[GRASS-SVN] r37540 - in grass/trunk/gui/wxpython: . compat
gui_modules icons support
svn_grass at osgeo.org
Wed May 27 15:58:36 EDT 2009
Author: martinl
Date: 2009-05-27 15:58:35 -0400 (Wed, 27 May 2009)
New Revision: 37540
grass/trunk/gui/wxpython/build_ext.py
grass/trunk/gui/wxpython/compat/subprocess.py
grass/trunk/gui/wxpython/gis_set.py
grass/trunk/gui/wxpython/gui_modules/colorrules.py
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py
grass/trunk/gui/wxpython/gui_modules/debug.py
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
grass/trunk/gui/wxpython/gui_modules/georect.py
grass/trunk/gui/wxpython/gui_modules/globalvar.py
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/gui/wxpython/gui_modules/histogram.py
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/gui/wxpython/gui_modules/ogc_services.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/profile.py
grass/trunk/gui/wxpython/gui_modules/prompt.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/gui_modules/utils.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
grass/trunk/gui/wxpython/gui_modules/workspace.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
grass/trunk/gui/wxpython/icons/icon.py
grass/trunk/gui/wxpython/support/update_menu_desc.py
grass/trunk/gui/wxpython/wxgui.py
parse docstrings by doxygen
Modified: grass/trunk/gui/wxpython/build_ext.py
--- grass/trunk/gui/wxpython/build_ext.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/build_ext.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -4,7 +4,7 @@
import sys
def __read_variables(file, dict={}):
- """Read variables from file (e.g. Platform.make)
+ """!Read variables from file (e.g. Platform.make)
@param file file descriptor
@param dict dictionary to store (variable, value)
@@ -22,7 +22,7 @@
dict[var.strip()] = val.strip()
def update_opts(flag, macros, inc_dirs, lib_dirs, libs, extras):
- """Update Extension options"""
+ """!Update Extension options"""
global variables
line = variables[flag]
fw_next = False
Modified: grass/trunk/gui/wxpython/compat/subprocess.py
--- grass/trunk/gui/wxpython/compat/subprocess.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/compat/subprocess.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -9,7 +9,7 @@
# Licensed to PSF under a Contributor Agreement.
# See http://www.python.org/2.4/license for licensing details.
-r"""subprocess - Subprocesses with accessible I/O streams
+r"""!subprocess - Subprocesses with accessible I/O streams
This module allows you to spawn processes, connect to their
input/output/error pipes, and obtain their return codes. This module
@@ -402,7 +402,7 @@
def call(*args, **kwargs):
- """Run command with arguments. Wait for command to complete, then
+ """!Run command with arguments. Wait for command to complete, then
return the returncode attribute.
The arguments are the same as for the Popen constructor. Example:
@@ -486,7 +486,7 @@
preexec_fn=None, close_fds=False, shell=False,
cwd=None, env=None, universal_newlines=False,
startupinfo=None, creationflags=0):
- """Create new Popen instance."""
+ """!Create new Popen instance."""
_cleanup()
if not isinstance(bufsize, (int, long)):
@@ -568,7 +568,7 @@
# Windows methods
def _get_handles(self, stdin, stdout, stderr):
- """Construct and return tupel with IO objects:
+ """!Construct and return tupel with IO objects:
p2cread, p2cwrite, c2pread, c2pwrite, errread, errwrite
if stdin == None and stdout == None and stderr == None:
@@ -628,14 +628,14 @@
def _make_inheritable(self, handle):
- """Return a duplicate of handle, which is inheritable"""
+ """!Return a duplicate of handle, which is inheritable"""
return DuplicateHandle(GetCurrentProcess(), handle,
GetCurrentProcess(), 0, 1,
DUPLICATE_SAME_ACCESS)
def _find_w9xpopen(self):
- """Find and return absolut path to w9xpopen.exe"""
+ """!Find and return absolut path to w9xpopen.exe"""
w9xpopen = os.path.join(os.path.dirname(GetModuleFileName(0)),
"w9xpopen.exe")
if not os.path.exists(w9xpopen):
@@ -656,7 +656,7 @@
p2cread, p2cwrite,
c2pread, c2pwrite,
errread, errwrite):
- """Execute program (MS Windows version)"""
+ """!Execute program (MS Windows version)"""
if not isinstance(args, types.StringTypes):
args = list2cmdline(args)
@@ -731,7 +731,7 @@
def poll(self):
- """Check if child process has terminated. Returns returncode
+ """!Check if child process has terminated. Returns returncode
attribute."""
if self.returncode == None:
if WaitForSingleObject(self._handle, 0) == WAIT_OBJECT_0:
@@ -741,7 +741,7 @@
def wait(self):
- """Wait for child process to terminate. Returns returncode
+ """!Wait for child process to terminate. Returns returncode
attribute."""
obj = WaitForSingleObject(self._handle, INFINITE)
@@ -755,7 +755,7 @@
def communicate(self, input=None):
- """Interact with process: Send data to stdin. Read data from
+ """!Interact with process: Send data to stdin. Read data from
stdout and stderr, until end-of-file is reached. Wait for
process to terminate. The optional input argument should be a
string to be sent to the child process, or None, if no data
@@ -812,7 +812,7 @@
# POSIX methods
p2cread, p2cwrite = None, None
@@ -882,7 +882,7 @@
p2cread, p2cwrite,
c2pread, c2pwrite,
errread, errwrite):
- """Execute program (POSIX version)"""
+ """!Execute program (POSIX version)"""
if isinstance(args, types.StringTypes):
args = [args]
@@ -988,7 +988,7 @@
def poll(self):
attribute."""
try:
@@ -1001,7 +1001,7 @@
def wait(self):
attribute."""
pid, sts = os.waitpid(self.pid, 0)
@@ -1010,7 +1010,7 @@
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gis_set.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -41,7 +41,7 @@
import wx.lib.mixins.listctrl as listmix
class GRASSStartup(wx.Frame):
- """GRASS start-up screen"""
+ """!GRASS start-up screen"""
def __init__(self, parent=None, id=wx.ID_ANY, style=wx.DEFAULT_FRAME_STYLE):
@@ -168,7 +168,7 @@
self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
def _set_properties(self):
- """Set frame properties"""
+ """!Set frame properties"""
self.SetTitle(_("Welcome to GRASS GIS"))
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, "grass.ico"),
wx.BITMAP_TYPE_ICO))
@@ -384,7 +384,7 @@
return None
def OnWizard(self, event):
- """Location wizard started"""
+ """!Location wizard started"""
from gui_modules import location_wizard
gWizard = location_wizard.LocationWizard(self, self.tgisdbase.GetValue())
if gWizard.location != None:
@@ -511,7 +511,7 @@
dlg.Destroy()
def UpdateLocations(self, dbase):
- """Update list of locations"""
+ """!Update list of locations"""
self.listOfLocations = []
for location in glob.glob(os.path.join(dbase, "*")):
@@ -534,7 +534,7 @@
return self.listOfLocations
def UpdateMapsets(self, location):
- """Update list of mapsets"""
+ """!Update list of mapsets"""
self.FormerMapsetSelection = wx.NOT_FOUND # for non-selectable item
self.listOfMapsets = []
@@ -591,7 +591,7 @@
return self.listOfMapsets
def OnSelectLocation(self, event):
- """Location selected"""
+ """!Location selected"""
if event:
self.lblocations.SetSelection(event.GetIndex())
@@ -633,7 +633,7 @@
self.manageloc.Enable(False)
def OnSelectMapset(self, event):
- """Mapset selected"""
+ """!Mapset selected"""
self.lbmapsets.SetSelection(event.GetIndex())
if event.GetText() not in self.listOfMapsetsSelectable:
@@ -643,7 +643,7 @@
event.Skip()
def OnSetDatabase(self, event):
- """Database set"""
+ """!Database set"""
self.gisdbase = self.tgisdbase.GetValue()
self.UpdateLocations(self.gisdbase)
@@ -664,7 +664,7 @@
dlg.Destroy()
def OnCreateMapset(self,event):
- """Create new mapset"""
+ """!Create new mapset"""
location = self.listOfLocations[self.lblocations.GetSelection()]
@@ -725,12 +725,12 @@
event.Skip()
def OnCloseWindow(self, event):
- """Close window event"""
+ """!Close window event"""
event.Skip()
sys.exit(2)
class HelpWindow(wx.Frame):
- """GRASS Quickstart help window"""
+ """!GRASS Quickstart help window"""
def __init__(self, parent, id, title, size, file):
wx.Frame.__init__(self, parent=parent, id=id, title=title, size=size)
@@ -755,7 +755,7 @@
self.Layout()
class GListBox(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin):
- """Use wx.ListCtrl instead of wx.ListBox, different style for
+ """!Use wx.ListCtrl instead of wx.ListBox, different style for
non-selectable items (e.g. mapsets with denied permission)"""
def __init__(self, parent, id, size,
choices, disabled=[]):
@@ -808,7 +808,7 @@
return self.selected
class StartUp(wx.App):
- """Start-up application"""
+ """!Start-up application"""
def OnInit(self):
wx.InitAllImageHandlers()
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -296,12 +296,12 @@
return cr_panel
def OnAddRules(self, event):
- """Add rules button pressed"""
+ """!Add rules button pressed"""
nrules = self.numRules.GetValue()
self.AddRules(nrules)
def AddRules(self, nrules):
- """Add rules"""
+ """!Add rules"""
snum = len(self.ruleslines.keys())
for num in range(snum, snum+nrules):
# enable
@@ -422,7 +422,7 @@
self.vect['rgb'] = event.GetString()
def OnRuleEnable(self, event):
- """Rule enabled/disabled"""
+ """!Rule enabled/disabled"""
id = event.GetId()
if event.IsChecked():
@@ -439,7 +439,7 @@
del self.ruleslines[id]
def OnRuleValue(self, event):
- """Rule value changed"""
+ """!Rule value changed"""
num = event.GetId()
vals = event.GetString().strip()
@@ -477,7 +477,7 @@
return
def OnRuleColor(self, event):
- """Rule color changed"""
+ """!Rule color changed"""
num = event.GetId()
rgba_color = event.GetValue()
@@ -512,7 +512,7 @@
self.Destroy()
def OnPreview(self, event):
- """Update preview"""
+ """!Update preview"""
# raster
if self.elem == 'cell':
cmdlist = ['d.rast',
@@ -563,14 +563,14 @@
map = self.inmap)
def OnHelp(self, event):
- """Show GRASS manual page"""
+ """!Show GRASS manual page"""
gcmd.RunCommand('g.manual',
quiet = True,
parent = self,
entry = self.cmd)
def CreateColorTable(self, force=False):
- """Creates color table"""
+ """!Creates color table"""
rulestxt = ''
for rule in self.ruleslines.itervalues():
@@ -613,7 +613,7 @@
input = gtemp)
class BufferedWindow(wx.Window):
- """A Buffered window class"""
+ """!A Buffered window class"""
pos = wx.DefaultPosition,
size = wx.DefaultSize,
@@ -654,7 +654,7 @@
self.Map.SetRegion()
def Draw(self, pdc, img=None, pdctype='image'):
- """Draws preview or clears window"""
+ """!Draws preview or clears window"""
pdc.BeginDrawing()
Debug.msg (3, "BufferedWindow.Draw(): pdctype=%s" % (pdctype))
@@ -678,7 +678,7 @@
self.Refresh()
def OnPaint(self, event):
- """Draw pseudo DC to buffer"""
+ """!Draw pseudo DC to buffer"""
self._Buffer = wx.EmptyBitmap(self.Map.width, self.Map.height)
dc = wx.BufferedPaintDC(self, self._Buffer)
@@ -699,7 +699,7 @@
self.pdc.DrawToDCClipped(dc, r)
def OnSize(self, event):
- """Init image size to match window size"""
+ """!Init image size to match window size"""
# set size of the input image
self.Map.width, self.Map.height = self.GetClientSize()
@@ -721,7 +721,7 @@
self.resize = True
def OnIdle(self, event):
- """Only re-render a preview image from GRASS during
+ """!Only re-render a preview image from GRASS during
idle time instead of multiple times during resizing.
if self.resize:
@@ -730,7 +730,7 @@
event.Skip()
def GetImage(self):
- """Converts files to wx.Image"""
+ """!Converts files to wx.Image"""
if self.Map.mapfile and os.path.isfile(self.Map.mapfile) and \
os.path.getsize(self.Map.mapfile):
img = wx.Image(self.Map.mapfile, wx.BITMAP_TYPE_ANY)
@@ -740,7 +740,7 @@
return img
def UpdatePreview(self, img=None):
- """Update canvas if window changes geometry"""
+ """!Update canvas if window changes geometry"""
Debug.msg (2, "BufferedWindow.UpdatePreview(%s): render=%s" % (img, self.render))
oldfont = ""
oldencoding = ""
@@ -767,6 +767,6 @@
self.resize = False
def EraseMap(self):
- """Erase preview"""
+ """!Erase preview"""
self.Draw(self.pdc, pdctype='clear')
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -57,7 +57,7 @@
from preferences import globalSettings as UserSettings
def unicodeValue(value):
- """Encode value"""
+ """!Encode value"""
enc = UserSettings.Get(group='atm', key='encoding', subkey='value')
if enc:
value = unicode(value, enc)
@@ -79,7 +79,7 @@
self.parent = parent
def write(self, text_string):
- """Update status bar"""
+ """!Update status bar"""
self.parent.SetStatusText(text_string.strip())
@@ -140,12 +140,12 @@
self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColumnClick) # sorting
def Update(self, mapDBInfo):
- """Update list according new mapDBInfo description"""
+ """!Update list according new mapDBInfo description"""
self.mapDBInfo = mapDBInfo
self.LoadData(self.layer)
def LoadData(self, layer, columns=None, where=None):
- """Load data into list
+ """!Load data into list
@param layer layer number
@param columns list of columns for output
@@ -317,7 +317,7 @@
return keyId
def OnItemSelected(self, event):
- """Item selected. Add item to selected cats..."""
+ """!Item selected. Add item to selected cats..."""
# cat = int(self.GetItemText(event.m_itemIndex))
# if cat not in self.selectedCats:
# self.selectedCats.append(cat)
@@ -326,7 +326,7 @@
event.Skip()
def OnItemDeselected(self, event):
- """Item deselected. Remove item from selected cats..."""
+ """!Item deselected. Remove item from selected cats..."""
# if cat in self.selectedCats:
# self.selectedCats.remove(cat)
@@ -335,7 +335,7 @@
event.Skip()
def GetSelectedItems(self):
- """Return list of selected items (category numbers)"""
+ """!Return list of selected items (category numbers)"""
cats = []
item = self.GetFirstSelected()
while item != -1:
@@ -345,22 +345,22 @@
return cats
def GetColumnText(self, index, col):
- """Return column text"""
+ """!Return column text"""
item = self.GetItem(index, col)
return item.GetText()
def GetListCtrl(self):
- """Returt list"""
+ """!Returt list"""
return self
def OnGetItemText(self, item, col):
- """Get item text"""
+ """!Get item text"""
index = self.itemIndexMap[item]
s = self.itemDataMap[index][col]
return s
def OnGetItemAttr(self, item):
- """Get item attributes"""
+ """!Get item attributes"""
if ( index % 2) == 0:
return self.attr2
@@ -368,7 +368,7 @@
return self.attr1
def OnColumnClick(self, event):
- """Column heading clicked -> sorting"""
+ """!Column heading clicked -> sorting"""
self._col = event.GetColumn()
# remove duplicated arrow symbol from column header
@@ -383,7 +383,7 @@
event.Skip()
def SortItems(self, sorter=cmp):
- """Sort items"""
+ """!Sort items"""
items = list(self.itemDataMap.keys())
items.sort(self.Sorter)
self.itemIndexMap = items
@@ -417,11 +417,11 @@
return -cmpVal
def GetSortImages(self):
- """Used by the ColumnSorterMixin, see wx/lib/mixins/listctrl.py"""
+ """!Used by the ColumnSorterMixin, see wx/lib/mixins/listctrl.py"""
return (self.sm_dn, self.sm_up)
def IsEmpty(self):
- """Check if list if empty"""
+ """!Check if list if empty"""
if self.columns:
return False
@@ -552,7 +552,7 @@
self.SetMinSize(self.GetSize())
def __createBrowsePage(self, onlyLayer=-1):
- """Create browse tab page"""
+ """!Create browse tab page"""
for layer in self.mapDBInfo.layers.keys():
if onlyLayer > 0 and layer != onlyLayer:
continue
@@ -694,7 +694,7 @@
self.layer = None
def __createManageTablePage(self, onlyLayer=-1):
- """Create manage page (create/link and alter tables)"""
+ """!Create manage page (create/link and alter tables)"""
continue
@@ -864,7 +864,7 @@
self.layer = None
def __createTableDesc(self, parent, table):
- """Create list with table description"""
+ """!Create list with table description"""
list = TableListCtrl(parent=parent, id=wx.ID_ANY,
table=self.mapDBInfo.tables[table],
columns=self.mapDBInfo.GetColumns(table))
@@ -876,7 +876,7 @@
return list
def __createManageLayerPage(self):
- """Create manage page"""
+ """!Create manage page"""
splitterWin = wx.SplitterWindow(parent=self.manageLayerPage, id=wx.ID_ANY)
splitterWin.SetMinimumPaneSize(100)
@@ -929,7 +929,7 @@
splitterWin.Fit()
def __createLayerDesc(self, parent):
- """Create list of linked layers"""
+ """!Create list of linked layers"""
list = LayerListCtrl(parent=parent, id=wx.ID_ANY,
layers=self.mapDBInfo.layers)
@@ -941,7 +941,7 @@
return list
def __layout(self):
- """Do layout"""
+ """!Do layout"""
# frame body
mainSizer = wx.BoxSizer(wx.VERTICAL)
@@ -961,7 +961,7 @@
self.Layout()
def OnDataRightUp(self, event):
- """Table description area, context menu"""
+ """!Table description area, context menu"""
if not hasattr(self, "popupDataID1"):
self.popupDataID1 = wx.NewId()
self.popupDataID2 = wx.NewId()
@@ -1023,7 +1023,7 @@
list.GetItemCount())
def OnDataItemDelete(self, event):
- """Delete selected item(s) from the list (layer/category pair)"""
+ """!Delete selected item(s) from the list (layer/category pair)"""
list = self.FindWindowById(self.layerPage[self.layer]['data'])
item = list.GetFirstSelected()
@@ -1087,7 +1087,7 @@
return True
def OnDataItemDeleteAll(self, event):
- """Delete all items from the list"""
+ """!Delete all items from the list"""
if UserSettings.Get(group='atm', key='askOnDeleteRec', subkey='enabled'):
deleteDialog = wx.MessageBox(parent=self,
@@ -1112,7 +1112,7 @@
event.Skip()
def _drawSelected(self, zoom):
- """Highlight selected features"""
+ """!Highlight selected features"""
if not self.map or not self.mapdisplay:
return
@@ -1177,7 +1177,7 @@
self.mapdisplay.MapWindow.UpdateMap(render=False, renderVector=True)
def OnDataDrawSelected(self, event):
- """Reload table description"""
+ """!Reload table description"""
self._drawSelected(zoom=False)
event.Skip()
@@ -1186,7 +1186,7 @@
event.Skip()
def OnDataItemAdd(self, event):
- """Add new record to the attribute table"""
+ """!Add new record to the attribute table"""
table = self.mapDBInfo.layers[self.layer]['table']
keyColumn = self.mapDBInfo.layers[self.layer]['key']
@@ -1299,7 +1299,7 @@
self.ApplyCommands()
def OnDataItemEdit(self, event):
- """Edit selected record of the attribute table"""
+ """!Edit selected record of the attribute table"""
if item == -1:
@@ -1395,12 +1395,12 @@
list.Update(self.mapDBInfo)
def OnDataReload(self, event):
- """Reload list of records"""
+ """!Reload list of records"""
self.OnApplySqlStatement(None)
self.listOfSQLStatements = []
def OnDataSelectAll(self, event):
- """Select all items"""
+ """!Select all items"""
item = -1
@@ -1413,7 +1413,7 @@
event.Skip()
def OnDataSelectNone(self, event):
- """Deselect items"""
+ """!Deselect items"""
item = -1
@@ -1427,7 +1427,7 @@
def OnTableChangeType(self, event):
- """Data type for new column changed. Enable or disable
+ """!Data type for new column changed. Enable or disable
data length widget"""
win = self.FindWindowById(self.layerPage[self.layer]['addColLength'])
if event.GetString() == "varchar":
@@ -1436,7 +1436,7 @@
win.Enable(False)
def OnTableRenameColumnName(self, event):
- """Editing column name to be added to the table"""
+ """!Editing column name to be added to the table"""
btn = self.FindWindowById(self.layerPage[self.layer]['renameColButton'])
col = self.FindWindowById(self.layerPage[self.layer]['renameCol'])
colTo = self.FindWindowById(self.layerPage[self.layer]['renameColTo'])
@@ -1448,7 +1448,7 @@
event.Skip()
def OnTableAddColumnName(self, event):
btn = self.FindWindowById(self.layerPage[self.layer]['addColButton'])
if len(event.GetString()) > 0:
btn.Enable(True)
@@ -1458,7 +1458,7 @@
event.Skip()
def OnTableItemChange(self, event):
- """Rename column in the table"""
+ """!Rename column in the table"""
list = self.FindWindowById(self.layerPage[self.layer]['tableData'])
name = self.FindWindowById(self.layerPage[self.layer]['renameCol']).GetValue()
nameTo = self.FindWindowById(self.layerPage[self.layer]['renameColTo']).GetValue()
@@ -1510,7 +1510,7 @@
event.Skip()
def OnTableRightUp(self, event):
if not hasattr(self, "popupTableID"):
self.popupTableID1 = wx.NewId()
self.popupTableID2 = wx.NewId()
@@ -1532,7 +1532,7 @@
menu.Destroy()
def OnTableItemDelete(self, event):
- """Delete selected item(s) from the list"""
+ """!Delete selected item(s) from the list"""
@@ -1556,7 +1556,7 @@
event.Skip()
def OnTableItemDeleteAll(self, event):
cols = self.mapDBInfo.GetColumns(table)
for col in cols:
@@ -1578,12 +1578,12 @@
event.Skip()
def OnTableReload(self, event=None):
self.FindWindowById(self.layerPage[self.layer]['tableData']).Populate(update=True)
