[GRASS-SVN] r37583 - grass/branches/develbranch_6/ps/ps.map
    svn_grass at osgeo.org
    Fri May 29 05:42:00 EDT 2009
Author: hamish
Date: 2009-05-29 05:42:00 -0400 (Fri, 29 May 2009)
New Revision: 37583
   grass/branches/develbranch_6/ps/ps.map/description.html
add back text erroneously removed in r22831
Modified: grass/branches/develbranch_6/ps/ps.map/description.html
--- grass/branches/develbranch_6/ps/ps.map/description.html	2009-05-29 09:26:48 UTC (rev 37582)
+++ grass/branches/develbranch_6/ps/ps.map/description.html	2009-05-29 09:42:00 UTC (rev 37583)
@@ -7,6 +7,15 @@
 <P>
 A file of mapping instructions that describes the various spatial and textual
 information to be printed must be prepared prior to running <EM>ps.map</EM>.
+<P>
+This program can also be run in an interactive command-line mode, which
+is launched by running <EM>ps.map</EM> from the command line with the
+<b>output</b> filename as the only parameter.
+The interactive mode will prompt the user for items to be mapped and
+does not require the user to prepare a file of instructions (n.b., some
+options may not be used in interactive mode).
+<P>
+Rules may also be given via direct pipe from <tt>stdin</tt>.
 <H2>NOTES</H2>
