[GRASS-SVN] r37514 - grass/branches/develbranch_6/lib/python
svn_grass at osgeo.org
Tue May 26 12:58:03 EDT 2009
Author: martinl
Date: 2009-05-26 12:58:03 -0400 (Tue, 26 May 2009)
New Revision: 37514
grass/branches/develbranch_6/lib/python/grasspythonlib.dox
grass/branches/develbranch_6/lib/python/vector.py
grass.script.vector: vector_db_select() added
(merge from trunk, r37511)
Modified: grass/branches/develbranch_6/lib/python/grasspythonlib.dox
--- grass/branches/develbranch_6/lib/python/grasspythonlib.dox 2009-05-26 16:57:52 UTC (rev 37513)
+++ grass/branches/develbranch_6/lib/python/grasspythonlib.dox 2009-05-26 16:58:03 UTC (rev 37514)
@@ -227,6 +227,8 @@
- vector_db()
+ - vector_db_select()
- vector_history()
- vector_info_topo()
Modified: grass/branches/develbranch_6/lib/python/vector.py
--- grass/branches/develbranch_6/lib/python/vector.py 2009-05-26 16:57:52 UTC (rev 37513)
+++ grass/branches/develbranch_6/lib/python/vector.py 2009-05-26 16:58:03 UTC (rev 37514)
@@ -123,3 +123,58 @@
s = read_command('v.info', flags = 't', map = map)
return parse_key_val(s, val_type = int)
+# interface for v.db.select
+def vector_db_select(map, layer = 1, **kwargs):
+ """Get attribute data of selected vector map layer.
+ Function returns list of columns and dictionary of values ordered by
+ key column value. Example:
+ \code
+ >>> print grass.vector_select('lakes')['values'][3]
+ ['3', '19512.86146', '708.44683', '4', '55652', 'LAKE/POND', '39000', '']
+ \endcode
+ @param map map name
+ @param layer layer number
+ @param kwargs v.db.select options
+ @return dictionary ('columns' and 'values')
+ try:
+ key = vector_db(map = map)[layer]['key']
+ except KeyError:
+ error('Missing layer %d in vector map <%s>' % (layer, map))
+ return { 'columns' : [], 'values' : {} }
+ if kwargs.has_key('columns'):
+ if key not in kwargs['columns'].split(','):
+ # add key column if missing
+ info("Adding key column to the output")
+ kwargs['columns'] += ',' + key
+ ret = read_command('v.db.select',
+ map = map,
+ layer = layer,
+ fs = '|', **kwargs)
+ if not ret:
+ error('vector_select() failed')
+ columns = []
+ values = {}
+ for line in ret.splitlines():
+ if not columns:
+ columns = line.split('|')
+ key_index = columns.index(key)
+ continue
+ value = line.split('|')
+ key_value = int(value[key_index])
+ values[key_value] = line.split('|')
+ return { 'columns' : columns,
+ 'values' : values }
