[GRASS-SVN] r37419 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Sun May 24 09:45:30 EDT 2009
Author: martinl
Date: 2009-05-24 09:45:30 -0400 (Sun, 24 May 2009)
New Revision: 37419
grass/trunk/gui/wxpython/gui_modules/prompt.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: autocomplete prompt stage 3 (list raster/vector maps)
Modified: grass/trunk/gui/wxpython/gui_modules/prompt.py
--- grass/trunk/gui/wxpython/gui_modules/prompt.py 2009-05-24 13:32:03 UTC (rev 37418)
+++ grass/trunk/gui/wxpython/gui_modules/prompt.py 2009-05-24 13:45:30 UTC (rev 37419)
@@ -25,6 +25,7 @@
import globalvar
import utils
import menuform
+from grass.script import core as grass
class GPrompt:
"""Interactive GRASS prompt"""
@@ -73,6 +74,10 @@
def GetPanel(self):
"""Get main widget panel"""
return self.panel
+ def GetInput(self):
+ """Get main prompt widget"""
+ return self.input
def OnCmdErase(self, event):
"""Erase command prompt"""
@@ -133,7 +138,7 @@
self._choices = choices
self._hideOnNoMatch = True
self._module = None # currently selected module
- self._params = None # params or flags ?
+ self._choiceType = None # type of choice (module, params, flags, raster, vector ...)
self._screenheight = wx.SystemSettings.GetMetric(wx.SYS_SCREEN_Y)
# sort variable needed by listmix
@@ -152,6 +157,10 @@
# set choices (list of GRASS modules)
self._choicesCmd = globalvar.grassCmd['all']
+ self._choicesMap = dict()
+ for type in ('raster', 'vector'):
+ self._choicesMap[type] = grass.list_strings(type = type[:4])
+ # first search for GRASS module
self.SetChoices(self._choicesCmd)
# bindings...
@@ -160,8 +169,6 @@
self.Bind(wx.EVT_KEY_DOWN , self.OnKeyDown, self)
# if need drop down on left click
- ### self.Bind ( wx.EVT_LEFT_DOWN , self.onClickToggleDown, self )
- ### self.Bind ( wx.EVT_LEFT_UP , self.onClickToggleUp, self )
self.dropdown.Bind(wx.EVT_LISTBOX , self.OnListItemSelected, self.dropdownlistbox)
self.dropdownlistbox.Bind(wx.EVT_LEFT_DOWN, self.OnListClick)
self.dropdownlistbox.Bind(wx.EVT_LEFT_DCLICK, self.OnListDClick)
@@ -237,26 +244,27 @@
else:
col = self._colSearch
itemtext = self.dropdownlistbox.GetItem(sel, col).GetText()
- ### if self._selectCallback:
- ### dd = self.dropdownlistbox
- ### values = [dd.GetItem(sel, x).GetText()
- ### for x in xrange(dd.GetColumnCount())]
- ### self._selectCallback(values)
cmd = shlex.split(str(self.GetValue()))
if len(cmd) > 1:
# -> append text (skip last item)
- if self._params is True:
+ if self._choiceType == 'param':
self.SetValue(' '.join(cmd[:-1]) + ' ' + itemtext + '=')
- else:
+ optType = self._module.get_param(itemtext)['prompt']
+ if optType in ('raster', 'vector'):
+ # -> raster/vector map
+ self.SetChoices(self._choicesMap[optType], optType)
+ elif self._choiceType == 'flag':
if len(itemtext) > 1:
prefix = '--'
else:
prefix = '-'
self.SetValue(' '.join(cmd[:-1]) + ' ' + prefix + itemtext)
+ elif self._choiceType in ('raster', 'vector'):
+ self.SetValue(' '.join(cmd[:-1]) + ' ' + cmd[-1].split('=', 1)[0] + '=' + itemtext)
else:
# -> reset text
- self.SetValue(itemtext)
+ self.SetValue(itemtext + ' ')
self.SetInsertionPointEnd()
self._showDropDown(False)
@@ -265,18 +273,21 @@
"""Method required by listmix.ColumnSorterMixin"""
return self.dropdownlistbox
- def SetChoices(self, choices):
+ def SetChoices(self, choices, type = 'module'):
Sets the choices available in the popup wx.ListBox.
