[GRASS-SVN] r39722 - grass/trunk/raster/r.watershed/ram
svn_grass at osgeo.org
Sat Nov 14 06:07:46 EST 2009
Author: mmetz
Date: 2009-11-14 06:07:45 -0500 (Sat, 14 Nov 2009)
New Revision: 39722
grass/trunk/raster/r.watershed/ram/do_astar.c
fix for ticket #807
Modified: grass/trunk/raster/r.watershed/ram/do_astar.c
--- grass/trunk/raster/r.watershed/ram/do_astar.c 2009-11-13 19:06:29 UTC (rev 39721)
+++ grass/trunk/raster/r.watershed/ram/do_astar.c 2009-11-14 11:07:45 UTC (rev 39722)
@@ -3,17 +3,42 @@
#include <grass/gis.h>
#include <grass/glocale.h>
+double get_slope2(CELL, CELL, double);
int do_astar(void)
int count;
SHORT upr, upc, r, c, ct_dir;
- CELL alt_val, alt_up, asp_up, wat_val;
- CELL in_val, drain_val;
+ CELL alt_val, alt_nbr[8];
+ CELL is_in_list, is_worked;
int index_doer, index_up;
+ /* sides
+ * |7|1|4|
+ * |2| |3|
+ * |5|0|6|
+ int nbr_ew[8] = { 0, 1, 2, 3, 1, 0, 0, 1 };
+ int nbr_ns[8] = { 0, 1, 2, 3, 3, 2, 3, 2 };
+ double dx, dy, dist_to_nbr[8], ew_res, ns_res;
+ double slope[8];
G_message(_("SECTION 2: A * Search."));
+ for (ct_dir = 0; ct_dir < sides; ct_dir++) {
+ /* get r, c (r_nbr, c_nbr) for neighbours */
+ upr = nextdr[ct_dir];
+ upc = nextdc[ct_dir];
+ /* account for rare cases when ns_res != ew_res */
+ dy = ABS(upr) * window.ns_res;
+ dx = ABS(upc) * window.ew_res;
+ if (ct_dir < 4)
+ dist_to_nbr[ct_dir] = dx + dy;
+ else
+ dist_to_nbr[ct_dir] = sqrt(dx * dx + dy * dy);
+ ew_res = window.ew_res;
+ ns_res = window.ns_res;
count = 0;
first_astar = heap_index[1];
first_cum = do_points;
@@ -45,37 +70,56 @@
/* get r, c (upr, upc) for this neighbour */
upr = r + nextdr[ct_dir];
upc = c + nextdc[ct_dir];
- index_up = SEG_INDEX(alt_seg, upr, upc);
+ slope[ct_dir] = alt_nbr[ct_dir] = 0;
/* check that r, c are within region */
if (upr >= 0 && upr < nrows && upc >= 0 && upc < ncols) {
- /* check if neighbour is in the list */
- /* if not, add as new point */
- in_val = FLAG_GET(in_list, upr, upc);
- if (in_val == 0) {
- alt_up = alt[index_up];
- /* flow direction is set here */
- add_pt(upr, upc, alt_up, alt_val);
- drain_val = drain[upr - r + 1][upc - c + 1];
- asp[index_up] = drain_val;
+ index_up = SEG_INDEX(alt_seg, upr, upc);
+ is_in_list = FLAG_GET(in_list, upr, upc);
+ is_worked = FLAG_GET(worked, upr, upc);
+ /* avoid diagonal flow direction bias */
+ if (!is_worked) {
+ alt_nbr[ct_dir] = alt[index_up];
+ slope[ct_dir] =
+ get_slope2(alt_val, alt_nbr[ct_dir],
+ dist_to_nbr[ct_dir]);
+ if (ct_dir > 3) {
+ if (slope[nbr_ew[ct_dir]]) {
+ /* slope to ew nbr > slope to center */
+ if (slope[ct_dir] <
+ get_slope2(alt_nbr[nbr_ew[ct_dir]],
+ alt_nbr[ct_dir], ew_res))
+ is_in_list = 1;
+ if (!is_in_list && slope[nbr_ns[ct_dir]]) {
+ /* slope to ns nbr > slope to center */
+ get_slope2(alt_nbr[nbr_ns[ct_dir]],
+ alt_nbr[ct_dir], ns_res))
+ is_in_list = 1;
+ /* add neighbour as new point if not in the list */
+ if (is_in_list == 0) {
+ add_pt(upr, upc, alt_nbr[ct_dir], alt_val);
+ /* set flow direction */
+ asp[index_up] = drain[upr - r + 1][upc - c + 1];
else {
- in_val = FLAG_GET(worked, upr, upc);
- /* neighbour is edge in list, not yet worked */
- asp_up = asp[index_up];
- if (asp_up < 0) {
+ if (is_worked == 0) {
+ /* neighbour is edge in list, not yet worked */
+ if (asp[index_up] < 0) {
- wat_val = wat[index_doer];
- if (wat_val > 0)
- wat[index_doer] = -wat_val;
+ if (wat[index_doer] > 0)
+ wat[index_doer] = -wat[index_doer];
+ } /* end if in region */
+ } /* end sides */
- /* this was a lot of indentation, improve code aesthetics? */
G_percent(count, do_points, 1); /* finish it */
if (mfd == 0)
flag_destroy(worked);
@@ -102,22 +146,18 @@
/* new add point routine for min heap */
int add_pt(SHORT r, SHORT c, CELL ele, CELL downe)
FLAG_SET(in_list, r, c);
/* add point to next free position */
heap_size++;
if (heap_size > do_points)
G_fatal_error(_("heapsize too large"));
heap_index[heap_size] = nxt_avail_pt++;
astar_pts[heap_size] = SEG_INDEX(alt_seg, r, c);
/* sift up: move new point towards top of heap */
sift_up(heap_size, ele);
return 0;
@@ -246,8 +286,15 @@
return (slope);
+double get_slope2(CELL ele, CELL up_ele, double dist)
+ if (ele == up_ele)
+ return 0.5 / dist;
+ else
+ return (double)(up_ele - ele) / dist;
-/* new replace */
+/* replace is unused */
int replace( /* ele was in there */
SHORT upr, SHORT upc, SHORT r, SHORT c)
/* CELL ele; */
@@ -265,7 +312,7 @@
/* if (astar_pts[now].r == upr && astar_pts[now].c == upc) { */
seg_index_rc(alt_seg, astar_pts[now], &r2, &c2);
if (r2 == upr && c2 == upc) {
- /*astar_pts[now].downr = r;
+ /* astar_pts[now].downr = r;
astar_pts[now].downc = c; */
return 0;
