[GRASS-SVN] r37347 - in grass/trunk/scripts: d.correlate d.polar
d.rast.edit d.rast.leg d.shadedmap db.dropcol db.droptable
db.in.ogr db.out.ogr db.test g.manual i.fusion.brovey
i.image.mosaic i.in.spotvgt i.landsat.rgb i.oif i.spectral
i.tasscap m.proj r.blend r.buffer r.fillnulls r.grow
r.in.aster r.in.srtm r.in.wms r.mask r.out.xyz r.plane
r.reclass.area r.regression.line r.rgb r.shaded.relief
r.tileset v.build.all v.centroids v.convert.all v.db.addcol
v.db.addtable v.db.dropcol v.db.droptable v.db.join
v.db.reconnect.all v.db.renamecol v.db.univar v.db.update
v.dissolve v.in.e00 v.in.geonames v.in.gns v.in.mapgen
v.in.sites.all v.in.wfs v.rast.stats v.report v.what.vect
svn_grass at osgeo.org
Thu May 21 18:04:15 EDT 2009
Author: martinl
Date: 2009-05-21 18:04:15 -0400 (Thu, 21 May 2009)
New Revision: 37347
grass/trunk/scripts/d.correlate/d.correlate.py
grass/trunk/scripts/d.polar/d.polar.py
grass/trunk/scripts/d.rast.edit/d.rast.edit.py
grass/trunk/scripts/d.rast.leg/d.rast.leg.py
grass/trunk/scripts/d.shadedmap/d.shadedmap.py
grass/trunk/scripts/db.dropcol/db.dropcol.py
grass/trunk/scripts/db.droptable/db.droptable.py
grass/trunk/scripts/db.in.ogr/db.in.ogr.py
grass/trunk/scripts/db.out.ogr/db.out.ogr.py
grass/trunk/scripts/db.test/db.test.py
grass/trunk/scripts/g.manual/g.manual.py
grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
grass/trunk/scripts/i.oif/i.oif.py
grass/trunk/scripts/i.spectral/i.spectral.py
grass/trunk/scripts/i.tasscap/i.tasscap.py
grass/trunk/scripts/m.proj/m.proj.py
grass/trunk/scripts/r.blend/r.blend.py
grass/trunk/scripts/r.buffer/r.buffer.py
grass/trunk/scripts/r.fillnulls/r.fillnulls.py
grass/trunk/scripts/r.grow/r.grow.py
grass/trunk/scripts/r.in.aster/r.in.aster.py
grass/trunk/scripts/r.in.srtm/r.in.srtm.py
grass/trunk/scripts/r.in.wms/gdalwarp.py
grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py
grass/trunk/scripts/r.in.wms/r.in.wms.py
grass/trunk/scripts/r.in.wms/wms_download.py
grass/trunk/scripts/r.in.wms/wms_request.py
grass/trunk/scripts/r.mask/r.mask.py
grass/trunk/scripts/r.out.xyz/r.out.xyz.py
grass/trunk/scripts/r.plane/r.plane.py
grass/trunk/scripts/r.reclass.area/r.reclass.area.py
grass/trunk/scripts/r.regression.line/r.regression.line.py
grass/trunk/scripts/r.rgb/r.rgb.py
grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
grass/trunk/scripts/r.tileset/r.tileset.py
grass/trunk/scripts/v.build.all/v.build.all.py
grass/trunk/scripts/v.centroids/v.centroids.py
grass/trunk/scripts/v.convert.all/v.convert.all.py
grass/trunk/scripts/v.db.addcol/v.db.addcol.py
grass/trunk/scripts/v.db.addtable/v.db.addtable.py
grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py
grass/trunk/scripts/v.db.droptable/v.db.droptable.py
grass/trunk/scripts/v.db.join/v.db.join.py
grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py
grass/trunk/scripts/v.db.univar/v.db.univar.py
grass/trunk/scripts/v.db.update/v.db.update.py
grass/trunk/scripts/v.dissolve/v.dissolve.py
grass/trunk/scripts/v.in.e00/v.in.e00.py
grass/trunk/scripts/v.in.geonames/v.in.geonames.py
grass/trunk/scripts/v.in.gns/v.in.gns.py
grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py
grass/trunk/scripts/v.in.wfs/v.in.wfs.py
grass/trunk/scripts/v.rast.stats/v.rast.stats.py
grass/trunk/scripts/v.report/v.report.py
grass/trunk/scripts/v.what.vect/v.what.vect.py
fix Python scripts, see r37345
Modified: grass/trunk/scripts/d.correlate/d.correlate.py
--- grass/trunk/scripts/d.correlate/d.correlate.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/d.correlate/d.correlate.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -31,7 +31,7 @@
import sys
import os
-import grass
+from grass.script import core as grass
def main():
layers = options['layers'].split(',')
Modified: grass/trunk/scripts/d.polar/d.polar.py
--- grass/trunk/scripts/d.polar/d.polar.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/d.polar/d.polar.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -56,7 +56,7 @@
import atexit
import glob
import shutil
-import grass
def cleanup():
grass.try_remove(tmp)
Modified: grass/trunk/scripts/d.rast.edit/d.rast.edit.py
--- grass/trunk/scripts/d.rast.edit/d.rast.edit.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/d.rast.edit/d.rast.edit.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -93,7 +93,7 @@
import sys
import math
import atexit
-import grass
+from grass.script import core, raster as grass
try:
import wxversion
Modified: grass/trunk/scripts/d.rast.leg/d.rast.leg.py
--- grass/trunk/scripts/d.rast.leg/d.rast.leg.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/d.rast.leg/d.rast.leg.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -71,7 +71,7 @@
import sys
import os
-import grass
def make_frame(f, b, t, l, r):
(ft, fb, fl, fr) = f
Modified: grass/trunk/scripts/d.shadedmap/d.shadedmap.py
--- grass/trunk/scripts/d.shadedmap/d.shadedmap.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/d.shadedmap/d.shadedmap.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -40,7 +40,7 @@
#%end
import sys
