");
- type_opt[0]->key = "atype";
- type_opt[0]->guisection = _("Selection");
+ parm.type[0] = G_define_standard_option(G_OPT_V_TYPE);
+ parm.type[0]->label = _("Feature type (vector map A)");
+ parm.type[0]->key = "atype";
+ parm.type[0]->guisection = _("Selection");
- field_opt[0] = G_define_standard_option(G_OPT_V_FIELD);
- field_opt[0]->label = _("Layer number (vector map A)");
- field_opt[0]->key = "alayer";
- field_opt[0]->guisection = _("Selection");
+ parm.field[0] = G_define_standard_option(G_OPT_V_FIELD);
+ parm.field[0]->label = _("Layer number (vector map A)");
+ parm.field[0]->key = "alayer";
+ parm.field[0]->guisection = _("Selection");
- in_opt[1] = G_define_standard_option(G_OPT_V_INPUT);
- in_opt[1]->description = _("Name of input vector map (B)");
- in_opt[1]->key = "binput";
+ parm.input[1] = G_define_standard_option(G_OPT_V_INPUT);
+ parm.input[1]->description = _("Name of input vector map (B)");
+ parm.input[1]->key = "binput";
- type_opt[1] = G_define_standard_option(G_OPT_V_TYPE);
- type_opt[1]->label = _("Feature type (vector map B)");
- type_opt[1]->key = "btype";
- type_opt[1]->guisection = _("Selection");
+ parm.type[1] = G_define_standard_option(G_OPT_V_TYPE);
+ parm.type[1]->label = _("Feature type (vector map B)");
+ parm.type[1]->key = "btype";
+ parm.type[1]->guisection = _("Selection");
- field_opt[1] = G_define_standard_option(G_OPT_V_FIELD);
- field_opt[1]->label = _("Layer number (vector map B)");
- field_opt[1]->key = "blayer";
- field_opt[1]->guisection = _("Selection");
+ parm.field[1] = G_define_standard_option(G_OPT_V_FIELD);
+ parm.field[1]->label = _("Layer number (vector map B)");
+ parm.field[1]->key = "blayer";
+ parm.field[1]->guisection = _("Selection");
- out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
+ parm.output = G_define_standard_option(G_OPT_V_OUTPUT);
- operator_opt = G_define_option();
- operator_opt->key = "operator";
- operator_opt->type = TYPE_STRING;
- operator_opt->required = NO;
- operator_opt->multiple = NO;
- operator_opt->options = "overlap";
- operator_opt->answer = "overlap";
- operator_opt->label =
+ parm.operator = G_define_option();
+ parm.operator->key = "operator";
+ parm.operator->type = TYPE_STRING;
+ parm.operator->required = NO;
+ parm.operator->multiple = NO;
+ parm.operator->label =
_("Operator defines required relation between features");
- operator_opt->description =
+ parm.operator->description =
_("A feature is written to output if the result of operation 'ainput operator binput' is true. "
"An input feature is considered to be true, if category of given layer is defined.");
- operator_opt->descriptions = _("overlap;features partially or completely overlap");
+ parm.operator->answer = "overlap";
+#ifndef HAVE_GEOS
+ parm.operator->options = "overlap";
+ parm.operator->descriptions = _("overlap;features partially or completely overlap");
+#else
+ parm.operator->options = "equals,disjoint,intersects,touches,crosses,within,contains,overlap,relate";
+ parm.operator->descriptions = _("equals;features are spatially equals (requires flag 'g');"
+ "disjoint;features do not spatially intersect (requires flag 'g');"
+ "intersects;features spatially intersect (requires flag 'g');"
+ "touches;features spatially touches (requires flag 'g');"
