[GRASS-SVN] r37392 -
grass/branches/releasebranch_6_4/raster/r.series
svn_grass at osgeo.org
Sat May 23 04:21:12 EDT 2009
Author: neteler
Date: 2009-05-23 04:21:10 -0400 (Sat, 23 May 2009)
New Revision: 37392
grass/branches/releasebranch_6_4/raster/r.series/description.html
hint for handling irregular time intervals for regression; example fixes
Modified: grass/branches/releasebranch_6_4/raster/r.series/description.html
--- grass/branches/releasebranch_6_4/raster/r.series/description.html 2009-05-23 08:20:59 UTC (rev 37391)
+++ grass/branches/releasebranch_6_4/raster/r.series/description.html 2009-05-23 08:21:10 UTC (rev 37392)
@@ -46,22 +46,33 @@
The <em>range</em> parameter can be set to <em>low,high</em> thresholds:
values outside of this range are treated as NULL (i.e., they will be
ignored by most aggregates, or will cause the result to be NULL if -n is given).
-The <em>low,high</em> thresholds are floating point, so use <em>-inf</em> or
+The <em>low,high</em> thresholds are floating point, so use <em>-inf</em> or
<em>inf</em> for a single threshold (e.g., <em>range=0,inf</em> to ignore
negative values, or <em>range=-inf,-200.4</em> to ignore values above -200.4).
+<p>
+Linear regression (slope, offset, coefficient of determination) assumes equal time intervals.
+If the data have irregular time intervals, NULL raster maps can be inserted into time series
+to make time intervals equal (see example).
<h2>EXAMPLES</h2>
Using <em>r.series</em> with wildcards:
<br>
<div class="code"><pre>
-r.series input="`g.mlist pattern='insitu_data.*' sep=,`"
- output=insitu_data.stddev method=stddev
+r.series input="`g.mlist pattern='insitu_data.*' sep=,`" \
+ output=insitu_data.stddev method=stddev
</pre></div>
<p>
-Note the <em>g.mlist</em> script also supports regular expressions for
+Note the <em>g.mlist</em> script also supports regular expressions for
selecting map names.
+<p>
+Using <em>r.series</em> with NULL raster maps:
+<br>
+<div class="code"><pre>
+r.mapcalc "dummy = null()"
+r.series in=map2001,map2002,dummy,dummy,map2005,map2006,dummy,map2008 \
+ out=res_slope,res_offset,res_coeff meth=slope,offset,detcoeff
+</pre></div>
<p>
Example for multiple aggregates to be computed in one run (3 resulting aggregates from two input maps):
