[GRASS-SVN] r37489 - in grass/trunk: . display/d.what.vect include/Make lib/form visualization/nviz/src
Mon May 25 13:56:01 EDT 2009
Author: kyngchaos
Date: 2009-05-25 13:56:01 -0400 (Mon, 25 May 2009)
New Revision: 37489
   grass/trunk/configure
   grass/trunk/configure.in
   grass/trunk/display/d.what.vect/Makefile
   grass/trunk/include/Make/Platform.make.in
   grass/trunk/lib/form/Makefile
   grass/trunk/visualization/nviz/src/Makefile
support 64bit build with 32bit TclTk aqua on OSX (from dev6 r37402)
Modified: grass/trunk/configure
--- grass/trunk/configure	2009-05-25 17:55:59 UTC (rev 37488)
+++ grass/trunk/configure	2009-05-25 17:56:01 UTC (rev 37489)
@@ -8403,857 +8403,11 @@
 # Done checking PNG
-# Enable TCLTK option
-echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8411: checking whether to use Tcl/Tk" >&5
-echo "$ac_t"""$with_tcltk"" 1>&6
-case "$with_tcltk" in
-	"no")	USE_TCLTK=	;;
-	"yes")	USE_TCLTK="1"	;;
-	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
-esac
-TCLINCDIR=
-TCLTKLIBPATH=
-TCLTKLIBS=
-if test -n "$USE_TCLTK"; then
-# With Tcl/Tk includes directory
-echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8431: checking for location of Tcl/Tk includes" >&5
-case "$with_tcltk_includes" in
-y | ye | yes | n | no)
-	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_tcltk_includes" 1>&6
-if test -n "$with_tcltk_includes" ; then
-    for dir in $with_tcltk_includes; do
-        if test -d "$dir"; then
-            TCLINCDIR="$TCLINCDIR -I$dir"
-        else
-            { echo "configure: error: *** Tcl/Tk includes directory $dir does not exist." 1>&2; exit 1; }
-        fi
-    done
-fi
-ac_save_cppflags="$CPPFLAGS"
-CPPFLAGS="$TCLINCDIR $CPPFLAGS"
-for ac_hdr in tcl.h
-do
-ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8457: checking for $ac_hdr" >&5
-cat > conftest.$ac_ext <<EOF
-#line 8460 "configure"
-#include "confdefs.h"
-#include <$ac_hdr>
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8465: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=yes"
-else
-  echo "$ac_err" >&5
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
-  echo "$ac_t""yes" 1>&6
-    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
-  cat >> confdefs.h <<EOF
-#define $ac_tr_hdr 1
-EOF
-else
-  echo "$ac_t""no" 1>&6
-{ echo "configure: error: *** Unable to locate Tcl includes." 1>&2; exit 1; }
-fi
-done
-CPPFLAGS=$ac_save_cppflags
-CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
-for ac_hdr in tk.h
-do
-echo "configure:8502: checking for $ac_hdr" >&5
-#line 8505 "configure"
-#include <$ac_hdr>
-EOF
-{ (eval echo configure:8510: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-EOF
-else
-{ echo "configure: error: *** Unable to locate Tk includes." 1>&2; exit 1; }
-fi
-done
-# Tcl/Tk version checks
-echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8544: checking Tcl version" >&5
-if test "$cross_compiling" = yes; then
-     tcl_ver=UNKNOWN
-    echo "$ac_t""unknown (cross-compiling)" 1>&6
-else
-  cat > conftest.$ac_ext <<EOF
-#line 8552 "configure"
-#include <stdio.h>
-#include <tcl.h>
-int main(void) {
- FILE *fp = fopen("conftestdata","w");
- fputs(TCL_VERSION, fp);
- return 0;
-EOF
-if { (eval echo configure:8564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
-then
-     tcl_ver=`cat conftestdata`
-    echo "$ac_t""$tcl_ver" 1>&6
-else
-  rm -fr conftest*
-     { echo "configure: error: *** Could not determine Tcl version." 1>&2; exit 1; }
-fi
-rm -fr conftest*
-fi
-echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8582: checking Tk version" >&5
-     tk_ver=UNKNOWN
-else
-#line 8590 "configure"
-#include <stdio.h>
-#include <tk.h>
-int main(void) {
- fputs(TK_VERSION, fp);
- return 0;
-EOF
-if { (eval echo configure:8602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
-then
-     tk_ver=`cat conftestdata`
-    echo "$ac_t""$tk_ver" 1>&6
-else
-  rm -fr conftest*
-     { echo "configure: error: *** Could not determine Tk version." 1>&2; exit 1; }
-fi
-rm -fr conftest*
-fi
-if test "$tcl_ver" = "$tk_ver" ; then
-    tcltk_ver=$tcl_ver
-else
-    { echo "configure: error: *** Tcl/Tk version mismatch." 1>&2; exit 1; }
-fi
-# FreeBSD and CygWin don't have a "dot" between major/minor version number
-tcltk_ver2=`echo $tcltk_ver | sed 's/\.//g'`
-# With Tcl/Tk library directory
-echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8631: checking for location of Tcl/Tk library" >&5
-case "$with_tcltk_libs" in
-	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_tcltk_libs" 1>&6
-if test -n "$with_tcltk_libs"; then
-    for dir in $with_tcltk_libs; do
-            TCLTKLIBPATH="$TCLTKLIBPATH -L$dir"
-        else
-            { echo "configure: error: *** Tcl/Tk library directory $dir does not exist." 1>&2; exit 1; }
-        fi
-    done
-fi
-TCLLIB=
-TKLIB=
-ac_save_ldflags="$LDFLAGS"
-LDFLAGS="$TCLTKLIBPATH $LDFLAGS"
-echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8661: checking for Tcl_Init in -ltcl" >&5
-ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-ltcl $MATHLIB $LIBS"
-#line 8667 "configure"
-/* Override any gcc2 internal prototype to avoid an error.  */
-/* We use char because int might match the return type of a gcc2
-    builtin and then its argument prototype would still apply.  */
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:8678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=yes"
-else
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
-  TCLLIB="$TCLLIB -ltcl $MATHLIB"
-else
-echo "configure:8697: checking for Tcl_Init in -ltcl" >&5
-LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8703 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:8714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TCLLIB="$TCLLIB -ltcl $MATHLIB $DLLIB"
-else
-LDFLAGS=${ac_save_ldflags}
-echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8741: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
-ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
-LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8747 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:8758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TCLLIB="$TCLLIB -ltcl$tcltk_ver $MATHLIB"
-else
-echo "configure:8777: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
-LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8783 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:8794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TCLLIB="$TCLLIB -ltcl$tcltk_ver $MATHLIB $DLLIB"
-else
-echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8821: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
-ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
-LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8827 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:8838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TCLLIB="$TCLLIB -ltcl$tcltk_ver2 $MATHLIB"
-else
-echo "configure:8857: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
-LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8863 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:8874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TCLLIB="$TCLLIB -ltcl$tcltk_ver2 $MATHLIB $DLLIB"
-else
-    { echo "configure: error: *** Unable to locate Tcl library." 1>&2; exit 1; }
-fi
-fi
-fi
-fi
-fi
-fi
-echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8952: checking for Tk_MainWindow in -ltk" >&5
-ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
-LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8958 "configure"
-char Tk_MainWindow();
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:8969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TKLIB="$TKLIB -ltk $MATHLIB"
-else
-echo "configure:8988: checking for Tk_MainWindow in -ltk" >&5
-LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8994 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:9005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TKLIB="$TKLIB -ltk $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
-else
-echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9032: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
-ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
-LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9038 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:9049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TKLIB="$TKLIB -ltk$tcltk_ver $MATHLIB"
-else
-echo "configure:9068: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
-LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9074 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:9085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TKLIB="$TKLIB -ltk$tcltk_ver $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
-else
-echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9112: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
-ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
-LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9118 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:9129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TKLIB="$TKLIB -ltk$tcltk_ver2 $MATHLIB"
-else
-echo "configure:9148: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
-LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9154 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:9165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TKLIB="$TKLIB -ltk$tcltk_ver2 $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
-else
-    { echo "configure: error: *** Unable to locate Tk library." 1>&2; exit 1; }
-fi
-fi
-fi
-fi
-fi
-fi
-TCLTKLIBS="$TKLIB $TCLLIB"
-cat >> confdefs.h <<\EOF
-#define HAVE_TCLTK 1
-EOF
-fi # $USE_TCLTK
-TKINCDIR=$TCLINCDIR
-# Done checking Tcl/Tk
 # Enable PostgreSQL option
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9257: checking whether to use PostgreSQL" >&5
+echo "configure:8411: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9280,7 +8434,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9284: checking for location of PostgreSQL includes" >&5
+echo "configure:8438: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9306,15 +8460,15 @@
 do
-echo "configure:9310: checking for $ac_hdr" >&5
+echo "configure:8464: checking for $ac_hdr" >&5
-#line 9313 "configure"
+#line 8467 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9318: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8472: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9352,7 +8506,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9356: checking for location of PostgreSQL library" >&5
+echo "configure:8510: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9381,13 +8535,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9385: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8539: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9391 "configure"
+#line 8545 "configure"
@@ -9398,7 +8552,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9417,13 +8571,13 @@
-echo "configure:9421: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8575: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9427 "configure"
+#line 8581 "configure"
@@ -9434,7 +8588,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9453,13 +8607,13 @@
-echo "configure:9457: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8611: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9463 "configure"
+#line 8617 "configure"
@@ -9470,7 +8624,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9489,13 +8643,13 @@
-echo "configure:9493: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8647: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9499 "configure"
+#line 8653 "configure"
@@ -9506,7 +8660,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9563,13 +8717,13 @@
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9567: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8721: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9573 "configure"
+#line 8727 "configure"
@@ -9580,7 +8734,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9602,13 +8756,13 @@
-echo "configure:9606: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8760: checking for PQcmdTuples in -lpq" >&5
-#line 9612 "configure"
+#line 8766 "configure"
@@ -9619,7 +8773,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9662,7 +8816,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9666: checking whether to use MySQL" >&5
+echo "configure:8820: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9682,7 +8836,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9686: checking for location of MySQL includes" >&5
+echo "configure:8840: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9708,15 +8862,15 @@
 do
-echo "configure:9712: checking for $ac_hdr" >&5
+echo "configure:8866: checking for $ac_hdr" >&5
-#line 9715 "configure"
+#line 8869 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9720: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9753,7 +8907,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9757: checking for location of MySQL library" >&5
+echo "configure:8911: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9784,13 +8938,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9788: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8942: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9794 "configure"
+#line 8948 "configure"
@@ -9801,7 +8955,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9820,13 +8974,13 @@
-echo "configure:9824: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8978: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9830 "configure"
+#line 8984 "configure"
@@ -9837,7 +8991,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9856,13 +9010,13 @@
-echo "configure:9860: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9014: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9866 "configure"
+#line 9020 "configure"
@@ -9873,7 +9027,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9892,13 +9046,13 @@
-echo "configure:9896: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9050: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9902 "configure"
+#line 9056 "configure"
@@ -9909,7 +9063,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9928,13 +9082,13 @@
-echo "configure:9932: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9086: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9938 "configure"
+#line 9092 "configure"
@@ -9945,7 +9099,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9964,13 +9118,13 @@
-echo "configure:9968: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9122: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9974 "configure"
+#line 9128 "configure"
@@ -9981,7 +9135,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10000,13 +9154,13 @@
-echo "configure:10004: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9158: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10010 "configure"
+#line 9164 "configure"
@@ -10017,7 +9171,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10036,13 +9190,13 @@
-echo "configure:10040: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9194: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10046 "configure"
+#line 9200 "configure"
@@ -10053,7 +9207,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10143,7 +9297,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:10147: checking for $ac_word" >&5
+echo "configure:9301: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10192,10 +9346,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10196: checking for mysql_server_init" >&5
+echo "configure:9350: checking for mysql_server_init" >&5
-#line 10199 "configure"
+#line 9353 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10221,7 +9375,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10273,7 +9427,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10277: checking whether to use SQLite" >&5
+echo "configure:9431: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10293,7 +9447,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10297: checking for location of SQLite includes" >&5
+echo "configure:9451: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10319,15 +9473,15 @@
 do
-echo "configure:10323: checking for $ac_hdr" >&5
+echo "configure:9477: checking for $ac_hdr" >&5
-#line 10326 "configure"
+#line 9480 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10331: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9485: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10370,7 +9524,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10374: checking for location of SQLite library" >&5
+echo "configure:9528: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10397,13 +9551,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10401: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9555: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10407 "configure"
+#line 9561 "configure"
@@ -10414,7 +9568,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10433,13 +9587,13 @@
-echo "configure:10437: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9591: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10443 "configure"
+#line 9597 "configure"
@@ -10450,7 +9604,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10503,7 +9657,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10507: checking whether to use FFMPEG" >&5
+echo "configure:9661: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10523,7 +9677,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10527: checking for location of FFMPEG includes" >&5