The items will be sorted case insensitively.
+ self._choiceType = type
self.dropdownlistbox.SetWindowStyleFlag(wx.LC_REPORT | wx.LC_SINGLE_SEL | \
wx.LC_SORT_ASCENDING | wx.LC_NO_HEADER)
if not isinstance(choices, list):
self._choices = [ x for x in choices ]
- utils.ListSortLower(self._choices)
+ if self._choiceType not in ('raster', 'vector'):
+ # do not sort raster/vector maps
+ utils.ListSortLower(self._choices)
self._updateDataList(self._choices)
@@ -321,8 +332,6 @@
"""Text entered"""
text = event.GetString()
- ### if self._entryCallback:
- ### self._entryCallback()
if not text:
# control is empty; hide dropdown if shown:
if self.dropdown.IsShown():
@@ -331,34 +340,36 @@
return
cmd = shlex.split(str(text))
+ pattern = str(text)
if len(cmd) > 1:
# search for module's options
if not self._module:
self._module = menuform.GUI().ParseInterface(cmd = cmd)
- if cmd[-1][0] == '-':
- # -> flags
- self.SetChoices(self._module.get_list_flags())
- self._params = False
+ if len(cmd[-1].split('=', 1)) == 1:
+ # new option
+ if cmd[-1][0] == '-':
+ # -> flags
+ self.SetChoices(self._module.get_list_flags(), type = 'flag')
+ pattern = cmd[-1].lstrip('-')
+ else:
+ # -> options
+ self.SetChoices(self._module.get_list_params(), type = 'param')
+ pattern = cmd[-1]
else:
- # -> options
- self.SetChoices(self._module.get_list_params())
- self._params = True
+ # value
+ pattern = cmd[-1].split('=', 1)[1]
else:
# search for GRASS modules
if self._module:
# -> switch back to GRASS modules list
self._module = None
found = False
choices = self._choices
for numCh, choice in enumerate(choices):
- ### if self._matchFunction and self._matchFunction(text, choice):
- ### found = True
- ### elif
- if choice.lower().startswith(cmd[-1].lower().lstrip('-')):
+ if choice.lower().startswith(pattern):
found = True
if found:
self._showDropDown(True)
@@ -397,10 +408,7 @@
self._listItemVisible()
self._showDropDown ()
skip = False
- elif KC == wx.WXK_LEFT:
- return
- elif KC == wx.WXK_RIGHT:
- return
if visible:
if event.GetKeyCode() == wx.WXK_RETURN:
self._setValueFromSelected()
@@ -408,7 +416,7 @@
if event.GetKeyCode() == wx.WXK_ESCAPE:
skip = False
- if skip :
+ if skip:
event.Skip()
def OnControlChanged(self, event):
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2009-05-24 13:32:03 UTC (rev 37418)
+++ grass/trunk/gui/wxpython/wxgui.py 2009-05-24 13:45:30 UTC (rev 37419)
@@ -126,7 +126,7 @@
# creating widgets
# -> self.notebook, self.goutput, self.outpage
self.notebook = self.__createNoteBook()
- self.cmdprompt = self.__createCommandPrompt()
+ self.cmdprompt, self.cmdinput = self.__createCommandPrompt()
self.menubar = self.__createMenuBar()
self.toolbar = self.__createToolBar()
self.statusbar = self.CreateStatusBar(number=1)
@@ -154,7 +154,8 @@
self._auimgr.Update()
wx.CallAfter(self.notebook.SetSelection, 0)
+ wx.CallAfter(self.cmdinput.SetFocus)
# use default window layout ?
if UserSettings.Get(group='general', key='defWindowPos', subkey='enabled') is True:
dim = UserSettings.Get(group='general', key='defWindowPos', subkey='dim')
@@ -193,7 +194,9 @@
def __createCommandPrompt(self):
"""Creates command-line input area"""
- return prompt.GPrompt(self).GetPanel()
+ p = prompt.GPrompt(self)
+ return p.GetPanel(), p.GetInput()
def __createMenuBar(self):
"""Creates menubar"""