self.listOfCommands = []
def OnTableItemAdd(self, event):
- """Add new column to the table"""
+ """!Add new column to the table"""
name = self.FindWindowById(self.layerPage[self.layer]['addColName']).GetValue()
@@ -1639,7 +1639,7 @@
event.Skip()
def OnLayerPageChanged(self, event):
- """Layer tab changed"""
+ """!Layer tab changed"""
pageNum = event.GetSelection()
self.layer = self.mapDBInfo.layers.keys()[pageNum]
@@ -1682,11 +1682,11 @@
event.Skip()
def OnLayerRightUp(self, event):
- """Layer description area, context menu"""
+ """!Layer description area, context menu"""
pass
def OnChangeSql(self, event):
- """Switch simple/advanced sql statement"""
+ """!Switch simple/advanced sql statement"""
if self.FindWindowById(self.layerPage[self.layer]['simple']).GetValue():
self.FindWindowById(self.layerPage[self.layer]['where']).Enable(True)
self.FindWindowById(self.layerPage[self.layer]['statement']).Enable(False)
@@ -1697,7 +1697,7 @@
self.FindWindowById(self.layerPage[self.layer]['builder']).Enable(True)
def ApplyCommands(self):
- """Apply changes"""
+ """!Apply changes"""
# perform GRASS commands (e.g. v.db.addcol)
if len(self.listOfCommands) > 0:
for cmd in self.listOfCommands:
@@ -1753,7 +1753,7 @@
def OnApplySqlStatement(self, event):
- """Apply simple/advanced sql statement"""
+ """!Apply simple/advanced sql statement"""
keyColumn = -1 # index of key column
listWin = self.FindWindowById(self.layerPage[self.layer]['data'])
@@ -1805,7 +1805,7 @@
self.FindWindowById(self.layerPage[self.layer]['data']).GetItemCount())
def ValidateSelectStatement(self, statement):
- """Validate SQL select statement
+ """!Validate SQL select statement
@return (columns, where)
@return None on error
@@ -1844,7 +1844,7 @@
return (cols, where)
def __createDbInfoDesc(self, panel, layer):
- """Create database connection information content"""
+ """!Create database connection information content"""
infoFlexSizer = wx.FlexGridSizer (cols=2, hgap=1, vgap=1)
infoFlexSizer.AddGrowableCol(1)
@@ -1868,12 +1868,12 @@
return infoFlexSizer
- """Cancel button pressed"""
+ """!Cancel button pressed"""
self.Close()
event.Skip()
def OnBuilder(self,event):
- """SQL Builder button pressed"""
+ """!SQL Builder button pressed"""
self.builder = sqlbuilder.SQLFrame(parent=self, id=wx.ID_ANY,
title=_("SQL Builder"),
vectorName=self.vectorName)
@@ -1884,7 +1884,7 @@
pass
def OnDataItemActivated(self, event):
- """Item activated, highlight selected item"""
+ """!Item activated, highlight selected item"""
self.OnDataDrawSelected(event)
event.Skip()
@@ -1939,7 +1939,7 @@
self.mapdisplay.MapWindow.UpdateMap(render=True, renderVector=True)
def AddQueryMapLayer(self):
- """Redraw a map
+ """!Redraw a map
Return True if map has been redrawn, False if no map is given
@@ -1959,7 +1959,7 @@
return self.qlayer
def UpdateDialog(self, layer):
- """Updates dialog layout for given layer"""
+ """!Updates dialog layout for given layer"""
# delete page
@@ -2018,7 +2018,7 @@
class TableListCtrl(wx.ListCtrl,
# listmix.TextEditMixin):
- """Table description list"""
+ """!Table description list"""
def __init__(self, parent, id, table, columns, pos=wx.DefaultPosition,
size=wx.DefaultSize):
@@ -2034,12 +2034,12 @@
# listmix.TextEditMixin.__init__(self)
def Update(self, table, columns):
- """Update column description"""
+ """!Update column description"""
self.table = table
self.columns = columns
def Populate(self, update=False):
- """Populate the list"""
+ """!Populate the list"""
itemData = {} # requested by sorter
if not update:
@@ -2072,7 +2072,7 @@
# listmix.ColumnSorterMixin):
- """Layer description list"""
+ """!Layer description list"""
def __init__(self, parent, id, layers,
@@ -2088,11 +2088,11 @@
def Update(self, layers):
- """Update description"""
+ """!Update description"""
self.layers = layers
if not update:
@@ -2134,7 +2134,7 @@
return itemData
class LayerBook(wx.Notebook):
- """Manage layers (add, delete, modify)"""
+ """!Manage layers (add, delete, modify)"""
parentDialog,
style=wx.BK_DEFAULT):
@@ -2188,7 +2188,7 @@
self.__createModifyPage()
def __createAddPage(self):
- """Add new layer"""
+ """!Add new layer"""
self.addPanel = wx.Panel(parent=self, id=wx.ID_ANY)
self.AddPage(page=self.addPanel, text=_("Add layer"))
@@ -2379,7 +2379,7 @@
pageSizer.Fit(self.addPanel)
def __createDeletePage(self):
- """Delete layer"""
+ """!Delete layer"""
self.deletePanel = wx.Panel(parent=self, id=wx.ID_ANY)
self.AddPage(page=self.deletePanel, text=_("Delete layer"))
@@ -2447,7 +2447,7 @@
self.deletePanel.SetSizer(pageSizer)
def __createModifyPage(self):
- """Modify layer"""
+ """!Modify layer"""
self.modifyPanel = wx.Panel(parent=self, id=wx.ID_ANY)
self.AddPage(page=self.modifyPanel, text=_("Modify layer"))
@@ -2557,7 +2557,7 @@
self.modifyPanel.SetSizer(pageSizer)
def __getTables(self, driver, database):
- """Get list of tables for given driver and database"""
+ """!Get list of tables for given driver and database"""
tables = []
ret = gcmd.RunCommand('db.tables',
@@ -2581,7 +2581,7 @@
return tables
def __getColumns(self, driver, database, table):
- """Get list of column of given table"""
+ """!Get list of column of given table"""
columns = []
ret = gcmd.RunCommand('db.columns',
@@ -2601,7 +2601,7 @@
return columns
def OnDriverChanged(self, event):
- """Driver selection changed, update list of tables"""
+ """!Driver selection changed, update list of tables"""
driver = event.GetString()
database = self.addLayerWidgets['database'][1].GetValue()
@@ -2618,11 +2618,11 @@
event.Skip()
def OnDatabaseChanged(self, event):
- """Database selection changed, update list of tables"""
+ """!Database selection changed, update list of tables"""
event.Skip()
def OnTableChanged(self, event):
- """Table name changed, update list of columns"""
+ """!Table name changed, update list of columns"""
driver = self.addLayerWidgets['driver'][1].GetStringSelection()
table = event.GetString()
@@ -2635,7 +2635,7 @@
event.Skip()
def OnSetDefault(self, event):
- """Set default values"""
+ """!Set default values"""
table = self.addLayerWidgets['table'][1]
@@ -2659,7 +2659,7 @@
event.Skip()
def OnCreateTable(self, event):
- """Create new table (name and key column given)"""
+ """!Create new table (name and key column given)"""
table = self.tableWidgets['table'][1].GetValue()
@@ -2702,7 +2702,7 @@
event.Skip()
def OnAddLayer(self, event):
- """Add new layer to vector map"""
+ """!Add new layer to vector map"""
layer = int(self.addLayerWidgets['layer'][1].GetValue())
layerWin = self.addLayerWidgets['layer'][1]
@@ -2756,7 +2756,7 @@
self.modifyLayerWidgets[label][1].Enable()
def OnDeleteLayer(self, event):
try:
layer = int(self.deleteLayer.GetValue())
except:
@@ -2802,7 +2802,7 @@
event.Skip()
def OnChangeLayer(self, event):
- """Layer number of layer to be deleted is changed"""
+ """!Layer number of layer to be deleted is changed"""
try:
layer = int(event.GetString())
except:
@@ -2828,7 +2828,7 @@
event.Skip()
def OnModifyLayer(self, event):
- """Modify layer connection settings"""
+ """!Modify layer connection settings"""
layer = int(self.modifyLayerWidgets['layer'][1].GetStringSelection())
@@ -2870,13 +2870,13 @@
event.Skip()
class VectorDBInfo(gselect.VectorDBInfo):
- """Class providing information about attribute tables
+ """!Class providing information about attribute tables
linked to the vector map"""
def __init__(self, map):
gselect.VectorDBInfo.__init__(self, map)
def GetColumns(self, table):
- """Return list of columns names (based on their index)"""
+ """!Return list of columns names (based on their index)"""
try:
names = [''] * len(self.tables[table].keys())
except KeyError:
@@ -2888,7 +2888,7 @@
return names
def SelectByPoint(self, queryCoords, qdist):
- """Get attributes by coordinates (all available layers)
+ """!Get attributes by coordinates (all available layers)
Return line id or None if no line is found"""
line = None
@@ -2950,7 +2950,7 @@
return data
def SelectFromTable(self, layer, cols='*', where=None):
- """Select records from the table
+ """!Select records from the table
Return number of selected records, -1 on error
Modified: grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py
--- grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -166,15 +166,15 @@
### self.mapDBInfo = None
def __SelectAttributes(self, layer):
- """Select attributes"""
+ """!Select attributes"""
pass
def OnSQLStatement(self, event):
- """Update SQL statement"""
+ """!Update SQL statement"""
pass
def GetSQLString(self, updateValues=False):
- """Create SQL statement string based on self.sqlStatement
+ """!Create SQL statement string based on self.sqlStatement
If updateValues is True, update dataFrame according to values
in textfields.
@@ -248,7 +248,7 @@
return sqlCommands
def OnReset(self, event):
- """Reset form"""
+ """!Reset form"""
table = self.mapDBInfo.layers[layer]["table"]
key = self.mapDBInfo.layers[layer]["key"]
@@ -266,7 +266,7 @@
self.FindWindowById(id).SetValue(str(value))
def OnCancel(self, event):
self.parent.parent.dialogs['attributes'] = None
if self.parent.parent.digit:
self.parent.parent.digit.driver.SetSelected([])
@@ -277,7 +277,7 @@
self.Close()
def OnSubmit(self, event):
- """Submit records"""
+ """!Submit records"""
for sql in self.GetSQLString(updateValues=True):
if not enc and \
@@ -298,7 +298,7 @@
self.UpdateDialog(cats=self.cats, fid=self.fid)
def GetCats(self):
- """Get id of selected vector object or 'None' if nothing selected
+ """!Get id of selected vector object or 'None' if nothing selected
@param id if true return ids otherwise cats
@@ -308,11 +308,11 @@
return self.cats[self.fid]
def GetFid(self):
- """Get selected feature id"""
+ """!Get selected feature id"""
return self.fid
def UpdateDialog(self, map=None, query=None, cats=None, fid=-1):
- """Update dialog
+ """!Update dialog
Return True if updated otherwise False
@@ -485,7 +485,7 @@
return True
class ModifyTableRecord(wx.Dialog):
- """Dialog for inserting/updating table record"""
+ """!Dialog for inserting/updating table record"""
def __init__(self, parent, id, title, data, keyEditable=(-1, True),
style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
@@ -556,7 +556,7 @@
# self.SetMinSize(winSize)
def __Layout(self):
- """Do layout"""
+ """!Do layout"""
sizer = wx.BoxSizer(wx.VERTICAL)
# data area
@@ -629,7 +629,7 @@
def GetValues(self, columns=None):
- """Return list of values (casted to string).
+ """!Return list of values (casted to string).
If columns is given (list), return only values of given columns.
Modified: grass/trunk/gui/wxpython/gui_modules/debug.py
--- grass/trunk/gui/wxpython/gui_modules/debug.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/debug.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -53,7 +53,7 @@
print >> sys.stderr, "GUI D%d/%d: %s" % (level, self.debuglevel, message)
def get_level(self):
- """Return current GUI debug level"""
+ """!Return current GUI debug level"""
return self.debuglevel
# Debug instance
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -62,7 +62,7 @@
from debug import Debug as Debug
class GException(Exception):
- """Generic exception"""
+ """!Generic exception"""
def __init__(self, message, title=_("Error"), parent=None):
self.message = message
@@ -87,13 +87,13 @@
return ''
class GStdError(GException):
GException.__init__(self, message, title=title, parent=parent)
class CmdError(GException):
- """Exception used for GRASS commands.
+ """!Exception used for GRASS commands.
See Command class (command exits with EXIT_FAILURE,
G_fatal_error() is called)."""
@@ -103,7 +103,7 @@
parent=parent)
class SettingsError(GException):
- """Exception used for GRASS settings, see
+ """!Exception used for GRASS settings, see
gui_modules/preferences.py."""
def __init__(self, message, parent=None):
@@ -111,28 +111,28 @@
parent=parent)
class DigitError(GException):
- """Exception raised during digitization session"""
+ """!Exception raised during digitization session"""
title=_("Vector digitizer error"),
parent=parent)
class DBMError(GException):
- """Attribute Table Manager exception class"""
+ """!Attribute Table Manager exception class"""
title=_("Attribute table manager error"),
parent=parent)
class NvizError(GException):
- """Nviz exception class"""
+ """!Nviz exception class"""
title=_("Nviz error"),
parent=parent)
class Popen(subprocess.Popen):
- """Subclass subprocess.Popen"""
+ """!Subclass subprocess.Popen"""
def recv(self, maxsize=None):
return self._recv('stdout', maxsize)
@@ -154,7 +154,7 @@
setattr(self, which, None)
def kill(self):
- """Try to kill running process"""
+ """!Try to kill running process"""
if subprocess.mswindows:
import win32api
handle = win32api.OpenProcess(1, 0, self.pid)
@@ -279,7 +279,7 @@
data = buffer(data, sent)
class Command:
- """Run command in separate thread. Used for commands launched
+ """!Run command in separate thread. Used for commands launched
on the background.
If stdout/err is redirected, write() method is required for the
@@ -376,7 +376,7 @@
del os.environ["GRASS_VERBOSE"]
def __ReadOutput(self, stream):
- """Read stream and return list of lines
+ """!Read stream and return list of lines
@param stream stream to be read
@@ -395,7 +395,7 @@
return lineList
def __ReadErrOutput(self):
- """Read standard error output and return list of lines"""
+ """!Read standard error output and return list of lines"""
return self.__ReadOutput(self.cmdThread.module.stderr)
def __ProcessStdErr(self):
@@ -435,7 +435,7 @@
return msg
def __GetError(self):
- """Get error message or ''"""
+ """!Get error message or ''"""
if not self.cmdThread.module:
return _("Unable to exectute command: '%s'") % ' '.join(self.cmd)
@@ -446,7 +446,7 @@
return ''
class CommandThread(Thread):
- """Create separate thread for command. Used for commands launched
+ """!Create separate thread for command. Used for commands launched
on the background."""
def __init__ (self, cmd, stdin=None,
stdout=sys.stdout, stderr=sys.stderr):
@@ -489,7 +489,7 @@
del os.environ["GRASS_MESSAGE_FORMAT"]
def run(self):
- """Run command"""
+ """!Run command"""
if len(self.cmd) == 0:
return
@@ -513,7 +513,7 @@
self.__redirect_stream()
def __redirect_stream(self):
- """Redirect stream"""
+ """!Redirect stream"""
if self.stdout:
# make module stdout/stderr non-blocking
out_fileno = self.module.stdout.fileno()
@@ -554,12 +554,12 @@
self.error = line
def abort(self):
- """Abort running process, used by main thread to signal an abort"""
+ """!Abort running process, used by main thread to signal an abort"""
self._want_abort = True
def RunCommand(prog, flags = "", overwrite = False, quiet = False, verbose = False,
parent = None, read = False, stdin = None, **kwargs):
- """Run GRASS command"""
+ """!Run GRASS command"""
kwargs['stderr'] = subprocess.PIPE
if read:
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -41,7 +41,7 @@
class NewVectorDialog(wx.Dialog):
- """Create new vector map layer"""
+ """!Create new vector map layer"""
def __init__(self, parent, id, title, disableAdd=False,
@@ -79,14 +79,14 @@
def OnMapName(self, event):
- """Name for vector map layer given"""
+ """!Name for vector map layer given"""
self.btnOK.Enable(True)
else:
self.btnOK.Enable(False)
def __Layout(self):
- """Do layout"""
+ """!Do layout"""
dataSizer = wx.BoxSizer(wx.VERTICAL)
@@ -119,14 +119,14 @@
sizer.Fit(self)
def GetName(self):
- """Return (mapName, overwrite)"""
+ """!Return (mapName, overwrite)"""
mapName = self.mapName.GetValue().split('@', 1)[0]
return mapName
def CreateNewVector(parent, cmd, title=_('Create new vector map'),
exceptMap=None, log=None, disableAdd=False):
@cmd cmd (prog, **kwargs)
@@ -401,13 +401,13 @@
self.parent.MapWindow.overlays[self.ovlId]['propwin'].Show()
- """Cancel dialog"""
+ """!Cancel dialog"""
self.parent.dialogs['barscale'] = None
self.Destroy()
def OnOK(self, event):
- """Button 'OK' pressed"""
+ """!Button 'OK' pressed"""
# enable or disable overlay
self.parent.Map.GetOverlay(self.ovlId).SetActive(self.chkbox.IsChecked())
@@ -418,7 +418,7 @@
self.OnCancel(None)
def GetOptData(self, dcmd, layer, params, propwin):
- """Process decoration layer data"""
+ """!Process decoration layer data"""
# update layer data
if params:
self.parent.MapWindow.overlays[self.ovlId]['params'] = params
@@ -559,21 +559,21 @@
self.Bind(wx.EVT_SPINCTRL, self.OnRotation, self.rotation)
def OnRefit(self, event):
- """Resize text entry to match text"""
+ """!Resize text entry to match text"""
self.sizer.Fit(self)
def OnText(self, event):
- """Change text string"""
+ """!Change text string"""
self.currText = event.GetString()
def OnRotation(self, event):
- """Change rotation"""
+ """!Change rotation"""
self.currRot = event.GetInt()
event.Skip()
def OnSelectFont(self, event):
- """Change font"""
+ """!Change font"""
data = wx.FontData()
data.EnableEffects(True)
data.SetColour(self.currClr) # set colour
@@ -594,7 +594,7 @@
dlg.Destroy()
def GetValues(self):
- """Get text properties"""
+ """!Get text properties"""
return { 'text' : self.currText,
'font' : self.currFont,
'color' : self.currClr,
@@ -603,7 +603,7 @@
'active' : self.chkbox.IsChecked() }
class LoadMapLayersDialog(wx.Dialog):
- """Load selected map layers (raster, vector) into layer tree"""
+ """!Load selected map layers (raster, vector) into layer tree"""
def __init__(self, parent, title, style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=title, style=style)
@@ -713,7 +713,7 @@
return bodySizer
def LoadMapLayers(self, type, mapset):
- """Load list of map layers
+ """!Load list of map layers
@param type layer type ('raster' or 'vector')
@param mapset mapset name
@@ -730,7 +730,7 @@
self.layers.Check(item)
def OnChangeParams(self, event):
- """Filter parameters changed by user"""
+ """!Filter parameters changed by user"""
# update list of layer to be loaded
self.LoadMapLayers(self.layerType.GetStringSelection()[:4],
self.mapset.GetStringSelection())
@@ -738,7 +738,7 @@
event.Skip()
def OnMenu(self, event):
if not hasattr(self, "popupID1"):
@@ -758,12 +758,12 @@
menu.Destroy()
def OnSelectAll(self, event):
- """Select all map layer from list"""
+ """!Select all map layer from list"""
for item in range(self.layers.GetCount()):
self.layers.Check(item, True)
def OnSelectInvert(self, event):
- """Invert current selection"""
+ """!Invert current selection"""
if self.layers.IsChecked(item):
self.layers.Check(item, False)
@@ -771,12 +771,12 @@
def OnDeselectAll(self, event):
def OnFilter(self, event):
- """Apply filter for map names"""
+ """!Apply filter for map names"""
if len(event.GetString()) == 0:
self.layers.Set(self.map_layers)
return
@@ -795,7 +795,7 @@
event.Skip()
def OnToggle(self, event):
- """Select toggle (check or uncheck all layers)"""
+ """!Select toggle (check or uncheck all layers)"""
check = event.Checked()
self.layers.Check(item, check)
@@ -803,7 +803,7 @@
event.Skip()
def GetMapLayers(self):
- """Return list of checked map layers"""
+ """!Return list of checked map layers"""
layerNames = []
for indx in self.layers.GetSelections():
# layers.append(self.layers.GetStringSelec(indx))
@@ -819,11 +819,11 @@
return layerNames
def GetLayerType(self):
- """Get selected layer type"""
+ """!Get selected layer type"""
return self.layerType.GetStringSelection()
class MultiImportDialog(wx.Dialog):
- """Import dxf layers"""
+ """!Import dxf layers"""
def __init__(self, parent, type,
id=wx.ID_ANY, title=_("Multiple import"),
@@ -970,11 +970,11 @@
self.list.SetColumnWidth(col=1, width=width/2 - 50)
def OnCancel(self, event=None):
- """Close dialog"""
+ """!Close dialog"""
self.Close()
def OnRun(self, event):
- """Import data (each layes as separate vector map)"""
+ """!Import data (each layes as separate vector map)"""
data = self.list.GetLayers()
# hide dialog
@@ -1029,14 +1029,14 @@
self.OnCancel()
def OnAbort(self, event):
- """Abort running import
+ """!Abort running import
@todo not yet implemented
pass
def OnSetInput(self, event):
- """Input DXF file/OGR dsn defined, update list of layer widget"""
+ """!Input DXF file/OGR dsn defined, update list of layer widget"""
path = event.GetString()
if self.inputType == 'dxf':
@@ -1076,7 +1076,7 @@
class LayersList(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin,
listmix.CheckListCtrlMixin):
# listmix.CheckListCtrlMixin, listmix.TextEditMixin):
- """List of layers to be imported (dxf, shp...)"""
