[GRASS-SVN] r37596 - in grass/trunk/gui/wxpython: . gui_modules xml
svn_grass at osgeo.org
Fri May 29 17:57:37 EDT 2009
Author: martinl
Date: 2009-05-29 17:57:37 -0400 (Fri, 29 May 2009)
New Revision: 37596
grass/trunk/gui/wxpython/gui_modules/menudata.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/prompt.py
grass/trunk/gui/wxpython/wxgui.py
grass/trunk/gui/wxpython/xml/menudata.xml
wxGUI: search modules (stage 1 - description only)
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py 2009-05-29 21:52:24 UTC (rev 37595)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py 2009-05-29 21:57:37 UTC (rev 37596)
@@ -1,4 +1,4 @@
@package menudata.py
@brief Complex list for main menu entries for GRASS wxPython GUI.
@@ -6,7 +6,7 @@
Classes:
- Data
-COPYRIGHT: (C) 2007-2008 by the GRASS Development Team
+(C) 2007-2009 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@@ -24,11 +24,11 @@
import elementtree.ElementTree as etree # Python <= 2.4
class Data:
- '''Data object that returns menu descriptions to be used in wxgui.py.'''
+ '''!Data object that returns menu descriptions to be used in wxgui.py.'''
def __init__(self, gisbase=None):
if not gisbase:
gisbase = os.getenv('GISBASE')
- filename = gisbase + '/etc/wxpython/xml/menudata.xml'
+ filename = os.path.join(gisbase, 'etc', 'wxpython', 'xml', 'menudata.xml')
self.tree = etree.parse(filename)
def getMenuItem(self, mi):
@@ -70,6 +70,24 @@
fh.write(' _(%r),\n' % node.text)
fh.write(' \'\']\n')
+ def GetModules(self):
+ """!Create dictionary of modules used to search module by
+ keywords, description, etc."""
+ modules = dict()
+ for node in self.tree.getiterator():
+ if node.tag == 'menuitem':
+ module = description = ''
+ for child in node.getchildren():
+ if child.tag == 'help':
+ description = child.text
+ if child.tag == 'command':
+ module = child.text
+ if module:
+ modules[module] = { 'desc': description }
+ return modules
if __name__ == "__main__":
import sys
if len(sys.argv) < 2:
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-05-29 21:52:24 UTC (rev 37595)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-05-29 21:57:37 UTC (rev 37596)
@@ -1792,13 +1792,13 @@
self.parent = parent
self.grass_task = None
- def ParseInterface(self, cmd):
+ def ParseInterface(self, cmd, parser = processTask):
"""!Parse interface
@param cmd command to be parsed (given as list)
grass_task = grassTask()
- handler = processTask(grass_task)
+ handler = parser(grass_task)
enc = locale.getdefaultlocale()[1]
if enc and enc.lower() not in ("utf8", "utf-8"):
xml.sax.parseString(getInterfaceDescription(cmd[0]).decode(enc).encode("utf-8"),
Modified: grass/trunk/gui/wxpython/gui_modules/prompt.py
--- grass/trunk/gui/wxpython/gui_modules/prompt.py 2009-05-29 21:52:24 UTC (rev 37595)
+++ grass/trunk/gui/wxpython/gui_modules/prompt.py 2009-05-29 21:57:37 UTC (rev 37596)
@@ -1,4 +1,4 @@
@package prompt.py
@brief GRASS prompt
@@ -25,22 +25,40 @@
import wx
import wx.lib.mixins.listctrl as listmix
+from grass.script import core as grass
import globalvar
import utils
import menuform
-from grass.script import core as grass
+import menudata
class GPrompt:
"""!Interactive GRASS prompt"""
def __init__(self, parent):
- self.parent = parent
+ self.parent = parent # GMFrame
+ # dictionary of modules (description, keywords, ...)