+ "crosses;features spatially crosses (requires flag 'g');"
+ "within;feature A is completely inside feature B (requires flag 'g');"
+ "contains;feature B is completely inside feature A (requires flag 'g');"
+ "overlap;features spatilly overlap;"
+ "relate;feature A is spatially related to feature B "
+ "(requires 'relate' option and flag 'g');");
+#endif
- table_flag = G_define_flag();
- table_flag->key = 't';
- table_flag->description = _("Do not create attribute table");
+ parm.relate = G_define_option();
+ parm.relate->key = "relate";
+ parm.relate->type = TYPE_STRING;
+ parm.relate->required = NO;
+ parm.relate->multiple = NO;
+ parm.relate->description = _("Intersection Matrix Pattern used for 'relate' operator");
+ flag.table = G_define_flag();
+ flag.table->key = 't';
+ flag.table->description = _("Do not create attribute table");
- r_flag = G_define_flag();
- r_flag->key = 'r';
- r_flag->description = _("Reverse selection");
- r_flag->guisection = _("Selection");
+ flag.reverse = G_define_flag();
+ flag.reverse->key = 'r';
+ flag.reverse->description = _("Reverse selection");
+ flag.reverse->guisection = _("Selection");
+#ifdef HAVE_GEOS
+ flag.geos = G_define_flag();
+ flag.geos->key = 'g';
+ flag.geos->description = _("Use GEOS operators");
+#else
+ flag.geos = NULL;
+#endif
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ if (parm.operator->answer[0] == 'e')
+ operator = OP_EQUALS;
+ else if (parm.operator->answer[0] == 'd')
+ operator = OP_DISJOINT;
+ else if (parm.operator->answer[0] == 'i')
+ operator = OP_INTERSECTS;
+ else if (parm.operator->answer[0] == 't')
+ operator = OP_TOUCHES;
+ else if (parm.operator->answer[0] == 'c' && parm.operator->answer[1] == 'r')
+ operator = OP_CROSSES;
+ else if (parm.operator->answer[0] == 'w')
+ operator = OP_WITHIN;
+ else if (parm.operator->answer[0] == 'c' && parm.operator->answer[1] == 'o')
+ operator = OP_CONTAINS;
+ else if (parm.operator->answer[0] == 'o')
+ operator = OP_OVERLAPS;
+ else if (parm.operator->answer[0] == 'r')
+ operator = OP_RELATE;
+ else
+ G_fatal_error(_("Unknown operator"));
+ if (operator != OP_OVERLAPS && flag.geos && !flag.geos->answer) {
+ G_fatal_error(_("Enable GEOS operators (flag '%c') to use '%s'"),
+ flag.geos->key, parm.operator->answer);
- if (operator_opt->answer[0] == 'o')
- operator = OP_OVERLAP;
+ if (operator == OP_RELATE && !parm.relate->answer) {
+ G_fatal_error(_("Required parameter <%s> not set"),
+ parm.relate->key);
+ for (iopt = 0; iopt < 2; iopt++) {
+ itype[iopt] = Vect_option_to_types(parm.type[iopt]);
+ ifield[iopt] = atoi(parm.field[iopt]->answer);
- for (input = 0; input < 2; input++) {
- type[input] = Vect_option_to_types(type_opt[input]);
- field[input] = atoi(field_opt[input]->answer);
- Vect_check_input_output_name(in_opt[input]->answer, out_opt->answer,
+ Vect_check_input_output_name(parm.input[iopt]->answer, parm.output->answer,
GV_FATAL_EXIT);
- if ((mapset[input] =
- G_find_vector2(in_opt[input]->answer, NULL)) == NULL) {
+ if ((mapset[iopt] =
+ G_find_vector2(parm.input[iopt]->answer, NULL)) == NULL) {
G_fatal_error(_("Vector map <%s> not found"),
- in_opt[input]->answer);
+ parm.input[iopt]->answer);
Vect_set_open_level(2);
- Vect_open_old(&(In[input]), in_opt[input]->answer, mapset[input]);