+ """!List of layers to be imported (dxf, shp...)"""
def __init__(self, parent, pos=wx.DefaultPosition,
log=None):
@@ -1098,7 +1098,7 @@
self.Bind(wx.EVT_RIGHT_UP, self.OnPopupMenu) #wxGTK
def LoadData(self, data=None):
- """Load data into list"""
+ """!Load data into list"""
if data is None:
return
@@ -1114,7 +1114,7 @@
self.SetColumnWidth(col=0, width=wx.LIST_AUTOSIZE_USEHEADER)
def OnPopupMenu(self, event):
- """Show popup menu"""
+ """!Show popup menu"""
if self.GetItemCount() < 1:
return
@@ -1134,7 +1134,7 @@
menu.Destroy()
item = -1
while True:
@@ -1146,7 +1146,7 @@
event.Skip()
def OnSelectNone(self, event):
item = -1
while True:
@@ -1158,7 +1158,7 @@
event.Skip()
def GetLayers(self):
- """Get list of layers (layer name, output name)"""
+ """!Get list of layers (layer name, output name)"""
data = []
item = -1
while True:
@@ -1173,7 +1173,7 @@
return data
class SetOpacityDialog(wx.Dialog):
- """Set opacity of map layers"""
+ """!Set opacity of map layers"""
def __init__(self, parent, id=wx.ID_ANY, title=_("Set Map Layer Opacity"),
size=wx.DefaultSize, pos=wx.DefaultPosition,
style=wx.DEFAULT_DIALOG_STYLE, opacity=100):
@@ -1235,7 +1235,7 @@
self.Layout()
def GetOpacity(self):
# return opacity value
opacity = float(self.value.GetValue()) / 100
return opacity
Modified: grass/trunk/gui/wxpython/gui_modules/georect.py
--- grass/trunk/gui/wxpython/gui_modules/georect.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/georect.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -212,7 +212,7 @@
self.Cleanup()
def SetSrcEnv(self, location, mapset):
- """Create environment to use for location and mapset
+ """!Create environment to use for location and mapset
that are the source of the file(s) to georectify
@param location source location
@@ -265,13 +265,13 @@
return True
def OnGLMFocus(self, event):
- """Layer Manager focus"""
+ """!Layer Manager focus"""
# self.SwitchEnv('original')
event.Skip()
def Cleanup(self):
- """Return to current location and mapset"""
+ """!Return to current location and mapset"""
self.parent.georectifying = None
@@ -355,7 +355,7 @@
# self.Bind(wx.EVT_CLOSE, self.parent.Cleanup)
def OnMaptype(self,event):
- """Change map type"""
+ """!Change map type"""
global maptype
if event.GetInt() == 0:
@@ -364,7 +364,7 @@
maptype = 'vector'
def OnLocation(self, event):
- """Sets source location for map(s) to georectify"""
+ """!Sets source location for map(s) to georectify"""
self.xylocation = event.GetString()
#create a list of valid mapsets
@@ -386,7 +386,7 @@
wx.FindWindowById(wx.ID_FORWARD).Enable(True)
def OnMapset(self, event):
- """Sets source mapset for map(s) to georectify"""
+ """!Sets source mapset for map(s) to georectify"""
if self.xylocation == '':
wx.MessageBox(_('You must select a valid location before selecting a mapset'))
return
@@ -486,13 +486,13 @@
self.xygroup = event.GetString()
def OnMkGroup(self, event):
- """Create new group in source location/mapset"""
+ """!Create new group in source location/mapset"""
menuform.GUI().ParseCommand(['i.group'],
completed=(self.GetOptData, None, ''),
parentframe=self.parent.parent, modal=True)
def OnVGroup(self, event):
- """Add vector maps to group"""
+ """!Add vector maps to group"""
dlg = VectGroup(parent = self,
id = wx.ID_ANY,
grassdb = self.grassdatabase,
@@ -507,7 +507,7 @@
self.OnEnterPage()
- """Process i.group"""
+ """!Process i.group"""
# update the page
if dcmd:
gcmd.RunCommand(utils.CmdToTuple(dcmd))
@@ -615,7 +615,7 @@
def OnSelection(self,event):
- """Map to display selected"""
+ """!Map to display selected"""
global xy_map
xy_map = event.GetString()
@@ -783,7 +783,7 @@
# sizer.Fit(self)
def __del__(self):
- """Disable georectification mode"""
+ """!Disable georectification mode"""
def SetMapDisplay(self, win):
@@ -999,7 +999,7 @@
# self.RMSError(self.xygroup, self.gr_order)
def ReloadGCPs(self, event):
- """Reload data from file"""
+ """!Reload data from file"""
self.list.LoadData()
def OnFocus(self, event):
@@ -1100,7 +1100,7 @@
'to_table=%s' % layer[2] + '_' + self.extension])
def OnGeorectDone(self, **kargs):
- """Print final message"""
+ """!Print final message"""
global maptype
if maptype == 'cell':
return
@@ -1147,7 +1147,7 @@
self.grwiz.SwitchEnv('original')
def OnSettings(self, event):
- """Georectifier settings"""
+ """!Georectifier settings"""
dlg = GrSettingsDialog(parent=self, id=wx.ID_ANY, title=_('Georectifier settings'))
if dlg.ShowModal() == wx.ID_OK:
@@ -1156,7 +1156,7 @@
dlg.Destroy()
def OnQuit(self, event):
- """Quit georectifier"""
+ """!Quit georectifier"""
self.grwiz.Cleanup()
self.Destroy()
@@ -1285,7 +1285,7 @@
idx_col += 1
def LoadData(self):
self.DeleteAllItems()
if os.path.isfile(self.gcp.file['points']):
@@ -1304,7 +1304,7 @@
self.ResizeColumns()
def OnCheckItem(self, index, flag):
- """Item is checked/unchecked"""
+ """!Item is checked/unchecked"""
pass
def AddGCPItem(self):
@@ -1348,7 +1348,7 @@
def ResizeColumns(self):
- """Resize columns"""
+ """!Resize columns"""
minWidth = 90
for i in range(self.GetColumnCount()):
self.SetColumnWidth(i, wx.LIST_AUTOSIZE)
@@ -1358,7 +1358,7 @@
self.SendSizeEvent()
def GetSelected(self):
- """Get index of selected item"""
+ """!Get index of selected item"""
@@ -1506,7 +1506,7 @@
self.Layout()
def MakeVGroup(self):
- """Create VREF file"""
+ """!Create VREF file"""
vgrouplist = []
for item in range(self.listMap.GetCount()):
if not self.listMap.IsChecked(item):
@@ -1524,7 +1524,7 @@
def __init__(self, parent, data, id=wx.ID_ANY,
title=_("Edit GCP"),
style=wx.DEFAULT_DIALOG_STYLE):
- """Dialog for editing GPC and map coordinates in list control"""
+ """!Dialog for editing GPC and map coordinates in list control"""
wx.Dialog.__init__(self, parent, id, title=title, style=style)
@@ -1595,7 +1595,7 @@
sizer.Fit(self)
- """Return list of values (as strings).
+ """!Return list of values (as strings).
valuelist = []
try:
@@ -1631,7 +1631,7 @@
self._do_layout()
def _do_layout(self):
- """Do layout"""
+ """!Do layout"""
# dialog layout
@@ -1716,7 +1716,7 @@
value=wx.FindWindowById(self.symbol['width']).GetValue())
def OnSave(self, event):
- """Button 'Save' pressed"""
+ """!Button 'Save' pressed"""
self.UpdateSettings()
fileSettings = {}
UserSettings.ReadSettingsFile(settings=fileSettings)
@@ -1726,10 +1726,10 @@
self.Close()
def OnApply(self, event):
- """Button 'Apply' pressed"""
+ """!Button 'Apply' pressed"""
self.Close()
- """Button 'Cancel' pressed"""
+ """!Button 'Cancel' pressed"""
self.Close()
Modified: grass/trunk/gui/wxpython/gui_modules/globalvar.py
--- grass/trunk/gui/wxpython/gui_modules/globalvar.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/globalvar.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -27,7 +27,7 @@
check = True
def CheckForWx():
- """Try to import wx module and check its version"""
+ """!Try to import wx module and check its version"""
global check
if not check:
return
@@ -75,14 +75,14 @@
ETCICONDIR = os.path.join(os.getenv("GISBASE"), "etc", "gui", "icons")
ETCWXDIR = os.path.join(ETCDIR, "wxpython")
-"""Style definition for FlatNotebook pages"""
+"""!Style definition for FlatNotebook pages"""
FNPageStyle = FN.FNB_VC8 | \
FN.FNB_BACKGROUND_GRADIENT | \
FN.FNB_NODRAG | \
FN.FNB_TABS_BORDER_SIMPLE
FNPageColor = wx.Colour(125,200,175)
-"""Dialog widget dimension"""
+"""!Dialog widget dimension"""
DIALOG_SPIN_SIZE = (150, -1)
DIALOG_COMBOBOX_SIZE = (300, -1)
DIALOG_GSELECT_SIZE = (400, -1)
@@ -101,7 +101,7 @@
_("Map scale"),
_("Go to")]
-"""File name extension binaries/scripts"""
+"""!File name extension binaries/scripts"""
EXT_BIN = '.exe'
EXT_SCT = '.bat'
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -42,12 +42,12 @@
wxCmdAbort, EVT_CMD_ABORT = NewEvent()
def GrassCmd(cmd, stdout, stderr):
- """Return GRASS command thread"""
+ """!Return GRASS command thread"""
return gcmd.CommandThread(cmd,
stdout=stdout, stderr=stderr)
class CmdThread(threading.Thread):
- """Thread for GRASS commands"""
+ """!Thread for GRASS commands"""
requestId = 0
def __init__(self, parent, requestQ, resultQ, **kwds):
threading.Thread.__init__(self, **kwds)
@@ -176,7 +176,7 @@
self.__layout()
def __layout(self):
- """Do layout"""
+ """!Do layout"""
boxsizer1 = wx.BoxSizer(wx.VERTICAL)
gridsizer1 = wx.GridSizer(rows=1, cols=2, vgap=0, hgap=0)
boxsizer1.Add(item=self.cmd_output, proportion=1,
@@ -201,7 +201,7 @@
self.SetSizer(boxsizer1)
def Redirect(self):
- """Redirect stderr
+ """!Redirect stderr
@return True redirected
@return False failed
@@ -217,7 +217,7 @@
def WriteLog(self, text, style = None, wrap = None,
switchPage = False):
- """Generic method for writing log message in
+ """!Generic method for writing log message in
given style
@param line text line
@@ -251,17 +251,17 @@
self.cmd_output.EnsureCaretVisible()
def WriteCmdLog(self, line, pid=None):
- """Write message in selected style"""
+ """!Write message in selected style"""
if pid:
line = '(' + str(pid) + ') ' + line
self.WriteLog(line, style=self.cmd_output.StyleCommand, switchPage = True)
def WriteWarning(self, line):
- """Write message in warning style"""
+ """!Write message in warning style"""
self.WriteLog(line, style=self.cmd_output.StyleWarning, switchPage = True)
def WriteError(self, line):
- """Write message in error style"""
+ """!Write message in error style"""
self.WriteLog(line, style=self.cmd_output.StyleError, switchPage = True)
def RunCmd(self, command, compReg=True, switchPage=False,
@@ -380,12 +380,12 @@
return None
def ClearHistory(self, event):
- """Clear history of commands"""
+ """!Clear history of commands"""
self.cmd_output.ClearAll()
self.console_progressbar.SetValue(0)
def SaveHistory(self, event):
- """Save history of commands"""
+ """!Save history of commands"""
self.history = self.cmd_output.GetSelectedText()
if self.history == '':
self.history = self.cmd_output.GetText()
@@ -412,11 +412,11 @@
dlg.Destroy()
def GetCmd(self):
- """Get running command or None"""
+ """!Get running command or None"""
return self.requestQ.get()
def OnCmdOutput(self, event):
- """Print command output"""
+ """!Print command output"""
message = event.text
type = event.type
if self.parent.notebook.GetSelection() != self.parent.goutput.pageid:
@@ -479,19 +479,19 @@
def OnCmdProgress(self, event):
- """Update progress message info"""
+ """!Update progress message info"""
self.console_progressbar.SetValue(event.value)
def OnCmdAbort(self, event):
- """Abort running command"""
+ """!Abort running command"""
self.cmdThread.abort()
def OnCmdRun(self, event):
- """Run command"""
self.WriteCmdLog('(%s)\n%s' % (str(time.ctime()), ' '.join(event.cmd)))
def OnCmdDone(self, event):
- """Command done (or aborted)"""
+ """!Command done (or aborted)"""
if event.aborted:
# Thread aborted (using our convention of None return)
self.WriteLog(_('Please note that the data are left in incosistent stage '
@@ -574,7 +574,7 @@
self.ProcessPendingEvents()
class GMStdout:
- """GMConsole standard output
+ """!GMConsole standard output
Based on FrameOutErr.py
@@ -600,7 +600,7 @@
wx.PostEvent(self.parent.cmd_output, evt)
class GMStderr:
- """GMConsole standard error output
+ """!GMConsole standard error output
@@ -670,7 +670,7 @@
wx.PostEvent(self.parent.console_progressbar, evt)
class GMStc(wx.stc.StyledTextCtrl):
- """Styled GMConsole
+ """!Styled GMConsole
@@ -744,14 +744,14 @@
self.Bind(wx.EVT_WINDOW_DESTROY, self.OnDestroy)
def OnDestroy(self, evt):
- """The clipboard contents can be preserved after
+ """!The clipboard contents can be preserved after
the app has exited"""
wx.TheClipboard.Flush()
evt.Skip()
def AddTextWrapped(self, txt, wrap=None):
- """Add string to text area.
+ """!Add string to text area.
String is wrapped and linesep is also added to the end
of the string"""
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -118,7 +118,7 @@
return str
def OnPopup(self):
- """Limited only for first selected"""
+ """!Limited only for first selected"""
# update list
self.seltree.DeleteAllItems()
self.GetElementList(self.type, self.mapsets, self.exceptOf)
@@ -318,7 +318,7 @@
evt.Skip()
def SetData(self, **kargs):
- """Set object properties"""
+ """!Set object properties"""
if kargs.has_key('type'):
self.type = kargs['type']
if kargs.has_key('mapsets'):
@@ -329,7 +329,7 @@
self.multiple = kargs['multiple']
class VectorDBInfo:
linked to a vector map"""
self.map = map
@@ -345,7 +345,7 @@
self.__DescribeTables() # -> self.tables
def __CheckDBConnection(self):
- """Check DB connection"""
+ """!Check DB connection"""
nuldev = file(os.devnull, 'w+')
self.layers = grass.vector_db(map=self.map, stderr=nuldev)
nuldev.close()
@@ -356,7 +356,7 @@
return True
def __DescribeTables(self):
- """Describe linked tables"""
+ """!Describe linked tables"""
for layer in self.layers.keys():
# determine column names and types
table = self.layers[layer]["table"]
@@ -395,7 +395,7 @@
return True
def Reset(self):
- """Reset"""
+ """!Reset"""
for layer in self.layers:
table = self.layers[layer]["table"] # get table desc
columns = self.tables[table]
@@ -436,7 +436,7 @@
self.SetStringSelection('1')
def InsertLayers(self, vector):
- """Insert layers for a vector into the layer combobox"""
+ """!Insert layers for a vector into the layer combobox"""
layerchoices = utils.GetVectorNumberOfLayers(vector)
if self.all:
@@ -496,7 +496,7 @@
self.InsertTables()
def InsertTables(self, driver=None, database=None):
- """Insert attribute tables into combobox"""
+ """!Insert attribute tables into combobox"""
items = []
if not driver or not database:
@@ -537,7 +537,7 @@
self.InsertColumns(vector, layer)
def InsertColumns(self, vector, layer):
- """Insert columns for a vector attribute table into the columns combobox"""
+ """!Insert columns for a vector attribute table into the columns combobox"""
dbInfo = VectorDBInfo(vector)
try:
@@ -553,7 +553,7 @@
self.SetValue('')
def InsertTableColumns(self, table, driver=None, database=None):
- """Insert table columns"""
+ """!Insert table columns"""
columns = []
Modified: grass/trunk/gui/wxpython/gui_modules/histogram.py
--- grass/trunk/gui/wxpython/gui_modules/histogram.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/histogram.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -343,7 +343,7 @@
def __createToolBar(self):
- """Creates toolbar"""
+ """!Creates toolbar"""
toolbar = self.CreateToolBar()
for each in self.toolbarData():
@@ -351,7 +351,7 @@
toolbar.Realize()
def AddToolbarButton(self, toolbar, label, icon, help, handler):
- """Adds buttons to the toolbar"""
+ """!Adds buttons to the toolbar"""
if not label:
toolbar.AddSeparator()
@@ -400,7 +400,7 @@
self.Map.geom = self.width, self.height
def OnOptions(self, event):
- """Change histogram settings"""
+ """!Change histogram settings"""
cmd = ['d.histogram']
if self.mapname != '':
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -70,26 +70,26 @@
resolution = ''
class BaseClass(wx.Object):
- """Base class providing basic methods"""
+ """!Base class providing basic methods"""
def __init__(self):
pass
def MakeLabel(self, text="", style=wx.ALIGN_LEFT, parent=None):
- """Make aligned label"""
+ """!Make aligned label"""
if not parent:
parent = self
return wx.StaticText(parent=parent, id=wx.ID_ANY, label=text,
style=style)
def MakeTextCtrl(self, text='', size=(100,-1), style=0, parent=None):
- """Generic text control"""
+ """!Generic text control"""
if not parent:
parent = self
return wx.TextCtrl(parent=parent, id=wx.ID_ANY, value=text,
size=size, style=style)
def MakeButton(self, text, id=wx.ID_ANY, size=(-1,-1), parent=None):
- """Generic button"""
+ """!Generic button"""
if not parent:
parent = self
return wx.Button(parent=parent, id=id, label=text,
@@ -112,7 +112,7 @@
self.sizer = wx.GridBagSizer(vgap=0, hgap=0)
def DoLayout(self):
- """Do page layout"""
+ """!Do page layout"""
tmpsizer = wx.BoxSizer(wx.VERTICAL)
@@ -193,7 +193,7 @@
# self.DoLayout()
def OnChangeName(self, event):
- """Name for new location was changed"""
+ """!Name for new location was changed"""
nextButton = wx.FindWindowById(wx.ID_FORWARD)
if not nextButton.IsEnabled():
@@ -233,7 +233,7 @@
self.grassdatabase = self.tgisdbase.GetValue()
def OnEnterPage(self, event):
- """Wizard page changed"""
+ """!Wizard page changed"""
self.location = self.tlocation.GetValue()
@@ -306,7 +306,7 @@
wx.FindWindowById(wx.ID_FORWARD).Enable()
def SetVal(self, event):
- """Choose method"""
+ """!Choose method"""
global coordsys
if event.GetId() == self.radio1.GetId():
coordsys = "proj"
@@ -400,7 +400,7 @@
self.parent.projtypepage.hemischoices = []
- """Projection name changed"""
+ """!Projection name changed"""
self.proj = event.GetString()
if len(self.proj) == 0 and nextButton.IsEnabled():
@@ -421,7 +421,7 @@
event.Skip()
def OnSearch(self, event):
- """Search projection by desc"""
+ """!Search projection by desc"""
str = event.GetString()
try:
self.proj, self.projdesc = self.projlist.Search(index=1, pattern=event.GetString())
@@ -431,7 +431,7 @@
event.Skip()
- """Projection selected"""
+ """!Projection selected"""
index = event.m_itemIndex
# set values
@@ -442,7 +442,7 @@
class ItemList(wx.ListCtrl,
- """Generic list (for projections, ellipsoids, etc.)"""
