[GRASS-SVN] r37298 - in grass/branches/develbranch_6/lib: gtcltk
init
svn_grass at osgeo.org
Wed May 20 01:15:35 EDT 2009
Author: hamish
Date: 2009-05-20 01:15:35 -0400 (Wed, 20 May 2009)
New Revision: 37298
grass/branches/develbranch_6/lib/gtcltk/gronsole.tcl
grass/branches/develbranch_6/lib/init/grass-run.bat
fix run_xterm for DOS, simplify bourne version
Modified: grass/branches/develbranch_6/lib/gtcltk/gronsole.tcl
--- grass/branches/develbranch_6/lib/gtcltk/gronsole.tcl 2009-05-20 05:01:36 UTC (rev 37297)
+++ grass/branches/develbranch_6/lib/gtcltk/gronsole.tcl 2009-05-20 05:15:35 UTC (rev 37298)
@@ -539,14 +539,12 @@
Gronsole::annotate $path $cmd [concat xterm $tags]
if { $mingw == "1" } {
- exec -- cmd.exe /c start $env(GISBASE)/etc/grass-run.bat $cmd &
+ eval [list exec -- cmd.exe /c start \
+ $env(GISBASE)/etc/grass-run.bat ] $cmd &
} else {
- set cmd_exe [lindex $cmd 0]
- set args [lrange $cmd 1 end]
eval [list exec -- $env(GISBASE)/etc/grass-xterm-wrapper \
- -name xterm-grass -e $env(GISBASE)/etc/grass-run.sh \
- $cmd_exe ] $args &
+ -name xterm-grass -e $env(GISBASE)/etc/grass-run.sh ] \
+ $cmd &
update idletasks
Modified: grass/branches/develbranch_6/lib/init/grass-run.bat
--- grass/branches/develbranch_6/lib/init/grass-run.bat 2009-05-20 05:01:36 UTC (rev 37297)
+++ grass/branches/develbranch_6/lib/init/grass-run.bat 2009-05-20 05:15:35 UTC (rev 37298)
@@ -8,7 +8,7 @@
set GRASS_UI_TERM=1
rem Run command
if not %errorlevel% == 0 goto error
