[GRASS-SVN] r37469 - grass/trunk/raster/r.in.gdal
svn_grass at osgeo.org
Mon May 25 10:15:08 EDT 2009
Author: hamish
Date: 2009-05-25 10:15:08 -0400 (Mon, 25 May 2009)
New Revision: 37469
grass/trunk/raster/r.in.gdal/main.c
grass/trunk/raster/r.in.gdal/r.in.gdal.html
add flag so that you can force the import of lat/lon imagery which is missing georef, at the cost of preserving map bounds (which were presumably bogus to begin with, so no great loss) (merge from devbr6)
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2009-05-25 14:09:51 UTC (rev 37468)
+++ grass/trunk/raster/r.in.gdal/main.c 2009-05-25 14:15:08 UTC (rev 37469)
@@ -68,7 +68,7 @@
struct Option *input, *output, *target, *title, *outloc, *band;
} parm;
- struct Flag *flag_o, *flag_e, *flag_k, *flag_f;
+ struct Flag *flag_o, *flag_e, *flag_k, *flag_f, *flag_l;
/* Initialize. */
@@ -134,6 +134,11 @@
flag_f->description = _("List supported formats and exit");
flag_f->guisection = _("Print");
+ flag_l = G_define_flag();
+ flag_l->key = 'l';
+ flag_l->description =
+ _("Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)");
flag_k = G_define_flag();
flag_k->key = 'k';
flag_k->description =
@@ -161,6 +166,8 @@
G_fatal_error(_("You have to specify a target location different from output location"));
+ if (flag_l->answer && G_projection() != PROJECTION_LL)
+ G_fatal_error(_("The '-l' flag only works in Lat/Lon locations"));
/* Fire up the engines. */
@@ -195,6 +202,7 @@
exit(EXIT_SUCCESS);
if (!input)
G_fatal_error(_("Required parameter <%s> not set"), parm.input->key);
@@ -270,6 +278,23 @@
cellhd.depths = 1;
+ /* constrain to geographic coords */
+ if (flag_l->answer && G_projection() == PROJECTION_LL) {
+ if (cellhd.north > 90.) cellhd.north = 90.;
+ if (cellhd.south < -90.) cellhd.south = -90.;
+ if (cellhd.east > 360.) cellhd.east = 180.;
+ if (cellhd.west < -180.) cellhd.west = -180.;
+ cellhd.ns_res = (cellhd.north - cellhd.south) / cellhd.rows;
+ cellhd.ew_res = (cellhd.east - cellhd.west) / cellhd.cols;
+ cellhd.ew_res3 = cellhd.ew_res;
+ cellhd.ns_res3 = cellhd.ns_res;
+ G_warning(_("Map bounds have been constrained to geographic "
+ "coordinates. You will almost certainly want to check "
+ "map bounds and resolution with r.info and reset them "
+ "with r.region before going any further."));
/* Fetch the projection in GRASS form. */
Modified: grass/trunk/raster/r.in.gdal/r.in.gdal.html
--- grass/trunk/raster/r.in.gdal/r.in.gdal.html 2009-05-25 14:09:51 UTC (rev 37468)
+++ grass/trunk/raster/r.in.gdal/r.in.gdal.html 2009-05-25 14:15:08 UTC (rev 37469)
@@ -89,7 +89,6 @@
the source dataset.
<p>
If the user wishes to ignore the difference between the apparent coordinate
system of the source data and the current location, they may pass the
<b>-o</b> flag to override the projection check.
@@ -105,7 +104,6 @@
imported with the indicated <b>output</b> name into the PERMANENT mapset.
<p>
Support for GCPs: In case the image contains GCPs they are written to a
POINTS file within an imagery group. They can directly be used for
<a href=i.rectify.html>i.rectify</a>. The <b>target</b> option allows to
@@ -119,7 +117,6 @@
reporting everything known about a dataset if the <b>output</b> parameter is not set.
<p>
The <em>r.in.gdal</em> comand does support the following features, as long as
the underlying format driver supports it:
@@ -190,10 +187,35 @@
<i>"ERROR: Projection of dataset does not appear to match the current location."</i><br>
You need to create a location whose projection matches the data you
-wish to import. Try using <b>location</b> parameter to create a new location based
-upon the projection information in the file. If desired, you can then re-project
-it to another location with <em>r.proj</em>.
+wish to import. Try using <b>location</b> parameter to create a new
+location based upon the projection information in the file. If desired,
+you can then re-project it to another location with <em>r.proj</em>.
+Alternatively you can override this error by using the <b>-o</b> flag.
+<p>
+<i>"WARNING: G_set_window(): Illegal latitude for North"</i><br>
+Latitude/Longitude locations in GRASS can not have regions which exceed
+90° North or South. Non-georeferenced imagery will have coordinates
+based on the images's number of pixels: 0,0 in the bottom left; cols,rows
+in the top right. Typically imagery will be much more than 90 pixels tall
+and so the GIS refuses to import it. If you are sure that the data is
+appropriate for your Lat/Lon location and intentd to reset the map's
+bounds with the <em>r.region</em> module directly after import you may
+use the <b>-l</b> flag to constrain the map coordinates to legal values.
+While the resulting bounds and resolution will likely be wrong for your
+map the map's data will be unaltered and safe. After resetting to known
+bounds with <em>r.region</em> you should double check them with
+<em>r.info</em>, paying special attention to the map resolution. In most
+cases you will want to import into the datafile's native projection, or
+into a simple XY location and use the Georectifaction tools
+(<em>i.rectify</em> et al.) to properly project into the target location.
+The <b>-l</b> flag should <i>only</i> be used if you know the projection
+is correct but the internal georeferencing has gotten lost, and you know
+the what the map's bounds and resolution should be beforehand.
<h2>EXAMPLES</h2>
<h3>GTOPO30 DEM</h3>
@@ -240,6 +262,7 @@
# ... likewise for other HDF bands in the file.
</pre></div>
<h2>SEE ALSO</h2>
<em>
<a href="r.colors.html">r.colors</a>,
@@ -249,12 +272,16 @@
<a href="r.null.html">r.null</a>
</em>
<h2>REFERENCES</h2>
GDAL Pages: <a href="http://www.gdal.org">http://www.gdal.org/</a><br>
<h2>AUTHOR</h2>
-<a href="http://home.gdal.org/warmerda/">Frank Warmerdam</a> (<a href="mailto:warmerdam AT pobox dot com">email</a>).
+<a href="http://home.gdal.org/warmerda/">Frank Warmerdam</a>
+ (<a href="mailto:warmerdam AT pobox dot com">email</a>).
-<p><i>Last changed: $Date$</i>I
+<p>
+<i>Last changed: $Date$</i>
