[GRASS-SVN] r37618 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules support
svn_grass at osgeo.org
Sat May 30 11:23:32 EDT 2009
Author: martinl
Date: 2009-05-30 11:23:31 -0400 (Sat, 30 May 2009)
New Revision: 37618
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
grass/branches/develbranch_6/gui/wxpython/support/update_menudata.py
menuform: use ElementTree instead of xml.sax
(merge from trunk, r37617)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2009-05-30 15:12:08 UTC (rev 37617)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2009-05-30 15:23:31 UTC (rev 37618)
@@ -4,7 +4,6 @@
description.
Classes:
- - testSAXContentHandler
- grassTask
- processTask
- helpPanel
@@ -43,7 +42,6 @@
@todo
- verify option value types
- - use DOM instead of SAX (is it really necessary? ML)
import sys
@@ -73,11 +71,10 @@
from wx.lib.expando import ExpandoTextCtrl, EVT_ETC_LAYOUT_NEEDED
from wx.lib.newevent import NewEvent
-# Do the python 2.0 standard xml thing and map it on the old names
-import xml.sax
-import xml.sax.handler
-HandlerBase=xml.sax.handler.ContentHandler
-from xml.sax import make_parser
+try:
+ import xml.etree.ElementTree as etree
+except ImportError:
+ import elementtree.ElementTree as etree # Python <= 2.4
import utils
@@ -302,21 +299,6 @@
event = wxUpdateDialog(data = self.request.data)
wx.PostEvent(self.parent, event)
-class testSAXContentHandler(HandlerBase):
-# SAX compliant
- def characters(self, ch, start, length):
- pass
-def test_for_broken_SAX():
- ch=testSAXContentHandler()
- try:
- xml.sax.parseString("""<?xml version="1.0"?>
- <child1 name="paul">Text goes here</child1>
- """,ch)
- except TypeError:
- return 1
- return 0
class grassTask:
This class holds the structures needed for both filling by the parser and
@@ -333,8 +315,9 @@
self.flags = []
self.keywords = []
if grassModule is not None:
- xml.sax.parseString( getInterfaceDescription( grassModule ) , processTask( self ) )
+ processTask(tree = etree.fromstring(getInterfaceDescription(grassModule)),
+ task = self)
def get_list_params(self, element = 'name'):
"""!Get list of parameters"""
params = []
@@ -421,220 +404,106 @@
return cmd
-class processTask(HandlerBase):
- A SAX handler for the --interface-description output, as
- defined in grass-interface.dtd. Extend or modify this and the
+class processTask():
+ """!A ElementTree handler for the --interface-description output,
+ as defined in grass-interface.dtd. Extend or modify this and the
DTD if the XML output of GRASS' parser is extended or modified.
+ @param tree root tree node
+ @param task grassTask instance or None
+ @return grassTask instance
- def __init__(self, task_description):
- self.inLabelContent = False
- self.inDescriptionContent = False
- self.inDefaultContent = False
- self.inValueContent = False
- self.inParameter = False
- self.inFlag = False
- self.inGispromptContent = False
- self.inGuisection = False
- self.inKeywordsContent = False
- self.inKeyDesc = False
- self.addKeyDesc = False
- self.inFirstParameter = True
- self.task = task_description
+ def __init__(self, tree, task = None):
+ if task:
+ self.task = task
+ else:
+ self.task = grassTask()
+ self.root = tree
+ self.__processModule()
+ self.__processParams()
+ self.__processFlags()
- def startElement(self, name, attrs):
- if name == 'task':
- self.task.name = attrs.get('name', None)
- if name == 'parameter':
- self.inParameter = True
- self.label = '' # tmp variable
- self.param_label = ''
- self.param_description = ''
- self.param_default = ''
- self.param_values = []
- self.param_values_description = []
- self.param_gisprompt = False
- self.param_age = ''
- self.param_element = ''
- self.param_prompt = ''
- self.param_guisection = ''
- self.param_key_desc = []
- # Look for the parameter name, type, requiredness
- self.param_name = attrs.get('name', None)
- self.param_type = attrs.get('type', None)
- self.param_required = attrs.get('required', None)
- self.param_multiple = attrs.get('multiple', None)
- if name == 'flag':
- self.inFlag = True
- self.flag_label = ''
- self.flag_description = ''
- self.flag_default = ''
- self.flag_guisection = ''
- self.flag_values = []
- # Look for the flag name
- self.flag_name = attrs.get('name', None)
- if name == 'label':
- self.inLabelContent = True
- self.label = ''
- if name == 'description':
- self.inDescriptionContent = True
- self.description = ''
- if name == 'default':
- self.inDefaultContent = True
- if name == 'value':
- self.inValueContent = True
- self.value_tmp = ''
- if name == 'gisprompt':
- self.param_gisprompt = True
- self.param_age = attrs.get('age', None)
- self.param_element = attrs.get('element', None)
- self.param_prompt = attrs.get('prompt', None)
- if name == 'guisection':
- self.inGuisection = True
- self.guisection = ''
- if name == 'keywords':
- self.inKeywordsContent = True
- self.keyword = ''
- if name == 'keydesc':
- self.inKeyDesc = True
- self.key_desc = ''
+ def __processModule(self):
+ """!Process module description"""
+ self.task.name = self.root.get('name', default = 'unknown')
+ # keywords
+ for keyword in self.__getNodeText(self.root, 'keywords').split(','):
+ self.task.keywords.append(keyword.strip())
