[GRASS-SVN] r37289 - in grass/branches/develbranch_6/lib: gtcltk
init
svn_grass at osgeo.org
Tue May 19 13:01:46 EDT 2009
Author: hamish
Date: 2009-05-19 13:01:45 -0400 (Tue, 19 May 2009)
New Revision: 37289
grass/branches/develbranch_6/lib/gtcltk/gronsole.tcl
grass/branches/develbranch_6/lib/init/grass-run.src
hack away on bugs #604 and #606
Modified: grass/branches/develbranch_6/lib/gtcltk/gronsole.tcl
--- grass/branches/develbranch_6/lib/gtcltk/gronsole.tcl 2009-05-19 14:42:51 UTC (rev 37288)
+++ grass/branches/develbranch_6/lib/gtcltk/gronsole.tcl 2009-05-19 17:01:45 UTC (rev 37289)
@@ -395,6 +395,8 @@
proc Gronsole::readout {path ci mark fh} {
+# global mingw
set lines {}
while {[gets $fh line] >= 0} {
@@ -406,6 +408,10 @@
if {[llength $lines] != 0} {
Gronsole::add_data_tag $path $ci out
+# if { $mingw == "1" } {
+ # FIXME bug #606
+# Gronsole::output_to_gronsole $path $mark $ci [list cmd$ci cmd$ci-out] "\n"
#output any messages from running the command
@@ -535,7 +541,9 @@
exec -- cmd.exe /c start $env(GISBASE)/etc/grass-run.bat $cmd &
} else {
- exec -- $env(GISBASE)/etc/grass-xterm-wrapper -name xterm-grass -e $env(GISBASE)/etc/grass-run.sh $cmd &
+ eval [list exec -- $env(GISBASE)/etc/grass-xterm-wrapper \
+ -name xterm-grass -e $env(GISBASE)/etc/grass-run.sh \
+ [lindex $cmd 0] [split [lrange $cmd 1 end]] ] &
update idletasks
Modified: grass/branches/develbranch_6/lib/init/grass-run.src
--- grass/branches/develbranch_6/lib/init/grass-run.src 2009-05-19 14:42:51 UTC (rev 37288)
+++ grass/branches/develbranch_6/lib/init/grass-run.src 2009-05-19 17:01:45 UTC (rev 37289)
@@ -1,6 +1,9 @@
#!/bin/sh
# script to launch GRASS commands
+#DEBUG:
+#print_args "$@"
# change console title to name of module
if [ "$TERM" = "xterm" ] && [ -n "$BASH" ] ; then
TITLE="GRASS: $1"
@@ -33,9 +36,9 @@
echo
echo "ERROR: \"$1\" exited abnormally. Press <enter> to continue."
read
-elif [ `g.gisenv get=DEBUG` -gt 0 ] ; then
+else
echo
- echo "\"$1\" exited normally. Press <enter> to continue."
+ echo "\"$1\" complete. Press <enter> to continue."
read
fi