+echo "configure:9681: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10549,15 +9703,15 @@
 do
-echo "configure:10553: checking for $ac_hdr" >&5
+echo "configure:9707: checking for $ac_hdr" >&5
-#line 10556 "configure"
+#line 9710 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10561: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9715: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10593,15 +9747,15 @@
 do
-echo "configure:10597: checking for $ac_hdr" >&5
+echo "configure:9751: checking for $ac_hdr" >&5
-#line 10600 "configure"
+#line 9754 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10605: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10637,15 +9791,15 @@
 do
-echo "configure:10641: checking for $ac_hdr" >&5
+echo "configure:9795: checking for $ac_hdr" >&5
-#line 10644 "configure"
+#line 9798 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10649: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9803: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10688,7 +9842,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10692: checking for location of FFMPEG library" >&5
+echo "configure:9846: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10715,13 +9869,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10719: checking for av_free in -lavutil" >&5
+echo "configure:9873: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10725 "configure"
+#line 9879 "configure"
@@ -10732,7 +9886,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10751,13 +9905,13 @@
-echo "configure:10755: checking for av_free in -lavutil" >&5
+echo "configure:9909: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10761 "configure"
+#line 9915 "configure"
@@ -10768,7 +9922,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10813,13 +9967,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10817: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9971: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10823 "configure"
+#line 9977 "configure"
@@ -10830,7 +9984,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10849,13 +10003,13 @@
-echo "configure:10853: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10007: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10859 "configure"
+#line 10013 "configure"
@@ -10866,7 +10020,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10911,13 +10065,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10915: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10069: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10921 "configure"
+#line 10075 "configure"
@@ -10928,7 +10082,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10947,13 +10101,13 @@
-echo "configure:10951: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10105: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10957 "configure"
+#line 10111 "configure"
@@ -10964,7 +10118,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11012,7 +10166,6 @@
 # Done checking FFMPEG
 # Enable OpenGL option
 OPENGLINC=
@@ -11024,7 +10177,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:11028: checking whether to use OpenGL" >&5
+echo "configure:10181: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -11058,7 +10211,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11062: checking for location of OpenGL includes" >&5
+echo "configure:10215: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11084,15 +10237,15 @@
 do
-echo "configure:11088: checking for $ac_hdr" >&5
+echo "configure:10241: checking for $ac_hdr" >&5
-#line 11091 "configure"
+#line 10244 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11096: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10249: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11126,7 +10279,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11130: checking for location of OpenGL library" >&5
+echo "configure:10283: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11155,13 +10308,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11159: checking for glBegin in -lGL" >&5
+echo "configure:10312: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11165 "configure"
+#line 10318 "configure"
@@ -11172,7 +10325,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11191,13 +10344,13 @@
-echo "configure:11195: checking for glBegin in -lGL" >&5
+echo "configure:10348: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11201 "configure"
+#line 10354 "configure"
@@ -11208,7 +10361,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11227,13 +10380,13 @@
-echo "configure:11231: checking for glBegin in -lGL" >&5
+echo "configure:10384: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11237 "configure"
+#line 10390 "configure"
@@ -11244,7 +10397,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11263,13 +10416,13 @@
-echo "configure:11267: checking for glBegin in -lGL" >&5
+echo "configure:10420: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11273 "configure"
+#line 10426 "configure"
@@ -11280,7 +10433,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11342,13 +10495,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11346: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10499: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11352 "configure"
+#line 10505 "configure"
@@ -11359,7 +10512,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11378,13 +10531,13 @@
-echo "configure:11382: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10535: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11388 "configure"
+#line 10541 "configure"
@@ -11395,7 +10548,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11442,10 +10595,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11446: checking for glXCreatePbuffer" >&5
+echo "configure:10599: checking for glXCreatePbuffer" >&5
-#line 11449 "configure"
+#line 10602 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11468,7 +10621,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11505,10 +10658,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11509: checking for glXCreateGLXPixmap" >&5
+echo "configure:10662: checking for glXCreateGLXPixmap" >&5
-#line 11512 "configure"
+#line 10665 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11531,7 +10684,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11574,7 +10727,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:11578: checking for location of OpenGL framework" >&5
+echo "configure:10731: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -11598,15 +10751,15 @@
 do
-echo "configure:11602: checking for $ac_hdr" >&5
+echo "configure:10755: checking for $ac_hdr" >&5
-#line 11605 "configure"
+#line 10758 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11610: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10763: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11642,10 +10795,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11646: checking for glBegin" >&5
+echo "configure:10799: checking for glBegin" >&5
-#line 11649 "configure"
+#line 10802 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11668,7 +10821,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11705,10 +10858,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11709: checking for gluBeginCurve" >&5
+echo "configure:10862: checking for gluBeginCurve" >&5
-#line 11712 "configure"
+#line 10865 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11731,7 +10884,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11779,7 +10932,7 @@
-echo "configure:11783: checking for location of OpenGL includes" >&5
+echo "configure:10936: checking for location of OpenGL includes" >&5
@@ -11805,15 +10958,15 @@
 do
-echo "configure:11809: checking for $ac_hdr" >&5
+echo "configure:10962: checking for $ac_hdr" >&5
-#line 11812 "configure"
+#line 10965 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11817: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10970: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11847,7 +11000,7 @@
-echo "configure:11851: checking for location of OpenGL library" >&5
+echo "configure:11004: checking for location of OpenGL library" >&5
@@ -11872,18 +11025,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11876: checking for OpenGL library" >&5
+echo "configure:11029: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11880 "configure"
+#line 11033 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11040: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11907,18 +11060,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11911: checking for GLU library" >&5
+echo "configure:11064: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11915 "configure"
+#line 11068 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11963,11 +11116,882 @@
 # Done checking OpenGL
+# Enable TCLTK option
+echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
+echo "configure:11124: checking whether to use Tcl/Tk" >&5
+echo "$ac_t"""$with_tcltk"" 1>&6
+case "$with_tcltk" in
+	"no")	USE_TCLTK=	;;
+	"yes")	USE_TCLTK="1"	;;
+	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
+esac
+TCLINCDIR=
+TCLTKLIBPATH=
+TCLTKLIBS=
+if test -n "$USE_TCLTK"; then
+# With Tcl/Tk includes directory
+echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
+echo "configure:11144: checking for location of Tcl/Tk includes" >&5
+case "$with_tcltk_includes" in
+y | ye | yes | n | no)
+	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_tcltk_includes" 1>&6
+if test -n "$with_tcltk_includes" ; then
+    for dir in $with_tcltk_includes; do
+        if test -d "$dir"; then
+            TCLINCDIR="$TCLINCDIR -I$dir"
+        else
+            { echo "configure: error: *** Tcl/Tk includes directory $dir does not exist." 1>&2; exit 1; }
+        fi
+    done
+fi
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$TCLINCDIR $CPPFLAGS"
+for ac_hdr in tcl.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:11170: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 11173 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:11178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=yes"
+else
+  echo "$ac_err" >&5
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+  cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+  echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate Tcl includes." 1>&2; exit 1; }
+fi
+done
+CPPFLAGS=$ac_save_cppflags
+CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
+for ac_hdr in tk.h
+do
+echo "configure:11215: checking for $ac_hdr" >&5
+#line 11218 "configure"
+#include <$ac_hdr>
+EOF
+{ (eval echo configure:11223: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+EOF
+else
+{ echo "configure: error: *** Unable to locate Tk includes." 1>&2; exit 1; }
+fi
+done
+# Tcl/Tk version checks
+echo $ac_n "checking Tcl version""... $ac_c" 1>&6
+echo "configure:11257: checking Tcl version" >&5
+if test "$cross_compiling" = yes; then
+     tcl_ver=UNKNOWN
+    echo "$ac_t""unknown (cross-compiling)" 1>&6
+else
+  cat > conftest.$ac_ext <<EOF
+#line 11265 "configure"
+#include <stdio.h>
+#include <tcl.h>
+int main(void) {
+ FILE *fp = fopen("conftestdata","w");
+ fputs(TCL_VERSION, fp);
+ return 0;
+EOF
+if { (eval echo configure:11277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+then
+     tcl_ver=`cat conftestdata`
+    echo "$ac_t""$tcl_ver" 1>&6
+else
+  rm -fr conftest*
+     { echo "configure: error: *** Could not determine Tcl version." 1>&2; exit 1; }
+fi
+rm -fr conftest*
+fi
+echo $ac_n "checking Tk version""... $ac_c" 1>&6
+echo "configure:11295: checking Tk version" >&5
+     tk_ver=UNKNOWN
+else
+#line 11303 "configure"
+#include <stdio.h>
+#include <tk.h>
+int main(void) {
+ fputs(TK_VERSION, fp);
+ return 0;
+EOF
+if { (eval echo configure:11315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+then
+     tk_ver=`cat conftestdata`
+    echo "$ac_t""$tk_ver" 1>&6
+else
+  rm -fr conftest*
+     { echo "configure: error: *** Could not determine Tk version." 1>&2; exit 1; }
+fi
+rm -fr conftest*
+fi
+if test "$tcl_ver" = "$tk_ver" ; then
+    tcltk_ver=$tcl_ver
+else
+    { echo "configure: error: *** Tcl/Tk version mismatch." 1>&2; exit 1; }
+fi
+# FreeBSD and CygWin don't have a "dot" between major/minor version number
+tcltk_ver2=`echo $tcltk_ver | sed 's/\.//g'`
+# With Tcl/Tk library directory
+echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
+echo "configure:11344: checking for location of Tcl/Tk library" >&5
+case "$with_tcltk_libs" in
+	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_tcltk_libs" 1>&6
+if test -n "$with_tcltk_libs"; then
+    for dir in $with_tcltk_libs; do
+            TCLTKLIBPATH="$TCLTKLIBPATH -L$dir"
+        else
+            { echo "configure: error: *** Tcl/Tk library directory $dir does not exist." 1>&2; exit 1; }
+        fi
+    done
+fi
+TCLLIB=
+TKLIB=
+# Can't test tcl/tk libs on 64bit OSX Aqua for now
+# assume that if OpenGL Aqua, then user specifies TclTk Aqua,
+# as there is no test for Tcl/Tk Aqua and Tck/Tk X11 won't work
+TCLTKAQUA_IS64BIT=
+if test "$OPENGL_AQUA" = 1 ; then
+    temp_CFLAGS="$CFLAGS"
+    CFLAGS="`echo \"$CFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
+    # can't save LDFLAGS, need to remember arch flags to insert back later
+    temp_ARCHES=
+    for a in x86_64 ppc64
+    do
+        if test -n "`echo \"$LDFLAGS\" | grep -E -e '-arch +'$a`" ; then
+            temp_ARCHES="$temp_ARCHES -arch $a"
+        fi
+    done
+    LDFLAGS="`echo \"$LDFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
+fi
+ac_save_ldflags="$LDFLAGS"
+LDFLAGS="$TCLTKLIBPATH $LDFLAGS"
+echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
+echo "configure:11392: checking for Tcl_Init in -ltcl" >&5
+ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-ltcl $MATHLIB $LIBS"
+#line 11398 "configure"
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:11409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=yes"
+else
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+  TCLLIB="$TCLLIB -ltcl $MATHLIB"
+else
+echo "configure:11428: checking for Tcl_Init in -ltcl" >&5
+LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
+#line 11434 "configure"
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:11445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TCLLIB="$TCLLIB -ltcl $MATHLIB $DLLIB"
+else
+LDFLAGS=${ac_save_ldflags}
+echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
+echo "configure:11472: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
+LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
+#line 11478 "configure"
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:11489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TCLLIB="$TCLLIB -ltcl$tcltk_ver $MATHLIB"
+else
+echo "configure:11508: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
+#line 11514 "configure"
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:11525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TCLLIB="$TCLLIB -ltcl$tcltk_ver $MATHLIB $DLLIB"
+else
+echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
+echo "configure:11552: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
+LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
+#line 11558 "configure"
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:11569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TCLLIB="$TCLLIB -ltcl$tcltk_ver2 $MATHLIB"
+else
+echo "configure:11588: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
+#line 11594 "configure"
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:11605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TCLLIB="$TCLLIB -ltcl$tcltk_ver2 $MATHLIB $DLLIB"
+else
+    { echo "configure: error: *** Unable to locate Tcl library." 1>&2; exit 1; }
+fi
+fi
+fi
+fi
+fi
+fi
+echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
+echo "configure:11683: checking for Tk_MainWindow in -ltk" >&5
+ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
+LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
+#line 11689 "configure"
+char Tk_MainWindow();
+int main() {
+Tk_MainWindow()
+; return 0; }
+EOF
+if { (eval echo configure:11700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TKLIB="$TKLIB -ltk $MATHLIB"
+else
+echo "configure:11719: checking for Tk_MainWindow in -ltk" >&5
+LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
+#line 11725 "configure"
+int main() {
+Tk_MainWindow()
+; return 0; }
+EOF
+if { (eval echo configure:11736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TKLIB="$TKLIB -ltk $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
+else
+echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
+echo "configure:11763: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
+LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
+#line 11769 "configure"
+int main() {
+Tk_MainWindow()
+; return 0; }
+EOF
+if { (eval echo configure:11780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TKLIB="$TKLIB -ltk$tcltk_ver $MATHLIB"
+else
+echo "configure:11799: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
+#line 11805 "configure"
+int main() {
+Tk_MainWindow()
+; return 0; }
+EOF
+if { (eval echo configure:11816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TKLIB="$TKLIB -ltk$tcltk_ver $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
+else
+echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
+echo "configure:11843: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
+LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
+#line 11849 "configure"
+int main() {
+Tk_MainWindow()
+; return 0; }
+EOF
