[GRASS-SVN] r39830 - grass/trunk/vector/v.hull
svn_grass at osgeo.org
Fri Nov 27 12:54:32 EST 2009
Author: martinl
Date: 2009-11-27 12:54:31 -0500 (Fri, 27 Nov 2009)
New Revision: 39830
grass/trunk/vector/v.hull/main.c
v.hull: topo not needed
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c 2009-11-27 17:51:50 UTC (rev 39829)
+++ grass/trunk/vector/v.hull/main.c 2009-11-27 17:54:31 UTC (rev 39830)
@@ -76,6 +76,7 @@
Vect_check_input_output_name(input->answer, output->answer,
GV_FATAL_EXIT);
+ Vect_set_open_level(1);
if (Vect_open_old2(&Map, sitefile, "", field->answer) < 0)
G_fatal_error(_("Unable to open vector map <%s>"), sitefile);