-import grass
def main():
drape_map = options['drapemap']
Modified: grass/trunk/scripts/db.dropcol/db.dropcol.py
--- grass/trunk/scripts/db.dropcol/db.dropcol.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/db.dropcol/db.dropcol.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -47,7 +47,7 @@
import sys
import os
import string
-import grass
+from grass.script import core, db as grass
def main():
table = options['table']
Modified: grass/trunk/scripts/db.droptable/db.droptable.py
--- grass/trunk/scripts/db.droptable/db.droptable.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/db.droptable/db.droptable.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -36,7 +36,7 @@
import sys
import os
-import grass
+from grass.script import core, db, vector as grass
def main():
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -52,7 +52,7 @@
import sys
import os
-import grass
def main():
dsn = options['dsn']
Modified: grass/trunk/scripts/db.out.ogr/db.out.ogr.py
--- grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -55,7 +55,7 @@
import sys
import os
-import grass
def main():
input = options['input']
Modified: grass/trunk/scripts/db.test/db.test.py
--- grass/trunk/scripts/db.test/db.test.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/db.test/db.test.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -27,7 +27,7 @@
import sys
import os
-import grass
def main():
test_file = options['test']
Modified: grass/trunk/scripts/g.manual/g.manual.py
--- grass/trunk/scripts/g.manual/g.manual.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/g.manual/g.manual.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -35,7 +35,7 @@
import sys
import os
-import grass
def start_browser(entry):
path = os.path.join(gisbase, 'docs', 'html', entry + '.html')
Modified: grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
--- grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -84,7 +84,7 @@
import sys
import os
-import grass
def main():
global tmp
Modified: grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
--- grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -44,7 +44,7 @@
import sys
import os
-import grass
def copy_colors(fh, map, offset):
p = grass.pipe_command('r.colors.out', map = map)
Modified: grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
--- grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -55,7 +55,7 @@
import sys
import os
import atexit
-import grass
vrt = """<VRTDataset rasterXSize="$XSIZE" rasterYSize="$YSIZE">
<SRS>GEOGCS["wgs84",DATUM["WGS_1984",SPHEROID["wgs84",6378137,298.257223563],TOWGS84[0.000,0.000,0.000]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]]</SRS>
Modified: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
--- grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -69,7 +69,7 @@
import sys
import os
import string
-import grass
def get_percentile(map, percentile):
s = grass.read_command('r.univar', flags = 'ge', map = map, percentile = percentile)
Modified: grass/trunk/scripts/i.oif/i.oif.py
--- grass/trunk/scripts/i.oif/i.oif.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/i.oif/i.oif.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -76,7 +76,7 @@
import sys
import os
-import grass
bands = [1,2,3,4,5,7]
Modified: grass/trunk/scripts/i.spectral/i.spectral.py
--- grass/trunk/scripts/i.spectral/i.spectral.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/i.spectral/i.spectral.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -69,7 +69,7 @@
import os
import atexit
import glob
-import grass
def cleanup():
grass.try_remove('spectrum.gnuplot')
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.py
--- grass/trunk/scripts/i.tasscap/i.tasscap.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -100,7 +100,7 @@
import sys
import os
-import grass
parms = [[( 0.3037, 0.2793, 0.4743, 0.5585, 0.5082, 0.1863),
(-0.2848,-0.2435,-0.5435, 0.7243, 0.0840,-0.1800),
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/m.proj/m.proj.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -89,7 +89,7 @@
import sys
import os
-import grass
def main():
Modified: grass/trunk/scripts/r.blend/r.blend.py
--- grass/trunk/scripts/r.blend/r.blend.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.blend/r.blend.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -53,7 +53,7 @@
import sys
import os
import string
-import grass
def main():
first = options['first']
Modified: grass/trunk/scripts/r.buffer/r.buffer.py
--- grass/trunk/scripts/r.buffer/r.buffer.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.buffer/r.buffer.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -61,7 +61,7 @@
import os
import atexit
import math
-import grass
scales = {
'meters': 1.0,
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -56,7 +56,7 @@
import sys
import os
import atexit
-import grass
# what to do in case of user break:
def cleanup():
Modified: grass/trunk/scripts/r.grow/r.grow.py
--- grass/trunk/scripts/r.grow/r.grow.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.grow/r.grow.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -76,7 +76,7 @@