+ Vect_open_old(&(In[iopt]), parm.input[iopt]->answer, mapset[iopt]);
/* Read field info */
- IFi = Vect_get_field(&(In[0]), field[0]);
+ IFi = Vect_get_field(&(In[0]), ifield[0]);
BPoints = Vect_new_line_struct();
@@ -225,20 +202,32 @@
/* Open output */
- Vect_open_new(&Out, out_opt->answer, Vect_is_3d(&(In[0])));
- Vect_set_map_name(&Out, "Output from v.select");
+ Vect_open_new(&Out, parm.output->answer, Vect_is_3d(&(In[0])));
+ Vect_set_map_name(&Out, _("Output from v.select"));
Vect_set_person(&Out, G_whoami());
Vect_copy_head_data(&(In[0]), &Out);
Vect_hist_copy(&(In[0]), &Out);
Vect_hist_command(&Out);
+ nskipped = 0;
nalines = Vect_get_num_lines(&(In[0]));
+#ifdef HAVE_GEOS
+ initGEOS(G_message, G_fatal_error);
+ GEOSGeometry *AGeom = NULL;
+#else
+ void *AGeom = NULL;
+#endif
/* Alloc space for input lines array */
ALines = (int *)G_calloc(nalines + 1, sizeof(int));
+ G_message(_("Building spatial index..."));
+ Vect_build_spatial_index(&In[0]);
+ Vect_build_spatial_index(&In[1]);
/* Lines in A. Go through all lines and mark those that meets condition */
- if (type[0] & (GV_POINTS | GV_LINES)) {
+ if (itype[0] & (GV_POINTS | GV_LINES)) {
G_message(_("Processing features..."));
for (aline = 1; aline <= nalines; aline++) {
@@ -248,75 +237,121 @@
G_percent(aline, nalines, 2); /* must be before any continue */
/* Check category */
- if (Vect_get_line_cat(&(In[0]), aline, field[0]) < 0)
+ if (Vect_get_line_cat(&(In[0]), aline, ifield[0]) < 0) {
+ nskipped++;
continue;
/* Read line and check type */
- if (!(Vect_read_line(&(In[0]), APoints, NULL, aline) & type[0]))
+ ltype = Vect_read_line(&(In[0]), APoints, NULL, aline);
+ if (!(ltype & itype[0]))
continue;
Vect_get_line_box(&(In[0]), aline, &abox);
abox.T = PORT_DOUBLE_MAX;
abox.B = -PORT_DOUBLE_MAX;
+ if (flag.geos && flag.geos->answer) {
+ if (!(ltype & (GV_POINT | GV_LINE)))
+ continue;
+#ifdef HAVE_GEOS
+ AGeom = Vect_line_to_geos(&(In[0]), APoints, ltype);
+#endif
+ if (!AGeom)
+ aline, Vect_get_full_name(&(In[0])));
/* Check if this line overlaps any feature in B */
/* x Lines in B */
- if (type[1] & (GV_POINTS | GV_LINES)) {
+ if (itype[1] & (GV_POINTS | GV_LINES)) {
int i;
int found = 0;
/* Lines */
- Vect_select_lines_by_box(&(In[1]), &abox, type[1], List);
+ Vect_select_lines_by_box(&(In[1]), &abox, itype[1], List);
for (i = 0; i < List->n_values; i++) {
int bline;
bline = List->value[i];
G_debug(3, " bline = %d", bline);
- if (!Vect_get_line_cat(&(In[1]), bline, field[1]) < 0)
+ if (!Vect_get_line_cat(&(In[1]), bline, ifield[1]) < 0) {
+ nskipped++;
continue;
+#ifdef HAVE_GEOS
+ if(line_relate_geos(&(In[1]), AGeom,
+ bline, operator, parm.relate->answer)) {
- Vect_read_line(&(In[1]), BPoints, NULL, bline);
+ found = 1;
+ break;
+#endif
+ else {
+ Vect_read_line(&(In[1]), BPoints, NULL, bline);
- if (Vect_line_check_intersection(APoints, BPoints, 0)) {
- found = 1;
- break;
+ if (Vect_line_check_intersection(APoints, BPoints, 0)) {
+ found = 1;
+ break;
if (found) {
ALines[aline] = 1;
continue; /* Go to next A line */
/* x Areas in B. */
- if (type[1] & GV_AREA) {
+ if (itype[1] & GV_AREA) {
int i;
Vect_select_areas_by_box(&(In[1]), &abox, List);
int barea;
barea = List->value[i];
G_debug(3, " barea = %d", barea);
- if (Vect_get_area_cat(&(In[1]), barea, field[1]) < 0)