+ self.task.label = self.__getNodeText(self.root, 'label')
+ self.task.description = self.__getNodeText(self.root, 'description')
+ def __processParams(self):
+ """!Process parameters description"""
+ for p in self.root.findall('parameter'):
+ # gisprompt
+ node_gisprompt = p.find('gisprompt')
+ gisprompt = False
+ age = element = prompt = None
+ if node_gisprompt is not None:
+ gisprompt = True
+ age = node_gisprompt.get('age')
+ element = node_gisprompt.get('element')
+ prompt = node_gisprompt.get('prompt')
- if name == 'item':
- if self.inKeyDesc:
- self.addKeyDesc = True
- # works with python 2.0, but is not SAX compliant
- def characters(self, ch):
- self.my_characters(ch)
- def my_characters(self, ch):
- if self.inLabelContent:
- self.label = self.label + ch
- if self.inDescriptionContent:
- self.description = self.description + ch
- if self.inDefaultContent:
- self.param_default = self.param_default + ch
- if self.inValueContent and not self.inDescriptionContent:
- # Beware: value_tmp will get anything outside of a <description>
- # so in this snippet:
- # <values>
- # <value>
- # <name> a </name>
- # <description> a desc </description>
- # </value>
- # </values>
- # 'a desc' will not be recorded anwhere; this unburdens further
- # handling of value sets to distinguish between those that do define
- # descriptions and those that do not.
- # TODO: a set of flags to treat this case of a description sub-element
- self.value_tmp = self.value_tmp + ch
- if self.inGuisection:
- self.guisection = self.guisection + ch
- if self.inKeywordsContent:
- self.keyword = self.keyword + ch
- if self.addKeyDesc:
- self.key_desc = self.key_desc + ch
- def endElement(self, name):
- # If it's not a parameter element, ignore it
- self.inParameter = False;
- # description -> label substitution is delegated to the client;
- # we deal in the parser only with getting interface-description
- # verbatim
- self.task.params.append({
- "name" : self.param_name,
- "type" : self.param_type,
- "required" : self.param_required,
- "multiple" : self.param_multiple,
- "label" : self.param_label,
- "description" : self.param_description,
- 'gisprompt' : self.param_gisprompt,
- 'age' : self.param_age,
- 'element' :self.param_element,
- 'prompt' : self.param_prompt,
- "guisection" : self.param_guisection,
- "default" : self.param_default,
- "values" : self.param_values,
- "values_desc" : self.param_values_description,
- "value" : '',
- "key_desc": self.param_key_desc})
- if self.inFirstParameter:
- self.task.firstParam = self.param_name # store name of first parameter
- self.inFirstParameter = False;
- self.inFlag = False;
- self.task.flags.append({
- "name" : self.flag_name,
- "label" : self.flag_label,
- "description" : self.flag_description,
- "guisection" : self.flag_guisection } )
- if self.inParameter:
- self.param_label = normalize_whitespace(self.label)
- elif self.inFlag:
- self.flag_label = normalize_whitespace(self.label)
- else:
- self.task.label = normalize_whitespace(self.label)
- if self.inValueContent:
- self.param_values_description.append(normalize_whitespace(self.description))
- elif self.inParameter:
- self.param_description = normalize_whitespace(self.description)
- elif self.inFlag:
- self.flag_description = normalize_whitespace(self.description)
- else:
- self.task.description = normalize_whitespace(self.description)
- self.param_default = normalize_whitespace(self.param_default)
- v = normalize_whitespace(self.value_tmp)
- self.param_values.append(normalize_whitespace(self.value_tmp))
- self.param_guisection = normalize_whitespace(self.guisection)
- elif self.inFlag:
- self.flag_guisection = normalize_whitespace(self.guisection)
- for keyword in self.keyword.split(','):
- self.task.keywords.append (normalize_whitespace(keyword))
- self.param_key_desc.append(normalize_whitespace(self.key_desc))
+ # value(s)
+ values = []
+ values_desc = []
+ for pv in p.findall('value'):
+ values.append(pv.text)
+ pvd = pv.find('description')
+ if pvd:
+ values_desc.append(pvd.text)
+ # keydesc
+ key_desc = []
+ node_key_desc = p.find('keydesc')
+ if node_key_desc:
+ for ki in node_key_desc.findall('item'):
+ key_desc.append(ki.text)
+ self.task.params.append( {
+ "name" : p.get('name'),
+ "type" : p.get('type'),
+ "required" : p.get('required'),
+ "multiple" : p.get('multiple'),
+ "label" : self.__getNodeText(p, 'label'),
+ "description" : self.__getNodeText(p, 'description'),
+ 'gisprompt' : gisprompt,
+ 'age' : age,
+ 'element' : element,
+ 'prompt' : prompt,
+ "guisection" : self.__getNodeText(p, 'guisection'),
+ "default" : self.__getNodeText(p, 'default'),
+ "values" : values,
+ "values_desc" : values_desc,
+ "value" : '',
+ "key_desc" : key_desc } )
+ def __processFlags(self):
+ """!Process flags description"""
+ for p in self.root.findall('flag'):
+ self.task.flags.append( {
+ "guisection" : self.__getNodeText(p, 'guisection') } )
+ def __getNodeText(self, node, tag, default = ''):
+ """!Get node text"""
+ p = node.find(tag)
+ if p is not None:
+ return normalize_whitespace(p.text)
+ return default
+ def GetTask(self):
+ """!Get grassTask intance"""
+ return self.task
class helpPanel(wx.html.HtmlWindow):
This panel holds the text from GRASS docs.