import os
import atexit
import math
-import grass
def cleanup():
Modified: grass/trunk/scripts/r.in.aster/r.in.aster.py
--- grass/trunk/scripts/r.in.aster/r.in.aster.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -61,7 +61,7 @@
import sys
import os
import platform
-import grass
bands = {
'L1A': {
Modified: grass/trunk/scripts/r.in.srtm/r.in.srtm.py
--- grass/trunk/scripts/r.in.srtm/r.in.srtm.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.in.srtm/r.in.srtm.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -112,7 +112,7 @@
import os
import shutil
import atexit
-import grass
def cleanup():
if not in_temp:
Modified: grass/trunk/scripts/r.in.wms/gdalwarp.py
--- grass/trunk/scripts/r.in.wms/gdalwarp.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.in.wms/gdalwarp.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -23,7 +23,7 @@
import os
import subprocess
-import grass
class GDALWarp:
def __init__(self, flags, options):
Modified: grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py
--- grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -77,7 +77,7 @@
import sys
import atexit
-import grass
path = os.path.join(os.getenv('GISBASE'), 'etc', 'r.in.wms')
sys.path.append(path)
Modified: grass/trunk/scripts/r.in.wms/r.in.wms.py
--- grass/trunk/scripts/r.in.wms/r.in.wms.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.in.wms/r.in.wms.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -177,7 +177,7 @@
import urllib
import xml.sax
-import grass
wmsPath = os.path.join(os.getenv('GISBASE'), 'etc', 'r.in.wms')
sys.path.append(wmsPath)
Modified: grass/trunk/scripts/r.in.wms/wms_download.py
--- grass/trunk/scripts/r.in.wms/wms_download.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.in.wms/wms_download.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -19,7 +19,7 @@
import os
import urllib
-import grass
class WMSDownload:
Modified: grass/trunk/scripts/r.in.wms/wms_request.py
--- grass/trunk/scripts/r.in.wms/wms_request.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.in.wms/wms_request.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -18,7 +18,7 @@
import os
import glob
-import grass
class WMSRequest:
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.mask/r.mask.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -43,7 +43,7 @@
import sys
import os
-import grass
import atexit
def cleanup():
Modified: grass/trunk/scripts/r.out.xyz/r.out.xyz.py
--- grass/trunk/scripts/r.out.xyz/r.out.xyz.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.out.xyz/r.out.xyz.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -46,7 +46,7 @@
#%end
import sys
-import grass
def main():
# if no output filename, output to stdout
Modified: grass/trunk/scripts/r.plane/r.plane.py
--- grass/trunk/scripts/r.plane/r.plane.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.plane/r.plane.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -73,7 +73,7 @@
import os
import math
import string
-import grass
def main():
name = options['name']
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area.py
--- grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -54,7 +54,7 @@
import sys
import os
-import grass
def main():
infile = options['input']
Modified: grass/trunk/scripts/r.regression.line/r.regression.line.py
--- grass/trunk/scripts/r.regression.line/r.regression.line.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.regression.line/r.regression.line.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -53,7 +53,7 @@
import sys
import os
import math
-import grass
def main():
shell = flags['g']
Modified: grass/trunk/scripts/r.rgb/r.rgb.py
--- grass/trunk/scripts/r.rgb/r.rgb.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.rgb/r.rgb.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -34,7 +34,7 @@
import sys
import os
import string
-import grass
def main():
Modified: grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
--- grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -108,7 +108,7 @@
import sys
import os
import string
-import grass
def main():
Modified: grass/trunk/scripts/r.tileset/r.tileset.py
--- grass/trunk/scripts/r.tileset/r.tileset.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/r.tileset/r.tileset.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -120,7 +120,7 @@
import tempfile
import math
-import grass
def bboxToPoints(bbox):
"""Make points that are the corners of a bounding box"""
Modified: grass/trunk/scripts/v.build.all/v.build.all.py
--- grass/trunk/scripts/v.build.all/v.build.all.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.build.all/v.build.all.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -18,7 +18,7 @@
#%End
import sys
-import grass
def main():
env = grass.gisenv()
Modified: grass/trunk/scripts/v.centroids/v.centroids.py
--- grass/trunk/scripts/v.centroids/v.centroids.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.centroids/v.centroids.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -71,7 +71,7 @@