+ """!Generic list (for projections, ellipsoids, etc.)"""
def __init__(self, parent, columns, data=None):
wx.ListCtrl.__init__(self, parent=parent, id=wx.ID_ANY,
@@ -502,7 +502,7 @@
def Populate(self, data=None, update=False):
- """Populate list"""
+ """!Populate list"""
self.itemDataMap = {}
self.itemIndexMap = []
@@ -547,7 +547,7 @@
caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
- """Sort by column"""
+ """!Sort by column"""
@@ -562,17 +562,17 @@
event.Skip()
s = str(self.itemDataMap[index][col])
return s
return self.attr2
@@ -580,7 +580,7 @@
return self.attr1
- """Sort items"""
+ """!Sort items"""
@@ -611,11 +611,11 @@
return -cmpVal
- """Used by listmix.ColumnSorterMixin"""
+ """!Used by listmix.ColumnSorterMixin"""
return self
def Search (self, index, pattern):
- """Search projection by description
+ """!Search projection by description
Return first found item or None
@@ -1031,7 +1031,7 @@
# self.GetNext().SetPrev(self) (???)
- """Ellipspoid code changed"""
+ """!Ellipspoid code changed"""
self.ellipse = event.GetString()
if len(self.ellipse) == 0 and nextButton.IsEnabled():
@@ -1046,7 +1046,7 @@
nextButton.Enable()
- """Search ellipsoid by desc"""
+ """!Search ellipsoid by desc"""
try:
self.ellipse, self.ellipsedesc = \
@@ -1135,7 +1135,7 @@
event.Skip()
def OnBrowse(self, event):
- """Choose file"""
+ """!Choose file"""
dlg = wx.FileDialog(self,
_("Select georeferenced file"),
os.getcwd(), "", "*.*", wx.OPEN)
@@ -1213,7 +1213,7 @@
event.Skip()
- """Choose file"""
_("Select WKT file"),
@@ -1382,7 +1382,7 @@
event.Skip()
- """Define path for EPSG code file"""
+ """!Define path for EPSG code file"""
path = os.path.dirname(self.tfile.GetValue())
if not path:
path = os.getcwd()
@@ -1400,7 +1400,7 @@
event.Skip()
- """EPSG code selected from the list"""
+ """!EPSG code selected from the list"""
item = event.GetItem()
@@ -1411,7 +1411,7 @@
event.Skip()
def OnBrowseCodes(self, event, search=None):
- """Browse EPSG codes"""
+ """!Browse EPSG codes"""
# try:
if True:
data = []
@@ -1494,7 +1494,7 @@
def GetProjstring(self, event):
- """Change proj string"""
+ """!Change proj string"""
# TODO: check PROJ.4 syntax
self.customstring = event.GetString()
@@ -1531,7 +1531,7 @@
self.__DoLayout()
def __DoLayout(self):
self.sizer.AddGrowableCol(1)
self.sizer.Add(item=self.MakeLabel(_("GRASS Database:")),
flag=wx.ALIGN_LEFT | wx.ALL,
@@ -1773,7 +1773,7 @@
caption=_("Location wizard"))
def __readData(self):
- """Get georeferencing information from tables in $GISBASE/etc"""
+ """!Get georeferencing information from tables in $GISBASE/etc"""
# read projection definitions
f = open(os.path.join(globalvar.ETCDIR, "projections"), "r")
self.projections = {}
@@ -1911,7 +1911,7 @@
return success
def XYCreate(self):
- """Create an XY location"""
+ """!Create an XY location"""
database = self.startpage.grassdatabase
location = self.startpage.location
@@ -1966,7 +1966,7 @@
return False
def CreateProj4String(self):
- """Constract PROJ.4 string"""
+ """!Constract PROJ.4 string"""
proj = self.projpage.proj
projdesc = self.projpage.projdesc
@@ -2035,7 +2035,7 @@
return False
def CustomCreate(self):
- """Create a new location based on given proj4 string"""
+ """!Create a new location based on given proj4 string"""
proj4string = self.custompage.customstring
@@ -2352,7 +2352,7 @@
self.minWindowSize = self.GetMinSize()
def MakeSettings3DPaneContent(self, pane):
- """Create 3D region settings pane"""
+ """!Create 3D region settings pane"""
border = wx.BoxSizer(wx.VERTICAL)
gridSizer = wx.GridBagSizer(vgap=0, hgap=0)
@@ -2429,7 +2429,7 @@
border.Fit(pane)
def OnSettings3DPaneChanged(self, event):
- """Collapse 3D settings box"""
+ """!Collapse 3D settings box"""
if self.settings3D.IsExpanded():
self.settings3D.SetLabel(self.infoCollapseLabelCol)
@@ -2445,7 +2445,7 @@
def __DoLayout(self, panel):
- """Window layout"""
+ """!Window layout"""
frameSizer = wx.BoxSizer(wx.VERTICAL)
settings3DSizer = wx.BoxSizer(wx.VERTICAL)
@@ -2549,7 +2549,7 @@
self.Layout()
def OnValue(self, event):
- """Set given value"""
+ """!Set given value"""
try:
if event.GetId() == self.tnorth.GetId():
self.north = float(event.GetString())
@@ -2598,7 +2598,7 @@
event.Skip()
def __UpdateInfo(self):
- """Update number of rows/cols/cells"""
+ """!Update number of rows/cols/cells"""
self.rows = int((self.north - self.south) / self.nsres)
self.cols = int((self.east - self.west) / self.ewres)
self.cells = self.rows * self.cols
@@ -2615,7 +2615,7 @@
self.lcells3.SetLabel(_("3D Cells: %d" % self.cells3))
def OnSetButton(self, event=None):
- """Set default region"""
+ """!Set default region"""
ret = gcmd.RunCommand('g.region',
flags = 'sgpa',
n = self.north,
@@ -2634,7 +2634,7 @@
self.Destroy()
class SelectDatumDialog(wx.Dialog):
- """Dialog for selecting datum transformations"""
+ """!Dialog for selecting datum transformations"""
def __init__(self, parent, datums, title=_("Select datum transformation"),
pos=wx.DefaultPosition, size=wx.DefaultSize, style=wx.DEFAULT_DIALOG_STYLE):
@@ -2706,7 +2706,7 @@
self.SetSize(self.GetBestSize())
def OnChangeDatum(self, event):
- """Datum changed, update description text"""
+ """!Datum changed, update description text"""
self.datumDesc.SetLabel('\n'.join(self.datums[event.GetString()]))
# self.textWidth = self.GetSize()[0]
# self.datumDesc.Wrap(self.textWidth)
@@ -2714,7 +2714,7 @@
event.Skip()
def GetDatum(self):
- """Get selected datum"""
+ """!Get selected datum"""
return self.cdatums.GetStringSelection()
if __name__ == "__main__":
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -792,7 +792,7 @@
self.goTo.SetFocus()
def StatusbarUpdate(self):
- """Update statusbar content"""
+ """!Update statusbar content"""
self.showRegion.Hide()
self.compResolution.Hide()
@@ -903,13 +903,13 @@
self.statusbar.SetStatusText("", 1)
def StatusbarEnableLongHelp(self, enable=True):
- """Enable/disable toolbars long help"""
+ """!Enable/disable toolbars long help"""
for toolbar in self.toolbars.itervalues():
if toolbar:
toolbar.EnableLongHelp(enable)
def StatusbarReposition(self):
- """Reposition checkbox in statusbar"""
+ """!Reposition checkbox in statusbar"""
# reposition checkbox
widgets = [(0, self.showRegion),
(0, self.compResolution),
@@ -1259,7 +1259,7 @@
self.dialogs['attributes'].Hide()
def OnQuery(self, event):
- """Query tools menu"""
+ """!Query tools menu"""
if self.toolbars['map']:
self.toolbars['map'].OnTool(event)
action = self.toolbars['map'].GetAction()
@@ -1459,7 +1459,7 @@
self.profile.OnSelectRaster(None)
def FormatDist(self, dist):
- """Format length numbers and units in a nice way,
+ """!Format length numbers and units in a nice way,
as a function of length. From code by Hamish Bowman
Grass Development Team 2006"""
@@ -1705,7 +1705,7 @@
def SetProperties(self, render=False, mode=0, showCompExtent=False,
constrainRes=False):
- """Set properies of map display window"""
+ """!Set properies of map display window"""
self.autoRender.SetValue(render)
self.toggleStatus.SetSelection(mode)
self.StatusbarUpdate()
@@ -1715,14 +1715,14 @@
self.MapWindow.regionCoords = []
def IsStandalone(self):
- """Check if Map display is standalone"""
+ """!Check if Map display is standalone"""
if self._layerManager:
return False
return True
def GetLayerManager(self):
- """Get reference to Layer Manager
+ """!Get reference to Layer Manager
@return window reference
@return None (if standalone)
@@ -1764,10 +1764,10 @@
# stop the timer
self.timer.Stop()
# terminate thread (a bit ugly)
- os.system("""echo "quit" >> %s""" % (cmdfilename))
+ os.system("""!echo "quit" >> %s""" % (cmdfilename))
def watcher(self):
- """Redraw, if new layer appears"""
+ """!Redraw, if new layer appears"""
if self.redraw:
self.mapFrm.OnDraw(None)
self.redraw = False
@@ -1798,7 +1798,7 @@
gm_map.MainLoop()
os.remove(cmdfilename)
- os.system("""g.gisenv set="GRASS_PYCMDFILE" """)
+ os.system("""!g.gisenv set="GRASS_PYCMDFILE" """)
print >> sys.stderr, "\nStopping monitor <%s>...\n" % (title)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -947,7 +947,7 @@
def DrawCross(self, pdc, coords, size, rotation=0,
text=None, textAlign='lr', textOffset=(5, 5)):
- """Draw cross in PseudoDC
+ """!Draw cross in PseudoDC
@todo implement rotation
@@ -2603,7 +2603,7 @@
os.environ["GRASS_REGION"] = tmpreg
def Distance(self, beginpt, endpt, screen=True):
- """Calculete distance
+ """!Calculete distance
LL-locations not supported
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -147,7 +147,7 @@
def normalize_whitespace(text):
- """Remove redundant whitespace from a string"""
+ """!Remove redundant whitespace from a string"""
return string.join( string.split(text), ' ')
def text_beautify( someString , width=70):
@@ -163,11 +163,11 @@
return escape_ampersand( string.strip(normalize_whitespace(someString ), ".,;:" ))
def escape_ampersand(text):
- """Escapes ampersands with additional ampersand for GUI"""
+ """!Escapes ampersands with additional ampersand for GUI"""
return string.replace(text, "&", "&&")
class UpdateThread(Thread):
- """Update dialog widgets in the thread"""
+ """!Update dialog widgets in the thread"""
def __init__(self, parent, event, eventId, task):
Thread.__init__(self)
@@ -268,7 +268,7 @@
return UpdateThread(parent, event, eventId, task)
class UpdateQThread(Thread):
requestId = 0
@@ -336,7 +336,7 @@
xml.sax.parseString( getInterfaceDescription( grassModule ) , processTask( self ) )
def get_list_params(self, element = 'name'):
- """Get list of parameters"""
+ """!Get list of parameters"""
params = []
for p in self.params:
params.append(p['name'])
@@ -344,7 +344,7 @@
return params
def get_list_flags(self, element = 'name'):
flags = []
for p in self.flags:
flags.append(p['name'])
@@ -352,7 +352,7 @@
return flags
def get_param(self, value, element='name', raiseError=True):
- """Find and return a param by name."""
+ """!Find and return a param by name."""
if p[element] == value:
return p
@@ -920,17 +920,17 @@
self.Layout()
def updateValuesHook(self):
- """Update status bar data"""
+ """!Update status bar data"""
self.SetStatusText(' '.join(self.notebookpanel.createCmd(ignoreErrors = True)) )
- """OK button pressed"""
+ """!OK button pressed"""
cmd = self.OnApply(event)
if cmd is not None and self.get_dcmd is not None:
self.OnCancel(event)
- """Apply the command"""
+ """!Apply the command"""
cmd = self.createCmd()
@@ -944,7 +944,7 @@
return cmd
- """Run the command"""
+ """!Run the command"""
if cmd == None or len(cmd) < 2:
@@ -975,12 +975,12 @@
self.btn_abort.Enable(True)
event = goutput.wxCmdAbort(aborted=True)
wx.PostEvent(self.goutput, event)
def OnCopy(self, event):
- """Copy the command"""
+ """!Copy the command"""
cmddata = wx.TextDataObject()
# list -> string
cmdstring = ' '.join(self.createCmd(ignoreErrors=True))
@@ -993,7 +993,7 @@
(cmdstring))
self.MakeModal(False)
if self.get_dcmd and \
@@ -1014,7 +1014,7 @@
self.Destroy()
def OnHelp(self, event):
- """Show manual page (switch to the 'Manual' notebook page)"""
+ """!Show manual page (switch to the 'Manual' notebook page)"""
if hasattr(self.notebookpanel, "manual_tab_id"):
self.notebookpanel.notebook.SetSelection(self.notebookpanel.manual_tab_id)
self.notebookpanel.OnPageChange(None)
@@ -1022,7 +1022,7 @@
event.Skip()
def createCmd(self, ignoreErrors = False):
- """Create command string (python list)"""
+ """!Create command string (python list)"""
return self.notebookpanel.createCmd(ignoreErrors=ignoreErrors)
class cmdPanel(wx.Panel):
@@ -1584,7 +1584,7 @@
fn(**kwargs)
def OnVerbosity(self, event):
- """Verbosity level changed"""
+ """!Verbosity level changed"""
verbose = self.FindWindowById(self.task.get_flag('verbose')['wxId'])
quiet = self.FindWindowById(self.task.get_flag('quiet')['wxId'])
if event.IsChecked():
@@ -1793,7 +1793,7 @@
self.grass_task = None
def ParseInterface(self, cmd):
- """Parse interface
+ """!Parse interface
@param cmd command to be parsed (given as list)
@@ -1895,7 +1895,7 @@
return cmd
def GetCommandInputMapParamKey(self, cmd):
- """Get parameter key for input raster/vector map
+ """!Get parameter key for input raster/vector map
@param cmd module name
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -58,7 +58,7 @@
self.nvizClass = wxnviz.Nviz(self.log)
class GLWindow(MapWindow, glcanvas.GLCanvas):
- """OpenGL canvas for Map Display Window"""
+ """!OpenGL canvas for Map Display Window"""
@@ -232,7 +232,7 @@
self.ReleaseMouse()
def UpdateView(self, event):
- """Change view settings"""
+ """!Change view settings"""
self.nvizClass.SetView(self.view['pos']['x'], self.view['pos']['y'],
self.iview['height']['value'],
self.view['persp']['value'],
@@ -300,7 +300,7 @@
self.SwapBuffers()
def IsLoaded(self, item):
- """Check if layer (item) is already loaded
+ """!Check if layer (item) is already loaded
@param item layer item
@@ -321,7 +321,7 @@
return 1
def _GetDataLayers(self, item, litems):
- """Return get list of enabled map layers"""
+ """!Return get list of enabled map layers"""
# load raster & vector maps
while item and item.IsOk():
type = self.tree.GetPyData(item)[0]['type']
@@ -340,7 +340,7 @@
item = self.tree.GetNextSibling(item)
def LoadDataLayers(self):
- """Load raster/vector from current layer tree
+ """!Load raster/vector from current layer tree
@todo volumes
@@ -385,7 +385,7 @@
# print stop - start
def UnloadDataLayers(self):
- """Unload any layers that have been deleted from layer tree"""
+ """!Unload any layers that have been deleted from layer tree"""
if not self.tree:
return
@@ -423,7 +423,7 @@
Debug.msg(3, "GLWindow.UnloadDataLayers(): time=%f" % (stop-start))
def SetMapObjProperties(self, item, id, nvizType):
- """Set map object properties
+ """!Set map object properties
Properties must be afterwards updated by
UpdateMapObjProperties().
@@ -497,21 +497,21 @@
return data
def LoadRaster(self, item):
- """Load 2d raster map and set surface attributes
+ """!Load 2d raster map and set surface attributes
@param layer item
return self._loadRaster(item)
def LoadRaster3d(self, item):
- """Load 3d raster map and set surface attributes
+ """!Load 3d raster map and set surface attributes
@param layer item
def _loadRaster(self, item):
- """Load 2d/3d raster map and set its attributes
+ """!Load 2d/3d raster map and set its attributes
@param layer item
@@ -561,21 +561,21 @@
return id
def UnloadRaster(self, item):
- """Unload 2d raster map
+ """!Unload 2d raster map
@param layer item
return self._unloadRaster(item)
def UnloadRaster3d(self, item):
- """Unload 3d raster map
+ """!Unload 3d raster map
@param layer item
def _unloadRaster(self, item):
- """Unload 2d/3d raster map
+ """!Unload 2d/3d raster map
@@ -623,7 +623,7 @@
toolWin.page['settings']['id'] = 1
def LoadVector(self, item, vecType=None):
- """Load 2D or 3D vector map overlay
+ """!Load 2D or 3D vector map overlay
@param vecType vector type (lines / points)
@@ -678,7 +678,7 @@
return id
def UnloadVector(self, item, vecType=None):
- """Unload vector map overlay
+ """!Unload vector map overlay
@param vecType vector type (lines, points)
@@ -726,7 +726,7 @@
def GetDrawMode(self, mode=None, style=None, shade=None, string=False):
- """Get surface draw mode (value) from description/selection
+ """!Get surface draw mode (value) from description/selection
@param mode,style,shade modes
@param string if True input parameters are strings otherwise
@@ -789,7 +789,7 @@
return (value, desc)
def SetSurfaceDefaultProp(self, data):
- """Set default surface data properties"""
+ """!Set default surface data properties"""
# attributes
@@ -832,7 +832,7 @@
'update': None }
def SetVolumeDefaultProp(self, data):
- """Set default volume data properties"""
+ """!Set default volume data properties"""
# draw
@@ -869,12 +869,12 @@
data['attribute'][attrb][key] = value
def SetVectorDefaultProp(self, data):
- """Set default vector data properties"""
+ """!Set default vector data properties"""
self.SetVectorLinesDefaultProp(data['lines'])
self.SetVectorPointsDefaultProp(data['points'])
def SetVectorLinesDefaultProp(self, data):
- """Set default vector properties -- lines"""
+ """!Set default vector properties -- lines"""
# width
data['width'] = {'value' : UserSettings.Get(group='nviz', key='vector',
subkey=['lines', 'width']) }
@@ -914,7 +914,7 @@
data[attrb]['update'] = None
def SetVectorPointsDefaultProp(self, data):
- """Set default vector properties -- points"""
+ """!Set default vector properties -- points"""
# size
data['size'] = { 'value' : UserSettings.Get(group='nviz', key='vector',
subkey=['points', 'size']) }
@@ -950,7 +950,7 @@
def Reset(self):
- """Reset (unload data)"""
+ """!Reset (unload data)"""
for item in self.layers:
type = self.tree.GetPyData(item)[0]['maplayer'].type
if type == 'raster':
@@ -980,7 +980,7 @@
self.nvizClass.SetViewportDefault()
def ResetView(self):
- """Reset to default view"""
+ """!Reset to default view"""
self.view['z-exag']['value'], \
self.iview['height']['value'], \
self.iview['height']['min'], \
@@ -1000,7 +1000,7 @@
wx.PostEvent(self, event)
def UpdateMapObjProperties(self, event):
- """Generic method to update data layer properties"""
+ """!Generic method to update data layer properties"""
data = event.data
if data.has_key('surface'):
@@ -1024,7 +1024,7 @@
data['vector'][type]['object']['init'] = True
def UpdateSurfaceProperties(self, id, data):
- """Update surface map object properties"""
+ """!Update surface map object properties"""
# surface attributes
for attrb in ('topo', 'color', 'mask',
'transp', 'shine', 'emit'):
@@ -1109,7 +1109,7 @@
data['position'].pop('update')
def UpdateVolumeProperties(self, id, data, isosurfId=None):
- """Update volume (isosurface/slice) map object properties"""
+ """!Update volume (isosurface/slice) map object properties"""
# draw
@@ -1167,7 +1167,7 @@
isosurfId += 1
def UpdateVectorProperties(self, id, data, type):
- """Update vector layer properties
+ """!Update vector layer properties
@param id layer id
@param data properties
@@ -1179,7 +1179,7 @@
self.UpdateVectorLinesProperties(id, data[type])
def UpdateVectorLinesProperties(self, id, data):
- """Update vector line map object properties"""
+ """!Update vector line map object properties"""
# mode
if data['color'].has_key('update') or \
data['width'].has_key('update') or \
@@ -1218,7 +1218,7 @@
data['mode'].pop('update')
def UpdateVectorPointsProperties(self, id, data):
- """Update vector point map object properties"""
+ """!Update vector point map object properties"""
if data['size'].has_key('update') or \
data['marker'].has_key('update') or \
@@ -1256,7 +1256,7 @@
def GetLayerNames(self, type):
- """Return list of map layer names of given type"""
+ """!Return list of map layer names of given type"""
layerName = []
@@ -1269,7 +1269,7 @@
return layerName
def GetLayerData(self, type, name):
- """Return layer item data
+ """!Return layer item data
@return {} if no layer item found
@@ -1281,7 +1281,7 @@
return {}
def GetLayerId(self, type, name):
- """Get layer object id or -1"""
+ """!Get layer object id or -1"""
if len(name) < 1:
return -1
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -33,7 +33,7 @@
import grass7_wxnviz as wxnviz
class NvizToolWindow(wx.Frame):
- """Experimental window for Nviz tools
+ """!Experimental window for Nviz tools
@todo integrate with Map display
@@ -104,12 +104,12 @@
self.notebook.ChangeSelection(new)
def PostViewEvent(self, zExag=False):
event = wxUpdateView(zExag=zExag)
wx.PostEvent(self.mapWindow, event)
def __createViewPage(self):
- """Create view settings page"""
+ """!Create view settings page"""
panel = wx.Panel(parent=self.notebook, id=wx.ID_ANY)
self.notebook.AddPage(page=panel,
text=" %s " % _("View"))
@@ -229,7 +229,7 @@
return panel.GetBestSize()
def __createSurfacePage(self):
self.page['surface'] = {}
self.page['surface']['id'] = -1
@@ -500,7 +500,7 @@
def __createVectorPage(self):
self.page['vector'] = {}
self.page['vector']['id'] = -1
@@ -725,7 +725,7 @@
def __createVolumePage(self):
self.page['volume'] = {}
self.page['volume']['id'] = -1
@@ -944,7 +944,7 @@
def __createSettingsPage(self):
- """Create settings page"""
+ """!Create settings page"""
text=" %s " % _("Settings"))
@@ -1291,7 +1291,7 @@
def CreateControl(self, parent, dict, name, range, bind, sliderHor=True, size=200):
- """Add control (Slider + SpinCtrl)"""
+ """!Add control (Slider + SpinCtrl)"""
dict[name] = {}
if sliderHor:
style = wx.SL_HORIZONTAL | wx.SL_AUTOTICKS | \
@@ -1332,7 +1332,7 @@
dict[name]['spin'] = spin.GetId()
def UpdateSettings(self):
- """Update dialog settings"""
+ """!Update dialog settings"""
for control in ('height',
'persp',
'twist',
@@ -1363,7 +1363,7 @@
return None
def OnViewChange(self, event):
- """Change view, render in quick mode"""
+ """!Change view, render in quick mode"""
# find control
winName = self.__GetWindowName(self.win['view'], event.GetId())
if not winName:
@@ -1389,25 +1389,25 @@
self.mapWindow.Refresh(False)
def OnViewChanged(self, event):
- """View changed, render in full resolution"""
+ """!View changed, render in full resolution"""
self.mapWindow.render['quick'] = False
def OnViewChangedSpin(self, event):
# TODO: use step value instead
self.OnViewChange(event)
self.OnViewChanged(None)
def OnResetView(self, event):
- """Reset to default view (view page)"""
+ """!Reset to default view (view page)"""
self.mapWindow.ResetView()
def OnLookAt(self, event):
- """Look at (view page)"""
+ """!Look at (view page)"""
sel = event.GetSelection()
if sel == 0: # top
self.mapWindow.view['pos']['x'] = 0.5
@@ -1444,7 +1444,7 @@
def OnDefault(self, event):
- """Restore default settings"""
+ """!Restore default settings"""
settings = copy.deepcopy(UserSettings.GetDefaultSettings()['nviz'])
UserSettings.Set(group='nviz',
value=settings)
@@ -1464,7 +1464,7 @@
event.Skip()
- """Apply button pressed"""
+ """!Apply button pressed"""
if self.notebook.GetSelection() == self.page['settings']['id']:
self.ApplySettings()
@@ -1472,7 +1472,7 @@
event.Skip()
def ApplySettings(self):
- """Apply Nviz settings for current session"""
+ """!Apply Nviz settings for current session"""
settings = UserSettings.Get(group='nviz')
for subgroup, key in settings.iteritems(): # view, surface, vector...
