[GRASS-SVN] r37398 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Sat May 23 12:07:57 EDT 2009
Author: martinl
Date: 2009-05-23 12:07:57 -0400 (Sat, 23 May 2009)
New Revision: 37398
grass/trunk/gui/wxpython/gui_modules/prompt.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: autocompete prompt stage 1 (static list of commands)
Modified: grass/trunk/gui/wxpython/gui_modules/prompt.py
--- grass/trunk/gui/wxpython/gui_modules/prompt.py 2009-05-23 11:47:27 UTC (rev 37397)
+++ grass/trunk/gui/wxpython/gui_modules/prompt.py 2009-05-23 16:07:57 UTC (rev 37398)
@@ -5,6 +5,8 @@
Classes:
- GPrompt
+ - PromptListCtrl
+ - TextCtrlAutoComplete
(C) 2008-2009 by the GRASS Development Team
This program is free software under the GNU General Public
@@ -14,10 +16,15 @@
@author Martin Landa <landa.martin gmail.com>
+import sys
import shlex
import wx
+import wx.lib.mixins.listctrl as listmix
+import globalvar
+import utils
class GPrompt:
"""Interactive GRASS prompt"""
def __init__(self, parent):
@@ -33,10 +40,10 @@
label = _("Cmd >"), size = (-1, 25))
label.SetToolTipString(_("Click for erasing command prompt"))
- cmdinput = wx.TextCtrl(parent = cmdprompt, id = wx.ID_ANY,
- value = "",
- style = wx.TE_LINEWRAP | wx.TE_PROCESS_ENTER,
- size = (-1, 25))
+ cmdinput = TextCtrlAutoComplete(parent = cmdprompt, id = wx.ID_ANY,
+ value = "",
+ style = wx.TE_LINEWRAP | wx.TE_PROCESS_ENTER,
+ size = (-1, 25))
cmdinput.SetFont(wx.Font(10, wx.FONTFAMILY_MODERN, wx.NORMAL, wx.NORMAL, 0, ''))
@@ -97,3 +104,277 @@
self.parent.statusbar.SetStatusText("")
else:
self.parent.statusbar.SetStatusText(_("Type GRASS command and run by pressing ENTER"))
+ event.Skip()
+class PromptListCtrl(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin):
+ def __init__(self, parent, id = wx.ID_ANY, pos = wx.DefaultPosition,
+ size = wx.DefaultSize, style = 0):
+ wx.ListCtrl.__init__(self, parent, id, pos, size, style)
+ listmix.ListCtrlAutoWidthMixin.__init__(self)
+class TextCtrlAutoComplete(wx.TextCtrl, listmix.ColumnSorterMixin):
+ def __init__ (self, parent, id = wx.ID_ANY, choices = [], **kwargs):
+ Constructor works just like wx.TextCtrl except you can pass in a
+ list of choices. You can also change the choice list at any time
+ by calling setChoices.
+ Inspired by http://wiki.wxpython.org/TextCtrlAutoComplete
+ if kwargs.has_key('style'):
+ kwargs['style'] = wx.TE_PROCESS_ENTER | kwargs['style']
+ else:
+ wx.TextCtrl.__init__(self, parent, id, **kwargs)
+ # some variables
+ self._choices = choices
+ self._hideOnNoMatch = True
+ self._screenheight = wx.SystemSettings.GetMetric(wx.SYS_SCREEN_Y)
+ # sort variable needed by listmix
+ self.itemDataMap = dict()
+ # widgets
+ self.dropdown = wx.PopupWindow(self)
+ # create the list and bind the events
+ self.dropdownlistbox = PromptListCtrl(parent = self.dropdown,
+ style = wx.LC_REPORT | wx.LC_SINGLE_SEL | \
+ wx.LC_SORT_ASCENDING | wx.LC_NO_HEADER,
+ pos = wx.Point(0, 0))
+ listmix.ColumnSorterMixin.__init__(self, 1)
+ # set choices (list of GRASS modules)
+ self.SetChoices(globalvar.grassCmd['all'])
+ # bindings...