+ self.modules = self.parent.menudata.GetModules()
self.panel, self.input = self.__create()
def __create(self):
"""!Create widget"""
cmdprompt = wx.Panel(self.parent)
+ # search
+ searchTxt = wx.StaticText(parent = cmdprompt, id = wx.ID_ANY,
+ label = _("Search:"))
+ self.searchBy = wx.Choice(parent = cmdprompt, id = wx.ID_ANY,
+ choices = [_("description"),
+ _("keywords")])
+ self.search = wx.TextCtrl(parent = cmdprompt, id = wx.ID_ANY,
+ value = "", size = (-1, 25))
label = wx.Button(parent = cmdprompt, id = wx.ID_ANY,
label = _("Cmd >"), size = (-1, 25))
label.SetToolTipString(_("Click for erasing command prompt"))
@@ -59,25 +77,46 @@
value = "",
style=wx.TE_LINEWRAP | wx.TE_PROCESS_ENTER,
size = (-1, 25))
+ self.searchBy.Enable(False)
+ self.search.Enable(False)
cmdinput.SetFont(wx.Font(10, wx.FONTFAMILY_MODERN, wx.NORMAL, wx.NORMAL, 0, ''))
wx.CallAfter(cmdinput.SetInsertionPoint, 0)
+ # bidnings
label.Bind(wx.EVT_BUTTON, self.OnCmdErase)
cmdinput.Bind(wx.EVT_TEXT_ENTER, self.OnRunCmd)
cmdinput.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar)
+ self.search.Bind(wx.EVT_TEXT, self.OnSearchModule)
# layout
- sizer = wx.BoxSizer(wx.HORIZONTAL)
- sizer.Add(item = label, proportion = 0,
- flag = wx.EXPAND | wx.LEFT | wx.RIGHT |
- wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER,
- border = 3)
- sizer.Add(item = cmdinput, proportion = 1,
- flag = wx.EXPAND | wx.ALL,
- border = 1)
+ sizer = wx.GridBagSizer(hgap=5, vgap=5)
+ sizer.AddGrowableCol(2)
+ sizer.Add(item = searchTxt,
+ flag = wx.ALIGN_RIGHT | wx.ALIGN_CENTER_VERTICAL,
+ pos = (0, 0))
+ sizer.Add(item = self.searchBy,
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER,
+ pos = (0, 1))
+ sizer.Add(item = self.search,
+ flag = wx.EXPAND | wx.RIGHT | wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER,
+ border = 5,
+ pos = (0, 2))
+ sizer.Add(item = label,
+ flag = wx.LEFT | wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER,
+ border = 5,
+ pos = (1, 0))
+ sizer.Add(item = cmdinput,
+ flag = wx.EXPAND | wx.RIGHT,
+ border = 5,
+ pos = (1, 1), span = (1, 2))
cmdprompt.SetSizer(sizer)
sizer.Fit(cmdprompt)
cmdprompt.Layout()
@@ -125,6 +164,21 @@
self.parent.statusbar.SetStatusText(_("Type GRASS command and run by pressing ENTER"))
event.Skip()
+ def OnSearchModule(self, event):
+ """!Search module by metadata"""
+ text = event.GetString()
+ if not text:
+ self.input.SetChoices(globalvar.grassCmd['all'])
+ return
+ modules = []
+ for module, data in self.modules.iteritems():
+ if text in data['desc']:
+ modules.append(module)
+ self.parent.statusbar.SetStatusText(_("%d modules found") % len(modules))
+ self.input.SetChoices(modules)
class PromptListCtrl(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin):
def __init__(self, parent, id = wx.ID_ANY, pos = wx.DefaultPosition,
size = wx.DefaultSize, style = 0):
@@ -133,8 +187,7 @@
class TextCtrlAutoComplete(wx.TextCtrl, listmix.ColumnSorterMixin):
def __init__ (self, parent, id = wx.ID_ANY, choices = [], **kwargs):
- Constructor works just like wx.TextCtrl except you can pass in a
+ """!Constructor works just like wx.TextCtrl except you can pass in a
list of choices. You can also change the choice list at any time
by calling setChoices.
@@ -146,7 +199,7 @@
kwargs['style'] = wx.TE_PROCESS_ENTER
wx.TextCtrl.__init__(self, parent, id, **kwargs)
# some variables
self._choices = choices
self._hideOnNoMatch = True
@@ -220,8 +273,7 @@
self.dropdown.SetClientSize(self.popupsize)
def _showDropDown(self, show = True):
- Eit`her display the drop down list (show = True) or hide it
+ """!Either display the drop down list (show = True) or hide it
(show = False).
if show:
@@ -240,8 +292,7 @@
self.dropdown.Show(show)
def _listItemVisible(self):
- Moves the selected item to the top of the list ensuring it is
+ """!Moves the selected item to the top of the list ensuring it is
always visible.
toSel = self.dropdownlistbox.GetFirstSelected()
@@ -250,8 +301,7 @@
self.dropdownlistbox.EnsureVisible(toSel)
def _setValueFromSelected(self):
- Sets the wx.TextCtrl value from the selected wx.ListCtrl item.
+ """!Sets the wx.TextCtrl value from the selected wx.ListCtrl item.