for subkey, value in key.iteritems():
@@ -1495,7 +1495,7 @@
settings[subgroup][subkey][subvalue] = value
Apply changes, update map and save settings of selected layer
@@ -1512,7 +1512,7 @@
self.lmgr.goutput.WriteLog(_('Nviz settings saved to file <%s>.') % file)
def OnBgColor(self, event):
- """Background color changed"""
+ """!Background color changed"""
color = event.GetValue()
color = str(color[0]) + ':' + str(color[1]) + ':' + str(color[2])
@@ -1522,14 +1522,14 @@
def OnClose(self, event):
- """Close button pressed
+ """!Close button pressed
Close dialog
self.Hide()
def OnMapObjUse(self, event):
- """Set surface attribute -- use -- map/constant"""
+ """!Set surface attribute -- use -- map/constant"""
if not self.mapWindow.init:
return
@@ -1583,7 +1583,7 @@
def SetMapObjUseMap(self, nvizType, attrb, map=None):
- """Update dialog widgets when attribute type changed"""
+ """!Update dialog widgets when attribute type changed"""
if attrb in ('topo', 'color', 'shine'):
incSel = -1 # decrement selection (no 'unset')
else:
@@ -1608,11 +1608,11 @@
self.FindWindowById(self.win[nvizType][attrb]['use']).SetSelection(0)
def OnSurfaceMap(self, event):
- """Set surface attribute"""
+ """!Set surface attribute"""
self.SetMapObjAttrb(nvizType='surface', winId=event.GetId())
def SetMapObjAttrb(self, nvizType, winId):
- """Set map object (surface/isosurface) attribute (map/constant)"""
+ """!Set map object (surface/isosurface) attribute (map/constant)"""
return
@@ -1663,14 +1663,14 @@
def OnSurfaceResolution(self, event):
- """Draw resolution changed"""
+ """!Draw resolution changed"""
self.SetSurfaceResolution()
if apply and self.parent.autoRender.IsChecked():
def SetSurfaceResolution(self):
- """Set draw resolution"""
+ """!Set draw resolution"""
coarse = self.FindWindowById(self.win['surface']['draw']['res-coarse']).GetValue()
fine = self.FindWindowById(self.win['surface']['draw']['res-fine']).GetValue()
@@ -1684,7 +1684,7 @@
def SetSurfaceMode(self):
- """Set draw mode
+ """!Set draw mode
@param apply allow auto-rendering
@@ -1708,7 +1708,7 @@
return value, desc
def OnSurfaceMode(self, event):
- """Set draw mode"""
+ """!Set draw mode"""
value, desc = self.SetSurfaceMode()
data = self.mapWindow.GetSelectedLayer(type='nviz')
@@ -1724,7 +1724,7 @@
def OnSurfaceModeAll(self, event):
- """Set draw mode (including wire color) for all loaded surfaces"""
+ """!Set draw mode (including wire color) for all loaded surfaces"""
@@ -1753,11 +1753,11 @@
def _getColorString(self, color):
- """Set wire color"""
+ """!Set wire color"""
return str(color[0]) + ':' + str(color[1]) + ':' + str(color[2])
def OnSurfaceWireColor(self, event):
value = self._getColorString(event.GetValue())
data['surface']['draw']['wire-color'] = { 'value' : value,
@@ -1771,7 +1771,7 @@
def OnSurfaceAxis(self, event):
- """Surface position, axis changed"""
+ """!Surface position, axis changed"""
mapLayer = self.mapWindow.GetSelectedLayer()
id = data['object']['id']
@@ -1792,7 +1792,7 @@
win.SetValue(z)
def OnSurfacePosition(self, event):
- """Surface position"""
+ """!Surface position"""
axis = self.FindWindowById(self.win['surface']['position']['axis']).GetSelection()
value = event.GetInt()
@@ -1821,7 +1821,7 @@
def UpdateVectorShow(self, vecType, enabled):
- """Enable/disable lines/points widgets
+ """!Enable/disable lines/points widgets
@@ -1846,7 +1846,7 @@
return True
def OnVectorShow(self, event):
- """Show vector lines/points"""
+ """!Show vector lines/points"""
winId = event.GetId()
if winId == self.win['vector']['lines']['show']:
vecType = 'lines'
@@ -1883,7 +1883,7 @@
event.Skip()
def OnVectorDisplay(self, event):
- """Display vector lines on surface/flat"""
+ """!Display vector lines on surface/flat"""
if event.GetSelection() == 0: # surface
if len(self.mapWindow.layers['raster']['name']) < 1:
event.Veto()
@@ -1903,7 +1903,7 @@
event.Skip()
def OnVectorLines(self, event):
- """Set vector lines mode, apply changes if auto-rendering is enabled"""
+ """!Set vector lines mode, apply changes if auto-rendering is enabled"""
width = self.FindWindowById(self.win['vector']['lines']['width']).GetValue()
color = self.FindWindowById(self.win['vector']['lines']['color']).GetColour()
@@ -1961,7 +1961,7 @@
def OnVectorHeightFull(self, event):
- """Vector height changed, render in full resolution"""
+ """!Vector height changed, render in full resolution"""
id = event.GetId()
if id == self.win['vector']['lines']['height']['spin'] or \
id == self.win['vector']['lines']['height']['slider']:
@@ -1974,14 +1974,14 @@
def OnVectorHeightSpin(self, event):
self.OnVectorHeight(event)
self.OnVectorHeightFull(event)
def OnVectorSurface(self, event):
- """Reference surface for vector map (lines/points)"""
+ """!Reference surface for vector map (lines/points)"""
id = event.GetId()
if id == self.win['vector']['lines']['surface']:
vtype = 'lines'
@@ -1999,7 +1999,7 @@
def OnVectorPoints(self, event):
- """Set vector points mode, apply changes if auto-rendering is enabled"""
+ """!Set vector points mode, apply changes if auto-rendering is enabled"""
size = self.FindWindowById(self.win['vector']['points']['size']).GetValue()
width = self.FindWindowById(self.win['vector']['points']['width']).GetValue()
@@ -2024,7 +2024,7 @@
def UpdateIsosurfButtons(self, list):
- """Enable/disable buttons 'add', 'delete',
+ """!Enable/disable buttons 'add', 'delete',
'move up', 'move down'"""
nitems = list.GetCount()
add = self.parent.FindWindowById(self.win['volume']['btnIsosurfAdd'])
@@ -2056,11 +2056,11 @@
moveUp.Enable(True)
def OnVolumeIsosurfMode(self, event):
- """Set isosurface draw mode"""
+ """!Set isosurface draw mode"""
self.SetIsosurfaceMode(event.GetSelection())
def SetIsosurfaceMode(self, selection):
layer = self.mapWindow.GetSelectedLayer()
data = self.mapWindow.GetSelectedLayer(type='nviz')['volume']
@@ -2077,11 +2077,11 @@
def OnVolumeIsosurfResolution(self, event):
- """Set isosurface draw resolution"""
+ """!Set isosurface draw resolution"""
self.SetIsosurfaceResolution(event.GetInt())
def SetIsosurfaceResolution(self, res):
@@ -2091,11 +2091,11 @@
def OnVolumeIsosurfMap(self, event):
self.SetMapObjAttrb(nvizType='volume', winId=event.GetId())
def OnVolumeIsosurfCheck(self, event):
- """Isosurface checked (->load) or unchecked (->unload)"""
+ """!Isosurface checked (->load) or unchecked (->unload)"""
index = event.GetSelection()
list = self.FindWindowById(self.win['volume']['isosurfs'])
@@ -2113,7 +2113,7 @@
def OnVolumeIsosurfSelect(self, event):
- """Isosurface item selected"""
+ """!Isosurface item selected"""
winUp = self.FindWindowById(self.win['volume']['btnIsosurfMoveUp'])
winDown = self.FindWindowById(self.win['volume']['btnIsosurfMoveDown'])
selection = event.GetSelection()
@@ -2138,7 +2138,7 @@
self.UpdateVolumeIsosurfPage(layer, data)
def OnVolumeIsosurfAdd(self, event):
- """Add new isosurface to the list"""
+ """!Add new isosurface to the list"""
level = self.FindWindowById(self.win['volume']['topo']['const']).GetValue()
@@ -2203,7 +2203,7 @@
event.Skip()
def OnVolumeIsosurfDelete(self, event):
- """Remove isosurface from list"""
+ """!Remove isosurface from list"""
# remove item from list
@@ -2231,7 +2231,7 @@
event.Skip()
def OnVolumeIsosurfMoveUp(self, event):
- """Move isosurface up in the list"""
+ """!Move isosurface up in the list"""
sel = list.GetSelection()
@@ -2261,7 +2261,7 @@
event.Skip()
def OnVolumeIsosurfMoveDown(self, event):
- """Move isosurface dowm in the list"""
+ """!Move isosurface dowm in the list"""
@@ -2291,7 +2291,7 @@
event.Skip()
def UpdatePage(self, pageId):
- """Update dialog (selected page)"""
+ """!Update dialog (selected page)"""
self.pageChanging = True
@@ -2526,7 +2526,7 @@
win.SetValue(data['points']['height']['value'])
def UpdateVolumePage(self, layer, data):
- """Update volume layer properties page"""
+ """!Update volume layer properties page"""
@@ -2557,7 +2557,7 @@
self.UpdateVolumeIsosurfPage(layer, data['attribute'])
def UpdateVolumeIsosurfPage(self, layer, data):
- """Update dialog -- isosurface attributes"""
+ """!Update dialog -- isosurface attributes"""
# isosurface attributes
@@ -2598,11 +2598,11 @@
attrb=attrb, map=data[attrb]['map'])
def SetPage(self, name):
- """Get named page"""
+ """!Get named page"""
self.notebook.SetSelection(self.page[name]['id'])
class ViewPositionWindow(wx.Window):
- """Position control window (for NvizToolWindow)"""
+ """!Position control window (for NvizToolWindow)"""
def __init__(self, parent, id, mapwindow,
size=wx.DefaultSize):
Modified: grass/trunk/gui/wxpython/gui_modules/ogc_services.py
--- grass/trunk/gui/wxpython/gui_modules/ogc_services.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/ogc_services.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -29,7 +29,7 @@
def __init__(self, parent, service = 'wms',
id=wx.ID_ANY,
- """Dialog to import data from WMS server"""
+ """!Dialog to import data from WMS server"""
self.parent = parent # GMFrame
self.service = service # currently only WMS is implemented
@@ -46,7 +46,7 @@
self.SetMinSize((550, 400))
def __createWidgets(self):
- """Create dialog widgets"""
+ """!Create dialog widgets"""
# settings
@@ -94,7 +94,7 @@
self.server.Bind(wx.EVT_TEXT, self.OnServer)
def __doLayout(self):
- """Do dialog layout"""
+ """!Do dialog layout"""
dialogSizer = wx.BoxSizer(wx.VERTICAL)
@@ -156,11 +156,11 @@
self.Layout()
def OnCancel(self, event):
- """Button 'Cancel' pressed -> close the dialog"""
+ """!Button 'Cancel' pressed -> close the dialog"""
self.Close()
def OnConnect(self, event):
- """Button 'Connect' pressed"""
+ """!Button 'Connect' pressed"""
server = self.server.GetValue()
if not server:
self.btn_import.Enable(False)
@@ -207,7 +207,7 @@
def OnServer(self, event):
- """Server settings changed"""
+ """!Server settings changed"""
value = event.GetString()
if value:
self.btn_connect.Enable(True)
@@ -215,16 +215,16 @@
self.btn_connect.Enable(False)
- """Get list of selected layers/styles to be imported"""
+ """!Get list of selected layers/styles to be imported"""
return self.list.GetSelectedLayers()
def GetSettings(self):
- """Get connection settings"""
+ """!Get connection settings"""
return { 'server' : self.server.GetValue() }
class LayersList(TreeListCtrl, listmix.ListCtrlAutoWidthMixin):
def __init__(self, parent, pos=wx.DefaultPosition):
TreeListCtrl.__init__(self, parent, wx.ID_ANY,
@@ -242,7 +242,7 @@
self.root = None
def LoadData(self, data = {}):
# detete first all items
self.root = self.AddRoot(_("Layers"))
@@ -270,15 +270,15 @@
self.Expand(self.root)
def GetItemCount(self):
- """Required for listmix.ListCtrlAutoWidthMixin"""
+ """!Required for listmix.ListCtrlAutoWidthMixin"""
return 0
def GetCountPerPage(self):
return 0
def GetSelectedLayers(self):
- """Get selected layers/styles"""
+ """!Get selected layers/styles"""
layers = {}
for item in self.GetSelections():
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -42,7 +42,7 @@
from debug import Debug as Debug
class Settings:
- """Generic class where to store settings"""
+ """!Generic class where to store settings"""
def __init__(self):
# settings filename
@@ -555,7 +555,7 @@
self.internalSettings['vdigit']['bgmap']['value'] = ''
def ReadSettingsFile(self, settings=None):
- """Reads settings file (mapset, location, gisdbase)"""
+ """!Reads settings file (mapset, location, gisdbase)"""
if settings is None:
settings = self.userSettings
@@ -592,7 +592,7 @@
key='font', subkey='encoding')
def __ReadFile(self, filename, settings=None):
- """Read settings from file to dict"""
+ """!Read settings from file to dict"""
@@ -628,7 +628,7 @@
file.close()
def SaveToFile(self, settings=None):
- """Save settings to the file"""
+ """!Save settings to the file"""
@@ -690,7 +690,7 @@
return filePath
def __parseValue(self, value, read=False):
- """Parse value to be store in settings file"""
+ """!Parse value to be store in settings file"""
if read: # -> read settings (cast values)
if value == 'True':
value = True
@@ -720,7 +720,7 @@
return value
def Get(self, group, key=None, subkey=None, internal=False):
- """Get value by key/subkey
+ """!Get value by key/subkey
Raise KeyError if key is not found
@@ -756,7 +756,7 @@
(group, key, subkey)
def Set(self, group, value, key=None, subkey=None, internal=False):
- """Set value of key/subkey
+ """!Set value of key/subkey
Raise KeyError if group/key is not found
@@ -786,7 +786,7 @@
raise gcmd.SettingsError("%s '%s:%s:%s'" % (_("Unable to set "), group, key, subkey))
def Append(self, dict, group, key, subkey, value):
Create group/key/subkey if not exists
@@ -811,13 +811,13 @@
dict[group][key][subkey] = value
def GetDefaultSettings(self):
- """Get default user settings"""
+ """!Get default user settings"""
return self.defaultSettings
globalSettings = Settings()
class PreferencesDialog(wx.Dialog):
- """User preferences dialog"""
+ """!User preferences dialog"""
def __init__(self, parent, title=_("User GUI settings"),
settings=globalSettings,
@@ -883,7 +883,7 @@
self.SetSize((500, 375))
def __CreateGeneralPage(self, notebook):
- """Create notebook page for general settings"""
+ """!Create notebook page for general settings"""
panel = wx.Panel(parent=notebook, id=wx.ID_ANY)
notebook.AddPage(page=panel, text=_("General"))
@@ -975,7 +975,7 @@
return panel
def __CreateDisplayPage(self, notebook):
- """Create notebook page for display settings"""
+ """!Create notebook page for display settings"""
notebook.AddPage(page=panel, text=_("Display"))
@@ -1121,7 +1121,7 @@
return panel
def __CreateCmdPage(self, notebook):
- """Create notebook page for commad dialog settings"""
+ """!Create notebook page for commad dialog settings"""
notebook.AddPage(page=panel, text=_("Command"))
@@ -1238,7 +1238,7 @@
return panel
def __CreateAttributeManagerPage(self, notebook):
- """Create notebook page for 'Attribute Table Manager' settings"""
+ """!Create notebook page for 'Attribute Table Manager' settings"""
notebook.AddPage(page=panel, text=_("Attributes"))
@@ -1367,7 +1367,7 @@
return panel
def __CreateWorkspacePage(self, notebook):
- """Create notebook page for workspace settings"""
+ """!Create notebook page for workspace settings"""
notebook.AddPage(page=panel, text=_("Workspace"))
return panel
def __CreateAdvancedPage(self, notebook):
- """Create notebook page for advanced settings"""
+ """!Create notebook page for advanced settings"""
notebook.AddPage(page=panel, text=_("Advanced"))
@@ -1503,23 +1503,23 @@
event.Skip()
if self.__UpdateSettings():
file = self.settings.SaveToFile()
self.parent.goutput.WriteLog(_('Settings saved to file \'%s\'.') % file)
self.Close()
self.Close()
self.Close()
- """Button 'Set to default' pressed"""
+ """!Button 'Set to default' pressed"""
self.settings.userSettings = copy.deepcopy(self.settings.defaultSettings)
# update widgets
@@ -1541,7 +1541,7 @@
value = win.SetValue(value)
def __UpdateSettings(self):
- """Update user settings"""
+ """!Update user settings"""
for item in self.winId.keys():
try:
group, key, subkey = item.split(':')
self.SetMinSize(size)
def GetMapsets(self):
- """Get list of checked mapsets"""
+ """!Get list of checked mapsets"""
ms = []
i = 0
for mset in self.all_mapsets:
@@ -1803,7 +1803,7 @@
return ms
class CheckListMapset(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin, listmix.CheckListCtrlMixin):
- """List of mapset/owner/group"""
+ """!List of mapset/owner/group"""
log=None):
@@ -1817,7 +1817,7 @@
listmix.ListCtrlAutoWidthMixin.__init__(self)
def LoadData(self):
self.InsertColumn(0, _('Mapset'))
self.InsertColumn(1, _('Owner'))
### self.InsertColumn(2, _('Group'))
@@ -1852,7 +1852,7 @@
### self.SetColumnWidth(col=1, width=wx.LIST_AUTOSIZE)
- """Mapset checked/unchecked"""
+ """!Mapset checked/unchecked"""
mapset = self.parent.all_mapsets[index]
if mapset == 'PERMANENT' or mapset == self.parent.curr_mapset:
self.CheckItem(index, True)
Modified: grass/trunk/gui/wxpython/gui_modules/profile.py
--- grass/trunk/gui/wxpython/gui_modules/profile.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/profile.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -594,7 +594,7 @@
self.client.SaveFile()
def DrawPointLabel(self, dc, mDataDict):
- """This is the fuction that defines how the pointLabels are plotted
+ """!This is the fuction that defines how the pointLabels are plotted
dc - DC that will be passed
mDataDict - Dictionary of data that you want to use for the pointLabel
@@ -891,7 +891,7 @@
self._do_layout()
- """Do layout"""
+ """!Do layout"""
# dialog layout
@@ -1071,7 +1071,7 @@
self.properties['font']['wxfont'].SetWeight(weight)
fileSettings = {}
@@ -1081,12 +1081,12 @@
self.Close()
self.Close()
self.Close()
class OptDialog(wx.Dialog):
@@ -1125,7 +1125,7 @@
self._do_layout()
- """Do layout"""
+ """!Do layout"""
# dialog layout
@@ -1416,7 +1416,7 @@
self.properties['legend']['enabled'] = self.FindWindowById(self.wxId['legend']['enabled']).IsChecked()
fileSettings = {}
@@ -1426,10 +1426,10 @@
self.Close()
self.Close()
self.Close()
Modified: grass/trunk/gui/wxpython/gui_modules/prompt.py
--- grass/trunk/gui/wxpython/gui_modules/prompt.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/prompt.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -31,14 +31,14 @@
from grass.script import core as grass
class GPrompt:
- """Interactive GRASS prompt"""
+ """!Interactive GRASS prompt"""
def __init__(self, parent):
self.panel, self.input = self.__create()
def __create(self):
- """Create widget"""
+ """!Create widget"""
cmdprompt = wx.Panel(self.parent)
label = wx.Button(parent = cmdprompt, id = wx.ID_ANY,
@@ -85,19 +85,19 @@
return cmdprompt, cmdinput
def GetPanel(self):
- """Get main widget panel"""
+ """!Get main widget panel"""
return self.panel
def GetInput(self):
- """Get main prompt widget"""
+ """!Get main prompt widget"""
return self.input
def OnCmdErase(self, event):
- """Erase command prompt"""
+ """!Erase command prompt"""
self.input.SetValue('')
def OnRunCmd(self, event):
- """Run command"""
+ """!Run command"""
cmdString = event.GetString()
if self.parent.GetName() != "LayerManager":
@@ -115,7 +115,7 @@
self.OnUpdateStatusBar(None)
def OnUpdateStatusBar(self, event):
- """Update Layer Manager status bar"""
+ """!Update Layer Manager status bar"""
return
@@ -192,7 +192,7 @@
self.dropdownlistbox.Bind(wx.EVT_LIST_COL_CLICK, self.OnListColClick)
def _updateDataList(self, choices):
- """Update data list"""
+ """!Update data list"""
# delete, if need, all the previous data
if self.dropdownlistbox.GetColumnCount() != 0:
self.dropdownlistbox.DeleteAllColumns()
@@ -206,7 +206,7 @@
self.SetColumnCount(numVal)
def _setListSize(self):
- """Set list size"""
+ """!Set list size"""
choices = self._choices
longest = 0
for choice in choices:
@@ -287,7 +287,7 @@
self._showDropDown(False)
def GetListCtrl(self):
- """Method required by listmix.ColumnSorterMixin"""
+ """!Method required by listmix.ColumnSorterMixin"""
return self.dropdownlistbox
def SetChoices(self, choices, type = 'module'):
@@ -320,18 +320,18 @@
self._colFetch = -1
def OnListClick(self, evt):
- """Left mouse button pressed"""
+ """!Left mouse button pressed"""
toSel, flag = self.dropdownlistbox.HitTest( evt.GetPosition() )
#no values on poition, return
if toSel == -1: return
self.dropdownlistbox.Select(toSel)
def OnListDClick(self, evt):
- """Mouse button double click"""
+ """!Mouse button double click"""
self._setValueFromSelected()
def OnListColClick(self, evt):
- """Left mouse button pressed on column"""
+ """!Left mouse button pressed on column"""
col = evt.GetColumn()
# reverse the sort
if col == self._colSearch:
@@ -341,12 +341,12 @@
evt.Skip()
def OnListItemSelected(self, event):
- """Item selected"""
+ """!Item selected"""
event.Skip()
def OnEnteredText(self, event):
- """Text entered"""
+ """!Text entered"""
text = event.GetString()
if not text:
@@ -445,7 +445,7 @@
event.Skip()
def OnControlChanged(self, event):
- """Control changed"""
+ """!Control changed"""
if self.IsShown():
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -54,7 +54,7 @@
USE_GPNMCOMP = True
class Layer(object):
- """Virtual class which stores information about layers (map layers and
+ """!Virtual class which stores information about layers (map layers and
overlays) of the map composition.