+if { (eval echo configure:11860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TKLIB="$TKLIB -ltk$tcltk_ver2 $MATHLIB"
+else
+echo "configure:11879: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
+#line 11885 "configure"
+int main() {
+Tk_MainWindow()
+; return 0; }
+EOF
+if { (eval echo configure:11896: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TKLIB="$TKLIB -ltk$tcltk_ver2 $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
+else
+    { echo "configure: error: *** Unable to locate Tk library." 1>&2; exit 1; }
+fi
+fi
+fi
+fi
+fi
+fi
+# restore CFLAGS/LDLFAGS from Aqua 64bit strip
+# only Tcl/Tk-based makefiles will strip 64bit out during compile
+   CFLAGS="$temp_CFLAGS"
+   LDFLAGS="$temp_ARCHES $LDFLAGS"
+fi
+TCLTKLIBS="$TKLIB $TCLLIB"
+cat >> confdefs.h <<\EOF
+#define HAVE_TCLTK 1
+EOF
+fi # $USE_TCLTK
+TKINCDIR=$TCLINCDIR
+# Done checking Tcl/Tk
 # Enable ODBC option
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11971: checking whether to use ODBC" >&5
+echo "configure:11995: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11986,7 +12010,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11990: checking for location of ODBC includes" >&5
+echo "configure:12014: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12012,15 +12036,15 @@
 do
-echo "configure:12016: checking for $ac_hdr" >&5
+echo "configure:12040: checking for $ac_hdr" >&5
-#line 12019 "configure"
+#line 12043 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12024: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12054,7 +12078,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12058: checking for location of ODBC library" >&5
+echo "configure:12082: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12079,13 +12103,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12083: checking for SQLConnect in -lodbc" >&5
+echo "configure:12107: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12089 "configure"
+#line 12113 "configure"
@@ -12096,7 +12120,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12121,13 +12145,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12125: checking for SQLConnect in -liodbc" >&5
+echo "configure:12149: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12131 "configure"
+#line 12155 "configure"
@@ -12138,7 +12162,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12163,11 +12187,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12167: checking for ODBC library" >&5
+echo "configure:12191: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12171 "configure"
+#line 12195 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12175,7 +12199,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12224,7 +12248,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12228: checking whether to use FFTW" >&5
+echo "configure:12252: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12243,7 +12267,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12247: checking for location of FFTW includes" >&5
+echo "configure:12271: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12269,15 +12293,15 @@
 do
-echo "configure:12273: checking for $ac_hdr" >&5
+echo "configure:12297: checking for $ac_hdr" >&5
-#line 12276 "configure"
+#line 12300 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12281: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12305: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12305,15 +12329,15 @@
 do
-echo "configure:12309: checking for $ac_hdr" >&5
+echo "configure:12333: checking for $ac_hdr" >&5
-#line 12312 "configure"
+#line 12336 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12317: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12341: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12341,15 +12365,15 @@
 do
-echo "configure:12345: checking for $ac_hdr" >&5
+echo "configure:12369: checking for $ac_hdr" >&5
-#line 12348 "configure"
+#line 12372 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12353: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12377: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12395,7 +12419,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12399: checking for location of FFTW library" >&5
+echo "configure:12423: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12420,13 +12444,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12424: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12448: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12430 "configure"
+#line 12454 "configure"
@@ -12437,7 +12461,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12462,13 +12486,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12466: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12490: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12472 "configure"
+#line 12496 "configure"
@@ -12479,7 +12503,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12504,13 +12528,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12508: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12532: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12514 "configure"
+#line 12538 "configure"
@@ -12521,7 +12545,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12578,7 +12602,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12582: checking whether to use BLAS" >&5
+echo "configure:12606: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12599,7 +12623,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12603: checking for location of BLAS includes" >&5
+echo "configure:12627: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12619,7 +12643,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12623: checking for location of BLAS library" >&5
+echo "configure:12647: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12645,15 +12669,15 @@
 do
-echo "configure:12649: checking for $ac_hdr" >&5
+echo "configure:12673: checking for $ac_hdr" >&5
-#line 12652 "configure"
+#line 12676 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12657: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12688,13 +12712,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12692: checking for dnrm2_ in -lblas" >&5
+echo "configure:12716: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12698 "configure"
+#line 12722 "configure"
@@ -12705,7 +12729,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12724,13 +12748,13 @@
-echo "configure:12728: checking for dnrm2_ in -lblas" >&5
+echo "configure:12752: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12734 "configure"
+#line 12758 "configure"
@@ -12741,7 +12765,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12785,13 +12809,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12789: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12813: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12795 "configure"
+#line 12819 "configure"
@@ -12802,7 +12826,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12817,13 +12841,13 @@
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12821: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12845: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12827 "configure"
+#line 12851 "configure"
@@ -12834,7 +12858,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12849,13 +12873,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12853: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12877: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12859 "configure"
+#line 12883 "configure"
@@ -12866,7 +12890,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12911,16 +12935,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12915: checking for sgemm in $vlib_flags" >&5
+echo "configure:12939: checking for sgemm in $vlib_flags" >&5
-#line 12917 "configure"
+#line 12941 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12938,13 +12962,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12942: checking for sgemm_ in -lblas" >&5
+echo "configure:12966: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 12948 "configure"
+#line 12972 "configure"
@@ -12955,7 +12979,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12970,13 +12994,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12974: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12998: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12980 "configure"
+#line 13004 "configure"
@@ -12987,7 +13011,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13002,13 +13026,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13006: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13030: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13012 "configure"
+#line 13036 "configure"
@@ -13019,7 +13043,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13053,13 +13077,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13057: checking for acosp in -lsunmath" >&5
