[GRASS-SVN] r39797 - grass-addons/raster/r.stream.order
svn_grass at osgeo.org
Wed Nov 25 06:50:17 EST 2009
Author: jarekj71
Date: 2009-11-25 06:50:16 -0500 (Wed, 25 Nov 2009)
New Revision: 39797
grass-addons/raster/r.stream.order/main.c
grass-addons/raster/r.stream.order/order.c
removing bug from hack and horton ordering
Modified: grass-addons/raster/r.stream.order/main.c
--- grass-addons/raster/r.stream.order/main.c 2009-11-24 23:11:36 UTC (rev 39796)
+++ grass-addons/raster/r.stream.order/main.c 2009-11-25 11:50:16 UTC (rev 39797)
@@ -27,7 +27,7 @@
struct GModule *module; /* GRASS module for parsing arguments */
struct Option *in_dir_opt, *in_stm_opt, *in_acc_opt, *out_str_opt, *out_shr_opt, *out_hck_opt, *out_hrt_opt; /* options */
struct Flag *out_back; /* flags */
- int stream_num;
+ int stream_num, i;
/* initialize GIS environment */
G_gisinit(argv[0]); /* reads grass env, stores program name to G_program_name() */
@@ -161,6 +161,8 @@
find_nodes(stream_num);
if ((out_hack || out_horton) && !in_accum)
do_cum_length();
if (out_strahler || out_horton)
strahler();
if (out_shreeve)
Modified: grass-addons/raster/r.stream.order/order.c
--- grass-addons/raster/r.stream.order/order.c 2009-11-24 23:11:36 UTC (rev 39796)
+++ grass-addons/raster/r.stream.order/order.c 2009-11-25 11:50:16 UTC (rev 39797)
@@ -40,7 +40,6 @@
s_streams[i].hack = -1;
s_streams[i].horton = -1;
s_streams[i].accum = 0.;
- /* s_streams[i].length = 0.0; */
s_streams[i].trib[0] = 0;
s_streams[i].trib[1] = 0;
s_streams[i].trib[2] = 0;
@@ -142,19 +141,20 @@
int do_cum_length (void) {
int nextr[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
int nextc[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
- int i, s, d; /* s - streams index, d - direction */
+ int i, s, d; /* s - streams index; d - direction */
int done = 1;
int r, c;
int next_r, next_c;
- int cur_stream, next_stream;
+ int cur_stream;
float cur_northing, cur_easting;
float next_northing, next_easting;
double cur_length=0.;
+ double cur_accum=0.;
+ G_message(_("Finding longests streams..."));
G_begin_distance_calculations();
for (s=0; s<springs_num; ++s) { /* main loop on springs */
@@ -164,24 +164,27 @@
cur_length=0;
done=1;
- while(streams && done) {
+ while(done) {
cur_northing = window.north - (r + .5) * window.ns_res;
cur_easting = window.west + (c + .5) * window.ew_res;
- d=dirs[r][c];
- if (d<1 || /* end of route: sink, border or something else */
- r + nextr[d] < 0 || r + nextr[d] > (nrows - 1) ||
- c + nextc[d] < 0 || c + nextc[d] > (ncols - 1)) {
- next_northing = window.north - (r + .5) * window.ns_res;
- next_easting = window.west + (c + .5) * window.ew_res;
- cur_length=G_distance(next_easting, next_northing, cur_easting, cur_northing);
- s_streams[cur_stream].accum += cur_length;
- break;
- next_r=r+nextr[dirs[r][c]];
- next_c=c+nextc[dirs[r][c]];
+ d=dirs[r][c];
+ next_r=r+nextr[d];
+ next_c=c+nextc[d];
+ if (d<1|| /* end of route: sink */
+ r + nextr[d] < 0 || r + nextr[d] > (nrows - 1) || /*border*/
+ c + nextc[d] < 0 || c + nextc[d] > (ncols - 1) ||
+ streams[next_r][next_c]<1) { /* mask */
+ next_northing = window.north - (r + .5) * window.ns_res;
+ next_easting = window.west + (c + .5) * window.ew_res;
+ cur_length=G_distance(next_easting, next_northing, cur_easting, cur_northing);
+ s_streams[cur_stream].accum += cur_length;
+ break;
next_northing = window.north - (next_r + .5) * window.ns_res;
next_easting = window.west + (next_c + .5) * window.ew_res;
cur_length = G_distance(next_easting, next_northing, cur_easting, cur_northing);
@@ -189,25 +192,23 @@
r=next_r;
c=next_c;
- if (streams[next_r][next_c] != cur_stream) {
- next_stream=streams[next_r][next_c];
- if (s_streams[next_stream].accum<s_streams[cur_stream].accum)
- s_streams[next_stream].accum=s_streams[cur_stream].accum;
+ if (streams[next_r][next_c] != cur_stream) {
+ cur_stream=streams[next_r][next_c];
+ cur_accum=0;
- for (i=0; i<s_streams[next_stream].trib_num;++i){
- if (s_streams[s_streams[next_stream].trib[i]].accum==0)
- done=0;
- cur_stream=next_stream;
- }/* end if */
+ for (i = 0; i < s_streams[cur_stream].trib_num; ++i) {
+ if (s_streams[s_streams[cur_stream].trib[i]].accum == 0) {
+ done=0;
+ cur_accum=0;
+ break; /* do not pass accum*/
+ if(s_streams[s_streams[cur_stream].trib[i]].accum>cur_accum)
+ cur_accum=s_streams[s_streams[cur_stream].trib[i]].accum;
+ } /* end for i */
+ s_streams[cur_stream].accum=cur_accum;
+ }/* end if */
} /* end while */
- } /* end for */
-/* for (i=1;i<stream_num+1;++i) {
- G_message(_("%d: %f"),i,s_streams[i].length);
+ } /* end for s*/
return 0;
