[GRASS-SVN] r37588 - grass/branches/develbranch_6/ps/ps.map
    svn_grass at osgeo.org
    Fri May 29 12:14:36 EDT 2009
Author: hamish
Date: 2009-05-29 12:14:36 -0400 (Fri, 29 May 2009)
New Revision: 37588
   grass/branches/develbranch_6/ps/ps.map/description.html
more correct instructions
Modified: grass/branches/develbranch_6/ps/ps.map/description.html
--- grass/branches/develbranch_6/ps/ps.map/description.html	2009-05-29 12:18:03 UTC (rev 37587)
+++ grass/branches/develbranch_6/ps/ps.map/description.html	2009-05-29 16:14:36 UTC (rev 37588)
@@ -9,8 +9,8 @@
 information to be printed must be prepared prior to running <EM>ps.map</EM>.
 <P>
 This program can also be run in an interactive command-line mode, which
-is launched by running <EM>ps.map</EM> from the command line with the
-<b>output</b> filename as the only parameter.
+is launched by running <EM>ps.map</EM> from the command line without the
+<b>input</b> parameter.
 The interactive mode will prompt the user for items to be mapped and
 does not require the user to prepare a file of instructions (n.b., some
 options may not be used in interactive mode).