@@ -1802,17 +1671,13 @@
@param cmd command to be parsed (given as list)
- grass_task = grassTask()
- handler = parser(grass_task)
enc = locale.getdefaultlocale()[1]
if enc and enc.lower() not in ("utf8", "utf-8"):
- xml.sax.parseString(getInterfaceDescription(cmd[0]).decode(enc).encode("utf-8"),
- handler)
+ tree = etree.fromstring(getInterfaceDescription(cmd[0]).decode(enc).encode("utf-8"))
else:
- xml.sax.parseString(getInterfaceDescription(cmd[0]),
- handler)
- return grass_task
+ tree = etree.fromstring(getInterfaceDescription(cmd[0]))
+ return processTask(tree).GetTask()
def ParseCommand(self, cmd, gmpath=None, completed=None, parentframe=None,
show=True, modal=False):
@@ -1909,10 +1774,9 @@
# parse the interface decription
if not self.grass_task:
- self.grass_task = grassTask()
- handler = processTask(self.grass_task)
- xml.sax.parseString(getInterfaceDescription(cmd), handler)
+ tree = etree.fromstring(getInterfaceDescription(cmd))
+ self.grass_task = processTask(tree).GetTask()
for p in self.grass_task.params:
if p.get('name', '') in ('input', 'map'):
age = p.get('age', '')
Modified: grass/branches/develbranch_6/gui/wxpython/support/update_menudata.py
--- grass/branches/develbranch_6/gui/wxpython/support/update_menudata.py 2009-05-30 15:12:08 UTC (rev 37617)
+++ grass/branches/develbranch_6/gui/wxpython/support/update_menudata.py 2009-05-30 15:23:31 UTC (rev 37618)
@@ -24,25 +24,31 @@
except ImportError:
+from grass.script import core as grass
def parseModules():
"""!Parse modules' interface"""
modules = dict()
# list of modules to be ignored
- ignore = [ 'mkftcap' ]
+ ignore = [ 'mkftcap',
+ 'g.parser',
+ 'r.mapcalc',
+ 'r3.mapcalc',
+ 'vcolors' ]
count = len(globalvar.grassCmd['all'])
i = 0
for module in globalvar.grassCmd['all']:
i += 1
if i % 10 == 0:
- print ' %d/%d' % (i, count)
+ grass.info('* %d/%d' % (i, count))
if module in ignore:
continue
try:
interface = menuform.GUI().ParseInterface(cmd = [module])
except IOError, e:
- print >> sys.stderr, e
+ grass.error(e)
continue
modules[interface.name] = { 'label' : interface.label,
'desc' : interface.description,
@@ -65,7 +71,7 @@
module = item['command'].split(' ')[0]
if not modules.has_key(module):
- print 'WARNING: \'%s\' not found in modules' % item['command']
+ grass.warning("'%s' not found in modules" % item['command'])
continue
if modules[module]['label']:
@@ -73,7 +79,10 @@
else:
desc = modules[module]['desc']
node.find('help').text = desc
- node.find('keywords').text = ','.join(modules[module]['keywords'])
+ if node.find('keywords') is not None:
+ node.find('keywords').text = ','.join(modules[module]['keywords'])
+ else:
+ grass.warning('%s: keywords missing' % module)
def writeData(data):
"""!Write updated menudata.xml"""
@@ -88,14 +97,14 @@
print >> sys.stderr, __doc__
return 1
- print "Step 1: parse modules..."
+ grass.info("Step 1: parsing modules...")
modules = dict()
modules = parseModules()
- print "Step 2: read menu data..."
+ grass.info("Step 2: reading menu data...")
data = menudata.Data()
- print "Step 3: update menu data..."
+ grass.info("Step 3: updating menu data...")
updateData(data, modules)
- print "Step 4: write menu data (menudata.xml)..."
+ grass.info("Step 4: writing menu data (menudata.xml)...")
writeData(data)
return 0