For map layer use MapLayer class.
@@ -108,7 +108,7 @@
(self.name, self.GetCmd(string=True)))
def Render(self):
- """Render layer to image
+ """!Render layer to image
@return rendered image filename
@return None on error
@@ -217,7 +217,7 @@
return self.cmd
def GetType(self):
- """Get map layer type"""
+ """!Get map layer type"""
return self.type
def GetOpacity(self, float=False):
@@ -234,7 +234,7 @@
return int (self.opacity * 100)
def GetName(self, fullyQualified=True):
- """Get map layer name
+ """!Get map layer name
@param fullyQualified if True return 'name at mapset' otherwise
('name', 'mapset')
@@ -250,11 +250,11 @@
'mapset' : '' }
def IsActive(self):
- """Check if layer is activated for rendering"""
+ """!Check if layer is activated for rendering"""
return self.active
def SetType(self, type):
- """Set layer type"""
+ """!Set layer type"""
if type not in ('raster', '3d-raster', 'vector',
'overlay', 'command',
'shaded', 'rgb', 'his', 'rastarrow', 'rastnum',
@@ -265,19 +265,19 @@
self.type = type
def SetName(self, name):
- """Set layer name"""
+ """!Set layer name"""
self.name = name
def SetActive(self, enable=True):
- """Active or deactive layer"""
+ """!Active or deactive layer"""
self.active = bool(enable)
def SetHidden(self, enable=False):
- """Hide or show map layer in Layer Manager"""
+ """!Hide or show map layer in Layer Manager"""
self.hidden = bool(enable)
def SetOpacity(self, value):
- """Set opacity value"""
+ """!Set opacity value"""
if value < 0:
value = 0.
elif value > 1:
@@ -286,7 +286,7 @@
self.opacity = float(value)
def SetCmd(self, cmd):
- """Set new command for layer"""
+ """!Set new command for layer"""
if self.type == 'command':
self.cmd = []
for c in cmd:
@@ -299,7 +299,7 @@
self.force_render = True
class MapLayer(Layer):
- """Represents map layer in the map canvas"""
+ """!Represents map layer in the map canvas"""
def __init__(self, type, cmd, name=None,
active=True, hidden=False, opacity=1.0):
@@ -332,7 +332,7 @@
return self.name
class Overlay(Layer):
- """Represents overlay displayed in map canvas"""
+ """!Represents overlay displayed in map canvas"""
def __init__(self, id, type, cmd,
active=True, hidden=True, opacity=1.0):
@@ -445,7 +445,7 @@
os.environ["GISRC"] = gisrc_orig
def GetWindow(self):
- """Read WIND file and set up self.wind dictionary"""
+ """!Read WIND file and set up self.wind dictionary"""
# FIXME: duplicated region WIND == g.region (at least some values)
filename = os.path.join (self.env['GISDBASE'],
self.env['LOCATION_NAME'],
@@ -526,7 +526,7 @@
return new
def AlignExtentFromDisplay(self):
- """Align region extent based on display size from center point"""
+ """!Align region extent based on display size from center point"""
# calculate new bounding box based on center of display
if self.region["ewres"] > self.region["nsres"]:
@@ -554,7 +554,7 @@
self.region['s'] = -90.0
def ChangeMapSize(self, (width, height)):
- """Change size of rendered map.
+ """!Change size of rendered map.
@param width,height map size
@@ -671,7 +671,7 @@
return region
def GetCurrentRegion(self):
- """Get current display region settings"""
+ """!Get current display region settings"""
return self.region
def SetRegion(self, windres=False):
@@ -1251,7 +1251,7 @@
return overlay
def GetOverlay(self, id, list=False):
- """Return overlay(s) with 'id'
+ """!Return overlay(s) with 'id'
@param id overlay id
@param list return list of overlays of True
@@ -1275,7 +1275,7 @@
return ovl
def DeleteOverlay(self, overlay):
- """Delete overlay
+ """!Delete overlay
@@ -1320,7 +1320,7 @@
self.layers = []
def ReverseListOfLayers(self):
- """Reverse list of layers"""
+ """!Reverse list of layers"""
return self.layers.reverse()
Modified: grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
--- grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -36,7 +36,7 @@
sys.path.append(imagepath)
class SQLFrame(wx.Frame):
- """SQL Frame class"""
+ """!SQL Frame class"""
def __init__(self, parent, id, title, vectmap, qtype="select"):
wx.Frame.__init__(self, parent, id, title)
@@ -219,7 +219,7 @@
self.Show(True)
def GetColumns(self):
- """Get columns"""
+ """!Get columns"""
ret = gcmd.RunCommand('db.describe',
quiet = True,
read = True,
@@ -243,7 +243,7 @@
self.list_values.Clear()
column = self.list_columns.GetString(idx)
i = 0
- for line in os.popen("""db.select -c database=%s driver=%s sql="SELECT %s FROM %s" """ %\
+ for line in os.popen("""!db.select -c database=%s driver=%s sql="SELECT %s FROM %s" """ %\
(self.database,self.driver,column,self.tablename)):
if justsample and i < 256 or \
not justsample:
@@ -314,7 +314,7 @@
pass
def OnVerify(self,event):
if self.text_sql.GetValue():
- if os.system("""db.select -t driver=%s database=%s sql="SELECT * FROM %s WHERE %s" """ % \
+ if os.system("""!db.select -t driver=%s database=%s sql="SELECT * FROM %s WHERE %s" """ % \
(self.driver, self.database,self.tablename,
self.text_sql.GetValue().strip().replace("\n"," "))):
# FIXME: LOG
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -40,12 +40,12 @@
sys.path.append(gmpath)
class AbstractToolbar(object):
- """Abstract toolbar class"""
+ """!Abstract toolbar class"""
def __init__(self):
pass
def InitToolbar(self, parent, toolbar, toolData):
- """Initialize toolbar, i.e. add tools to the toolbar
+ """!Initialize toolbar, i.e. add tools to the toolbar
@return list of ids (of added tools)
@@ -59,12 +59,12 @@
def ToolbarData(self):
- """Toolbar data"""
+ """!Toolbar data"""
return None
def CreateTool(self, parent, toolbar, tool, label, bitmap, kind,
shortHelp, longHelp, handler):
- """Add tool to the toolbar
+ """!Add tool to the toolbar
@return id of tool
@@ -84,11 +84,11 @@
return tool
def GetToolbar(self):
- """Get toolbar widget reference"""
+ """!Get toolbar widget reference"""
return self._toolbar
def EnableLongHelp(self, enable=True):
- """Enable/disable long help
+ """!Enable/disable long help
@param enable True for enable otherwise disable
@@ -102,7 +102,7 @@
self._toolbar.SetToolLongHelp(tool[0], "")
def OnTool(self, event):
- """Tool selected"""
+ """!Tool selected"""
if self.parent.toolbars['vdigit']:
# update vdigit toolbar (unselect currently selected tool)
id = self.parent.toolbars['vdigit'].GetAction(type='id')
@@ -124,18 +124,18 @@
self._toolbar.ToggleTool(self.action['id'], True)
def GetAction(self, type='desc'):
- """Get current action info"""
+ """!Get current action info"""
return self.action.get(type, '')
def SelectDefault(self, event):
- """Select default tool"""
+ """!Select default tool"""
self._toolbar.ToggleTool(self.defaultAction['id'], True)
self.defaultAction['bind'](event)
self.action = { 'id' : self.defaultAction['id'],
'desc' : self.defaultAction.get('desc', '') }
def FixSize(self, width):
- """Fix toolbar width on Windows
+ """!Fix toolbar width on Windows
@todo Determine why combobox causes problems here
@@ -183,7 +183,7 @@
self.FixSize(width = 90)
self.displaymap = wx.NewId()
self.rendermap = wx.NewId()
@@ -276,7 +276,7 @@
self.mapdisplay.toolbars['nviz'].OnExit()
def Enable2D(self, enabled):
- """Enable/Disable 2D display mode specific tools"""
+ """!Enable/Disable 2D display mode specific tools"""
for tool in (self.pointer,
self.query,
self.pan,
@@ -310,7 +310,7 @@
self.toolbar.Realize()
@@ -356,7 +356,7 @@
def OnZoomMap(self, event):
- """Zoom to selected map"""
+ """!Zoom to selected map"""
self.mapdisplay.MapWindow.ZoomToMap(layers = self.mapcontent.GetListOfLayers())
event.Skip()
@@ -576,7 +576,7 @@
return data
- """Tool selected -> disable selected tool in map toolbar"""
+ """!Tool selected -> disable selected tool in map toolbar"""
# update map toolbar (unselect currently selected tool)
id = self.parent.toolbars['map'].GetAction(type='id')
self.parent.toolbars['map'].toolbar.ToggleTool(id, False)
@@ -611,7 +611,7 @@
self.parent.MapWindow.OnMiddleDown(None)
def OnAddPoint(self, event):
- """Add point to the vector map Laier"""
+ """!Add point to the vector map Laier"""
Debug.msg (2, "VDigitToolbar.OnAddPoint()")
self.action = { 'desc' : "addLine",
'type' : "point",
@@ -619,7 +619,7 @@
self.parent.MapWindow.mouse['box'] = 'point'
def OnAddLine(self, event):
- """Add line to the vector map layer"""
+ """!Add line to the vector map layer"""
Debug.msg (2, "VDigitToolbar.OnAddLine()")
'type' : "line",
@@ -628,7 +628,7 @@
### self.parent.MapWindow.polycoords = [] # reset temp line
def OnAddBoundary(self, event):
- """Add boundary to the vector map layer"""
+ """!Add boundary to the vector map layer"""
Debug.msg (2, "VDigitToolbar.OnAddBoundary()")
if self.action['desc'] != 'addLine' or \
self.action['type'] != 'boundary':
@@ -639,7 +639,7 @@
self.parent.MapWindow.mouse['box'] = 'line'
def OnAddCentroid(self, event):
- """Add centroid to the vector map layer"""
+ """!Add centroid to the vector map layer"""
Debug.msg (2, "VDigitToolbar.OnAddCentroid()")
'type' : "centroid",
@@ -647,7 +647,7 @@
def OnExit (self, event=None):
- """Quit digitization tool"""
+ """!Quit digitization tool"""
# stop editing of the currently selected map layer
if self.mapLayer:
self.StopEditing()
@@ -665,14 +665,14 @@
def OnMoveVertex(self, event):
- """Move line vertex"""
+ """!Move line vertex"""
Debug.msg(2, "Digittoolbar.OnMoveVertex():")
self.action = { 'desc' : "moveVertex",
'id' : self.moveVertex }
def OnAddVertex(self, event):
- """Add line vertex"""
+ """!Add line vertex"""
Debug.msg(2, "Digittoolbar.OnAddVertex():")
self.action = { 'desc' : "addVertex",
'id' : self.addVertex }
@@ -680,7 +680,7 @@
def OnRemoveVertex(self, event):
- """Remove line vertex"""
+ """!Remove line vertex"""
Debug.msg(2, "Digittoolbar.OnRemoveVertex():")
self.action = { 'desc' : "removeVertex",
'id' : self.removeVertex }
@@ -688,49 +688,49 @@
def OnSplitLine(self, event):
- """Split line"""
+ """!Split line"""
Debug.msg(2, "Digittoolbar.OnSplitLine():")
self.action = { 'desc' : "splitLine",
'id' : self.splitLine }
def OnEditLine(self, event):
- """Edit line"""
+ """!Edit line"""
Debug.msg(2, "Digittoolbar.OnEditLine():")
self.action = { 'desc' : "editLine",
'id' : self.editLine }
def OnMoveLine(self, event):
- """Move line"""
+ """!Move line"""
Debug.msg(2, "Digittoolbar.OnMoveLine():")
self.action = { 'desc' : "moveLine",
'id' : self.moveLine }
self.parent.MapWindow.mouse['box'] = 'box'
def OnDeleteLine(self, event):
- """Delete line"""
+ """!Delete line"""
Debug.msg(2, "Digittoolbar.OnDeleteLine():")
self.action = { 'desc' : "deleteLine",
'id' : self.deleteLine }
def OnDisplayCats(self, event):
- """Display/update categories"""
+ """!Display/update categories"""
Debug.msg(2, "Digittoolbar.OnDisplayCats():")
self.action = { 'desc' : "displayCats",
'id' : self.displayCats }
def OnDisplayAttr(self, event):
- """Display/update attributes"""
+ """!Display/update attributes"""
Debug.msg(2, "Digittoolbar.OnDisplayAttr():")
self.action = { 'desc' : "displayAttrs",
'id' : self.displayAttr }
def OnCopyCA(self, event):
- """Copy categories/attributes menu"""
+ """!Copy categories/attributes menu"""
point = wx.GetMousePosition()
toolMenu = wx.Menu()
# Add items to the menu
@@ -759,7 +759,7 @@
self.toolbar[0].ToggleTool(self.copyCats, False)
def OnCopyCats(self, event):
- """Copy categories"""
+ """!Copy categories"""
if self.action['desc'] == 'copyCats': # select previous action
self.toolbar[0].ToggleTool(self.addPoint, True)
@@ -784,13 +784,13 @@
def OnUndo(self, event):
- """Undo previous changes"""
+ """!Undo previous changes"""
self.parent.digit.Undo()
event.Skip()
def EnableUndo(self, enable=True):
- """Enable 'Undo' in toolbar
+ """!Enable 'Undo' in toolbar
@param enable False for disable
@@ -802,7 +802,7 @@
self.toolbar[0].EnableTool(self.undo, False)
def OnSettings(self, event):
- """Show settings dialog"""
+ """!Show settings dialog"""
if self.parent.digit is None:
reload(vdigit)
@@ -815,7 +815,7 @@
self.settingsDialog.Show()
def OnAdditionalToolMenu(self, event):
- """Menu for additional tools"""
+ """!Menu for additional tools"""
@@ -900,7 +900,7 @@
self.toolbar[0].ToggleTool(self.additionalTools, False)
- """Copy selected features from (background) vector map"""
+ """!Copy selected features from (background) vector map"""
if self.action['desc'] == 'copyLine': # select previous action
@@ -913,7 +913,7 @@
def OnFlip(self, event):
- """Flip selected lines/boundaries"""
+ """!Flip selected lines/boundaries"""
if self.action['desc'] == 'flipLine': # select previous action
@@ -926,7 +926,7 @@
def OnMerge(self, event):
- """Merge selected lines/boundaries"""
+ """!Merge selected lines/boundaries"""
if self.action['desc'] == 'mergeLine': # select previous action
@@ -939,7 +939,7 @@
def OnBreak(self, event):
- """Break selected lines/boundaries"""
+ """!Break selected lines/boundaries"""
if self.action['desc'] == 'breakLine': # select previous action
@@ -952,7 +952,7 @@
def OnSnap(self, event):
- """Snap selected features"""
+ """!Snap selected features"""
if self.action['desc'] == 'snapLine': # select previous action
@@ -965,7 +965,7 @@
- """Connect selected lines/boundaries"""
+ """!Connect selected lines/boundaries"""
if self.action['desc'] == 'connectLine': # select previous action
@@ -978,7 +978,7 @@
- """Query selected lines/boundaries"""
+ """!Query selected lines/boundaries"""
if self.action['desc'] == 'queryLine': # select previous action
@@ -992,7 +992,7 @@
def OnZBulk(self, event):
- """Z bulk-labeling selected lines/boundaries"""
+ """!Z bulk-labeling selected lines/boundaries"""
if self.action['desc'] == 'zbulkLine': # select previous action
@@ -1005,7 +1005,7 @@
def OnTypeConversion(self, event):
- """Feature type conversion
+ """!Feature type conversion
Supported conversions:
- point <-> centroid
@@ -1138,7 +1138,7 @@
return True
def StopEditing (self):
- """Stop editing of selected vector map layer.
+ """!Stop editing of selected vector map layer.
@return True on success
@return False on failure
@@ -1240,7 +1240,7 @@
return layerNameList
def GetLayer(self):
- """Get selected layer for editing -- MapLayer instance"""
+ """!Get selected layer for editing -- MapLayer instance"""
return self.mapLayer
class ProfileToolbar(AbstractToolbar):
@@ -1262,7 +1262,7 @@
self.transect = wx.NewId()
self.addraster = wx.NewId()
@@ -1333,7 +1333,7 @@
self.settings = wx.NewId()
self.quit = wx.NewId()
@@ -1356,7 +1356,7 @@
self.parent.nvizToolWin.Hide()
- """Quit nviz tool (swith to 2D mode)"""
+ """!Quit nviz tool (swith to 2D mode)"""
# hide dialogs if still open
if self.parent.nvizToolWin:
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -64,7 +64,7 @@
def GetLayerNameFromCmd(dcmd, fullyQualified=False, param=None,
layerType=None):
- """Get map name from GRASS command
+ """!Get map name from GRASS command
@param dcmd GRASS command (given as tuple)
@param fullyQualified change map name to be fully qualified
@@ -127,7 +127,7 @@
return mapname
def GetValidLayerName(name):
- """Make layer name SQL compliant, based on G_str_to_sql()
+ """!Make layer name SQL compliant, based on G_str_to_sql()
@todo: Better use directly GRASS Python SWIG...