+echo "configure:13081: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13063 "configure"
+#line 13087 "configure"
@@ -13070,7 +13094,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13085,13 +13109,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13089: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13113: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13095 "configure"
+#line 13119 "configure"
@@ -13102,7 +13126,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13132,13 +13156,13 @@
 # Generic BLAS library
-echo "configure:13136: checking for sgemm_ in -lblas" >&5
+echo "configure:13160: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13142 "configure"
+#line 13166 "configure"
@@ -13149,7 +13173,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13188,7 +13212,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13192: checking whether to use LAPACK" >&5
+echo "configure:13216: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13213,7 +13237,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13217: checking for location of LAPACK includes" >&5
+echo "configure:13241: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13233,7 +13257,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13237: checking for location of LAPACK library" >&5
+echo "configure:13261: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13259,15 +13283,15 @@
 do
-echo "configure:13263: checking for $ac_hdr" >&5
+echo "configure:13287: checking for $ac_hdr" >&5
-#line 13266 "configure"
+#line 13290 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13271: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13295: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13299,10 +13323,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13303: checking for dsegv_" >&5
+echo "configure:13327: checking for dsegv_" >&5
-#line 13306 "configure"
+#line 13330 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13325,7 +13349,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13352,13 +13376,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13356: checking for desgv_ in -llapack" >&5
+echo "configure:13380: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13362 "configure"
+#line 13386 "configure"
@@ -13369,7 +13393,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13401,13 +13425,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13405: checking for dgesv_ in -llapack" >&5
+echo "configure:13429: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13411 "configure"
+#line 13435 "configure"
@@ -13418,7 +13442,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13437,13 +13461,13 @@
-echo "configure:13441: checking for dgesv_ in -llapack" >&5
+echo "configure:13465: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13447 "configure"
+#line 13471 "configure"
@@ -13454,7 +13478,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13510,7 +13534,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13514: checking whether to use Cairo" >&5
+echo "configure:13538: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13536,7 +13560,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13540: checking for location of cairo includes" >&5
+echo "configure:13564: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13562,15 +13586,15 @@
 do
-echo "configure:13566: checking for $ac_hdr" >&5
+echo "configure:13590: checking for $ac_hdr" >&5
-#line 13569 "configure"
+#line 13593 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13574: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13598: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13606,7 +13630,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13610: checking for location of cairo library" >&5
+echo "configure:13634: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13626,7 +13650,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13630: checking for cairo linking flags" >&5
+echo "configure:13654: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13642,10 +13666,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13646: checking for cairo_create" >&5
+echo "configure:13670: checking for cairo_create" >&5
-#line 13649 "configure"
+#line 13673 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13668,7 +13692,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13702,10 +13726,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:13706: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:13730: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 13709 "configure"
+#line 13733 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -13728,7 +13752,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -13761,10 +13785,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:13765: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:13789: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 13768 "configure"
+#line 13792 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -13787,7 +13811,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13815: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -13829,7 +13853,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13833: checking whether to use FreeType" >&5
+echo "configure:13857: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -13848,7 +13872,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13852: checking for location of FreeType includes" >&5
+echo "configure:13876: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13874,15 +13898,15 @@
 do
-echo "configure:13878: checking for $ac_hdr" >&5
+echo "configure:13902: checking for $ac_hdr" >&5
-#line 13881 "configure"
+#line 13905 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13886: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13910: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13916,7 +13940,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13920: checking for location of FreeType library" >&5
+echo "configure:13944: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13941,13 +13965,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13945: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13969: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 13951 "configure"
+#line 13975 "configure"
@@ -13958,7 +13982,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:13962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13999,7 +14023,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14003: checking whether to use NLS" >&5
+echo "configure:14027: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14019,10 +14043,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14023: checking for gettext" >&5
+echo "configure:14047: checking for gettext" >&5
-#line 14026 "configure"
+#line 14050 "configure"
     which can conflict with char gettext(); below.  */
@@ -14045,7 +14069,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14063,13 +14087,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14067: checking for gettext in -lintl" >&5
+echo "configure:14091: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14073 "configure"
+#line 14097 "configure"
@@ -14080,7 +14104,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14115,7 +14139,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14119: checking whether to use C++" >&5
+echo "configure:14143: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14131,7 +14155,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14135: checking for $ac_word" >&5
+echo "configure:14159: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14160,7 +14184,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14164: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14188: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14171,12 +14195,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14175 "configure"
+#line 14199 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14202,19 +14226,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14206: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14230: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14211: checking whether we are using GNU C++" >&5
+echo "configure:14235: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14218: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14242: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14232,7 +14256,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14236: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14260: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14273,7 +14297,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14277: checking whether to use openDWG" >&5
+echo "configure:14301: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14293,7 +14317,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14297: checking for location of openDGW includes" >&5
