[GRASS-SVN] r37459 - grass/branches/develbranch_6/scripts/d.rast.leg
svn_grass at osgeo.org
Mon May 25 04:36:27 EDT 2009
Author: hamish
Date: 2009-05-25 04:36:27 -0400 (Mon, 25 May 2009)
New Revision: 37459
grass/branches/develbranch_6/scripts/d.rast.leg/d.rast.leg
bugfix: file search needs path vars
Modified: grass/branches/develbranch_6/scripts/d.rast.leg/d.rast.leg
--- grass/branches/develbranch_6/scripts/d.rast.leg/d.rast.leg 2009-05-25 08:33:43 UTC (rev 37458)
+++ grass/branches/develbranch_6/scripts/d.rast.leg/d.rast.leg 2009-05-25 08:36:27 UTC (rev 37459)
@@ -82,12 +82,12 @@
#%end
if test "$GISBASE" = ""; then
- echo "You must be in GRASS GIS to run this program." >&2
- exit 1
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
- exec g.parser "$0" "$@"
+ exec g.parser "$0" "$@"
fi
if [ $GIS_FLAG_N -eq 1 ] ; then
@@ -114,6 +114,7 @@
fi
filemapset="${mapset}"
# would it be better to search for cats/ file ??
+eval `g.gisenv`
HISTFILEDIR=$GISDBASE/$LOCATION_NAME/$filemapset/cell_misc/
eval `r.info -t "$GIS_OPT_MAP"`
