[GRASS-SVN] r37293 - grass/branches/develbranch_6/gui/tcltk/gis.m
svn_grass at osgeo.org
Tue May 19 15:22:57 EDT 2009
Author: hamish
Date: 2009-05-19 15:22:57 -0400 (Tue, 19 May 2009)
New Revision: 37293
grass/branches/develbranch_6/gui/tcltk/gis.m/runandoutput.tcl
native term name on button; linewrap
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/runandoutput.tcl
--- grass/branches/develbranch_6/gui/tcltk/gis.m/runandoutput.tcl 2009-05-19 19:16:34 UTC (rev 37292)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/runandoutput.tcl 2009-05-19 19:22:57 UTC (rev 37293)
@@ -108,22 +108,29 @@
proc command_window {where} {
global keycontrol
global bgcolor
+ global mingw
set cmdpane [frame $where.command -bg $bgcolor]
set cmdwin [ScrolledWindow $where.win -relief flat -borderwidth 1]
set gronsole [Gronsole $where.gronsole -clickcmd "gronsole_history $cmdwin.text"]
set cmdtext [text $cmdwin.text -height 2 -width 80]
$cmdwin setwidget $cmdtext
- set runbutton [button $cmdpane.run -text [G_msg "Run"] -width 17 -wraplength 100 -default active -bd 1 \
- -highlightbackground $bgcolor \
+ set runbutton [button $cmdpane.run -text [G_msg "Run"] -width 17 -wraplength 100 \
+ -default active -bd 1 -highlightbackground $bgcolor \
-command "run_disabled $gronsole $cmdpane.run \[string trim \[$cmdtext get 1.0 end\]\]"]
- set run2button [button $cmdpane.run2 -text [G_msg "Run (background)"] -width 17 -wraplength 100 -bd 1 \
+ set run2button [button $cmdpane.run2 -text [G_msg "Run (background)"] -width 17 \
+ -wraplength 100 -bd 1 -highlightbackground $bgcolor \
-command "$gronsole run \[string trim \[$cmdtext get 1.0 end\]\] {} {}"]
- set runuibutton [button $cmdpane.runui -text [G_msg "Run (GUI)"] -width 17 -wraplength 100 -bd 1 \
+ set runuibutton [button $cmdpane.runui -text [G_msg "Run (GUI)"] -width 17 \
-command "run_ui \[string trim \[$cmdtext get 1.0 end\]\]"]
- set runxterm [button $cmdpane.xterm -text [G_msg "Run (in Xterm)"] -width 17 -wraplength 100 -bd 1 \
+ if { $mingw } {
+ set termbox "DOS box"
+ } else {
+ set termbox "Xterm"
+ set runxterm [button $cmdpane.xterm -text [G_msg "Run (in $termbox)"] -width 17 \
-command "$gronsole run_xterm \[string trim \[$cmdtext get 1.0 end\]\] {}"]
set outpane [frame $where.output -bg $bgcolor]
set savebutton [button $outpane.save -text [G_msg " Save "] -command "$gronsole save" \
