[GRASS-SVN] r37406 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat May 23 14:14:39 EDT 2009
Author: martinl
Date: 2009-05-23 14:14:38 -0400 (Sat, 23 May 2009)
New Revision: 37406
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
wxGUI: autocomplete prompt stage 2 (complete flags/params)
(merge from trunk, r37405)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2009-05-23 18:11:00 UTC (rev 37405)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2009-05-23 18:14:38 UTC (rev 37406)
@@ -335,6 +335,22 @@
if grassModule is not None:
xml.sax.parseString( getInterfaceDescription( grassModule ) , processTask( self ) )
+ def get_list_params(self, element = 'name'):
+ """Get list of parameters"""
+ params = []
+ for p in self.params:
+ params.append(p['name'])
+ return params
+ def get_list_flags(self, element = 'name'):
+ flags = []
+ for p in self.flags:
+ flags.append(p['name'])
+ return flags
def get_param(self, value, element='name', raiseError=True):
"""Find and return a param by name."""
@@ -353,7 +369,7 @@
param = self.get_param(aParam)
param['value'] = aValue
- def get_flag( self, aFlag ):
+ def get_flag(self, aFlag):
Find and return a flag by name.
@@ -368,8 +384,7 @@
param = self.get_flag(aFlag)
def getCmd(self, ignoreErrors = False):
Produce an array of command name and arguments for feeding
@@ -1782,6 +1797,23 @@
self.parent = parent
self.grass_task = None
+ def ParseInterface(self, cmd):
+ """Parse interface
+ @param cmd command to be parsed (given as list)
+ grass_task = grassTask()
+ handler = processTask(grass_task)
+ enc = locale.getdefaultlocale()[1]
+ if enc and enc.lower() not in ("utf8", "utf-8"):
+ xml.sax.parseString(getInterfaceDescription(cmd[0]).decode(enc).encode("utf-8"),
+ handler)
+ else:
+ xml.sax.parseString(getInterfaceDescription(cmd[0]),
+ handler)
+ return grass_task
def ParseCommand(self, cmd, gmpath=None, completed=None, parentframe=None,
show=True, modal=False):
@@ -1808,16 +1840,8 @@
self.parent = parentframe
# parse the interface decription
- self.grass_task = grassTask()
- handler = processTask(self.grass_task)
- enc = locale.getdefaultlocale()[1]
- if enc and enc.lower() not in ("utf8", "utf-8"):
- xml.sax.parseString(getInterfaceDescription(cmd[0]).decode(enc).encode("utf-8"),
- handler)
- else:
- xml.sax.parseString(getInterfaceDescription(cmd[0]),
- handler)
+ self.grass_task = self.ParseInterface(cmd)
# if layer parameters previously set, re-insert them into dialog
if completed is not None:
if 'params' in dcmd_params:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2009-05-23 18:11:00 UTC (rev 37405)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2009-05-23 18:14:38 UTC (rev 37406)
@@ -24,6 +24,7 @@
import globalvar
import utils
+import menuform
class GPrompt:
"""Interactive GRASS prompt"""
@@ -131,6 +132,8 @@
# some variables
self._choices = choices
self._hideOnNoMatch = True
+ self._module = None # currently selected module
+ self._params = None # params or flags ?
self._screenheight = wx.SystemSettings.GetMetric(wx.SYS_SCREEN_Y)
# sort variable needed by listmix
@@ -148,7 +151,8 @@
listmix.ColumnSorterMixin.__init__(self, 1)
# set choices (list of GRASS modules)
- self.SetChoices(globalvar.grassCmd['all'])
+ self._choicesCmd = globalvar.grassCmd['all']
+ self.SetChoices(self._choicesCmd)
# bindings...
self.Bind(wx.EVT_KILL_FOCUS, self.OnControlChanged, self)
@@ -238,7 +242,21 @@
### values = [dd.GetItem(sel, x).GetText()
### for x in xrange(dd.GetColumnCount())]
### self._selectCallback(values)
- self.SetValue(itemtext)
+ cmd = shlex.split(str(self.GetValue()))
+ if len(cmd) > 1:
+ # -> append text (skip last item)
+ if self._params is True:
+ self.SetValue(' '.join(cmd[:-1]) + ' ' + itemtext + '=')
+ else:
+ if len(itemtext) > 1:
+ prefix = '--'
+ else:
+ prefix = '-'
+ self.SetValue(' '.join(cmd[:-1]) + ' ' + prefix + itemtext)
+ else:
+ # -> reset text
+ self.SetValue(itemtext)
self.SetInsertionPointEnd()
self._showDropDown(False)
@@ -312,13 +330,35 @@
event.Skip()
return
+ cmd = shlex.split(str(text))
+ if len(cmd) > 1:
+ # search for module's options
+ if not self._module:
+ self._module = menuform.GUI().ParseInterface(cmd = cmd)
+ if cmd[-1][0] == '-':
+ # -> flags
+ self.SetChoices(self._module.get_list_flags())
+ self._params = False
+ else:
+ # -> options
+ self.SetChoices(self._module.get_list_params())
+ self._params = True
+ else:
+ # search for GRASS modules
+ if self._module:
+ # -> switch back to GRASS modules list
found = False
choices = self._choices
for numCh, choice in enumerate(choices):
### if self._matchFunction and self._matchFunction(text, choice):
### found = True
### elif
- if choice.lower().startswith(text.lower()):
+ if choice.lower().startswith(cmd[-1].lower().lstrip('-')):
found = True
if found:
self._showDropDown(True)