+ if (Vect_get_area_cat(&(In[1]), barea, ifield[1]) < 0) {
+ nskipped++;
continue;
- if (line_overlap_area(&(In[0]), aline, &(In[1]), barea)) {
- break;
+#ifdef HAVE_GEOS
+ if(area_relate_geos(&(In[1]), AGeom,
+ barea, operator, parm.relate->answer)) {
+ ALines[aline] = 1;
+ break;
+#endif
+ else {
+ if (line_overlap_area(&(In[0]), aline, &(In[1]), barea)) {
+ break;
+#ifdef HAVE_GEOS
+ GEOSGeom_destroy(AGeom);
+#endif
+ AGeom = NULL;
/* Areas in A. */
- if (type[0] & GV_AREA) {
+ if (itype[0] & GV_AREA) {
int aarea, naareas;
G_message(_("Processing areas..."));
@@ -324,38 +359,62 @@
naareas = Vect_get_num_areas(&(In[0]));
for (aarea = 1; aarea <= naareas; aarea++) {
- int i;
BOUND_BOX abox;
G_percent(aarea, naareas, 2); /* must be before any continue */
- if (Vect_get_area_cat(&(In[0]), aarea, field[0]) < 0)
+ if (Vect_get_area_cat(&(In[0]), aarea, ifield[0]) < 0) {
+ nskipped++;
continue;
Vect_get_area_box(&(In[0]), aarea, &abox);
+#ifdef HAVE_GEOS
+ AGeom = Vect_read_area_geos(&(In[0]), aarea);
+#endif
+ if (!AGeom)
/* x Lines in B */
int bline;
- if (Vect_get_line_cat(&(In[1]), bline, field[1]) < 0)
+ if (Vect_get_line_cat(&(In[1]), bline, ifield[1]) < 0) {
+ nskipped++;
continue;
- if (line_overlap_area(&(In[1]), bline, &(In[0]), aarea)) {
- add_aarea(&(In[0]), aarea, ALines);
- continue;
+#ifdef HAVE_GEOS
+ add_aarea(&(In[0]), aarea, ALines);
+ break;
+#endif
+ else {
+ if (line_overlap_area(&(In[1]), bline, &(In[0]), aarea)) {
+ continue;
/* x Areas in B */
int naisles;
int found = 0;
@@ -395,25 +454,38 @@
barea = TmpList->value[j];
+ nskipped++;
continue;
/* Check if any centroid of area B is in area A.
* This test is important in if area B is completely within area A */
bcentroid = Vect_get_area_centroid(&(In[1]), barea);
Vect_read_line(&(In[1]), BPoints, NULL, bcentroid);
- (&(In[0]), aarea, BPoints->x[0], BPoints->y[0])) {
- found = 1;
- break;
+#ifdef HAVE_GEOS
+ found = 1;
+ break;
+#endif
- /* Check intersectin of lines from List with area B */
- (&(In[0]), aline, &(In[1]), barea)) {
- found = 1;
- break;
+ else {
+ if (Vect_point_in_area(&(In[0]), aarea,
+ BPoints->x[0], BPoints->y[0])) {
+ found = 1;
+ break;
+ /* Check intersectin of lines from List with area B */
+ &(In[1]), barea)) {
+ found = 1;
+ break;
if (found) {
@@ -422,11 +494,21 @@
+#ifdef HAVE_GEOS
+#endif
+ AGeom = NULL;
Vect_close(&(In[1]));
+#ifdef HAVE_GEOS
+ finishGEOS();
+#endif
/* Write lines */
nfields = Vect_cidx_get_num_fields(&(In[0]));
cats = (int **)G_malloc(nfields * sizeof(int *));
@@ -447,14 +529,14 @@
G_debug(4, "aline = %d ALines[aline] = %d", aline, ALines[aline]);
- if ((!r_flag->answer && !(ALines[aline])) ||
- (r_flag->answer && ALines[aline]))
+ if ((!flag.reverse->answer && !(ALines[aline])) ||
+ (flag.reverse->answer && ALines[aline]))
continue;
atype = Vect_read_line(&(In[0]), APoints, ACats, aline);
Vect_write_line(&Out, atype, APoints, ACats);
- if (!(table_flag->answer) && (IFi != NULL)) {
+ if (!(flag.table->answer) && (IFi != NULL)) {
for (i = 0; i < ACats->n_cats; i++) {
int f, j;
@@ -471,7 +553,7 @@
/* Copy tables */
- if (!(table_flag->answer)) {
+ if (!(flag.table->answer)) {
int ttype, ntabs = 0;
G_message(_("Writing attributes..."));
@@ -535,7 +617,11 @@
Vect_build(&Out);
Vect_close(&Out);
