[GRASS-SVN] r37320 - in grass/trunk: include lib/vector/Vlib
svn_grass at osgeo.org
Thu May 21 05:11:39 EDT 2009
Author: martinl
Date: 2009-05-21 05:11:39 -0400 (Thu, 21 May 2009)
New Revision: 37320
grass/trunk/include/Vect.h
grass/trunk/lib/vector/Vlib/geos.c
vlib/geos: determine feature type (work in progress)
(merge from devbr6, r37319)
Modified: grass/trunk/include/Vect.h
--- grass/trunk/include/Vect.h 2009-05-21 09:09:38 UTC (rev 37319)
+++ grass/trunk/include/Vect.h 2009-05-21 09:11:39 UTC (rev 37320)
@@ -470,7 +470,7 @@
/* GEOS support */
#ifdef HAVE_GEOS
-GEOSGeometry *Vect_read_line_geos(struct Map_info *, int);
+GEOSGeometry *Vect_read_line_geos(struct Map_info *, int, int*);
GEOSGeometry *Vect_line_to_geos(struct Map_info *, const struct line_pnts*, int);
GEOSGeometry *Vect_read_area_geos(struct Map_info *, int);
GEOSCoordSequence *Vect_get_area_points_geos(struct Map_info *, int);
Modified: grass/trunk/lib/vector/Vlib/geos.c
--- grass/trunk/lib/vector/Vlib/geos.c 2009-05-21 09:09:38 UTC (rev 37319)
+++ grass/trunk/lib/vector/Vlib/geos.c 2009-05-21 09:11:39 UTC (rev 37320)
@@ -21,8 +21,8 @@
#ifdef HAVE_GEOS
#include <geos_c.h>
-static GEOSGeometry *Vect__read_line_geos(struct Map_info *, long);
-static GEOSCoordSequence *V1_read_line_geos(struct Map_info *, long);
+static GEOSGeometry *Vect__read_line_geos(struct Map_info *, long, int *);
+static GEOSCoordSequence *V1_read_line_geos(struct Map_info *, long, int *);
static GEOSCoordSequence *V2_read_line_geos(struct Map_info *, int);
@@ -37,12 +37,13 @@
\param Map pointer to Map_info structure
\param line feature id
+ \param[out] type feature type or NULL
\return pointer to GEOSGeometry instance
\return empty GEOSGeometry for unsupported feature type
\return NULL on error
-GEOSGeometry *Vect_read_line_geos(struct Map_info *Map, int line)
+GEOSGeometry *Vect_read_line_geos(struct Map_info *Map, int line, int *type)
P_LINE *Line;
@@ -64,7 +65,7 @@
G_fatal_error("Vect_read_line_geos(): %s %d",
_("Attempt to read dead line"), line);
- return Vect__read_line_geos(Map, Line->offset);
+ return Vect__read_line_geos(Map, Line->offset, type);
@@ -122,8 +123,8 @@
-GEOSGeometry *Vect_line_to_geos(struct Map_info * Map,
- const struct line_pnts * points, int type)
+GEOSGeometry *Vect_line_to_geos(struct Map_info *Map,
+ const struct line_pnts *points, int type)
int i, with_z;
GEOSGeometry *geom;
@@ -181,29 +182,30 @@
\param offset line offset
\return NULL dead line
\return NULL end of file
-GEOSGeometry *Vect__read_line_geos(struct Map_info *Map, long offset)
+GEOSGeometry *Vect__read_line_geos(struct Map_info *Map, long offset, int *type)
- int type;
+ int ftype;
double *x, *y, *z;
GEOSGeometry *geom;
GEOSCoordSequence *pseq;
- pseq = V1_read_line_geos(Map, offset);
+ pseq = V1_read_line_geos(Map, offset, &ftype);
if (!pseq)
G_fatal_error(_("Unable to read line offset %ld"), offset);
- if (type & GV_POINT) {
+ if (ftype & GV_POINT) {
G_debug(3, " geos_type = point");
geom = GEOSGeom_createPoint(pseq);
- else if (type & GV_LINE) {
+ else if (ftype & GV_LINE) {
G_debug(3, " geos_type = linestring");
geom = GEOSGeom_createLineString(pseq);
@@ -226,6 +228,9 @@
/* GEOSCoordSeq_destroy(pseq); */
+ if (type)
+ *type = ftype;
return geom;
@@ -243,6 +248,7 @@
GEOSCoordSequence *V2_read_line_geos(struct Map_info *Map, int line)
+ int ftype;
P_LINE *Line;
G_debug(3, "V2_read_line_geos(): line = %d", line);
@@ -253,7 +259,7 @@
G_fatal_error("V2_read_line_geos(): %s %d",
- return V1_read_line_geos(Map, Line->offset);
+ return V1_read_line_geos(Map, Line->offset, &ftype);
@@ -267,14 +273,15 @@
\return pointer to GEOSCoordSequence
\return empty GEOSCoordSequence for dead line or unsuppored feature type
-GEOSCoordSequence *V1_read_line_geos(struct Map_info *Map, long offset)
+GEOSCoordSequence *V1_read_line_geos(struct Map_info *Map, long offset, int *type)
- int i, n_points, type;
+ int i, n_points;
char rhead;
double *x, *y, *z;
@@ -296,13 +303,13 @@
return GEOSCoordSeq_create(0, (Map->head.with_z) ? 3 : 2);
rhead >>= 2;
- type = dig_type_from_store((int)rhead);
+ *type = dig_type_from_store((int) rhead);
/* read only points / lines / boundaries */
- if (!(type & (GV_POINT | GV_LINES)))
+ if (!(*type & (GV_POINT | GV_LINES)))
- if (type & GV_POINTS) {
+ if (*type & GV_POINTS) {
n_points = 1;
else {