import sys
import os
import re
-import grass
+from grass.script import core, vector as grass
def main():
if options['option'] == 'add':
Modified: grass/trunk/scripts/v.convert.all/v.convert.all.py
--- grass/trunk/scripts/v.convert.all/v.convert.all.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.convert.all/v.convert.all.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -20,7 +20,7 @@
#%end
import sys
-import grass
def main():
Modified: grass/trunk/scripts/v.db.addcol/v.db.addcol.py
--- grass/trunk/scripts/v.db.addcol/v.db.addcol.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.db.addcol/v.db.addcol.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -47,7 +47,7 @@
import sys
import os
-import grass
def main():
map = options['map']
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -51,7 +51,7 @@
import sys
import os
-import grass
def main():
Modified: grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py
--- grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -50,7 +50,7 @@
import sys
import os
import string
-import grass
def main():
Modified: grass/trunk/scripts/v.db.droptable/v.db.droptable.py
--- grass/trunk/scripts/v.db.droptable/v.db.droptable.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.db.droptable/v.db.droptable.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -46,7 +46,7 @@
import sys
import os
-import grass
def main():
force = flags['f']
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.db.join/v.db.join.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -64,7 +64,7 @@
import sys
import os
import string
-import grass
def main():
Modified: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
--- grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -44,7 +44,7 @@
import sys
import os
-import grass
def main():
old_database = options['old_database']
Modified: grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py
--- grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -50,7 +50,7 @@
import sys
import os
-import grass
def main():
Modified: grass/trunk/scripts/v.db.univar/v.db.univar.py
--- grass/trunk/scripts/v.db.univar/v.db.univar.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.db.univar/v.db.univar.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -59,7 +59,7 @@
import os
import atexit
import math
-import grass
def cleanup():
for ext in ['', '.sort']:
Modified: grass/trunk/scripts/v.db.update/v.db.update.py
--- grass/trunk/scripts/v.db.update/v.db.update.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.db.update/v.db.update.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -63,7 +63,7 @@
import sys
import os
-import grass
def main():
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -54,7 +54,7 @@
import sys
import os
-import grass
import atexit
def cleanup():
Modified: grass/trunk/scripts/v.in.e00/v.in.e00.py
--- grass/trunk/scripts/v.in.e00/v.in.e00.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.in.e00/v.in.e00.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -55,7 +55,7 @@
import os
import shutil
import glob
-import grass
def main():
filename = options['file']
Modified: grass/trunk/scripts/v.in.geonames/v.in.geonames.py
--- grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -45,7 +45,7 @@
import sys
import os
-import grass
def main():
Modified: grass/trunk/scripts/v.in.gns/v.in.gns.py
--- grass/trunk/scripts/v.in.gns/v.in.gns.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.in.gns/v.in.gns.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -45,7 +45,7 @@
import sys
import os
-import grass
def main():
fileorig = options['file']
Modified: grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
--- grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -58,7 +58,7 @@
import string
import time
import shutil
-import grass
def cleanup():
Modified: grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py
--- grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -19,7 +19,7 @@
#%End
import sys
-import grass
def main():
Modified: grass/trunk/scripts/v.in.wfs/v.in.wfs.py
--- grass/trunk/scripts/v.in.wfs/v.in.wfs.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.in.wfs/v.in.wfs.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -34,7 +34,7 @@
#%End
import os
-import grass
import urllib
def main():
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -68,7 +68,7 @@
import sys
import os
import atexit
-import grass
+from grass.script import core, raster, vector as grass
def has_column(vector, col):
return
Modified: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.report/v.report.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -56,7 +56,7 @@
import sys
import os
-import grass
def uniq(l):
result = []
Modified: grass/trunk/scripts/v.what.vect/v.what.vect.py
--- grass/trunk/scripts/v.what.vect/v.what.vect.py 2009-05-21 21:20:54 UTC (rev 37346)
+++ grass/trunk/scripts/v.what.vect/v.what.vect.py 2009-05-21 22:04:15 UTC (rev 37347)
@@ -69,7 +69,7 @@
#%end
import sys
-import grass
def main():
grass.exec_command(