- G_done_msg(" ");
+ if (nskipped > 0) {
+ G_warning(_("%d features without category skipped"), nskipped);
+ G_done_msg(_("%d features written to output."), Vect_get_num_lines(&Out));
exit(EXIT_SUCCESS);
Copied: grass/branches/develbranch_6/vector/v.select/overlap.c (from rev 36512, grass/trunk/vector/v.select/overlap.c)
--- grass/branches/develbranch_6/vector/v.select/overlap.c (rev 0)
+++ grass/branches/develbranch_6/vector/v.select/overlap.c 2009-05-19 13:12:35 UTC (rev 37280)
@@ -0,0 +1,90 @@
+#include "proto.h"
+/* Add all elements of area A to the list */
+void add_aarea(struct Map_info *In, int aarea, int *ALines)
+ int i, j, aline, naisles, aisle, acentroid;
+ static struct ilist *BoundList = NULL;
+ if (!BoundList)
+ BoundList = Vect_new_list();
+ acentroid = Vect_get_area_centroid(In, aarea);
+ ALines[acentroid] = 1;
+ Vect_get_area_boundaries(In, aarea, BoundList);
+ for (i = 0; i < BoundList->n_values; i++) {
+ aline = abs(BoundList->value[i]);
+ naisles = Vect_get_area_num_isles(In, aarea);
+ for (j = 0; j < naisles; j++) {
+ aisle = Vect_get_area_isle(In, aarea, j);
+ Vect_get_isle_boundaries(In, aisle, BoundList);
+/* Returns 1 if line1 from Map1 overlaps area2 from Map2,
+ * 0 otherwise */
+int line_overlap_area(struct Map_info *LMap, int line, struct Map_info *AMap,
+ int area)
+ int i, nisles, isle;
+ static struct line_pnts *LPoints = NULL;
+ static struct line_pnts *APoints = NULL;
+ G_debug(4, "line_overlap_area line = %d area = %d", line, area);
+ if (!LPoints) {
+ LPoints = Vect_new_line_struct();
+ APoints = Vect_new_line_struct();
+ /* Read line coordinates */
+ Vect_read_line(LMap, LPoints, NULL, line);
+ /* Try if any of line vertices is within area */
+ for (i = 0; i < LPoints->n_points; i++) {
+ if (Vect_point_in_area(AMap, area, LPoints->x[i], LPoints->y[i])) {
+ G_debug(4, " -> line vertex inside area");
+ return 1;
+ /* Skip points */
+ if (LPoints->n_points < 2)
+ return 0;
+ /* Try intersections of line with area/isles boundary */
+ /* Outer boundary */
+ Vect_get_area_points(AMap, area, APoints);
+ if (Vect_line_check_intersection(LPoints, APoints, 0)) {
+ G_debug(4, " -> line intersects outer area boundary");
+ return 1;
+ nisles = Vect_get_area_num_isles(AMap, area);
+ for (i = 0; i < nisles; i++) {
+ isle = Vect_get_area_isle(AMap, area, i);
+ Vect_get_isle_points(AMap, isle, APoints);
+ G_debug(4, " -> line intersects area island boundary");
+ return 1;
+ return 0;
Copied: grass/branches/develbranch_6/vector/v.select/proto.h (from rev 36512, grass/trunk/vector/v.select/proto.h)
--- grass/branches/develbranch_6/vector/v.select/proto.h (rev 0)
+++ grass/branches/develbranch_6/vector/v.select/proto.h 2009-05-19 13:12:35 UTC (rev 37280)
@@ -0,0 +1,22 @@
+#define OP_EQUALS 0
+#define OP_DISJOINT 1
+#define OP_INTERSECTS 2
+#define OP_TOUCHES 3
+#define OP_CROSSES 4
+#define OP_WITHIN 5
+#define OP_CONTAINS 6
+#define OP_OVERLAPS 7
+#define OP_RELATE 8
+#ifdef HAVE_GEOS
+/* geos.c */
+int line_relate_geos(const struct Map_info *, const GEOSGeometry *,
+ int, int, const char *);
+int area_relate_geos(const struct Map_info *, const GEOSGeometry *,
+#endif
+/* overlap.c */
+void add_aarea(struct Map_info *, int, int *);
+int line_overlap_area(struct Map_info *, int, struct Map_info *, int);
