[GRASS-SVN] r37563 -
grass/branches/releasebranch_6_4/raster/r.mapcalc
svn_grass at osgeo.org
Thu May 28 04:32:22 EDT 2009
Author: neteler
Date: 2009-05-28 04:32:21 -0400 (Thu, 28 May 2009)
New Revision: 37563
grass/branches/releasebranch_6_4/raster/r.mapcalc/r.mapcalc.html
grass/branches/releasebranch_6_4/raster/r.mapcalc/r3.mapcalc.html
title cosmetics; replace non-standard chars
Modified: grass/branches/releasebranch_6_4/raster/r.mapcalc/r.mapcalc.html
--- grass/branches/releasebranch_6_4/raster/r.mapcalc/r.mapcalc.html 2009-05-28 08:32:14 UTC (rev 37562)
+++ grass/branches/releasebranch_6_4/raster/r.mapcalc/r.mapcalc.html 2009-05-28 08:32:21 UTC (rev 37563)
@@ -1,7 +1,7 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
-<title>r.mapcalc</title>
+<title>GRASS GIS manual: r.mapcalc</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link rel="stylesheet" href="grassdocs.css" type="text/css">
</head>
@@ -385,7 +385,7 @@
<h3>NULL support</h3>
-<menu>
+<ul>
<li>Division by zero should result in NULL.
<li>Modulus by zero should result in NULL.
<li> NULL-values in any arithmetic or logical operation should result
@@ -422,7 +422,7 @@
sqrt(-2)
pow(a,b) where a is negative and b is not an integer
</pre></div>
-</menu>
+</ul>
<p>
NULL support: Please note that any math performed with NULL cells always
results in a NULL value for these cells. If you want to replace a NULL cell
@@ -519,7 +519,7 @@
</pre></div>
use:
<div class="code"><pre>
- r.mapcalc <<EOF
+ r.mapcalc <<EOF
$GIS_OPT_OUTPUT.r = r#$GIS_OPT_FIRST * .$GIS_OPT_PERCENT + (1.0 - .$GIS_OPT_PERCENT) * r#$GIS_OPT_SECOND
$GIS_OPT_OUTPUT.g = g#$GIS_OPT_FIRST * .$GIS_OPT_PERCENT + (1.0 - .$GIS_OPT_PERCENT) * g#$GIS_OPT_SECOND
$GIS_OPT_OUTPUT.b = b#$GIS_OPT_FIRST * .$GIS_OPT_PERCENT + (1.0 - .$GIS_OPT_PERCENT) * b#$GIS_OPT_SECOND
Modified: grass/branches/releasebranch_6_4/raster/r.mapcalc/r3.mapcalc.html
--- grass/branches/releasebranch_6_4/raster/r.mapcalc/r3.mapcalc.html 2009-05-28 08:32:14 UTC (rev 37562)
+++ grass/branches/releasebranch_6_4/raster/r.mapcalc/r3.mapcalc.html 2009-05-28 08:32:21 UTC (rev 37563)
@@ -1,7 +1,7 @@
<html>
<head>
-<title>r3.mapcalc</title>
+<title>GRASS GIS manual: r3.mapcalc</title>
</head>
