[GRASS-SVN] r37326 - grass-addons/vector/v.autokrige2
svn_grass at osgeo.org
Thu May 21 08:26:04 EDT 2009
Author: aghisla
Date: 2009-05-21 08:26:04 -0400 (Thu, 21 May 2009)
New Revision: 37326
grass-addons/vector/v.autokrige2/v.autokrige2.py
provided an empty window
Modified: grass-addons/vector/v.autokrige2/v.autokrige2.py
--- grass-addons/vector/v.autokrige2/v.autokrige2.py 2009-05-21 12:21:30 UTC (rev 37325)
+++ grass-addons/vector/v.autokrige2/v.autokrige2.py 2009-05-21 12:26:04 UTC (rev 37326)
@@ -18,10 +18,47 @@
#list of parameters
-#import directives
+#import directives. to be completed.
+import wx
+import sys
-#function(s)
-#@TODO
+#classes in alphabetical order
+class KrigingModule(wx.Frame):
+ Kriging module for GRASS GIS.
+ def __init__(self, parent, id=wx.ID_ANY, size=None,
+ style = wx.DEFAULT_FRAME_STYLE, title=None, log=None):
+ self.parent = parent
+ self.size = size
+ wx.Frame.__init__(self, parent, id, style=style, size=self.size)
+ # setting properties
+ self.SetTitle("Kriging Module")
#main
-#@TODO
\ No newline at end of file
+def main(argv=None):
+ if argv is None:
+ argv = sys.argv
+ """if len(argv) != 2:
+ print >> sys.stderr, __doc__
+ sys.exit()"""
+ # Command line arguments of the script to be run are preserved by the
+ # hotswap.py wrapper but hotswap.py and its options are removed that
+ # sys.argv looks as if no wrapper was present.
+ #print "argv:", `argv`
+ # commmented, as I don't know if the module will need it.
+ ##some applications might require image handlers
+ #wx.InitAllImageHandlers()
+ app = wx.PySimpleApp()
+ k = KrigingModule(parent=None, id=wx.ID_ANY, size=(300,300))
+ k.Show()
+ app.MainLoop()
+if __name__ == '__main__':
+ main()