@@ -157,7 +157,7 @@
return retName
def ListOfCatsToRange(cats):
- """Convert list of category number to range(s)
+ """!Convert list of category number to range(s)
Used for example for d.vect cats=[range]
@@ -195,7 +195,7 @@
return catstr.strip(',')
def ListOfMapsets(all=False):
- """Get list of available/accessible mapsets
+ """!Get list of available/accessible mapsets
@param all if True get list of all mapsets
@@ -230,11 +230,11 @@
return mapsets
def ListSortLower(list):
- """Sort list items (not case-sensitive)"""
+ """!Sort list items (not case-sensitive)"""
list.sort(cmp=lambda x, y: cmp(x.lower(), y.lower()))
def GetVectorNumberOfLayers(vector):
- """Get list of vector layers"""
+ """!Get list of vector layers"""
cmdlist = ['v.category',
'input=%s' % vector,
'option=report']
@@ -262,7 +262,7 @@
return layers
def Deg2DMS(lon, lat):
- """Convert deg value to dms string
+ """!Convert deg value to dms string
@param lat latitude
@param lon longitude
@@ -301,7 +301,7 @@
return slon + hlon + '; ' + slat + hlat
def __ll_parts(value):
- """Converts deg to d:m:s string"""
+ """!Converts deg to d:m:s string"""
if value == 0.0:
return '00:00:00.0000'
@@ -340,7 +340,7 @@
return scmd
def CmdToTuple(cmd):
- """Convert command list to tuple for gcmd.RunCommand()"""
+ """!Convert command list to tuple for gcmd.RunCommand()"""
if len(cmd) < 1:
return None
@@ -358,7 +358,7 @@
dcmd)
def PathJoin(*args):
- """Check path created by os.path.join"""
+ """!Check path created by os.path.join"""
path = os.path.join(*args)
if platform.system() == 'Windows' and \
'/' in path:
@@ -367,7 +367,7 @@
return path
def reexec_with_pythonw():
- """Re-execute Python on Mac OS"""
+ """!Re-execute Python on Mac OS"""
if sys.platform == 'darwin' and \
not sys.executable.endswith('MacOS/Python'):
print >> sys.stderr, 're-executing using pythonw'
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -68,7 +68,7 @@
Abstract digitization class
def __init__(self, mapwindow):
- """Initialization
+ """!Initialization
@param mapwindow reference to mapwindow (MapFrame) instance
@param settings initial settings of digitization tool
@@ -87,7 +87,7 @@
pass
def SetCategoryNextToUse(self):
- """Find maximum category number in the map layer
+ """!Find maximum category number in the map layer
and update Digit.settings['category']
@return 'True' on success, 'False' on failure
@@ -102,14 +102,14 @@
value=cat)
def SetCategory(self):
- """Return category number to use (according Settings)"""
+ """!Return category number to use (according Settings)"""
if UserSettings.Get(group='vdigit', key="categoryMode", subkey='selection') == 0:
self.SetCategoryNextToUse()
return UserSettings.Get(group='vdigit', key="category", subkey='value')
def SetMapName(self, map):
- """Set map name
+ """!Set map name
@param map map name to be set up or None (will close currently edited map)
@@ -142,7 +142,7 @@
self.digit.InitCats()
def SelectLinesByQueryThresh(self):
- """Generic method used for SelectLinesByQuery()
+ """!Generic method used for SelectLinesByQuery()
-- to get threshold value"""
thresh = 0.0
if UserSettings.Get(group='vdigit', key='query', subkey='selection') == 0:
@@ -157,7 +157,7 @@
return thresh
def GetSelectType(self):
- """Get type(s) to be selected
+ """!Get type(s) to be selected
Used by SelectLinesByBox() and SelectLinesByPoint()"""
@@ -173,7 +173,7 @@
return type
def SelectLinesFromBackgroundMap(self, pos1, pos2):
- """Select features from background map
+ """!Select features from background map
@param pos1,pos2 bounding box
@@ -224,7 +224,7 @@
Under development (wxWidgets C/C++ background)
- """Initialization
@@ -245,7 +245,7 @@
del self.digit
def AddPoint (self, map, point, x, y, z=None):
- """Add new point/centroid
+ """!Add new point/centroid
@param map map name (unused, for compatability with VEdit)
@param point feature type (if true point otherwise centroid)
@@ -278,7 +278,7 @@
return ret
def AddLine (self, map, line, coords):
- """Add line/boundary
+ """!Add line/boundary
@param line feature type (if True line, otherwise boundary)
@@ -317,7 +317,7 @@
return ret
def DeleteSelectedLines(self):
- """Delete selected features
+ """!Delete selected features
@return number of deleted lines
@@ -329,7 +329,7 @@
return nlines
def MoveSelectedLines(self, move):
- """Move selected features
+ """!Move selected features
@param move direction (x, y)
@@ -350,7 +350,7 @@
return nlines
def MoveSelectedVertex(self, coords, move):
- """Move selected vertex of the line
+ """!Move selected vertex of the line
@param coords click coordinates
@param move X,Y direction
@@ -374,7 +374,7 @@
return moved
def AddVertex(self, coords):
- """Add new vertex to the selected line/boundary on position 'coords'
+ """!Add new vertex to the selected line/boundary on position 'coords'
@param coords coordinates to add vertex
@@ -391,7 +391,7 @@
return added
def RemoveVertex(self, coords):
- """Remove vertex from the selected line/boundary on position 'coords'
+ """!Remove vertex from the selected line/boundary on position 'coords'
@param coords coordinates to remove vertex
@@ -409,7 +409,7 @@
def SplitLine(self, coords):
- """Split selected line/boundary on position 'coords'
+ """!Split selected line/boundary on position 'coords'
@param coords coordinates to split line
@@ -426,7 +426,7 @@
return ret
def EditLine(self, line, coords):
- """Edit existing line/boundary
+ """!Edit existing line/boundary
@param line id of line to be modified
@param coords list of coordinates of modified line
@@ -465,7 +465,7 @@
return ret
def FlipLine(self):
@return number of modified lines
@return -1 on error
@@ -478,7 +478,7 @@
return ret
def MergeLine(self):
@return -1 on error
@@ -491,7 +491,7 @@
return ret
def BreakLine(self):
@return -1 on error
@@ -504,7 +504,7 @@
return ret
def SnapLine(self):
- """Snap selected lines/boundaries
+ """!Snap selected lines/boundaries
@return on success
@return -1 on error
@@ -518,7 +518,7 @@
return ret
def ConnectLine(self):
@return 1 lines connected
@return 0 lines not connected
@@ -533,7 +533,7 @@
return ret
def CopyLine(self, ids=[]):
- """Copy features from (background) vector map
+ """!Copy features from (background) vector map
@param ids list of line ids to be copied
@@ -554,7 +554,7 @@
return ret
def CopyCats(self, fromId, toId, copyAttrb=False):
- """Copy given categories to objects with id listed in ids
+ """!Copy given categories to objects with id listed in ids
@param cats ids of 'from' feature
@param ids ids of 'to' feature(s)
@@ -573,7 +573,7 @@
return ret
def SelectLinesByQuery(self, pos1, pos2):
- """Select features by query
+ """!Select features by query
@param pos1, pos2 bounding box definition
@@ -600,14 +600,14 @@
return ids
def GetLineCats(self, line=-1):
- """Get layer/category pairs from given (selected) line
+ """!Get layer/category pairs from given (selected) line
@param line feature id (-1 for first selected line)
return dict(self.digit.GetLineCats(line))
def SetLineCats(self, line, layer, cats, add=True):
- """Set categories for given line and layer
+ """!Set categories for given line and layer
@param layer layer number (-1 for first selected line)
@@ -625,11 +625,11 @@
return ret
def GetLayers(self):
- """Get list of layers"""
+ """!Get list of layers"""
return self.digit.GetLayers()
def TypeConvForSelectedLines(self):
- """Feature type conversion for selected objects.
+ """!Feature type conversion for selected objects.
@@ -646,7 +646,7 @@
return ret
def Undo(self, level=-1):
- """Undo action
+ """!Undo action
@param level levels to undo (0 to revert all)
@@ -666,11 +666,11 @@
self.toolbar.EnableUndo(False)
def GetUndoLevel(self):
- """Get undo level (number of active changesets)"""
+ """!Get undo level (number of active changesets)"""
return self.digit.GetUndoLevel()
- """Update digit settigs"""
+ """!Update digit settigs"""
if not self.digit:
return
@@ -682,7 +682,7 @@
subkey='enabled'))
def __getSnapThreshold(self):
- """Get snap mode and threshold value
+ """!Get snap mode and threshold value
@return (snap, thresh)
@@ -699,7 +699,7 @@
class Digit(VDigit):
- """Default digit class"""
+ """!Default digit class"""
VDigit.__init__(self, mapwindow)
self.type = 'vdigit'
@@ -708,9 +708,9 @@
VDigit.__del__(self)
class AbstractDisplayDriver:
- """Abstract classs for display driver"""
+ """!Abstract classs for display driver"""
def __init__(self, parent, mapwindow):
- """Initialization
@param parent
@param mapwindow reference to mapwindow (MFrame)
@@ -722,7 +722,7 @@
self.selected = [] # list of selected objects (grassId!)
def GetThreshold(self, type='snapping', value=None, units=None):
- """Return threshold in map units
+ """!Return threshold in map units
@param value threshold to be set up
@param units units (map, screen)
@@ -757,7 +757,7 @@
Display driver using grass7_wxdriver module
- """Initialization
@param parent
@@ -782,18 +782,18 @@
self.UpdateSettings()
def GetDevice(self):
- """Get device"""
+ """!Get device"""
return self.__display
def SetDevice(self, pdc):
- """Set device for driver
+ """!Set device for driver
@param pdc wx.PseudoDC instance
self.__display.SetDevice(pdc)
def Reset(self, map):
- """Reset map
+ """!Reset map
Open or close the vector map by driver.
@@ -816,7 +816,7 @@
return ret
def ReloadMap(self):
- """Reload map (close and re-open).
+ """!Reload map (close and re-open).
Needed for v.edit, TODO: get rid of that..."""
@@ -824,7 +824,7 @@
self.__display.ReloadMap()
def DrawMap(self):
- """Draw vector map layer content
+ """!Draw vector map layer content
@return wx.Image instance
@@ -834,7 +834,7 @@
return nlines
def SelectLinesByBox(self, begin, end, type=0, drawSeg=False):
- """Select vector features by given bounding box.
+ """!Select vector features by given bounding box.
If type is given, only vector features of given type are selected.
@@ -856,7 +856,7 @@
return nselected
def SelectLineByPoint(self, point, type=0):
- """Select vector feature by coordinates of click point (in given threshold).
+ """!Select vector feature by coordinates of click point (in given threshold).
@@ -876,7 +876,7 @@
return None
def GetSelected(self, grassId=True):
- """Return ids of selected vector features
+ """!Return ids of selected vector features
@param grassId if grassId is True returns GRASS ids, otherwise
internal ids of objects drawn in PseudoDC"""
@@ -891,15 +891,15 @@
return selected
def GetSelectedCoord(self):
- """Return ids of selected vector features and their coordinates"""
+ """!Return ids of selected vector features and their coordinates"""
return dict(self.__display.GetSelectedCoord())
def GetRegionSelected(self):
- """Get minimal region extent of selected features (ids/cats)"""
+ """!Get minimal region extent of selected features (ids/cats)"""
return self.__display.GetRegionSelected()
def GetDuplicates(self):
- """Return ids of (selected) duplicated vector features
+ """!Return ids of (selected) duplicated vector features
# -> id : (list of ids)
dupl = dict(self.__display.GetDuplicates())
@@ -926,7 +926,7 @@
return dupl_full
def GetSelectedVertex(self, coords):
- """Get PseudoDC id(s) of vertex (of selected line)
+ """!Get PseudoDC id(s) of vertex (of selected line)
@param coords click position
@@ -941,7 +941,7 @@
return id
def SetSelected(self, id, field=-1):
- """Set selected vector features
+ """!Set selected vector features
@param id list of feature ids/categories to be selected
@param field field(layer) number, -1 for ids instead of cats
@@ -952,7 +952,7 @@
self.__display.SetSelected(id, field)
def UnSelect(self, id):
- """Unselect vector features
+ """!Unselect vector features
@param id list of feature id(s)
@@ -963,7 +963,7 @@
self.__display.UnSelect(id)
def UpdateRegion(self):
- """Set geographical region
+ """!Set geographical region
Needed for 'cell2pixel' conversion"""
@@ -981,7 +981,7 @@
map.width, map.height)
def GetMapBoundingBox(self):
- """Return bounding box of given vector map layer
+ """!Return bounding box of given vector map layer
@return (w,s,b,e,n,t)
@@ -989,11 +989,11 @@
return self.__display.GetMapBoundingBox()
def DrawSelected(self, draw=True):
- """Show/hide selected features"""
+ """!Show/hide selected features"""
self.__display.DrawSelected(draw)
def UpdateSettings(self, alpha=255):
- """Update display driver settings"""
+ """!Update display driver settings"""
# TODO map units
if not self.__display:
@@ -1119,7 +1119,7 @@
mainSizer.Fit(self)
def __CreateSymbologyPage(self, notebook):
- """Create notebook page concerning with symbology settings"""
+ """!Create notebook page concerning with symbology settings"""
notebook.AddPage(page=panel, text=_("Symbology"))
@@ -1157,7 +1157,7 @@
return panel
@@ -1303,7 +1303,7 @@
return panel
def __CreateQueryPage(self, notebook):
- """Create notebook page for query tool"""
+ """!Create notebook page for query tool"""
notebook.AddPage(page=panel, text=_("Query tool"))
@@ -1385,7 +1385,7 @@
return panel
def __CreateAttributesPage(self, notebook):
@@ -1514,7 +1514,7 @@
(_("Direction"), "direction"),)
def OnChangeCategoryMode(self, event):
- """Change category mode"""
+ """!Change category mode"""
mode = event.GetSelection()
UserSettings.Set(group='vdigit', key="categoryMode", subkey='selection', value=mode)
@@ -1530,7 +1530,7 @@
self.category.SetValue(UserSettings.Get(group='vdigit', key='category', subkey='value'))
def OnChangeLayer(self, event):
- """Layer changed"""
+ """!Layer changed"""
layer = int(event.GetString())
if layer > 0:
UserSettings.Set(group='vdigit', key='layer', subkey='value', value=layer)
@@ -1540,11 +1540,11 @@
event.Skip()
def OnChangeAddRecord(self, event):
- """Checkbox 'Add new record' status changed"""
+ """!Checkbox 'Add new record' status changed"""
self.category.SetValue(self.parent.digit.SetCategory())
def OnChangeSnappingValue(self, event):
- """Change snapping value - update static text"""
+ """!Change snapping value - update static text"""
value = self.snappingValue.GetValue()
if value < 0:
@@ -1572,7 +1572,7 @@
event.Skip()
def OnChangeSnappingUnits(self, event):
- """Snapping units change -> update static text"""
+ """!Snapping units change -> update static text"""
units = self.snappingUnit.GetStringSelection()
threshold = self.parent.digit.driver.GetThreshold(value=value, units=units)
@@ -1589,7 +1589,7 @@
event.Skip()
def OnChangeQuery(self, event):
- """Change query"""
+ """!Change query"""
if self.queryLength.GetValue():
# length
self.queryLengthSL.Enable(True)
@@ -1604,7 +1604,7 @@
self.queryDangleValue.Enable(True)
def OnSave(self, event):
- """Button 'Save' clicked"""
+ """!Button 'Save' clicked"""
self.parent.toolbars['vdigit'].settingsDialog = None
@@ -1620,11 +1620,11 @@
event.Skip()
def OnApply(self, event):
- """Button 'Apply' clicked"""
+ """!Button 'Apply' clicked"""
- """Button 'Cancel' clicked"""
+ """!Button 'Cancel' clicked"""
self.Destroy()
@@ -1632,7 +1632,7 @@
event.Skip()
- """Update UserSettings"""
+ """!Update UserSettings"""
# symbology
for key, (enabled, color) in self.symbology.iteritems():
@@ -1907,19 +1907,19 @@
self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColClick, self.list)
- """Used by ColumnSorterMixin"""
+ """!Used by ColumnSorterMixin"""
return self.list
def OnColClick(self, event):
- """Click on column header (order by)"""
+ """!Click on column header (order by)"""
event.Skip()
def OnBeginEdit(self, event):
- """Editing of item started"""
+ """!Editing of item started"""
event.Allow()
def OnEndEdit(self, event):
- """Finish editing of item"""
+ """!Finish editing of item"""
itemIndex = event.GetIndex()
layerOld = int (self.list.GetItem(itemIndex, 0).GetText())
catOld = int (self.list.GetItem(itemIndex, 1).GetText())
@@ -1951,7 +1951,7 @@
return False
def OnRightDown(self, event):
- """Mouse right button down"""
+ """!Mouse right button down"""
x = event.GetX()
y = event.GetY()
item, flags = self.list.HitTest((x, y))
@@ -1963,7 +1963,7 @@
event.Skip()
def OnRightUp(self, event):
- """Mouse right button up"""
+ """!Mouse right button up"""
if not hasattr(self, "popupID1"):
self.popupID1 = wx.NewId()
self.popupID2 = wx.NewId()
@@ -1986,11 +1986,11 @@
menu.Destroy()
def OnItemSelected(self, event):
event.Skip()
def OnItemDelete(self, event):
- """Delete selected item(s) from the list (layer/category pair)"""
+ """!Delete selected item(s) from the list (layer/category pair)"""
item = self.list.GetFirstSelected()
while item != -1:
layer = int (self.list.GetItem(item, 0).GetText())
@@ -2003,14 +2003,14 @@
event.Skip()
def OnItemDeleteAll(self, event):
- """Delete all items from the list"""
+ """!Delete all items from the list"""
self.list.DeleteAllItems()
self.cats[self.fid] = {}
event.Skip()
def OnFeature(self, event):
- """Feature id changed (on duplicates)"""
+ """!Feature id changed (on duplicates)"""
self.fid = int(event.GetString())
self.itemDataMap = self.list.Populate(self.cats[self.fid],
@@ -2026,7 +2026,7 @@
event.Skip()
def __GetCategories(self, coords, qdist):
- """Get layer/category pairs for all available
+ """!Get layer/category pairs for all available
layers
Return True line found or False if not found"""
@@ -2056,7 +2056,7 @@
return True
def OnReload(self, event):
- """Reload button pressed"""
+ """!Reload button pressed"""
# restore original list
self.cats = copy.deepcopy(self.cats_orig)
@@ -2067,7 +2067,7 @@
event.Skip()
- """Cancel button pressed"""
+ """!Cancel button pressed"""
self.parent.parent.dialogs['category'] = None
if self.parent.parent.digit:
self.parent.parent.digit.driver.SetSelected([])
@@ -2078,7 +2078,7 @@
self.Close()
for fid in self.cats.keys():
newfid = self.ApplyChanges(fid)
if fid == self.fid:
@@ -2131,12 +2131,12 @@
return newfid
def OnOK(self, event):
- """OK button pressed"""
+ """!OK button pressed"""
self.OnApply(event)
self.OnCancel(event)
def OnAddCat(self, event):
- """Button 'Add' new category pressed"""
+ """!Button 'Add' new category pressed"""
try:
layer = int(self.layerNew.GetStringSelection())
cat = int(self.catNew.GetValue())
@@ -2170,11 +2170,11 @@
return True
def GetLine(self):
- """Get id of selected line of 'None' if no line is selected"""
+ """!Get id of selected line of 'None' if no line is selected"""
return self.cats.keys()
def UpdateDialog(self, query=None, cats=None):
- """Update dialog
+ """!Update dialog
@param query {coordinates, distance} - v.edit/v.what
@param cats directory layer/cats - vdigit
@@ -2229,7 +2229,7 @@
class CategoryListCtrl(wx.ListCtrl,
listmix.TextEditMixin):
- """List of layers/categories"""
+ """!List of layers/categories"""
def __init__(self, parent, id, pos=wx.DefaultPosition,
size=wx.DefaultSize, style=0):
@@ -2242,7 +2242,7 @@
listmix.TextEditMixin.__init__(self)
def Populate(self, cats, update=False):
- """Populate the list"""
+ """!Populate the list"""
itemData = {} # requested by sorter
@@ -2395,7 +2395,7 @@
self.SetMinSize((250, 180))
def GetUnSelected(self):
- """Get unselected items (feature id)
+ """!Get unselected items (feature id)
@return list of ids
@@ -2410,7 +2410,7 @@
return ids
class CheckListFeature(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin, listmix.CheckListCtrlMixin):
def __init__(self, parent, data,
pos=wx.DefaultPosition, log=None):
@@ -2429,7 +2429,7 @@
self.LoadData(self.data)
def LoadData(self, data):
- """Load data into list"""
+ """!Load data into list"""
self.InsertColumn(0, _('Feature id'))
self.InsertColumn(1, _('Layer (Categories)'))
@@ -2445,5 +2445,5 @@
self.SetColumnWidth(col=1, width=wx.LIST_AUTOSIZE_USEHEADER)
def OnCheckItem(self, index, flag):
pass
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -69,7 +69,7 @@
self.displayIndex = -1 # first display has index '0'
def __filterValue(self, value):
- """Translate value"""
+ """!Translate value"""
value = value.replace('<', '<')
value = value.replace('>', '>')
@@ -342,7 +342,7 @@
self.value += ch
class WriteWorkspaceFile(object):
- """Generic class for writing workspace file"""
+ """!Generic class for writing workspace file"""
def __init__(self, lmgr, file):
self.file = file
self.lmgr = lmgr
@@ -403,14 +403,14 @@
file.write('%s</gxw>\n' % (' ' * self.indent))
- """Make value XML-valid"""
+ """!Make value XML-valid"""
return value
def __writeLayer(self, mapTree, item):
- """Write bunch of layers to GRASS Workspace XML file"""
+ """!Write bunch of layers to GRASS Workspace XML file"""
self.indent += 4
itemSelected = mapTree.GetSelections()
while item and item.IsOk():
@@ -481,7 +481,7 @@
self.indent -= 4
def __writeNvizSurface(self, data):
- """Save Nviz raster layer properties to workspace
+ """!Save Nviz raster layer properties to workspace
@param data Nviz layer properties
@@ -555,7 +555,7 @@
self.indent -= 4
def __writeNvizVector(self, data):
- """Save Nviz vector layer properties (lines/points) to workspace
+ """!Save Nviz vector layer properties (lines/points) to workspace
@@ -601,7 +601,7 @@
class ProcessGrcFile(object):
def __init__(self, filename):
- """Process GRC file"""
+ """!Process GRC file"""
self.filename = filename
# elements
@@ -617,7 +617,7 @@
self.num_error = 0
def read(self, parent):
- """Read GRC file
+ """!Read GRC file
@param parent parent window
@@ -651,7 +651,7 @@
return self.layers
def process_line(self, line, line_id):
- """Process line definition"""
+ """!Process line definition"""
element = self._get_element(line)
if element == 'Group':
self.groupName = self._get_value(line)
@@ -862,18 +862,18 @@
self.num_error += 1
def _get_value(self, line):
- """Get value of element"""
+ """!Get value of element"""
try:
return line.strip(' ').split(' ')[1].strip(' ')
except:
return ''
def _get_element(self, line):
- """Get element tag"""
+ """!Get element tag"""
return line.strip(' ').split(' ')[0].strip(' ')
def _get_cmd_param_index(self, cmd, name):
- """Get index of parameter in cmd list
+ """!Get index of parameter in cmd list
@param cmd cmd list
@param name parameter name
@@ -894,7 +894,7 @@
return -1
def _color_name_to_rgb(self, value):
- """Convert color name (#) to rgb values"""
+ """!Convert color name (#) to rgb values"""
col = wx.NamedColour(value)
return str(col.Red()) + ':' + \
str(col.Green()) + ':' + \
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -208,7 +208,7 @@
event.Skip()
def OnKeyUp(self, event):
- """Key pressed"""
+ """!Key pressed"""
key = event.GetKeyCode()
if key == wx.WXK_DELETE and self.lmgr:
self.lmgr.OnDeleteLayer(None)
@@ -216,11 +216,11 @@
event.Skip()
#def OnChangeLayerName (self, event):
- # """Change layer name"""
+ # """!Change layer name"""
# Debug.msg (3, "LayerTree.OnChangeLayerName: name=%s" % event.GetLabel())
def OnLayerContextMenu (self, event):
- """Contextual menu for item/layer"""
+ """!Contextual menu for item/layer"""
if not self.layer_selected:
event.Skip()
return
@@ -377,7 +377,7 @@
self.popupMenu.Destroy()
def OnMetadata(self, event):
- """Print metadata of raster/vector map layer
+ """!Print metadata of raster/vector map layer
TODO: Dialog to modify metadata
mapLayer = self.GetPyData(self.layer_selected)[0]['maplayer']
@@ -393,7 +393,7 @@
self.lmgr.goutput.RunCmd(cmd, switchPage=True)
def OnSetCompRegFromRaster(self, event):
- """Set computational region from selected raster map (ignore NULLs)"""
+ """!Set computational region from selected raster map (ignore NULLs)"""
cmd = ['g.region',
@@ -404,7 +404,7 @@
self.lmgr.goutput.RunCmd(cmd)
def OnSetCompRegFromMap(self, event):
- """Set computational region from selected raster/vector map"""
+ """!Set computational region from selected raster/vector map"""
rast = []
vect = []
rast3d = []
@@ -433,7 +433,7 @@
def OnProfile(self, event):
- """Plot profile of given raster map layer"""
+ """!Plot profile of given raster map layer"""
if not mapLayer.name:
wx.MessageBox(parent=self,
@@ -456,7 +456,7 @@
self.profileFrame.Show()
def OnColorTable(self, event):
- """Set color table for raster map"""
+ """!Set color table for raster map"""
name = self.GetPyData(self.layer_selected)[0]['maplayer'].name
menuform.GUI().ParseCommand(['r.colors',
'map=%s' % name],
@@ -536,7 +536,7 @@
self.mapdisplay.imgVectorMap = None
def OnSetBgMap(self, event):
- """Set background vector map for editing sesstion"""
+ """!Set background vector map for editing sesstion"""
if event.IsChecked():
mapName = self.GetPyData(self.layer_selected)[0]['maplayer'].GetName()
UserSettings.Set(group='vdigit', key='bgmap', subkey='value',
@@ -546,11 +546,11 @@
value='', internal=True)
def OnPopupProperties (self, event):
- """Popup properties dialog"""
+ """!Popup properties dialog"""
self.PropertiesDialog(self.layer_selected)
def OnPopupOpacityLevel(self, event):
- """Popup opacity level indicator"""
+ """!Popup opacity level indicator"""
if not self.GetPyData(self.layer_selected)[0]['ctrl']:
return
@@ -590,7 +590,7 @@
# self.mapdisplay.OnRender(None)
def OnNvizProperties(self, event):
- """Nviz-related properties (raster/vector/volume)
+ """!Nviz-related properties (raster/vector/volume)
@todo vector/volume
@@ -600,12 +600,12 @@
self.mapdisplay.nvizToolWin.SetPage('surface')
def RenameLayer (self, event):
- """Rename layer"""
+ """!Rename layer"""
self.EditLabel(self.layer_selected)
def AddLayer(self, ltype, lname=None, lchecked=None,
lopacity=1.0, lcmd=None, lgroup=None, lnviz=None):
- """Add new item to the layer tree, create corresponding MapLayer instance.