+echo "configure:14321: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14319,15 +14343,15 @@
 do
-echo "configure:14323: checking for $ac_hdr" >&5
+echo "configure:14347: checking for $ac_hdr" >&5
-#line 14326 "configure"
+#line 14350 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14331: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14355: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14361,7 +14385,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14365: checking for location of openDWG library" >&5
+echo "configure:14389: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14402,7 +14426,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:14406: checking whether to use POSIX threads" >&5
+echo "configure:14430: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -14422,7 +14446,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:14426: checking for location of POSIX threads includes" >&5
+echo "configure:14450: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -14448,15 +14472,15 @@
 do
-echo "configure:14452: checking for $ac_hdr" >&5
+echo "configure:14476: checking for $ac_hdr" >&5
-#line 14455 "configure"
+#line 14479 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14460: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14484: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14490,7 +14514,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:14494: checking for location of POSIX threads library" >&5
+echo "configure:14518: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -14515,10 +14539,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:14519: checking for pthread_create" >&5
+echo "configure:14543: checking for pthread_create" >&5
-#line 14522 "configure"
+#line 14546 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char pthread_create(); below.  */
@@ -14541,7 +14565,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -14568,13 +14592,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:14572: checking for pthread_create in -lpthread" >&5
+echo "configure:14596: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 14578 "configure"
+#line 14602 "configure"
@@ -14585,7 +14609,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:14589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14641,7 +14665,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14645: checking for special C compiler options needed for large files" >&5
+echo "configure:14669: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14649,7 +14673,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14653 "configure"
+#line 14677 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14665,7 +14689,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14669: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14693: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -14674,7 +14698,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14678 "configure"
+#line 14702 "configure"
@@ -14690,7 +14714,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14694: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14718: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14710,11 +14734,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14714: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14738: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14718 "configure"
+#line 14742 "configure"
@@ -14730,14 +14754,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14734: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14758: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14741 "configure"
+#line 14765 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14755,7 +14779,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14759: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14783: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14774,11 +14798,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14778: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14802: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14782 "configure"
+#line 14806 "configure"
@@ -14794,14 +14818,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14798: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14822: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14805 "configure"
+#line 14829 "configure"
 #define _LARGE_FILES 1
@@ -14819,7 +14843,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14823: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14847: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14838,25 +14862,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14842: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14866: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14846 "configure"
+#line 14870 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14853: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14877: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14860 "configure"
+#line 14884 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14865,7 +14889,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14869: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14893: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14886,10 +14910,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14890: checking if system supports Large Files at all" >&5
+echo "configure:14914: checking if system supports Large Files at all" >&5
-#line 14893 "configure"
+#line 14917 "configure"
 #include <stdio.h>
@@ -14921,7 +14945,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14925: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14949: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14950,7 +14974,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14954: checking whether to use Python" >&5
+echo "configure:14978: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -14970,7 +14994,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:14974: checking for $ac_word" >&5
+echo "configure:14998: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15012,15 +15036,15 @@
 do
-echo "configure:15016: checking for $ac_hdr" >&5
+echo "configure:15040: checking for $ac_hdr" >&5
-#line 15019 "configure"
+#line 15043 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15024: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15061,7 +15085,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15065: checking for $ac_word" >&5
+echo "configure:15089: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15107,7 +15131,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15111: checking whether to use wxWidgets" >&5
+echo "configure:15135: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15127,7 +15151,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15131: checking for $ac_word" >&5
+echo "configure:15155: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15175,7 +15199,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15179: checking wxWidgets version" >&5
+echo "configure:15203: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15198,15 +15222,15 @@
 do
-echo "configure:15202: checking for $ac_hdr" >&5
+echo "configure:15226: checking for $ac_hdr" >&5
-#line 15205 "configure"
+#line 15229 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15210: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15234: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15458,10 +15482,6 @@
 s%@PNGINC@%$PNGINC%g
 s%@PNGLIB@%$PNGLIB%g
 s%@USE_PNG@%$USE_PNG%g
-s%@TCLINCDIR@%$TCLINCDIR%g
-s%@TKINCDIR@%$TKINCDIR%g
-s%@TCLTKLIBPATH@%$TCLTKLIBPATH%g
-s%@TCLTKLIBS@%$TCLTKLIBS%g
 s%@USE_POSTGRES@%$USE_POSTGRES%g
 s%@PQINCPATH@%$PQINCPATH%g
 s%@PQLIBPATH@%$PQLIBPATH%g
@@ -15487,6 +15507,11 @@
 s%@OPENGLINC@%$OPENGLINC%g
 s%@OPENGLLIB@%$OPENGLLIB%g
 s%@OPENGLULIB@%$OPENGLULIB%g
+s%@TCLINCDIR@%$TCLINCDIR%g
+s%@TKINCDIR@%$TKINCDIR%g
+s%@TCLTKLIBPATH@%$TCLTKLIBPATH%g
+s%@TCLTKLIBS@%$TCLTKLIBS%g
+s%@TCLTKAQUA_IS64BIT@%$TCLTKAQUA_IS64BIT%g
 s%@ODBCINC@%$ODBCINC%g
 s%@ODBCLIB@%$ODBCLIB%g
 s%@FFTWINC@%$FFTWINC%g
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2009-05-25 17:55:59 UTC (rev 37488)
+++ grass/trunk/configure.in	2009-05-25 17:56:01 UTC (rev 37489)
@@ -828,75 +828,6 @@
 # Done checking PNG
-# Enable TCLTK option
-LOC_CHECK_USE(tcltk,Tcl/Tk,USE_TCLTK)
-TCLINCDIR=
-TCLTKLIBPATH=
-TCLTKLIBS=
-if test -n "$USE_TCLTK"; then
-# With Tcl/Tk includes directory
-LOC_CHECK_INC_PATH(tcltk,Tcl/Tk,TCLINCDIR)
-LOC_CHECK_INCLUDES(tcl.h,Tcl,$TCLINCDIR)
-LOC_CHECK_INCLUDES(tk.h,Tk,$TCLINCDIR $X_CFLAGS)
-# Tcl/Tk version checks
-LOC_CHECK_VERSION_STRING(tcl.h,TCL_VERSION,Tcl,tcl_ver,$TCLINCDIR,UNKNOWN)
-LOC_CHECK_VERSION_STRING(tk.h,TK_VERSION,Tk,tk_ver,$TCLINCDIR $X_CFLAGS,UNKNOWN)
-if test "$tcl_ver" = "$tk_ver" ; then
-    tcltk_ver=$tcl_ver
-else
-    AC_MSG_ERROR([*** Tcl/Tk version mismatch.])