+ self.Bind(wx.EVT_KILL_FOCUS, self.OnControlChanged, self)
+ self.Bind(wx.EVT_TEXT, self.OnEnteredText, self)
+ self.Bind(wx.EVT_KEY_DOWN , self.OnKeyDown, self)
+ # if need drop down on left click
+ ### self.Bind ( wx.EVT_LEFT_DOWN , self.onClickToggleDown, self )
+ ### self.Bind ( wx.EVT_LEFT_UP , self.onClickToggleUp, self )
+ self.dropdown.Bind(wx.EVT_LISTBOX , self.OnListItemSelected, self.dropdownlistbox)
+ self.dropdownlistbox.Bind(wx.EVT_LEFT_DOWN, self.OnListClick)
+ self.dropdownlistbox.Bind(wx.EVT_LEFT_DCLICK, self.OnListDClick)
+ self.dropdownlistbox.Bind(wx.EVT_LIST_COL_CLICK, self.OnListColClick)
+ def _updateDataList(self, choices):
+ """Update data list"""
+ # delete, if need, all the previous data
+ if self.dropdownlistbox.GetColumnCount() != 0:
+ self.dropdownlistbox.DeleteAllColumns()
+ self.dropdownlistbox.DeleteAllItems()
+ # and update the dict
+ if choices:
+ for numVal, data in enumerate(choices):
+ self.itemDataMap[numVal] = data
+ else:
+ numVal = 0
+ self.SetColumnCount(numVal)
+ def _setListSize(self):
+ """Set list size"""
+ choices = self._choices
+ longest = 0
+ for choice in choices:
+ longest = max(len(choice), longest)
+ longest += 3
+ itemcount = min(len( choices ), 7) + 2
+ charheight = self.dropdownlistbox.GetCharHeight()
+ charwidth = self.dropdownlistbox.GetCharWidth()
+ self.popupsize = wx.Size(charwidth*longest, charheight*itemcount)
+ self.dropdownlistbox.SetSize(self.popupsize)
+ self.dropdown.SetClientSize(self.popupsize)
+ def _showDropDown(self, show = True):
+ Eit`her display the drop down list (show = True) or hide it
+ (show = False).
+ if show:
+ size = self.dropdown.GetSize()
+ width, height = self.GetSizeTuple()
+ x, y = self.ClientToScreenXY(0, height)
+ if size.GetWidth() != width:
+ size.SetWidth(width)
+ self.dropdown.SetSize(size)
+ self.dropdownlistbox.SetSize(self.dropdown.GetClientSize())
+ if (y + size.GetHeight()) < self._screenheight:
+ self.dropdown.SetPosition(wx.Point(x, y))
+ else:
+ self.dropdown.SetPosition(wx.Point(x, y - height - size.GetHeight()))
+ self.dropdown.Show(show)
+ def _listItemVisible(self):
+ Moves the selected item to the top of the list ensuring it is
+ always visible.
+ toSel = self.dropdownlistbox.GetFirstSelected()
+ if toSel == -1:
+ return
+ self.dropdownlistbox.EnsureVisible(toSel)
+ def _setValueFromSelected(self):
+ Sets the wx.TextCtrl value from the selected wx.ListCtrl item.
+ Will do nothing if no item is selected in the wx.ListCtrl.
+ sel = self.dropdownlistbox.GetFirstSelected()
+ if sel > -1:
+ if self._colFetch != -1:
+ col = self._colFetch
+ else:
+ col = self._colSearch
+ itemtext = self.dropdownlistbox.GetItem(sel, col).GetText()
+ ### if self._selectCallback:
+ ### dd = self.dropdownlistbox
+ ### values = [dd.GetItem(sel, x).GetText()
+ ### for x in xrange(dd.GetColumnCount())]
+ ### self._selectCallback(values)
+ self.SetValue(itemtext)
+ self.SetInsertionPointEnd()
+ self._showDropDown(False)
+ def GetListCtrl(self):
+ """Method required by listmix.ColumnSorterMixin"""
+ return self.dropdownlistbox
+ def SetChoices(self, choices):
+ Sets the choices available in the popup wx.ListBox.
+ The items will be sorted case insensitively.