+ """!Add new item to the layer tree, create corresponding MapLayer instance.
Launch property dialog if needed (raster, vector, etc.)
@param ltype layer type (raster, vector, 3d-raster, ...)
@@ -822,7 +822,7 @@
return layer
def PropertiesDialog (self, layer, show=True):
- """Launch the properties dialog"""
+ """!Launch the properties dialog"""
if self.GetPyData(layer)[0].has_key('propwin') and \
self.GetPyData(layer)[0]['propwin'] is not None:
# recycle GUI dialogs
@@ -912,7 +912,7 @@
pass
def OnActivateLayer(self, event):
- """Double click on the layer item.
+ """!Double click on the layer item.
Launch property dialog, or expand/collapse group of items, etc."""
layer = event.GetItem()
@@ -927,7 +927,7 @@
self.Expand(layer)
def OnDeleteLayer(self, event):
- """Remove selected layer item from the layer tree"""
+ """!Remove selected layer item from the layer tree"""
item = event.GetItem()
@@ -968,7 +968,7 @@
event.Skip()
def OnLayerChecked(self, event):
- """Enable/disable data layer"""
+ """!Enable/disable data layer"""
checked = item.IsChecked()
@@ -1043,7 +1043,7 @@
def OnCmdChanged(self, event):
- """Change command string"""
+ """!Change command string"""
ctrl = event.GetEventObject().GetId()
cmd = event.GetString()
@@ -1061,7 +1061,7 @@
event.Skip()
def OnChangeSel(self, event):
- """Selection changed"""
+ """!Selection changed"""
oldlayer = event.GetOldItem()
if layer == oldlayer:
return newItem
def GetOptData(self, dcmd, layer, params, propwin):
- """Process layer data"""
+ """!Process layer data"""
# set layer text to map name
if dcmd:
mapLayer = self.GetPyData(layer)[0]['maplayer']
@@ -1341,7 +1341,7 @@
mapWin.ResetView()
def ReorderLayers(self):
- """Add commands from data associated with
+ """!Add commands from data associated with
any valid layers (checked or not) to layer list in order to
match layers in layer tree."""
@@ -1374,7 +1374,7 @@
self.reorder = False
def ChangeLayer(self, item):
- """Change layer"""
+ """!Change layer"""
type = self.GetPyData(item)[0]['type']
layerName = None
@@ -1421,12 +1421,12 @@
# self.Map.Clean()
def FindItemByData(self, key, value):
- """Find item based on key and value (see PyData[0])"""
+ """!Find item based on key and value (see PyData[0])"""
item = self.GetFirstChild(self.root)[0]
return self.__FindSubItemByData(item, key, value)
def EnableItemType(self, type, enable=True):
- """Enable/disable items in layer tree"""
+ """!Enable/disable items in layer tree"""
mapLayer = self.GetPyData(item)[0]['maplayer']
@@ -1436,7 +1436,7 @@
item = self.GetNextSibling(item)
def __FindSubItemByData(self, item, key, value):
- """Support method for FindItemByValue"""
+ """!Support method for FindItemByValue"""
itemValue = self.GetPyData(item)[0][key]
if value == itemValue:
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/icons/icon.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -103,11 +103,11 @@
self.description = ''
def __str__(self):
- """Debugging"""
+ """!Debugging"""
return "label=%s, img=%s, type=%s" % (self.label, self.imagepath, self.type)
def GetBitmap(self, size=None):
- """Get bitmap"""
+ """!Get bitmap"""
bmp = None
if self.type == 'wx':
Modified: grass/trunk/gui/wxpython/support/update_menu_desc.py
--- grass/trunk/gui/wxpython/support/update_menu_desc.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/support/update_menu_desc.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -61,7 +61,7 @@
print ' ),'
def get_description(item):
- """Return command desctiption based on interface
+ """!Return command desctiption based on interface
description"""
print
desc, type, cmd = item
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2009-05-27 19:34:29 UTC (rev 37539)
+++ grass/trunk/gui/wxpython/wxgui.py 2009-05-27 19:58:35 UTC (rev 37540)
@@ -193,13 +193,13 @@
self.Raise()
def __createCommandPrompt(self):
- """Creates command-line input area"""
+ """!Creates command-line input area"""
p = prompt.GPrompt(self)
return p.GetPanel(), p.GetInput()
def __createMenuBar(self):
- """Creates menubar"""
+ """!Creates menubar"""
self.menubar = wx.MenuBar()
menud = menudata.Data()
@@ -213,7 +213,7 @@
return self.menubar
def __createMenu(self, menuData):
- """Creates menu"""
+ """!Creates menu"""
menu = wx.Menu()
for eachItem in menuData:
@@ -227,7 +227,7 @@
return menu
def __createMenuItem(self, menu, label, help, handler, gcmd, kind=wx.ITEM_NORMAL):
- """Creates menu items"""
+ """!Creates menu items"""
if not label:
menu.AppendSeparator()
@@ -251,7 +251,7 @@
self.Bind(wx.EVT_MENU, rhandler, menuItem)
def __createNoteBook(self):
- """Creates notebook widgets"""
+ """!Creates notebook widgets"""
#create main notebook widget
nbStyle = FN.FNB_FANCY_TABS | \
@@ -290,7 +290,7 @@
return self.notebook
def __createToolBar(self):
- """Creates toolbar"""
+ """!Creates toolbar"""
self.toolbar = self.CreateToolBar()
self.toolbar.SetToolBitmapSize(globalvar.toolbarSize)
@@ -343,7 +343,7 @@
pass
def OnCBPageChanged(self, event):
- """Page in notebook (display) changed"""
+ """!Page in notebook (display) changed"""
old_pgnum = event.GetOldSelection()
new_pgnum = event.GetSelection()
@@ -359,7 +359,7 @@
event.Skip()
def OnPageChanged(self, event):
- """Page in notebook changed"""
+ """!Page in notebook changed"""
page = event.GetSelection()
if page == self.goutput.pageid:
# remove '(...)'
@@ -411,11 +411,11 @@
event.Skip()
def GetLogWindow(self):
- """Get widget for command output"""
+ """!Get widget for command output"""
return self.goutput
def GetMenuCmd(self, event):
- """Get GRASS command from menu item
+ """!Get GRASS command from menu item
Return command as a list"""
layer = None
@@ -448,17 +448,17 @@
return cmdlist
def RunMenuCmd(self, event):
- """Run command selected from menu"""
+ """!Run command selected from menu"""
cmd = self.GetMenuCmd(event)
self.goutput.RunCmd(cmd, switchPage=True)
def OnMenuCmd(self, event):
- """Parse command selected from menu"""
+ """!Parse command selected from menu"""
menuform.GUI().ParseCommand(cmd, parentframe=self)
def OnNewVector(self, event):
- """Create new vector map layer"""
+ """!Create new vector map layer"""
name, add = gdialogs.CreateNewVector(self, log = self.goutput,
cmd = (('v.edit',
{ 'tool' : 'create' },
@@ -473,7 +473,7 @@
lcmd=['d.vect', 'map=%s' % name])
def OnAboutGRASS(self, event):
- """Display 'About GRASS' dialog"""
+ """!Display 'About GRASS' dialog"""
info = wx.AboutDialogInfo()
# name
@@ -506,7 +506,7 @@
wx.AboutBox(info)
def OnWorkspace(self, event):
- """Workspace menu (new, load)"""
+ """!Workspace menu (new, load)"""
menu = wx.Menu()
@@ -526,7 +526,7 @@
menu.Destroy()
def OnWorkspaceNew(self, event=None):
- """Create new workspace file
+ """!Create new workspace file
Erase current workspace settings first"""
@@ -567,7 +567,7 @@
self.SetTitle(self.baseTitle)
def OnWorkspaceOpen(self, event=None):
- """Open file with workspace definition"""
+ """!Open file with workspace definition"""
dlg = wx.FileDialog(parent=self, message=_("Choose workspace file"),
defaultDir=os.getcwd(), wildcard="*.gxw")
@@ -589,7 +589,7 @@
self.SetTitle(self.baseTitle + " - " + os.path.basename(self.workspaceFile))
def LoadWorkspaceFile(self, filename):
- """Load layer tree definition stored in GRASS Workspace XML file (gxw)
+ """!Load layer tree definition stored in GRASS Workspace XML file (gxw)
Return True on success
Return False on error"""
@@ -738,7 +738,7 @@
return True
def OnWorkspaceLoad(self, event=None):
- """Load given map layers into layer tree"""
+ """!Load given map layers into layer tree"""
dialog = gdialogs.LoadMapLayersDialog(parent=self, title=_("Load map layers into layer tree"))
if dialog.ShowModal() == wx.ID_OK:
@@ -766,7 +766,7 @@
busy.Destroy()
def OnWorkspaceLoadGrcFile(self, event):
- """Load map layers from GRC file (Tcl/Tk GUI) into map layer tree"""
+ """!Load map layers from GRC file (Tcl/Tk GUI) into map layer tree"""
dlg = wx.FileDialog(parent=self, message=_("Choose GRC file to load"),
defaultDir=os.getcwd(), wildcard="*.grc")
@@ -804,7 +804,7 @@
maptree.Map.ReverseListOfLayers()
def OnWorkspaceSaveAs(self, event=None):
- """Save workspace definition to selected file"""
+ """!Save workspace definition to selected file"""
dlg = wx.FileDialog(parent=self, message=_("Choose file to save current workspace"),
defaultDir=os.getcwd(), wildcard="*.gxw", style=wx.FD_SAVE)
@@ -835,7 +835,7 @@
def OnWorkspaceSave(self, event=None):
- """Save file with workspace definition"""
+ """!Save file with workspace definition"""
if self.workspaceFile:
dlg = wx.MessageDialog(self, message=_("Workspace file <%s> already exists. "
@@ -851,7 +851,7 @@
self.OnWorkspaceSaveAs()
def SaveToWorkspaceFile(self, filename):
- """Save layer tree layout to workspace file
+ """!Save layer tree layout to workspace file
Return True on success, False on error
@@ -879,7 +879,7 @@
return True
def OnWorkspaceClose(self, event=None):
- """Close file with workspace definition
+ """!Close file with workspace definition
If workspace has been modified ask user to save the changes.
@@ -933,7 +933,7 @@
self.goutput.RunCmd(cmdlist)
def OnPreferences(self, event):
- """General GUI preferences/settings"""
+ """!General GUI preferences/settings"""
preferences.PreferencesDialog(parent=self).ShowModal()
def DispHistogram(self, event):
@@ -977,7 +977,7 @@
dimension=3)
def AddToolbarButton(self, toolbar, label, icon, help, handler):
- """Adds button to the given toolbar"""
+ """!Adds button to the given toolbar"""
if not label:
toolbar.AddSeparator()
@@ -1020,25 +1020,25 @@
def OnImportDxfFile(self, event):
- """Convert multiple DXF layers to GRASS vector map layers"""
+ """!Convert multiple DXF layers to GRASS vector map layers"""
dlg = gdialogs.MultiImportDialog(parent=self, type='dxf',
title=_("Import DXF layers"))
dlg.ShowModal()
def OnImportGdalLayers(self, event):
- """Convert multiple GDAL layers to GRASS vector map layers"""
+ """!Convert multiple GDAL layers to GRASS vector map layers"""
dlg = gdialogs.MultiImportDialog(parent=self, type='gdal',
title=_("Import GDAL layers"))
dlg.ShowModal()
def OnImportOgrLayers(self, event):
- """Convert multiple OGR layers to GRASS vector map layers"""
+ """!Convert multiple OGR layers to GRASS vector map layers"""
dlg = gdialogs.MultiImportDialog(parent=self, type='ogr',
title=_("Import OGR layers"))
dlg.ShowModal()
def OnImportWMS(self, event):
- """Import data from OGC WMS server"""
+ """!Import data from OGC WMS server"""
dlg = ogc_services.WMSDialog(parent = self, service = 'wms')
dlg.CenterOnScreen()
@@ -1107,11 +1107,11 @@
self.dbmanager.Show()
def OnNewDisplay(self, event=None):
- """Create new layer tree and map display instance"""
+ """!Create new layer tree and map display instance"""
self.NewDisplay()
def NewDisplay(self, show=True):
- """Create new layer tree, which will
+ """!Create new layer tree, which will
create an associated map display frame
@param show show map display window if True
@@ -1159,7 +1159,7 @@
# toolBar button handlers
def OnAddRaster(self, event):
- """Add raster map layer"""
+ """!Add raster map layer"""
# start new map display if no display is available
if not self.curr_page:
self.NewDisplay(show=False)
@@ -1167,7 +1167,7 @@
self.AddRaster(event)
def OnAddRasterMisc(self, event):
- """Add raster menu"""
+ """!Add raster menu"""
@@ -1216,7 +1216,7 @@
self.curr_page.maptree.mapdisplay.Show()
def OnAddVector(self, event):
- """Add vector map layer"""
+ """!Add vector map layer"""
@@ -1224,7 +1224,7 @@
self.AddVector(event)
def OnAddVectorMisc(self, event):
- """Add vector menu"""
+ """!Add vector menu"""
def OnAddOverlay(self, event):
- """Add overlay menu"""
+ """!Add overlay menu"""
@@ -1296,47 +1296,47 @@
self.curr_page.maptree.AddLayer('3d-raster')
def AddRGB(self, event):
- """Add RGB layer"""
+ """!Add RGB layer"""
self.notebook.SetSelection(0)
self.curr_page.maptree.AddLayer('rgb')
def AddHIS(self, event):
- """Add HIS layer"""
+ """!Add HIS layer"""
self.curr_page.maptree.AddLayer('his')
def AddShaded(self, event):
- """Add shaded relief map layer"""
+ """!Add shaded relief map layer"""
self.curr_page.maptree.AddLayer('shaded')
def AddRastarrow(self, event):
- """Add raster flow arrows map"""
+ """!Add raster flow arrows map"""
self.curr_page.maptree.AddLayer('rastarrow')
def AddRastnum(self, event):
- """Add raster map with cell numbers"""
+ """!Add raster map with cell numbers"""
self.curr_page.maptree.AddLayer('rastnum')
def AddVector(self, event):
- """Add vector layer"""
+ """!Add vector layer"""
self.curr_page.maptree.AddLayer('vector')
def AddThemeMap(self, event):
- """Add thematic map layer"""
+ """!Add thematic map layer"""
self.curr_page.maptree.AddLayer('thememap')
def AddThemeChart(self, event):
- """Add thematic chart layer"""
+ """!Add thematic chart layer"""
self.curr_page.maptree.AddLayer('themechart')
def OnAddCommand(self, event):
- """Add command line layer"""
+ """!Add command line layer"""
@@ -1348,7 +1348,7 @@
def OnAddGroup(self, event):
- """Add layer group"""
+ """!Add layer group"""
@@ -1360,22 +1360,22 @@
def AddGrid(self, event):
- """Add layer grid"""
+ """!Add layer grid"""
self.curr_page.maptree.AddLayer('grid')
def AddGeodesic(self, event):
- """Add layer geodesic"""
+ """!Add layer geodesic"""
self.curr_page.maptree.AddLayer('geodesic')
def AddRhumb(self, event):
- """Add layer rhumb"""
+ """!Add layer rhumb"""
self.curr_page.maptree.AddLayer('rhumb')
def OnAddLabels(self, event):
- """Add layer vector labels"""
+ """!Add layer vector labels"""
@@ -1428,7 +1428,7 @@
self.curr_page.maptree.Delete(layer)
def OnCloseWindow(self, event):
- """Cleanup when wxGUI is quit"""
+ """!Cleanup when wxGUI is quit"""
self._auimgr.UnInit()
self.Destroy()
@@ -1474,7 +1474,7 @@
self.Destroy()
def MsgNoLayerSelected(self):
- """Show dialog message 'No layer selected'"""
+ """!Show dialog message 'No layer selected'"""
message=_("No map layer selected. Operation cancelled."),
caption=_("Message"),
@@ -1516,7 +1516,7 @@
self.msg = msg
def printHelp():
- """Print program help"""
+ """!Print program help"""
print >> sys.stderr, "Usage:"
print >> sys.stderr, " python wxgui.py [options]"
print >> sys.stderr, "%sOptions:" % os.linesep
@@ -1524,7 +1524,7 @@
sys.exit(0)
def process_opt(opts, args):
- """Process command-line arguments"""
+ """!Process command-line arguments"""
workspaceFile = None
for o, a in opts:
if o in ("-h", "--help"):
