[GRASS-SVN] r39809 - in grass/trunk: lib/vector/Vlib vector/v.buffer
Thu Nov 26 15:05:21 EST 2009
Author: martinl
Date: 2009-11-26 15:05:21 -0500 (Thu, 26 Nov 2009)
New Revision: 39809
   grass/trunk/lib/vector/Vlib/snap.c
   grass/trunk/vector/v.buffer/main.c
v.buffer: OGR support (read access)
	  be less verbose by default
Modified: grass/trunk/lib/vector/Vlib/snap.c
--- grass/trunk/lib/vector/Vlib/snap.c	2009-11-26 18:52:10 UTC (rev 39808)
+++ grass/trunk/lib/vector/Vlib/snap.c	2009-11-26 20:05:21 UTC (rev 39809)
@@ -148,8 +148,7 @@
     point = 1;			/* index starts from 1 ! */
     nvertices = 0;
-    G_verbose_message(_("Snap vertices Pass 1: select points"));
+    G_message(_("Snap vertices (pass 1: select points)..."));
     for (line_idx = 0; line_idx < List_lines->n_values; line_idx++) {
 	int v;
@@ -192,7 +191,7 @@
      * points within threshold.
      * Update anchor for marked points if new anchor is closer. */
-    G_verbose_message(_("Snap vertices Pass 2: assign anchor vertices"));
+    G_message(_("Snap vertices (pass 2: assign anchor vertices)..."));
     nanchors = ntosnap = 0;
     rbtree_init_trav(&RBTrav1, RBTree);
@@ -273,7 +272,7 @@
     nsnapped = ncreated = 0;
-    G_verbose_message(_("Snap vertices Pass 3: snap to assigned points"));
+    G_message(_("Snap vertices (pass 3: snap to assigned points)..."));
 	int v;
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c	2009-11-26 18:52:10 UTC (rev 39808)
+++ grass/trunk/vector/v.buffer/main.c	2009-11-26 20:05:21 UTC (rev 39809)
@@ -5,19 +5,20 @@
  * AUTHOR(S):    Radim Blazek
  *               Upgraded by Rosen Matev (Google Summer of Code 2008)
+ *               OGR support by Martin Landa <landa.martin gmail.com> (2009)
  * PURPOSE:      Vector buffer
- * COPYRIGHT:    (C) 2001-2008 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2001-2009 by the GRASS Development Team
- *               This program is free software under the
- *               GNU General Public License (>=v2).
- *               Read the file COPYING that comes with GRASS
- *               for details.
+ *               This program is free software under the GNU General
+ *               Public License (>=v2). Read the file COPYING that
+ *               comes with GRASS for details.
 #include <stdlib.h>
 #include <string.h>
 #include <grass/gis.h>
 #include <grass/vector.h>
 #include <grass/dbmi.h>
@@ -118,13 +119,13 @@
     struct Map_info In, Out;
     struct line_pnts *Points;
     struct line_cats *Cats, *BCats;
-    const char *mapset;
     struct GModule *module;
     struct Option *in_opt, *out_opt, *type_opt, *dista_opt, *distb_opt,
 	*angle_opt;
     struct Flag *straight_flag, *nocaps_flag;
     struct Option *tol_opt, *bufcol_opt, *scale_opt, *field_opt;
+    int verbose;
     double da, db, dalpha, tolerance, unit_tolerance;
     int type;
     int i, j, ret, nareas, area, nlines, line;
@@ -143,9 +144,10 @@
     module = G_define_module();
     G_add_keyword(_("vector"));
+    G_add_keyword(_("geometry"));
     G_add_keyword(_("buffer"));
     module->description =
-	_("Creates a buffer around features of given type (areas must contain centroid).");
+	_("Creates a buffer around vector features of given type.");
     in_opt = G_define_standard_option(G_OPT_V_INPUT);
     out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -219,7 +221,6 @@
 	exit(EXIT_FAILURE);
     type = Vect_option_to_types(type_opt);
-    field = atoi(field_opt->answer);
     if ((dista_opt->answer && bufcol_opt->answer) ||
 	(!(dista_opt->answer || bufcol_opt->answer)))
@@ -265,15 +266,13 @@
     Cats = Vect_new_cats_struct();
     BCats = Vect_new_cats_struct();
-    /* open input vector */
-    if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL)
-	G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
+    Vect_set_open_level(2); /* topology required */
-    Vect_set_open_level(2);
-    if (1 > Vect_open_old(&In, in_opt->answer, mapset))
+    if (1 > Vect_open_old2(&In, in_opt->answer, "", field_opt->answer))
 	G_fatal_error(_("Unable to open vector map <%s>"), in_opt->answer);
+    field = Vect_get_field_number(&In, field_opt->answer);
     if (0 > Vect_open_new(&Out, out_opt->answer, WITHOUT_Z)) {
 	Vect_close(&In);
 	G_fatal_error(_("Unable to create vector map <%s>"), out_opt->answer);
@@ -340,7 +339,7 @@
 	int ltype;
 	if (nlines > 0)
-	    G_message(_("Buffering lines..."));
+	    G_message(_("Buffering features..."));
 	for (line = 1; line <= nlines; line++) {
 	    int cat;
@@ -458,21 +457,28 @@
     /* write all buffer contours */
+    G_message(_("Writting buffers..."));
     for (i = 0; i < buffers_count; i++) {
+	G_percent(i, buffers_count, 2);
 	Vect_write_line(&Out, GV_BOUNDARY, arr_bc[i].oPoints, BCats);
 	for (j = 0; j < arr_bc[i].inner_count; j++)
 	    Vect_write_line(&Out, GV_BOUNDARY, arr_bc[i].iPoints[j], BCats);
-    /* Create areas */
+    G_percent(1, 1, 1);
+    verbose = G_verbose();
+    if (verbose < G_verbose_max()) {
+	G_message(_("Cleaning buffers..."));
+	G_set_verbose(0);
     /* Break lines */
-    G_verbose_message(_("Building parts of topology..."));
+    G_message(_("Building parts of topology..."));
     Vect_build_partial(&Out, GV_BUILD_BASE);
     G_message(_("Snapping boundaries..."));
     Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL);
     G_message(_("Breaking boundaries..."));
     Vect_break_lines(&Out, GV_BOUNDARY, NULL);
@@ -600,6 +606,7 @@
     G_message(_("Attaching centroids..."));
     Vect_build_partial(&Out, GV_BUILD_CENTROIDS);
+    G_set_verbose(verbose);
     stop(&In, &Out);
     exit(EXIT_SUCCESS);