-fi
-# FreeBSD and CygWin don't have a "dot" between major/minor version number
-tcltk_ver2=`echo $tcltk_ver | sed 's/\.//g'`
-# With Tcl/Tk library directory
-LOC_CHECK_LIB_PATH(tcltk,Tcl/Tk,TCLTKLIBPATH)
-TCLLIB=
-TKLIB=
-LOC_CHECK_LIBS(tcl,           Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
-LOC_CHECK_LIBS(tcl$tcltk_ver, Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
-LOC_CHECK_LIBS(tcl$tcltk_ver2,Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
-],$DLLIB)
-],$DLLIB)
-],$DLLIB)
-LOC_CHECK_LIBS(tk,           Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
-LOC_CHECK_LIBS(tk$tcltk_ver, Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
-LOC_CHECK_LIBS(tk$tcltk_ver2,Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
-],$X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS)
-TCLTKLIBS="$TKLIB $TCLLIB"
-AC_DEFINE(HAVE_TCLTK)
-fi # $USE_TCLTK
-TKINCDIR=$TCLINCDIR
-AC_SUBST(TCLINCDIR)
-AC_SUBST(TKINCDIR)
-AC_SUBST(TCLTKLIBPATH)
-AC_SUBST(TCLTKLIBS)
-# Done checking Tcl/Tk
 # Enable PostgreSQL option
 LOC_CHECK_USE(postgres,PostgreSQL,USE_POSTGRES)
@@ -1083,7 +1014,6 @@
 # Done checking FFMPEG
 # Enable OpenGL option
 OPENGLINC=
@@ -1202,6 +1132,100 @@
+LOC_CHECK_USE(tcltk,Tcl/Tk,USE_TCLTK)
+TCLINCDIR=
+TCLTKLIBPATH=
+TCLTKLIBS=
+LOC_CHECK_INC_PATH(tcltk,Tcl/Tk,TCLINCDIR)
+LOC_CHECK_INCLUDES(tcl.h,Tcl,$TCLINCDIR)
+LOC_CHECK_INCLUDES(tk.h,Tk,$TCLINCDIR $X_CFLAGS)
+LOC_CHECK_VERSION_STRING(tcl.h,TCL_VERSION,Tcl,tcl_ver,$TCLINCDIR,UNKNOWN)
+LOC_CHECK_VERSION_STRING(tk.h,TK_VERSION,Tk,tk_ver,$TCLINCDIR $X_CFLAGS,UNKNOWN)
+else
+    AC_MSG_ERROR([*** Tcl/Tk version mismatch.])
+fi
+LOC_CHECK_LIB_PATH(tcltk,Tcl/Tk,TCLTKLIBPATH)
+TCLLIB=
+TKLIB=
+TCLTKAQUA_IS64BIT=
+    temp_ARCHES=
+    do
+        fi
+    done
+fi
+LOC_CHECK_LIBS(tcl,           Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
+LOC_CHECK_LIBS(tcl$tcltk_ver, Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
+LOC_CHECK_LIBS(tcl$tcltk_ver2,Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
+],$DLLIB)
+],$DLLIB)
+],$DLLIB)
+LOC_CHECK_LIBS(tk,           Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
+LOC_CHECK_LIBS(tk$tcltk_ver, Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
+LOC_CHECK_LIBS(tk$tcltk_ver2,Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
+],$X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS)
+fi
+AC_DEFINE(HAVE_TCLTK)
+fi # $USE_TCLTK
+AC_SUBST(TCLINCDIR)
+AC_SUBST(TKINCDIR)
+AC_SUBST(TCLTKLIBPATH)
+AC_SUBST(TCLTKLIBS)
+AC_SUBST(TCLTKAQUA_IS64BIT)
 LOC_CHECK_USE(odbc,ODBC,USE_ODBC)
Modified: grass/trunk/display/d.what.vect/Makefile
--- grass/trunk/display/d.what.vect/Makefile	2009-05-25 17:55:59 UTC (rev 37488)
+++ grass/trunk/display/d.what.vect/Makefile	2009-05-25 17:56:01 UTC (rev 37489)
@@ -12,6 +12,13 @@
 include $(MODULE_TOPDIR)/include/Make/Module.make
+ifeq ($(OPENGL_AQUA),1)
+ifneq ($(TCLTKAQUA_IS64BIT),1)
+CFLAGS := $(subst -arch ppc64,,$(subst -arch x86_64,,$(CFLAGS)))
+LDFLAGS := $(subst -arch ppc64,,$(subst -arch x86_64,,$(LDFLAGS)))
+endif
+endif
 default: cmd
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in	2009-05-25 17:55:59 UTC (rev 37488)
+++ grass/trunk/include/Make/Platform.make.in	2009-05-25 17:56:01 UTC (rev 37489)
@@ -173,6 +173,8 @@
 TCLTKLIBPATH        = @TCLTKLIBPATH@
 TCLTKLIBS           = @TCLTKLIBS@
 USE_TCLTK           = @USE_TCLTK@
+# set from configure when 64bit TclTk Aqua becomes possible on OSX
+TCLTKAQUA_IS64BIT    = @TCLTKAQUA_IS64BIT@
 #FFTW:
 FFTWINC             = @FFTWINC@
Modified: grass/trunk/lib/form/Makefile
--- grass/trunk/lib/form/Makefile	2009-05-25 17:55:59 UTC (rev 37488)
+++ grass/trunk/lib/form/Makefile	2009-05-25 17:56:01 UTC (rev 37489)
@@ -20,6 +20,13 @@
     GTCLTKFORM = $(HTMLLIB) $(FORM) $(FORMPROG)
 endif
+endif
+endif
 default: lib $(GTCLTKFORM)
 $(FORMDIR):
Modified: grass/trunk/visualization/nviz/src/Makefile
--- grass/trunk/visualization/nviz/src/Makefile	2009-05-25 17:55:59 UTC (rev 37488)
+++ grass/trunk/visualization/nviz/src/Makefile	2009-05-25 17:56:01 UTC (rev 37489)
@@ -19,7 +19,11 @@
 endif
 OGL_LIBS := $(OPENGLULIB) $(OPENGLLIB) $(MATHLIB)
 endif
+endif
 SURFLIB = $(OGSFLIB)
