[GRASS-SVN] r37377 - grass/branches/develbranch_6/swig/python
svn_grass at osgeo.org
Fri May 22 12:46:39 EDT 2009
Author: neteler
Date: 2009-05-22 12:46:39 -0400 (Fri, 22 May 2009)
New Revision: 37377
grass/branches/develbranch_6/swig/python/README
updated
Modified: grass/branches/develbranch_6/swig/python/README
--- grass/branches/develbranch_6/swig/python/README 2009-05-22 16:46:16 UTC (rev 37376)
+++ grass/branches/develbranch_6/swig/python/README 2009-05-22 16:46:39 UTC (rev 37377)
@@ -1,9 +1,7 @@
What is this?
This is SWIG based python wrapping for GRASS API
-which allows to call GRASS functions from python programs.
-Currently only a limited set of functions (those needed for
-me) are wrapped.
+which allows to call GRASS library functions from Python programs.
How to INSTALL?
@@ -11,7 +9,7 @@
1. Install SWIG, the Simplified Wrapper and Interface Generator
http://www.swig.org
-2. Be sure you configured GRASS with support for Python:
+2. Be sure you configured GRASS with support for Python (example):
./configure --with-python=/usr/bin/python2.5-config
3. Run make in the swig/python/ directory
@@ -41,7 +39,7 @@
See examples/m.distance for an example of a working SWIG-Python module.
More examples can be found on the GRASS Wiki site's Python page:
- http://grass.gdf-hannover.de/wiki/GRASS_and_Python#Python-SWIG-GRASS_interface
+ http://grass.osgeo.org/wiki/GRASS_and_Python#Python-SWIG-GRASS_interface
DEBUGGING
@@ -58,10 +56,16 @@
See TODO in this directory.
-AUTHOR
+AUTHORS
-Sajith VK sajithvk at gmail.com
-Thu, 9 Mar 2006 16:02:50 +0530
-http://grass.itc.it/pipermail/grass-dev/2006-March/021651.html
-http://freegis.gnu.org.in/temporary/python_grass6.tar.bz2
+Initial version:
+ Sajith VK sajithvk at gmail.com
+ Thu, 9 Mar 2006 16:02:50 +0530
+ http://lists.osgeo.org/pipermail/grass-dev/2006-March/021800.html
+ http://freegis.gnu.org.in/temporary/python_grass6.tar.bz2
+Further work:
+ Markus Landa
+ Glynn Clements
