[GRASS-SVN] r37334 - grass/trunk/raster/r.out.ppm
    svn_grass at osgeo.org
    Thu May 21 11:39:12 EDT 2009
Author: hamish
Date: 2009-05-21 11:39:12 -0400 (Thu, 21 May 2009)
New Revision: 37334
   grass/trunk/raster/r.out.ppm/main.c
   grass/trunk/raster/r.out.ppm/r.out.ppm.html
lowercase flag
Modified: grass/trunk/raster/r.out.ppm/main.c
--- grass/trunk/raster/r.out.ppm/main.c	2009-05-21 15:03:14 UTC (rev 37333)
+++ grass/trunk/raster/r.out.ppm/main.c	2009-05-21 15:39:12 UTC (rev 37334)
@@ -62,7 +62,7 @@
     ppm_file->description = _("Name for new PPM file (use '-' for stdout)");
     gscale = G_define_flag();
-    gscale->key = 'G';
+    gscale->key = 'g';
     gscale->description = _("Output greyscale instead of color");
     if (G_parser(argc, argv))
Modified: grass/trunk/raster/r.out.ppm/r.out.ppm.html
--- grass/trunk/raster/r.out.ppm/r.out.ppm.html	2009-05-21 15:03:14 UTC (rev 37333)
+++ grass/trunk/raster/r.out.ppm/r.out.ppm.html	2009-05-21 15:39:12 UTC (rev 37334)
@@ -13,7 +13,7 @@
 before running <em>r.out.ppm</em>.<p>
 By default the PPM file created is 24-bit color, rawbits storage.
-You can use the <b>-G</b> flag to force <em>r.out.ppm</em> to
+You can use the <b>-g</b> flag to force <em>r.out.ppm</em> to
 output an 8-bit greyscale instead.
 The greyscale conversion uses the NTSC conversion:<p>