Will do nothing if no item is selected in the wx.ListCtrl.
sel = self.dropdownlistbox.GetFirstSelected()
@@ -291,8 +341,7 @@
return self.dropdownlistbox
def SetChoices(self, choices, type = 'module'):
- Sets the choices available in the popup wx.ListBox.
+ """!Sets the choices available in the popup wx.ListBox.
The items will be sorted case insensitively.
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2009-05-29 21:52:24 UTC (rev 37595)
+++ grass/trunk/gui/wxpython/wxgui.py 2009-05-29 21:57:37 UTC (rev 37596)
@@ -104,7 +104,7 @@
self.baseTitle = title
self.iconsize = (16, 16)
- wx.Frame.__init__(self, parent=parent, id=id, size=(550, 400),
+ wx.Frame.__init__(self, parent=parent, id=id, size=(550, 450),
style=wx.DEFAULT_FRAME_STYLE)
self.SetTitle(self.baseTitle)
@@ -126,8 +126,8 @@
# creating widgets
# -> self.notebook, self.goutput, self.outpage
self.notebook = self.__createNoteBook()
+ self.menubar, self.menudata = self.__createMenuBar()
self.cmdprompt, self.cmdinput = self.__createCommandPrompt()
- self.menubar = self.__createMenuBar()
self.toolbar = self.__createToolBar()
self.statusbar = self.CreateStatusBar(number=1)
@@ -146,7 +146,7 @@
Left().CentrePane().BestSize((-1,-1)).Dockable(False).
CloseButton(False).DestroyOnClose(True).Row(1).Layer(0))
self._auimgr.AddPane(self.cmdprompt, wx.aui.AuiPaneInfo().
- Bottom().BestSize((-1,25)).Dockable(False).
+ Bottom().BestSize((-1, 60)).Dockable(False).
PaneBorder(False).Row(1).Layer(0).Position(0).
CaptionVisible(False))
@@ -202,15 +202,15 @@
"""!Creates menubar"""
self.menubar = wx.MenuBar()
- menud = menudata.Data()
- for eachMenuData in menud.GetMenu():
+ self.menudata = menudata.Data()
+ for eachMenuData in self.menudata.GetMenu():
for eachHeading in eachMenuData:
menuLabel = eachHeading[0]
menuItems = eachHeading[1]
self.menubar.Append(self.__createMenu(menuItems), menuLabel)
self.SetMenuBar(self.menubar)
- return self.menubar
+ return (self.menubar, self.menudata)
def __createMenu(self, menuData):
"""!Creates menu"""
@@ -935,7 +935,7 @@
def OnPreferences(self, event):
"""!General GUI preferences/settings"""
preferences.PreferencesDialog(parent=self).ShowModal()
def DispHistogram(self, event):
Init histogram display canvas and tools
@@ -1481,17 +1481,21 @@
style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
class GMApp(wx.App):
- GMApp class
- def __init__(self, workspace=None):
+ def __init__(self, workspace = None):
+ """!Main GUI class.
+ @param workspace path to the workspace file
self.workspaceFile = workspace
# call parent class initializer
wx.App.__init__(self, False)
def OnInit(self):
- # initialize all available image handlers
+ """!Initialize all available image handlers
+ @return True
wx.InitAllImageHandlers()
# create splash screen
@@ -1501,7 +1505,7 @@
wx.SplashScreen (bitmap=introBmp, splashStyle=wx.SPLASH_CENTRE_ON_SCREEN | wx.SPLASH_TIMEOUT,
milliseconds=1500, parent=None, id=wx.ID_ANY)
wx.Yield()
# create and show main frame
mainframe = GMFrame(parent=None, id=wx.ID_ANY,
workspace = self.workspaceFile)
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2009-05-29 21:52:24 UTC (rev 37595)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2009-05-29 21:57:37 UTC (rev 37596)
@@ -593,6 +593,7 @@
<handler>self.OnMenuCmd</handler>
<command>g.access</command>
</menuitem>
+ <separator/>
<menuitem>
<label>Show settings</label>
<help>Outputs and modifies the user's current GRASS variable settings.</help>
@@ -611,6 +612,7 @@
<command>g.change.gui.py</command>
</menuitem>
+ <separator/>
<menuitem>
<label>Version</label>
<help>Displays version and copyright information.</help>
@@ -628,16 +630,7 @@
<command>g.proj</command>
</menuitem>
<menuitem>
- <label>Projection for current location</label>
- <help>Create/edit projection information for current location</help>
- <handler>self.OnXTerm</handler>
- <command>g.setproj</command>
- </menuitem>
- <separator/>
- <menuitem>
<label>Convert coordinates</label>
<help>Convert coordinates from one projection to another (cs2cs frontend).</help>