+ self.dropdownlistbox.SetWindowStyleFlag(wx.LC_REPORT | wx.LC_SINGLE_SEL | \
+ wx.LC_SORT_ASCENDING | wx.LC_NO_HEADER)
+ if not isinstance(choices, list):
+ self._choices = [ x for x in choices ]
+ utils.ListSortLower(self._choices)
+ self._updateDataList(self._choices)
+ self.dropdownlistbox.InsertColumn(0, "")
+ for num, colVal in enumerate(self._choices):
+ index = self.dropdownlistbox.InsertImageStringItem(sys.maxint, colVal, -1)
+ self.dropdownlistbox.SetStringItem(index, 0, colVal)
+ self.dropdownlistbox.SetItemData(index, num)
+ self._setListSize()
+ # there is only one choice for both search and fetch if setting a single column:
+ self._colSearch = 0
+ self._colFetch = -1
+ def OnListClick(self, evt):
+ """Left mouse button pressed"""
+ toSel, flag = self.dropdownlistbox.HitTest( evt.GetPosition() )
+ #no values on poition, return
+ if toSel == -1: return
+ self.dropdownlistbox.Select(toSel)
+ def OnListDClick(self, evt):
+ """Mouse button double click"""
+ self._setValueFromSelected()
+ def OnListColClick(self, evt):
+ """Left mouse button pressed on column"""
+ col = evt.GetColumn()
+ # reverse the sort
+ if col == self._colSearch:
+ self._ascending = not self._ascending
+ self.SortListItems( evt.GetColumn(), ascending=self._ascending )
+ self._colSearch = evt.GetColumn()
+ evt.Skip()
+ def OnListItemSelected(self, event):
+ """Item selected"""
+ event.Skip()
+ def OnEnteredText(self, event):
+ """Text entered"""
+ text = event.GetString()
+ ### if self._entryCallback:
+ ### self._entryCallback()
+ if not text:
+ # control is empty; hide dropdown if shown:
+ if self.dropdown.IsShown():
+ event.Skip()
+ return
+ found = False
+ for numCh, choice in enumerate(choices):
+ ### if self._matchFunction and self._matchFunction(text, choice):
+ ### found = True
+ ### elif
+ if choice.lower().startswith(text.lower()):
+ found = True
+ if found:
+ self._showDropDown(True)
+ item = self.dropdownlistbox.GetItem(numCh)
+ toSel = item.GetId()
+ break
+ if not found:
+ self.dropdownlistbox.Select(self.dropdownlistbox.GetFirstSelected(), False)
+ if self._hideOnNoMatch:
+ self._listItemVisible()
+ event.Skip()
+ def OnKeyDown (self, event):
+ Do some work when the user press on the keys: up and down:
+ move the cursor left and right: move the search
+ skip = True
+ visible = self.dropdown.IsShown()
+ KC = event.GetKeyCode()
+ if KC == wx.WXK_DOWN:
+ if sel < (self.dropdownlistbox.GetItemCount() - 1):
+ self.dropdownlistbox.Select(sel + 1)
+ self._showDropDown()
+ skip = False
+ elif KC == wx.WXK_UP:
+ if sel > 0:
+ self.dropdownlistbox.Select(sel - 1)
+ self._showDropDown ()
+ skip = False
+ elif KC == wx.WXK_LEFT:
+ return
+ elif KC == wx.WXK_RIGHT:
+ return
+ if visible:
+ if event.GetKeyCode() == wx.WXK_RETURN:
+ skip = False
+ if event.GetKeyCode() == wx.WXK_ESCAPE:
+ skip = False
+ if skip :
+ event.Skip()
+ def OnControlChanged(self, event):
+ """Control changed"""
+ if self.IsShown():
+ event.Skip()
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2009-05-23 11:47:27 UTC (rev 37397)
+++ grass/trunk/gui/wxpython/wxgui.py 2009-05-23 16:07:57 UTC (rev 37398)
@@ -490,7 +490,7 @@
550, wx.ClientDC(self)))
copyrightFile.close()
# website
- info.SetWebSite(("http://grass.osgeo.org", "The official GRASS site"))
+ info.SetWebSite(("http://grass.osgeo.org", _("The official GRASS site")))
# licence
licenceFile = open(os.path.join(os.getenv("GISBASE"), "GPL.TXT"), 'r')
info.SetLicence(''.join(licenceFile.readlines()))
