[GRASS-SVN] r37388 - grass/branches/develbranch_6/raster/wildfire/r.ros
Sat May 23 04:12:34 EDT 2009
Author: neteler
Date: 2009-05-23 04:12:31 -0400 (Sat, 23 May 2009)
New Revision: 37388
   grass/branches/develbranch_6/raster/wildfire/r.ros/description.html
Add missing <DD> tag
Modified: grass/branches/develbranch_6/raster/wildfire/r.ros/description.html
--- grass/branches/develbranch_6/raster/wildfire/r.ros/description.html	2009-05-23 02:02:40 UTC (rev 37387)
+++ grass/branches/develbranch_6/raster/wildfire/r.ros/description.html	2009-05-23 08:12:31 UTC (rev 37388)
@@ -66,8 +66,8 @@
 <DD>Name of an existing raster map
 layer in the user's current mapset search path containing elevation (meters).
-<DT><B>output=</B>name Prefix of new
-raster map layers in the user's current mapset to contain
+<DT><B>output=</B>name
+<DD>Prefix of new raster map layers in the user's current mapset to contain
 <BR> 1) the base (perpendicular) ROS
 (cm/minute);
 <BR> 2) the maximum (forward) ROS (cm/minute),
