[GRASS-SVN] r37607 -
grass/branches/releasebranch_6_4/gui/wxpython/support
svn_grass at osgeo.org
Sat May 30 06:26:31 EDT 2009
Author: martinl
Date: 2009-05-30 06:26:31 -0400 (Sat, 30 May 2009)
New Revision: 37607
Added:
grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py
Removed:
grass/branches/releasebranch_6_4/gui/wxpython/support/update_menu_desc.py
script synchronized with devbr6
Deleted: grass/branches/releasebranch_6_4/gui/wxpython/support/update_menu_desc.py
--- grass/branches/releasebranch_6_4/gui/wxpython/support/update_menu_desc.py 2009-05-30 10:18:02 UTC (rev 37606)
+++ grass/branches/releasebranch_6_4/gui/wxpython/support/update_menu_desc.py 2009-05-30 10:26:31 UTC (rev 37607)
@@ -1,103 +0,0 @@
- at brief Reads menu data from menudata.py and for each command updates
-its description (based on interface description).
-Updated menu data is printed to stdout.
-Support script for wxGUI.
-COPYRIGHT: (C) 2008 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
-Usage: python update_menu_desc.py
- at author Martin Landa <landa.martin gmail.com>
-import os
-import sys
-import xml.sax
-import xml.sax.handler
-HandlerBase=xml.sax.handler.ContentHandler
-from xml.sax import make_parser
-def read_menudata():
- menu = menudata.Data() # get menu data
- for mainItem in menu.GetMenu()[0]:
- print ' (_("%s"), (' % mainItem[0]
- for item1 in mainItem[1]:
- if len(item1[0]) == 0: # separator
- print ' ("","","", ""),'
- continue
- if len(item1) == 4:
- desc = get_description(item1[1:])
- print ' (_("%s"),' % item1[0]
- if desc and desc != item1[1]:
- print ' _("%s"),' % desc
- else:
- print ' _("%s"),' % item1[1]
- print ' "%s",' % item1[2]
- print ' "%s"),' % item1[3]
- else: # submenu
- print ' (_("%s"), (' % item1[0]
- for item2 in item1[1]:
- if len(item2[0]) == 0: # separator
- continue
- desc = get_description(item2[1:])
- print ' (_("%s"),' % item2[0]
- if desc and desc != item2[1]:
- else:
- print ' _("%s"),' % item2[1]
- print ' "%s",' % item2[2]
- print ' "%s"),' % item2[3]
- print ' )'
- print ' ),'
- print ' )'
- print ' ),'
-def get_description(item):
- """Return command desctiption based on interface
- description"""
- print
- desc, type, cmd = item
- if type in ("self.OnMenuCmd", "self.RunMenuCmd"):
- module = cmd.split(' ')[0]
- grass_task = menuform.grassTask()
- handler = menuform.processTask(grass_task)
- xml.sax.parseString(menuform.getInterfaceDescription(module), handler )
- return grass_task.description.replace('"', '\\"')
- return None
-def main(argv=None):
- if argv is None:
- argv = sys.argv
- if len(argv) != 1:
- print >> sys.stderr, __doc__
- return 0
- ### i18N
- import gettext
- gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
- read_menudata()
- return 0
-if __name__ == '__main__':
- if os.getenv("GISBASE") is None:
- print >> sys.stderr, "You must be in GRASS GIS to run this program."
- sys.exit(1)
- sys.path.append('../gui_modules')
- import menudata
- import menuform
- sys.exit(main())
Copied: grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py (from rev 37602, grass/branches/releasebranch_6_4/gui/wxpython/support/update_menu_desc.py)
--- grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py (rev 0)
+++ grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py 2009-05-30 10:26:31 UTC (rev 37607)
@@ -0,0 +1,111 @@
+ at brief Support script for wxGUI - only for developers needs. Updates
+menudata.xml file.
+Parse all GRASS modules in the search path ('bin' & 'script') and
+updates: - description (i.e. help)
+Prints warning for missing modules.
+(C) 2008-2009 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+Usage: python update_menudata.py
+ at author Martin Landa <landa.martin gmail.com>
+import os
+import sys
+try:
+ import xml.etree.ElementTree as etree
+except ImportError:
+ import elementtree.ElementTree as etree # Python <= 2.4
+def parseModules():
+ """!Parse modules' interface"""
+ modules = dict()
+ # list of modules to be ignored
+ ignore = [ 'mkftcap' ]
+ count = len(globalvar.grassCmd['all'])
+ i = 0
+ for module in globalvar.grassCmd['all']:
+ i += 1
+ if i % 10 == 0:
+ print ' %d/%d' % (i, count)
+ if module in ignore:
+ continue
+ try:
+ interface = menuform.GUI().ParseInterface(cmd = [module])
+ except IOError, e:
+ print >> sys.stderr, e
+ continue
+ modules[interface.name] = { 'label' : interface.label,
+ 'desc' : interface.description }
+ return modules
+def updateData(data, modules):
+ """!Update menu data tree"""
+ for node in data.tree.getiterator():
+ if node.tag != 'menuitem':
+ continue
+ item = dict()
+ for child in node.getchildren():
+ item[child.tag] = child.text
+ if not item.has_key('command'):
+ continue
+ module = item['command'].split(' ')[0]
+ if not modules.has_key(module):
+ print 'WARNING: \'%s\' not found in modules' % item['command']
+ continue
+ if modules[module]['label']:
+ desc = modules[module]['label']
+ else:
+ desc = modules[module]['desc']
+ node.find('help').text = desc
+def writeData(data):
+ """!Write updated menudata.xml"""
+ file = os.path.join('..', 'xml', 'menudata.xml')
+ data.tree.write(file)
+def main(argv = None):
+ if argv is None:
+ argv = sys.argv
+ if len(argv) != 1:
+ print >> sys.stderr, __doc__
+ return 1
+ print "Step 1: parse modules..."
+ modules = dict()
+ modules = parseModules()
+ print "Step 2: read menu data..."
+ data = menudata.Data()
+ print "Step 3: update menu data..."
+ updateData(data, modules)
+ print "Step 4: write menu data (menudata.xml)..."
+ writeData(data)
+ return 0
+if __name__ == '__main__':
+ if os.getenv("GISBASE") is None:
+ print >> sys.stderr, "You must be in GRASS GIS to run this program."
+ sys.exit(1)
+ sys.path.append('../gui_modules')
+ import menudata
+ import menuform
+ import globalvar
+ sys.exit(main())
Property changes on: grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py
___________________________________________________________________
+ text/x-python
+ Author Date Id
+ native
