[GRASS-SVN] r39777 - grass/trunk/vector/v.in.dxf
svn_grass at osgeo.org
Sat Nov 21 04:09:28 EST 2009
Author: hcho
Date: 2009-11-21 04:09:27 -0500 (Sat, 21 Nov 2009)
New Revision: 39777
grass/trunk/vector/v.in.dxf/add_polyline.c
Imports triangular mesh faces.
Modified: grass/trunk/vector/v.in.dxf/add_polyline.c
--- grass/trunk/vector/v.in.dxf/add_polyline.c 2009-11-21 08:13:00 UTC (rev 39776)
+++ grass/trunk/vector/v.in.dxf/add_polyline.c 2009-11-21 09:09:27 UTC (rev 39777)
@@ -43,7 +43,7 @@
switch (code) {
case 66: /* vertices follow flag */
vert_flag = atoi(dxf_buf);
- if (vert_flag != 1) /* flag must always be 1 */
+ if (vert_flag != 1) /* flag must be always 1 */
if (warn_flag66) {
G_warning(_("vertices following flag missing"));
warn_flag66 = 0;
@@ -151,7 +151,7 @@
8 = Spline vertex created by spline-fitting
16 = Spline frame control point
32 = 3D polyline vertex
- 64 = 3D polygon mesh
+ 64 = 3D polygon mesh vertex
128 = Polyface mesh vertex
if (vertex_flag == 16) {
@@ -168,6 +168,7 @@
case 74:
if (!((vertex_flag & 128) && !(vertex_flag & 64)))
break;
if (!polyface_mesh_started) {
/* save vertex coordinates to mesh_?pnts */
mesh_xpnts =
@@ -180,11 +181,6 @@
memcpy(mesh_ypnts, ypnts, arr_size * sizeof(double));
memcpy(mesh_zpnts, zpnts, arr_size * sizeof(double));
- * if (flag_frame)
- * write_pnts(Map, layer, polyline_flag, zflag,
- * arr_size);
polyface_mesh_started = 1;
arr_size = 0;
mesh_pnts = 0;
@@ -195,43 +191,38 @@
ypnts[arr_size] = mesh_ypnts[vertex_idx - 1];
zpnts[arr_size] = mesh_zpnts[vertex_idx - 1];
arr_size++;
+ mesh_pnts++;
- if (++mesh_pnts == 4 || vertex_idx == 0) {
- /* check if there are any vertices when vertex_idx is 0
- if (arr_size > 0) {
- /* close a mesh */
- xpnts[arr_size] = xpnts[0];
- ypnts[arr_size] = ypnts[0];
- zpnts[arr_size] = zpnts[0];
- arr_size++;
- if (flag_frame)
- write_vect(Map, layer, "POLYFACE FRAME",
- handle, "", arr_size, GV_LINE);
- else
- write_vect(Map, layer, "POLYFACE", handle, "",
- arr_size, GV_FACE);
- arr_size = 0;
- mesh_pnts = 0;
break;
- if (polyface_mesh_started) {
- /* discard a premature mesh */
- arr_size = 0;
- mesh_pnts = 0;
- continue;
+ if (polyface_mesh_started) {
+ if (mesh_pnts > 0) {
+ /* close a mesh */
+ xpnts[arr_size] = xpnts[0];
+ ypnts[arr_size] = ypnts[0];
+ zpnts[arr_size] = zpnts[0];
+ arr_size++;
+ if (flag_frame)
+ write_vect(Map, layer, "POLYFACE FRAME", handle, "",
+ arr_size, GV_LINE);
+ else
+ write_vect(Map, layer, "POLYFACE", handle, "",
+ arr_size, GV_FACE);
+ arr_size = 0;
+ mesh_pnts = 0;
+ continue;
- if (xflag && yflag) {
- arr_size = make_arc_from_polyline(arr_size, bulge, prev_bulge);
- prev_bulge = bulge;
- bulge = 0.0;
- } /* processing polyline vertex */
+ if (xflag && yflag) {
+ arr_size =
+ make_arc_from_polyline(arr_size, bulge, prev_bulge);
+ prev_bulge = bulge;
+ bulge = 0.0;
+ } /* processing polyline vertex */
} /* vertex loop */
